[GRASS-SVN] r57638 - sandbox/turek/scatter_plot
Wed Sep 11 06:00:27 PDT 2013
Author: turek
Date: 2013-09-11 06:00:26 -0700 (Wed, 11 Sep 2013)
New Revision: 57638
   sandbox/turek/scatter_plot/README.txt
   sandbox/turek/scatter_plot/testing_patch.diff
scatter plot: added settings
Modified: sandbox/turek/scatter_plot/README.txt
--- sandbox/turek/scatter_plot/README.txt	2013-09-11 09:04:56 UTC (rev 57637)
+++ sandbox/turek/scatter_plot/README.txt	2013-09-11 13:00:26 UTC (rev 57638)
@@ -21,7 +21,7 @@
 - flip of digitized area on scatter plot
 - synch whith digitizer #DONE
 - statusbar showing information about computations and coordinates #DONE
-- scatter plot settings
+- scatter plot settings #DONE
 - export raster map #DONE
 - check for range of data, if big show warning
 - better temp files clean up
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff	2013-09-11 09:04:56 UTC (rev 57637)
+++ sandbox/turek/scatter_plot/testing_patch.diff	2013-09-11 13:00:26 UTC (rev 57638)
@@ -1,1232 +1,3 @@
-Index: lib/vector/Vlib/open.c
---- lib/vector/Vlib/open.c	(revision 57633)
-+++ lib/vector/Vlib/open.c	(working copy)
-@@ -240,7 +240,9 @@
-         else {
-             char file_path[GPATH_MAX];
-+            /* reduce to current mapset if search path was set */
-+            if(strcmp(Map->mapset, "") == 0)
-+                Map->mapset = G_store(G_mapset());
-             /* temporary map: reduce to current mapset if search path
-              * was set */
-             if (strcmp(Map->mapset, "") == 0)
-Index: lib/imagery/scatt.c
---- lib/imagery/scatt.c	(revision 0)
-+++ lib/imagery/scatt.c	(working copy)
-@@ -0,0 +1,799 @@
-+   \file lib/imagery/scatt.c
-+   \brief Imagery library - functions for wx Scatter Plot Tool.
-+   Low level functions used by wx Scatter Plot Tool.
-+   Copyright (C) 2013 by the GRASS Development Team
-+   This program is free software under the GNU General Public License
-+   (>=v2).  Read the file COPYING that comes with GRASS for details.
-+   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <grass/glocale.h>
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+struct rast_row
-+    CELL * row;
-+    char * null_row;
-+    struct Range rast_range; /*Range of whole raster.*/
-+   \brief Create pgm header.
-+   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
-+   \param region region to be pgm header generated for
-+   \param [out] header header of pgm file
-+static int get_cat_rast_header(struct Cell_head * region, char * header){
-+    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
-+   \brief Create category raster conditions file.
-+   \param cat_rast_region region to be file generated for
-+   \param cat_rast path of generated category raster file
-+int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    FILE * f_cat_rast;
-+    char cat_rast_header[1024];//TODO magic number
-+    int i_row, i_col;
-+    int head_nchars;
-+    unsigned char * row_data;
-+    f_cat_rast = fopen(cat_rast, "wb");
-+    if(!f_cat_rast) {
-+        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
-+        return -1;
-+    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
-+    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
-+    if (ferror(f_cat_rast)){
-+        fclose(f_cat_rast);
-+        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
-+        return -1;
-+    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
-+    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
-+        row_data[i_col] = 0 & 255;
-+    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
-+        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
-+            return -1;
-+    return 0;
-+static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
-+    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
-+               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
-+   \brief Find intersection region of two regions.
-+   \param A pointer to intersected region
-+   \param B pointer to intersected region
-+   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
-+   \return  0 if interection exists
-+   \return -1 if regions does not intersect
-+static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
-+    if(B->north < A->south) return -1;
-+    else if(B->north > A->north) intersec->north = A->north;
-+    else intersec->north = B->north;
-+    if(B->south > A->north) return -1;
-+    else if(B->south < A->south) intersec->south = A->south;
-+    else intersec->south = B->south;
-+    if(B->east < A->west) return -1;
-+    else if(B->east > A->east) intersec->east = A->east;
-+    else intersec->east = B->east;
-+    if(B->west > A->east) return -1;
-+    else if(B->west < A->west) intersec->west = A->west;
-+    else intersec->west = B->west;
-+    if(intersec->north == intersec->south) return -1;
-+    if(intersec->east == intersec->west) return -1;
-+    return 0;
-+   \brief Get rows and cols numbers, which defines intersection of the regions.
-+   \param B pointer to intersected region (A and B must have same resolution)
-+   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
-+   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
-+   \return -1 if regions do not intersect
-+   \return -2 resolution of regions is not same
-+static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
-+    float ns_res, ew_res;
-+    struct Cell_head intersec;
-+    /* TODO is it right check? */
-+    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
-+        return -2;
-+    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
-+        return -2;
-+    ns_res = A->ns_res;
-+    ew_res = A->ew_res;
-+    if(regions_intersecion(A, B, &intersec) == -1)
-+        return -1;
-+    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
-+    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
-+    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
-+    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
-+    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
-+    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
-+    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
-+    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
-+    return 0;
-+   \brief Insert raster map patch into pgm file.
-+   \param patch_rast name of raster map
-+   \param cat_rast_region region of category raster file
-+   \param cat_rast path to category raster file
-+   \return  0 on success
-+   \return -1 on failure
-+int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
-+    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
-+    int head_nchars, ret;
-+    int fd_patch_rast, init_shift, step_shift;
-+    unsigned char * patch_data;
-+    char * null_chunk_row;
-+    const char *mapset;
-+    struct Cell_head patch_lines, cat_rast_lines;
-+    f_cat_rast = fopen(cat_rast, "rb+");
-+        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
-+        return -1;
-+    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
-+        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
-+        return -1;
-+    Rast_get_cellhd(patch_rast, mapset, &patch_region);
-+    Rast_set_window(&patch_region);
-+    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
-+        return -1;
-+    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
-+    if(ret == -2) {
-+        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
-+        Rast_close(fd_patch_rast);
-+        return -1;
-+    else if (ret == -1){
-+        return 0;
-+    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
-+    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
-+    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
-+    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
-+    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
-+        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
-+        G_free(null_chunk_row);
-+        return -1;
-+    step_shift = cat_rast_region->cols - ncols;
-+    null_chunk_row =  Rast_allocate_null_buf();
-+    for(i_row = 0; i_row < nrows; i_row++) {
-+        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
-+        for(i_col = 0; i_col < ncols; i_col++) {
-+            patch_col = patch_bounds.west + i_col;
-+            if(null_chunk_row[patch_col] != 1)
-+                patch_data[i_col] = 1 & 255;
-+            else {
-+                patch_data[i_col] = 0 & 255;
-+        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
-+            return -1;
-+        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
-+            return -1;
-+    return 0;
-+   \brief Updates scatter plots data in category by pixels which meets category conditions.
