[GRASS-SVN] r57632 - grass/branches/releasebranch_6_4/gui/wxpython/nviz
Tue Sep 10 19:25:56 PDT 2013
Author: annakrat
Date: 2013-09-10 19:25:55 -0700 (Tue, 10 Sep 2013)
New Revision: 57632
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/wxnviz.py
wxNviz: fix displaying 3d points on surface and with z coordinate (merge from trunk, r57631)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2013-09-11 02:00:41 UTC (rev 57631)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/mapwindow.py	2013-09-11 02:25:55 UTC (rev 57632)
@@ -1305,8 +1305,10 @@
                     if (vInfo['points']) > 0:
                         # include vInfo['centroids'] to initially load centroids
                         self.LoadVector(item, points = True)
-                    if (vInfo['lines'] + vInfo['boundaries']) > 0 or vInfo['map3d']:
+                    if (vInfo['lines'] + vInfo['boundaries']) > 0:
                         self.LoadVector(item, points = False)
+                    if vInfo['map3d'] and (vInfo['kernels'] + vInfo['faces']) > 0:
+                        self.LoadVector(item, points=None)
             except GException, e:
                 GError(parent = self,
@@ -2109,17 +2111,21 @@
             data['height'].pop('update')
         # surface
-        if 'update' in data['mode'] and 'surface' in data['mode']:
-            for item in range(len(data['mode']['surface']['value'])):
-                for type in ('raster', 'constant'):
-                    sid = self.GetLayerId(type = type,
-                                          name = data['mode']['surface']['value'][item])
-                    if sid > -1:
-                        if data['mode']['surface']['show'][item]:
-                            self._display.SetVectorPointSurface(id, sid)
-                        else:
-                            self._display.UnsetVectorPointSurface(id, sid)
-                        break
+        if 'update' in data['mode']:
+            if data['mode'].get('3d', False):
+                self._display.SetVectorPointZMode(id, True)
+            elif 'surface' in data['mode']:
+                self._display.SetVectorPointZMode(id, False)
+                for item in range(len(data['mode']['surface']['value'])):
+                    for type in ('raster', 'constant'):
+                        sid = self.GetLayerId(type=type,
+                                              name=data['mode']['surface']['value'][item])
+                        if sid > -1:
+                            if data['mode']['surface']['show'][item]:
+                                self._display.SetVectorPointSurface(id, sid)
+                            else:
+                                self._display.UnsetVectorPointSurface(id, sid)
+                            break
             data['mode'].pop('update')
     def GetLayerNames(self, type):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py	2013-09-11 02:00:41 UTC (rev 57631)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/tools.py	2013-09-11 02:25:55 UTC (rev 57632)
@@ -1253,7 +1253,7 @@
                              choices = [_("on surface(s):"),
                                         _("flat")])
         self.win['vector']['lines']['flat'] = display.GetId()
-        display.Bind(wx.EVT_CHOICE, self.OnVectorDisplay)
+        display.Bind(wx.EVT_CHOICE, self.OnVectorLinesMode)
         gridSizer.Add(item = display, flag = wx.ALIGN_CENTER_VERTICAL |
                       wx.ALIGN_LEFT|wx.EXPAND, pos = (1, 1), span = (1,4))
@@ -1382,20 +1382,24 @@
         vertSizer.Add(gridSizer, proportion = 0, flag = wx.EXPAND, border = 0)
         # high
         gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
-        gridSizer.AddGrowableCol(1)
+        gridSizer.Add(item=wx.StaticText(parent=panel, label=_("Display")),
+                      pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
+        display = wx.Choice(parent=panel)
+        self.win['vector']['points']['3d'] = display.GetId()
+        display.Bind(wx.EVT_CHOICE, self.OnVectorPointsMode)
+        gridSizer.Add(item=display,
+                      pos=(0, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
         gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
-                                         label = _("Display on surface(s):")),
-                      pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
-        gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