-+   \param bands_rows data represents data describig one row from raster band
-+   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
-+static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
-+    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    char * b_1_null_row,* b_2_null_row;
-+    struct rast_row b_1_rast_row, b_2_rast_row;
-+    struct Range b_1_range, b_2_range;
-+    int b_1_range_size;
-+    int row_size = Rast_window_cols();
-+    int * scatts_bands = scatts->scatts_bands;
-+    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
-+        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
-+        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
-+        b_1_row = b_1_rast_row.row;
-+        b_2_row = b_2_rast_row.row;
-+        b_1_null_row =  b_1_rast_row.null_row;
-+        b_2_null_row =  b_2_rast_row.null_row;
-+        b_1_range = b_1_rast_row.rast_range;
-+        b_2_range = b_2_rast_row.rast_range;
-+        b_1_range_size = b_1_range.max - b_1_range.min + 1;
-+        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
-+        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
-+            /* pixel does not belongs to scatter plot or has null value in one of the bands */
-+            if(!belongs_pix[i_chunk_rows_pix] ||
-+                b_1_null_row[i_chunk_rows_pix] == 1 ||
-+                b_2_null_row[i_chunk_rows_pix] == 1)
-+                continue;
-+            /* index in scatter plot array */
-+            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
-+            if(array_idx < 0 || array_idx >= max_arr_idx) {
-+                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
-+                continue;
-+            /* increment scatter plot value */
-+            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
-+   \brief Computes scatter plots data from chunk_rows.
-+   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
-+   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
-+   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
-+   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
-+   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
-+   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
-+   \param region analysis region
-+static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
-+                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
-+                                                struct scCats * scatts, int * fd_cats_rasts)
-+    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
-+    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
-+    CELL * cat_rast_row;
-+    struct scScatts * scatts_conds;
-+    struct scScatts * scatts_scatt_plts;
-+    struct scdScattData * conds;
-+    int * scatts_bands;
-+    struct scdScattData ** scatts_arr;
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    unsigned char * i_scatt_conds;
-+    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
-+    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
-+    cat_rast_row =  Rast_allocate_c_buf();
-+    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
-+        scatts_conds = scatt_conds->cats_arr[i_cat];
-+        cat_id = scatt_conds->cats_ids[i_cat];
-+        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
-+        if(scatt_plts_cat_idx < 0)
-+            continue;
-+        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
-+        G_zero(belongs_pix, row_size * sizeof(unsigned short));
-+        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
-+        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
-+            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
-+                /* all pixels belongs */
-+                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
-+                    belongs_pix[i_rows_pix] = 1;
-+        /* compute belonging pixels for defined conditions */
-+        else
-+            scatts_bands = scatts_conds->scatts_bands;
-+            /* check conditions from category raster condtitions file */
-+            if(f_cats_rasts_conds[i_cat]) {
-+                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
-+                if (ferror(f_cats_rasts_conds[i_cat]))
-+                    G_free(rast_pixs);
-+                    G_free(belongs_pix);
-+                    G_warning(_("Unable to read from category raster condtition file."));
-+                    return -1;
-+                if (n_pixs != n_pixs) {
-+                    G_warning(_("Invalid size of category raster conditions file."));
-+                    return -1;
-+                    if(rast_pixs[i_rows_pix] != 0 & 255)
-+            /* check condtions defined in scatter plots*/
-+            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
-+                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
-+                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
-+                    if(belongs_pix[i_rows_pix] ||
-+                       b_1_null_row[i_rows_pix] == 1 ||
-+                       b_2_null_row[i_rows_pix] == 1)
-+                        continue;
-+                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
-+                        continue;
-+                    /* pixels meets condtion defined in scatter plot */
-+                    if(i_scatt_conds[array_idx])
-+        /* update category raster with belonging pixels */
-+        if(fd_cats_rasts[i_cat] >= 0) {
-+            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
-+                if(belongs_pix[i_rows_pix])
-+                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
-+            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
-+        /* update scatter plots with belonging pixels */
-+        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
-+    G_free(cat_rast_row);
-+    return 0;
-+   \brief Get list if bands needed to be opened for analysis from scCats struct.
-+static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
-+    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
-+    int i_cat, i_scatt, cat_id;
-+    for(i_cat = 0;  i_cat < cats->n_a_cats; i_cat++)
-+        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
-+            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
-+    return;
-+   \brief Helper function for clean up.
-+static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
-+                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
-+    int i, band_id;
-+    for(i = 0; i < n_a_bands; i++)
-+        band_id = bands_ids[i];
-+        if(band_id >= 0) {
-+            Rast_close(fd_bands[i]);
-+            G_free(bands_rows[band_id].row);
-+            G_free(bands_rows[band_id].null_row);
-+    if(f_cats_rasts_conds)
-+        for(i = 0; i < n_a_cats; i++)
-+            if(f_cats_rasts_conds[i])
-+                fclose(f_cats_rasts_conds[i]);
-+    if(fd_cats_rasts)
-+            if(fd_cats_rasts[i] >= 0)
-+                Rast_close(fd_cats_rasts[i]);
-+   \brief Compute scatter plots data.
-+    If category has not defined no category raster condition file and no scatter plot with consdtion,
-+    default scatter plot is computed.
-+   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
-+   \param region function calls Rast_set_window for this region
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
-+   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
-+   \param cats_rasts_conds index in array represents corresponding category id
-+   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
-+   \param bands names of analyzed bands, order of bands is defined by their id
-+   \param n_bands number of bands
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
-+int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
-+                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
-+    char header[1024];
-+    int fd_cats_rasts[scatt_conds->n_a_cats];
-+    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
-+    struct rast_row bands_rows[n_bands];
-+    RASTER_MAP_TYPE data_type;
-+    int nrows, i_band, n_a_bands, band_id,
-+        i, i_row, head_nchars, i_cat, id_cat;
-+    int fd_bands[n_bands];
-+    int bands_ids[n_bands];
-+    int b_needed_bands[n_bands];
-+    Rast_set_window(region);
-+    for(i_band = 0; i_band < n_bands; i_band++)
-+        fd_bands[i_band] = -1;
-+        bands_ids[i_band] = -1;
-+    if (n_bands != scatts->n_bands ||
-+        n_bands != scatt_conds->n_bands)
-+        return -1;
-+    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
-+    get_needed_bands(scatt_conds, &b_needed_bands[0]);
-+    get_needed_bands(scatts, &b_needed_bands[0]);
-+    n_a_bands = 0;
-+    /* open band rasters, which are needed for computation */
-+    for(band_id = 0; band_id < n_bands; band_id++)
-+        if(b_needed_bands[band_id])
-+            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
-+            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
-+                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
-+                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
-+                return -1;
-+            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
-+                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
-+                return -1;
-+            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
-+            if(data_type != CELL_TYPE) {
-+                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
-+                return -1;
-+            bands_rows[band_id].row =  Rast_allocate_c_buf();
-+            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
-+            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
-+                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
-+                return -1;
-+            bands_ids[n_a_bands] = band_id;
-+            ++n_a_bands;
-+    /* open category rasters condition files and category rasters */
-+    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
-+        id_cat = scatts->cats_ids[i_cat];
-+        if(cats_rasts[id_cat]) {
-+            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
-+        else
-+            fd_cats_rasts[i_cat] = -1;
-+        if(cats_rasts_conds[id_cat]) {
-+            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
-+            if(!f_cats_rasts_conds[i_cat]) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
-+                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
-+                return -1;
-+        else
-+            f_cats_rasts_conds[i_cat] = NULL;
-+    head_nchars =  get_cat_rast_header(region, header);
-+            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
-+                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
-+                return -1;
-+    nrows = Rast_window_rows();
-+    /* analyze bands by rows */
-+    for (i_row = 0; i_row < nrows; i_row++)
-+        for(i_band = 0; i_band < n_a_bands; i_band++)
-+            band_id = bands_ids[i_band];
-+            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
-+            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
-+        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
-+            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
-+                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
-+            return -1;
-+                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+    return 0;
-+int I_merge_arrays(unsigned char *  merged_arr, unsigned char *  overlay_arr, unsigned rows, unsigned cols, double alpha)
-+    unsigned int i_row, i_col, i_b;
-+    unsigned int row_idx, col_idx, idx;
-+    unsigned int c_a_i, c_a;
-+    for(i_row = 0; i_row < rows; i_row++)
-+        row_idx = i_row * cols;
-+        for(i_col = 0; i_col < cols; i_col++)
-+                col_idx = 4 * (row_idx + i_col);
-+                idx = col_idx + 3;
-+                c_a = overlay_arr[idx] * alpha;
-+                c_a_i = 255 - c_a;
-+                merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * 255) / 255;
-+                for(i_b = 0; i_b < 3; i_b++)
-+                    idx = col_idx + i_b;
-+                    merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * (int)overlay_arr[idx]) / 255;
-+    return 0;
-+int I_apply_colormap(unsigned char * vals, unsigned char * vals_mask, unsigned vals_size, unsigned char * colmap, unsigned char * col_vals){
-+    unsigned int i_val;
-+    int v, i, i_cm;
-+    for(i_val = 0; i_val < vals_size; i_val++){
-+        i_cm = 4 * i_val;
-+        v = vals[i_val];
-+        if(vals_mask[i_val])
-+            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[258 * 4 + i];
-+        else if(v > 255)
-+            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[257 * 4 + i];
-+        else if(v < 0)
-+            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[256 * 4 + i];
-+        else
-+            for(i = 0; i < 4; i++){ col_vals[i_cm + i] = colmap[v * 4 + i];
-+    return 0;
-Index: lib/imagery/scatt_sccats.c
---- lib/imagery/scatt_sccats.c	(revision 0)
-+++ lib/imagery/scatt_sccats.c	(working copy)
-@@ -0,0 +1,405 @@
-+   \file lib/imagery/scatt_cat_rast.c
-+   \brief Imagery library - functions for manipulation with scatter plot structs.
-+#include <math.h>
-+   \brief Compute band ids from scatter plot id.
-+    Scatter plot id describes which bands defines the scatter plot.
-+    Let say we have 3 bands, their ids are 0, 1 and 2.
-+    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
-+    All scatter plots:
-+    scatt_id b_1_id b_2_id
-+    0        0      1
-+    1        0      2
-+    2        1      2
-+   \param scatt_id scatter plot id
-+   \param [out] b_1_id id of band1
-+   \param[out] b_2_id id of band2
-+   \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+    int n_b1 = n_bands - 1;
-+    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
-+    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
-+    return 0;
-+   \brief Compute scatter plot id from band ids.
-+    See also I_id_scatt_to_bands().
-+   \param b_1_id id of band1
-+   \param b_1_id id of band2
-+   \param [out] scatt_id scatter plot id
-+   \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
-+    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
-+    return 0;
-+   \brief Initialize structure for storing scatter plots data.
-+   \param cats pointer to scCats struct
-+   \param type SC_SCATT_DATA - stores scatter plots
-+   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+    int i_cat;
-+    cats->type = type;
-+    cats->n_cats = 100;
-+    cats->n_a_cats = 0;
-+    cats->n_bands = n_bands;
-+    cats->n_scatts = (n_bands - 1) * n_bands / 2;
-+    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
-+    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
-+    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
-+    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+        cats->cats_idxs[i_cat] = -1;
-+    return;
-+   \brief Free data of struct scCats, the structure itself remains alocated.
-+   \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+    int i_cat;
-+        if(cats->cats_arr[i_cat])
-+            G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+            G_free(cats->cats_arr[i_cat]->scatts_bands);
-+            G_free(cats->cats_arr[i_cat]->scatts_arr);
-+            G_free(cats->cats_arr[i_cat]);
-+    G_free(cats->cats_ids);
-+    G_free(cats->cats_idxs);
-+    G_free(cats->cats_arr);
-+    cats->n_cats = 0;
-+    cats->n_bands = 0;
-+    cats->n_scatts = 0;
-+    cats->type = -1;
-+    return;
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+    a_cats_ids = cats->cats_ids;
-+    * n_a_cats = cats->n_a_cats;
-+#endif
-+   \brief Add category.