                                          label = _("Height above surface:")),
-                      pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL)
+                      pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL)
         surface = wx.CheckListBox(parent = panel, id = wx.ID_ANY, size = (-1, 60),
                                   choices = [], style = wx.LB_NEEDED_SB)
         surface.Bind(wx.EVT_CHECKLISTBOX, self.OnVectorSurface)
         self.win['vector']['points']['surface'] = surface.GetId()
         gridSizer.Add(item = surface,
-                      pos = (1, 0), span = (3, 1),
+                      pos = (1, 0), span = (3, 2),
                       flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND)
         self._createControl(panel, data = self.win['vector']['points'], name = 'height', size = -1,
@@ -1406,10 +1410,11 @@
         self.FindWindowById(self.win['vector']['points']['height']['text']).SetValue(0)
         gridSizer.Add(item = self.FindWindowById(self.win['vector']['points']['height']['slider']),
-                      pos = (2, 1),flag = wx.EXPAND|wx.ALIGN_CENTER_VERTICAL)
+                      pos = (2, 2),flag = wx.EXPAND|wx.ALIGN_CENTER_VERTICAL)
         gridSizer.Add(item = self.FindWindowById(self.win['vector']['points']['height']['text']),
-                      pos = (3, 1),
+                      pos = (3, 2),
                       flag = wx.ALIGN_CENTER)
+        gridSizer.AddGrowableCol(2)
         boxSizer.Add(item = vertSizer, proportion = 1,
@@ -3296,7 +3301,7 @@
         event.Skip()
-    def OnVectorDisplay(self, event):
+    def OnVectorLinesMode(self, event):
         """!Display vector lines on surface/flat"""
         rasters = self.mapWindow.GetLayerNames('raster')
         if event.GetSelection() == 0: # surface
@@ -3359,7 +3364,32 @@
         if self.mapDisplay.IsAutoRendered():
             self.mapWindow.Refresh(False)
+    def OnVectorPointsMode(self, event):
+        rasters = self.mapWindow.GetLayerNames('raster')
+        if event.GetSelection() == 0: # surface
+            if len(rasters) < 1:
+                self.FindWindowById(self.win['vector']['points']['surface']).Enable(False)
+                self.FindWindowById(self.win['vector']['points']['flat']).SetSelection(1)
+                return
+            self.FindWindowById(self.win['vector']['points']['surface']).Enable(True)
+            # set first found surface
+            data = self.GetLayerData('vector')
+            data['vector']['points']['mode']['surface']['value'] = rasters
+            data['vector']['points']['mode']['3d'] = False
+            self.FindWindowById(self.win['vector']['points']['surface']).SetStringSelection( \
+                rasters[0])
+        else: # use z coordinate if 3d
+            data['vector']['points']['mode']['3d'] = True
+        data['vector']['points']['mode']['update'] = None
+        self.OnVectorPoints(event)
+        event.Skip()
     def OnVectorHeight(self, event):
         id = event.GetId()
         if id in self.win['vector']['lines']['height'].values():
@@ -4553,7 +4583,18 @@
                 win.SetValue(color)
             else:
                 win.SetValue(data['points'][prop]['value'])
+        win = self.FindWindowById(self.win['vector']['points']['3d'])
+        if vInfo['map3d']:
+            items = [_("on surface(s):"), _("as 3D")]
+        else:
+            items = [_("on surface")]
+        win.SetItems(items)
+        if data['points']['mode'].get('3d', False):
+            win.SetSelection(1)
+        else:
+            win.SetSelection(0)
         # height
         for type in ('slider', 'text'):
             win = self.FindWindowById(self.win['vector']['points']['height'][type])
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/wxnviz.py
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/wxnviz.py	2013-09-11 02:00:41 UTC (rev 57631)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/wxnviz.py	2013-09-11 02:25:55 UTC (rev 57632)
@@ -1049,6 +1049,21 @@
         return 1
+    def SetVectorPointZMode(self, id, zMode):
+        """!Set z mode (use z coordinate or not)
+        @param id volume id
+        @param zMode bool
+        @return -1 on failure
+        @return 0 when no 3d
+        @return 1 on success
+        if not GP_site_exists(id):
+            return -1
+        return GP_set_zmode(id, int(zMode))
     def AddIsosurface(self, id, level, isosurf_id = None):
         """!Add new isosurface