-+    Category represents group of scatter plots.
-+   \return assigned category id (starts with 0)
-+   \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+    int i_scatt, i_cat_id, cat_id;
-+    int n_a_cats = cats->n_a_cats;
-+    if(cats->n_a_cats >= cats->n_cats)
-+        return -1;
-+    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+        if(cats->cats_idxs[i_cat_id] < 0) {
-+            cat_id = i_cat_id;
-+            break;
-+    cats->cats_ids[n_a_cats] = cat_id;
-+    cats->cats_idxs[cat_id] = n_a_cats;
-+    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+    ++cats->n_a_cats;
-+    return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+    int cat_idx, i_cat;
-+    if(cat_id < 0 || cat_id >= cats->n_cats)
-+        return -1;
-+    cat_idx = cats->cats_idxs[cat_id];
-+    if(cat_idx < 0)
-+        return -1;
-+    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+    G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+    G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+    G_free(cats->cats_arr[cat_idx]);
-+    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+    cats->cats_idxs[cat_id] = -1;
-+    --cats->n_a_cats;
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data .
-+    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+   \param cat_id id number of category.
-+   \param scatt_id id number of scatter plot.
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int band_1, band_2, cat_idx, n_a_scatts;
-+    struct scScatts * scatts;
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+        return -1;
-+    scatts = cats->cats_arr[cat_idx];
-+    if(scatts->scatt_idxs[scatt_id] >= 0)
-+        return -1;
-+    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+        return -1;
-+    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+        return -1;
-+    n_a_scatts = scatts->n_a_scatts;
-+    scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+    scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+    scatts->scatts_arr[n_a_scatts] = scatt_data;
-+    ++scatts->n_a_scatts;
-+    return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+    if(cat_id < 0 && cat_id >= cats->n_cats)
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+        return -1;
-+    if(scatts->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_data = scatts->scatts_arr[scatt_idx];
-+    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+    scatts->scatt_idxs[scatt_id] = -1;
-+    scatt_data = scatts->scatts_arr[scatt_id];
-+    scatts->n_a_scatts--;
-+    return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+    int cat_idx, scatt_idx, ret;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data.
-+   \param scatt_data pointer to existing struct scdScattData
-+   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+   \param n_vals number of data values
-+   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+    scatt_data->n_vals = n_vals;
-+    if(type == SC_SCATT_DATA)
-+        if(data)
-+            scatt_data->scatt_vals_arr = (unsigned int *) data;
-+        else {
-+            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+        scatt_data->b_conds_arr = NULL;
-+    else if(type == SC_SCATT_CONDITIONS)
-+        if(data)
-+            scatt_data->b_conds_arr = (unsigned char *) data;
-+        else {
-+            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+        scatt_data->scatt_vals_arr = NULL;
-+    return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+    return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+    if(!scatt_data->b_conds_arr)
-+        return scatt_data->b_conds_arr;
-+    else if(!scatt_data->scatt_vals_arr)
-+        return scatt_data->scatt_vals_arr;
-+    return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
-+        return -1;
-+    if(scatt_data->b_conds_arr)
-+        scatt_data->b_conds_arr[val_idx] = val;
-+    else if(scatt_data->scatt_vals_arr)
-+        scatt_data->scatt_vals_arr[val_idx] = val;
-+    else
-+        return -1;
-+    return 0;
-+#endif
 Index: include/imagery.h
 --- include/imagery.h	(revision 57633)
@@ -1332,20 +103,6 @@
  /* sig.c */
  int I_init_signatures(struct Signature *, int);
  int I_new_signature(struct Signature *);
-Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py	(revision 57633)
-+++ gui/wxpython/mapdisp/toolbars.py	(working copy)
-@@ -239,7 +239,8 @@
-                       (MapIcons["scatter"],     self.parent.OnScatterplot),
-                       (MapIcons["histogram"],   self.parent.OnHistogramPyPlot),
-                       (BaseIcons["histogramD"], self.parent.OnHistogram),
--                      (MapIcons["vnet"],        self.parent.OnVNet)))
-+                      (MapIcons["vnet"],        self.parent.OnVNet),
-+                      (MapIcons["scatter"],     self.parent.OnScatterplot2)))
-     def OnDecoration(self, event):
-         """!Decorations overlay menu
 Index: gui/wxpython/mapdisp/frame.py
 --- gui/wxpython/mapdisp/frame.py	(revision 57633)
@@ -1378,595 +135,20 @@
      def OnVNet(self, event):
          """!Dialog for v.net* modules
-Index: gui/wxpython/vdigit/wxdigit.py
+Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/vdigit/wxdigit.py	(revision 57633)
-+++ gui/wxpython/vdigit/wxdigit.py	(working copy)
-@@ -17,7 +17,7 @@
- (and NumPy would be an excellent candidate for acceleration via
- e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
--(C) 2007-2011 by the GRASS Development Team
-+(C) 2007-2011, 2013 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
-@@ -27,6 +27,8 @@
- import grass.script.core as grass
-+from grass.pydispatch.signal import Signal
- from core.gcmd        import GError
- from core.debug       import Debug
- from core.settings    import UserSettings
-@@ -176,7 +178,21 @@
+--- gui/wxpython/mapdisp/toolbars.py	(revision 57633)
++++ gui/wxpython/mapdisp/toolbars.py	(working copy)
+@@ -239,7 +239,8 @@
+                       (MapIcons["scatter"],     self.parent.OnScatterplot),
+                       (MapIcons["histogram"],   self.parent.OnHistogramPyPlot),
+                       (BaseIcons["histogramD"], self.parent.OnHistogram),
+-                      (MapIcons["vnet"],        self.parent.OnVNet)))
++                      (MapIcons["vnet"],        self.parent.OnVNet),
++                      (MapIcons["scatter"],     self.parent.OnScatterplot2)))
-         if self.poMapInfo:
-             self.InitCats()
-+        self.emit_signals = False
-+        # signals which describes features changes during digitization,
-+        # activate them using EmitSignals method
-+        #TODO signal for errors?
-+        self.featureAdded = Signal('IVDigit.featureAdded')
-+        self.areasDeleted = Signal('IVDigit.areasDeleted')
-+        self.vertexMoved = Signal('IVDigit.vertexMoved')
-+        self.vertexAdded = Signal('IVDigit.vertexAdded')
-+        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
-+        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
-+        self.featuresMoved = Signal('IVDigit.featuresMoved')
-+        self.lineEdited = Signal('IVDigit.lineEdited')
-     def __del__(self):
-         Debug.msg(1, "IVDigit.__del__()")
-         Vect_destroy_line_struct(self.poPoints)
-@@ -188,7 +204,12 @@
-             Vect_close(self.poBgMapInfo)
-             self.poBgMapInfo = self.popoBgMapInfo = None
-             del self.bgMapInfo
-+    def EmitSignals(self, emit):
-+        """!Activate/deactivate signals which describes features changes during digitization.
-+        self.emit_signals = emit
-     def CloseBackgroundMap(self):
-         """!Close background vector map"""
-         if not self.poBgMapInfo:
-@@ -394,7 +415,6 @@
-         @return tuple (number of added features, feature ids)
-         layer = self._getNewFeaturesLayer()
-         cat = self._getNewFeaturesCat()
-@@ -419,10 +439,14 @@
-             return (-1, None)
-         self.toolbar.EnableUndo()
--        return self._addFeature(vtype, points, layer, cat,
--                                self._getSnapMode(), self._display.GetThreshold())
-+        ret = self._addFeature(vtype, points, layer, cat,
-+                               self._getSnapMode(), self._display.GetThreshold())
-+        if ret[0] > -1 and self.emit_signals:
-+            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
-+        return ret
-     def DeleteSelectedLines(self):
-         """!Delete selected features
-@@ -434,16 +458,27 @@
-         # collect categories for deleting if requested
-         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
-         catDict = dict()
-+        old_bboxs = []
-+        old_areas_cats = []
-         if deleteRec:
-             for i in self._display.selected['ids']:
-                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
-                     self._error.ReadLine(i)
--                cats = self.poCats.contents
--                for j in range(cats.n_cats):
--                    if cats.field[j] not in catDict.keys():
--                        catDict[cats.field[j]] = list()
--                    catDict[cats.field[j]].append(cats.cat[j])
-+                if self.emit_signals:
-+                    ret = self._getLineAreaBboxCats(i)
-+                    if ret:
-+                        old_bboxs += ret[0]
-+                        old_areas_cats += ret[1]
-+                # catDict was not used -> put into comment
-+                #cats = self.poCats.contents
-+                #for j in range(cats.n_cats):
-+                #    if cats.field[j] not in catDict.keys():
-+                #        catDict[cats.field[j]] = list()
-+                #    catDict[cats.field[j]].append(cats.cat[j])
-         poList = self._display.GetSelectedIList()
-         nlines = Vedit_delete_lines(self.poMapInfo, poList)
-@@ -456,7 +491,10 @@
-                 self._deleteRecords(catDict)
-             self._addChangeset()
-+                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-         return nlines
-     def _deleteRecords(self, cats):
-@@ -512,22 +550,173 @@
-         @return number of deleted
-+        if len(self._display.selected['ids']) < 1:
-+            return 0
-         cList  = poList.contents
-         nareas = 0
-+        old_bboxs = []
-         for i in range(cList.n_values):
-             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
-                 continue
-+                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
-+                if area > 0:
-+                    bbox, cats = self._getaAreaBboxCats(area)
-+                    old_bboxs += bbox
-+                    old_areas_cats += cats
-             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
-         if nareas > 0:
-+                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-+        return nareas
-+    def _getLineAreaBboxCats(self, ln_id):
-+        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
-+        if ltype == GV_CENTROID:
-+            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
-+            return self._getCentroidAreaBboxCats(ln_id)
-+        else:
-+            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
-+    def _getCentroidAreaBboxCats(self, centroid):
-+        if not Vect_line_alive(self.poMapInfo, centroid):
-+            return None
-+        area = Vect_get_centroid_area(self.poMapInfo, centroid)
-+        if area > 0:
-+            return self._getaAreaBboxCats(area)
-+        else:
-+            return None
-+    def _getaAreaBboxCats(self, area):
-+        po_b_list = Vect_new_list()
-+        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
-+        b_list = po_b_list.contents
-+        geoms = []
-+        areas_cats = []
-+        if b_list.n_values > 0:
-+            for i_line in range(b_list.n_values):
-+                line = b_list.value[i_line];
-+                geoms.append(self._getBbox(abs(line)))
-+                areas_cats.append(self._getLineAreasCategories(abs(line)))
--        return nareas
-+        Vect_destroy_list(po_b_list);
-+        return geoms, areas_cats
-+    def _getLineAreasCategories(self, ln_id):
-+        if not Vect_line_alive (self.poMapInfo, ln_id):
-+            return []
-+        if ltype != GV_BOUNDARY:
-+            return []
-+        cats = [None, None]
-+        left = c_int()
-+        right = c_int()
-+        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
-+            areas = [left.value, right.value]
-+            for i, a in enumerate(areas):
-+                if a > 0:
-+                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
-+                    if centroid <= 0:
-+                        continue
-+                    c = self._getCategories(centroid)
-+                    if c:
-+                        cats[i] = c
-+        return cats
-+    def _getCategories(self, ln_id):
-+            return none
-+        poCats = Vect_new_cats_struct()
-+        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
-+            Vect_destroy_cats_struct(poCats)
-+            return None
-+        cCats = poCats.contents
-+        cats = {}
-+        for j in range(cCats.n_cats):
-+            if cats.has_key(cCats.field[j]):
-+                cats[cCats.field[j]].append(cCats.cat[j])
-+            else:
-+                cats[cCats.field[j]] = [cCats.cat[j]]
-+        return cats
-+    def _getBbox(self, ln_id):
-+            return None
-+        poPoints = Vect_new_line_struct()
-+        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
-+            Vect_destroy_line_struct(poPoints)
-+            return []
-+        geom = self._convertGeom(poPoints)
-+        bbox = self._createBbox(geom)
-+        return bbox
-+    def _createBbox(self, points):
-+        bbox = {}
-+        for pt in points:
-+            if not bbox.has_key('maxy'):
-+                bbox['maxy'] = pt[1]
-+                bbox['miny'] = pt[1]
-+                bbox['maxx'] = pt[0]
-+                bbox['minx'] = pt[0]
-+                continue
-+            if   bbox['maxy'] < pt[1]:
-+            elif bbox['miny'] > pt[1]:
-+            if   bbox['maxx'] < pt[0]:
-+            elif bbox['minx'] > pt[0]:
-+        return bbox
-+    def _convertGeom(self, poPoints):
-+        Points = poPoints.contents
-+        pts_geom = []
-+        for j in range(Points.n_points):
-+            pts_geom.append((Points.x[j], Points.y[j]))
-+        return pts_geom
-     def MoveSelectedLines(self, move):
-         """!Move selected features
-@@ -536,16 +725,45 @@
-         if not self._checkMap():
-             return -1
-+        nsel = len(self._display.selected['ids'])
-+        if nsel < 1:
-+            return -1
-         thresh = self._display.GetThreshold()
-         snap   = self._getSnapMode()
-+            old_bboxs = []
-+            for sel_id in self._display.selected['ids']:
-+                ret = self._getLineAreaBboxCats(sel_id)
-+                if ret:
-+            Vect_set_updated(self.poMapInfo, 1)
-+            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
-         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList,
-                                   move[0], move[1], 0,
-                                   snap, thresh)
-         Vect_destroy_list(poList)
-+        if nlines > 0 and self.emit_signals:
-+            new_bboxs = []
-+            new_areas_cats = []
-+            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
-+            for i in range(n_up_lines_old, n_up_lines):
-+                new_id = Vect_get_updated_line(self.poMapInfo, i)
-+                ret = self._getLineAreaBboxCats(new_id)
-+                if ret:
-+                    new_bboxs += ret[0]
-+                    new_areas_cats += ret[1]
-         if nlines > 0 and self._settings['breakLines']:
-             for i in range(1, nlines):
-                 self._breakLineAtIntersection(nlines + i, None, changeset)
-@@ -553,7 +771,13 @@
-         if nlines > 0:
-+                self.featuresMoved.emit(new_bboxs = new_bboxs,
-+                                        old_bboxs = old_bboxs,
-+                                        old_areas_cats = old_areas_cats,
-+                                        new_areas_cats = new_areas_cats)
-         return nlines
-     def MoveSelectedVertex(self, point, move):
-@@ -571,12 +795,21 @@
-         if len(self._display.selected['ids']) != 1:
-             return -1
-+        # move only first found vertex in bbox
-+        poList = self._display.GetSelectedIList()
-+            cList = poList.contents
-+            old_bboxs = [self._getBbox(cList.value[0])]
-+            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
-         Vect_reset_line(self.poPoints)
-         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
--        # move only first found vertex in bbox
--        poList = self._display.GetSelectedIList()
-         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList, self.poPoints,
-                                   self._display.GetThreshold(type = 'selectThresh'),
-@@ -584,7 +817,17 @@
-                                   move[0], move[1], 0.0,
-                                   1, self._getSnapMode())
-+        if moved > 0 and self.emit_signals:
-+            new_bboxs = []
-+                new_bboxs.append(self._getBbox(new_id))
-+                new_areas_cats.append(self._getLineAreasCategories(new_id))
-         if moved > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
-                                           None)
-@@ -592,7 +835,13 @@
-         if moved > 0:
-+                self.vertexMoved.emit(new_bboxs = new_bboxs,
-+                                      new_areas_cats = new_areas_cats,
-+                                      old_bboxs = old_bboxs)
-         return moved
-     def AddVertex(self, coords):
-@@ -681,6 +930,10 @@
-             self._error.ReadLine(line)
-             return -1
-+            old_bboxs = [self._getBbox(line)]
-+            old_areas_cats = [self._getLineAreasCategories(line)]
-         # build feature geometry
-         for p in coords:
-@@ -696,6 +949,9 @@
-         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
-                                     self.poPoints, self.poCats)
-+        if newline > 0 and self.emit_signals:
-+            new_geom = [self._getBbox(newline)]
-+            new_areas_cats = [self._getLineAreasCategories(newline)]
-         if newline > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(newline, None)
-@@ -703,7 +959,13 @@
-         if newline > 0:
-+                self.lineEdited.emit(old_bboxs = old_bboxs,
-+                                     new_bboxs = new_bboxs,
-         return newline
-     def FlipLine(self):
-@@ -1514,6 +1776,16 @@
-             return 0
-         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
-@@ -1525,15 +1797,35 @@
-         else:
-             ret = Vedit_remove_vertex(self.poMapInfo, poList,
-                                       self.poPoints, thresh)
-+        if ret > 0 and self.emit_signals:
-+            new_bboxs = []
-         if not add and ret > 0 and self._settings['breakLines']:
-                                           None)
-         if ret > 0:
-+            if add:
-+                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
-+            else:
-+                self.vertexRemoved.emit(old_bboxs = old_bboxs,
-         return 1
-     def GetLineCats(self, line):
-Index: gui/wxpython/vdigit/toolbars.py
---- gui/wxpython/vdigit/toolbars.py	(revision 57633)
-+++ gui/wxpython/vdigit/toolbars.py	(working copy)
-@@ -17,6 +17,7 @@
- import wx
- from grass.script import core as grass
- from gui_core.toolbars  import BaseToolbar, BaseIcons
- from gui_core.dialogs   import CreateNewVector
-@@ -42,6 +43,8 @@
-         self.digit         = None
-         self._giface       = giface
-+        self.editingStarted = Signal("VDigitToolbar.editingStarted")
-         # currently selected map layer for editing (reference to MapLayer instance)
-         self.mapLayer = None
-         # list of vector layers from Layer Manager (only in the current mapset)
-@@ -860,6 +863,7 @@
-             alpha = int(opacity * 255)
-             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
-+        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
-         return True
-     def StopEditing(self):
-Index: gui/wxpython/vnet/toolbars.py
---- gui/wxpython/vnet/toolbars.py	(revision 57633)
-+++ gui/wxpython/vnet/toolbars.py	(working copy)
-@@ -19,9 +19,9 @@
- import wx
--from icon              import MetaIcon
-+from icons.icon import MetaIcon
--from core.gcmd         import RunCommand
-+from core.gcmd import RunCommand
- from core.utils import _
- class PointListToolbar(BaseToolbar):
-Index: gui/wxpython/Makefile
---- gui/wxpython/Makefile	(revision 57633)
-+++ gui/wxpython/Makefile	(working copy)
-@@ -13,7 +13,7 @@
- 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
- 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
- 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
--	vnet/*.py web_services/*.py wxplot/*.py) \
-+	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
- 	gis_set.py gis_set_error.py wxgui.py README
- DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
-@@ -21,8 +21,9 @@
- PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
- 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
--	mapswipe vdigit wxplot web_services rlisetup vnet timeline)
-+	mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
- DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
- default: $(DSTFILES)
+     def OnDecoration(self, event):
+         """!Decorations overlay menu
 Index: gui/wxpython/iclass/dialogs.py
 --- gui/wxpython/iclass/dialogs.py	(revision 57633)
@@ -2579,7 +761,7 @@
 --- gui/wxpython/scatt_plot/dialogs.py	(revision 0)
 +++ gui/wxpython/scatt_plot/dialogs.py	(working copy)
-@@ -0,0 +1,249 @@
+@@ -0,0 +1,419 @@
 + at package scatt_plot.dialogs
@@ -2600,6 +782,7 @@
 +import wx
 +from scatt_plot.scatt_core import idBandsToidScatt
 +from gui_core.gselect import Select
++import wx.lib.colourselect as csel
 +import grass.script as grass
@@ -2828,13 +1011,182 @@
 +            qdlg.Destroy()
 +        else:
 +            event.Skip()
++class SettingsDialog(wx.Dialog):
++    def __init__(self, parent, id, title, scatt_mgr, pos=wx.DefaultPosition, size=wx.DefaultSize,
++                 style=wx.DEFAULT_DIALOG_STYLE):
++        """!Settings dialog"""
++        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
++        self.scatt_mgr = scatt_mgr
++        maxValue = 1e8
++        self.parent = parent
++        self.settings = {}
++        settsLabels = {}
++        self.settings["show_ellips"] = wx.CheckBox(parent = self, id=wx.ID_ANY,
++                                                  label = _('Show confidence ellipses'))
++        show_ellips = UserSettings.Get(group ='scatt', key = "ellipses", subkey = "show_ellips")
++        self.settings["show_ellips"].SetValue(show_ellips)
++        self.colorsSetts = {
++                            "sel_pol" : ["selection", _("Selection polygon color:")],
++                            "sel_pol_vertex" : ["selection", _("Color of selection polygon vertex:")],
++                            "sel_area" : ["selection", _("Selected area color:")]
++        for settKey, sett in self.colorsSetts.iteritems():
++            settsLabels[settKey] = wx.StaticText(parent = self, id = wx.ID_ANY, label = sett[1])
++            col = UserSettings.Get(group ='scatt', key = sett[0], subkey = settKey)
++            self.settings[settKey] = csel.ColourSelect(parent = self, id = wx.ID_ANY,
++                                            colour = wx.Colour(col[0],
++                                                               col[1],
++                                                               col[2],
++                                                               255))
++        self.sizeSetts = {
++                          "snap_tresh" : ["selection", _("Snapping treshold in pixels:")],
++                          "sel_area_opacty" : ["selection", _("Selected area opacity:")]
++        for settKey, sett in self.sizeSetts.iteritems():
++            self.settings[settKey] = wx.SpinCtrl(parent = self, id = wx.ID_ANY, min=0, max = 100)
++            size = int(UserSettings.Get(group = 'scatt', key = sett[0], subkey = settKey))
++            self.settings[settKey].SetValue(size)
++        # buttons
++        self.btnSave = wx.Button(self, wx.ID_SAVE)
++        self.btnApply = wx.Button(self, wx.ID_APPLY)
++        self.btnClose = wx.Button(self, wx.ID_CLOSE)
++        self.btnApply.SetDefault()
++        # bindings
++        self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
++        self.btnApply.SetToolTipString(_("Apply changes for the current session"))
++        self.btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
++        self.btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
++        self.btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
++        self.btnClose.SetToolTipString(_("Close dialog"))
++        #Layout
++        # Analysis result style layout
++        self.SetMinSize(self.GetBestSize())
++        sizer = wx.BoxSizer(wx.VERTICAL)
++        sel_pol_box = wx.StaticBox(parent = self, id = wx.ID_ANY,
++                                   label =" %s " % _("Selection style:"))
++        selPolBoxSizer = wx.StaticBoxSizer(sel_pol_box, wx.VERTICAL)
++        gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
++        row = 0
++        setts = dict(self.colorsSetts.items() + self.sizeSetts.items())
++        settsOrder = ["sel_pol", "sel_pol_vertex", "sel_area",
++                      "sel_area_opacty", "snap_tresh"]
++        for settKey in settsOrder:
++            sett = setts[settKey]
++            gridSizer.Add(item = settsLabels[settKey], flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
++            gridSizer.Add(item = self.settings[settKey],
++                          flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
++                          pos =(row, 1))
++            row += 1
++        gridSizer.AddGrowableCol(1)
++        selPolBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
++        ell_box = wx.StaticBox(parent = self, id = wx.ID_ANY,
++                                   label =" %s " % _("Ellipses settings:"))
++        ellPolBoxSizer = wx.StaticBoxSizer(ell_box, wx.VERTICAL)
++        row = 0
++        gridSizer.Add(item=self.settings["show_ellips"],
++                      flag=wx.ALIGN_CENTER_VERTICAL,
++                      pos=(row, 0))
++        ellPolBoxSizer.Add(item=gridSizer, flag=wx.EXPAND)
++        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
++        btnSizer.Add(self.btnApply, flag=wx.LEFT | wx.RIGHT, border=5)
++        btnSizer.Add(self.btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
++        btnSizer.Add(self.btnClose, flag=wx.LEFT | wx.RIGHT, border=5)
++        sizer.Add(item=selPolBoxSizer, flag=wx.EXPAND | wx.ALL, border=5)
++        sizer.Add(item=ellPolBoxSizer, flag=wx.EXPAND | wx.ALL, border=5)
++        sizer.Add(item=btnSizer, flag=wx.EXPAND | wx.ALL, border=5, proportion=0)
++        self.SetSizer(sizer)
++        sizer.Fit(self)
++    def OnSave(self, event):
++        """!Button 'Save' pressed"""
++        self.UpdateSettings()
++        fileSettings = {}
++        UserSettings.ReadSettingsFile(settings=fileSettings)
++        fileSettings['scatt'] = UserSettings.Get(group='scatt')
++        UserSettings.SaveToFile(fileSettings)
++        self.Close()
++    def UpdateSettings(self):
++        chanaged_setts = [];
++            col = tuple(self.settings[settKey].GetColour())
++            col_s = UserSettings.Get(group='scatt', key=sett[0], subkey=settKey)
++            if col_s != col:
++                UserSettings.Set(group='scatt',
++                                 key=sett[0],
++                                 subkey=settKey,
++                                 value=col)
++                chanaged_setts.append([settKey, sett[0]])
++            val = self.settings[settKey].GetValue()
++            val_s = UserSettings.Get(group ='scatt', key = sett[0], subkey = settKey)
++            if val_s != val:
++                UserSettings.Set(group = 'scatt', key = sett[0], subkey = settKey,
++                                 value = val)
++        val = self.settings['show_ellips'].IsChecked()
++        val_s = UserSettings.Get(group ='scatt', key='ellipses', subkey='show_ellips')
++        if val != val_s:
++            UserSettings.Set(group='scatt', key='ellipses', subkey='show_ellips',
++                             value=val)
++            chanaged_setts.append(['ellipses', 'show_ellips'])
++        if chanaged_setts:
++            self.scatt_mgr.SettingsUpdated(chanaged_setts)
++    def OnApply(self, event):
++        """!Button 'Apply' pressed"""
++        #self.Close()
++    def OnClose(self, event):
++        """!Button 'Cancel' pressed"""
++        self.Close()
 \ No newline at end of file
 Index: gui/wxpython/scatt_plot/toolbars.py
 --- gui/wxpython/scatt_plot/toolbars.py	(revision 0)
 +++ gui/wxpython/scatt_plot/toolbars.py	(working copy)
-@@ -0,0 +1,216 @@
+@@ -0,0 +1,224 @@
 + at package scatt_plot.toolbars
@@ -2857,8 +1209,8 @@
 +from core.gcmd import GException, GError, RunCommand
++from scatt_plot.dialogs import SettingsDialog
 +class MainToolbar(BaseToolbar):
 +    """!Main toolbar
@@ -2908,12 +1260,13 @@
 +                                     ("zoom_extend", icons["zoomExtent"],
 +                                     lambda event: self.SetPloltsMode(event, 'zoom_extend'),
 +                                      wx.ITEM_CHECK),
-+                                    (None, ),
++                                     (None, ),
 +                                     ('sel_pol_mode', icons['selCatPol'],
 +                                      self.ActivateSelectionPolygonMode,
-+                                     wx.ITEM_CHECK)
-+                                     #('settings', icon["settings"],
-+                                     # self.parent.OnSettings),
++                                     wx.ITEM_CHECK),
++                                     (None, ),
++                                     ('settings', icons["settings"],
++                                      self.OnSettings)
 +                                     #('help', icons["help"],
 +                                     # self.OnHelp),
@@ -2957,6 +1310,13 @@
 +                i_tool_id = vars(self)[i_tool_name]
 +                self.ToggleTool(i_tool_id, False)
++    def OnSettings(self, event):
++        dlg = SettingsDialog(parent=self, id=wx.ID_ANY,
++                             title=_('Settings'), scatt_mgr = self.scatt_mgr)
++        dlg.ShowModal()
++        dlg.Destroy()
 +class EditingToolbar(BaseToolbar):
 +    """!Main toolbar
@@ -2993,8 +1353,8 @@
 +                                         label = _('Remove vertex'),
 +                                         desc = _('Remove boundary vertex.')),
 +            'delete'        : MetaIcon(img = 'polygon-delete',
-+                                         label = _('Edit line/boundary'),
-+                                         desc = _('Delete polygon')),
++                                       label = _('Remove polygon.'),
++                                       desc = _('Remove polygon.')),
 +        return self._getToolbarData((
@@ -3015,8 +1375,8 @@
 +                                     ('delete_vertex', self.icons['removeVertex'],
 +                                     lambda event: self.SetMode(event, 'delete_vertex'),
 +                                     wx.ITEM_CHECK),
-+                                     ('delete', self.icons['delete'],
-+                                     lambda event: self.SetMode(event, 'delete'),
++                                     ('remove_polygon', self.icons['delete'],
++                                     lambda event: self.SetMode(event, 'remove_polygon'),
 +                                     wx.ITEM_CHECK)
@@ -4721,7 +3081,7 @@
 --- gui/wxpython/scatt_plot/plots.py	(revision 0)
 +++ gui/wxpython/scatt_plot/plots.py	(working copy)
-@@ -0,0 +1,906 @@
+@@ -0,0 +1,936 @@
@@ -4747,6 +3107,7 @@
 +#from numpy.lib.stride_tricks import as_strided
 +from copy import deepcopy
 +from scatt_plot.core_c import MergeArrays, ApplyColormap
++from core.settings import UserSettings
 +try:
 +    import matplotlib
@@ -5151,19 +3512,21 @@
 +    An polygon editor.
-+    showverts = True
-+    epsilon = 5  #TODO settings max pixel distance to count as a vertex hit
 +    def __init__(self, ax, pol, empty_pol):
 +        if pol.figure is None:
 +            raise RuntimeError('You must first add the polygon to a figure or canvas before defining the interactor')
 +        self.ax = ax
 +        self.canvas = pol.figure.canvas
++        self.showverts = True
 +        self.pol = pol
 +        self.empty_pol = empty_pol
 +        x, y = zip(*self.pol.xy)
++        style = self._getPolygonStyle()
 +        self.line = Line2D(x, y, marker='o', markerfacecolor='r', animated=True)
 +        self.ax.add_line(self.line)
 +        #self._update_line(pol)
@@ -5182,6 +3545,26 @@
 +        self.canvas.mpl_connect('motion_notify_event', self.motion_notify_callback)
 +        self.it = 0
++    def _getPolygonStyle(self):
++        style = {}
++        style['sel_pol'] = UserSettings.Get(group='scatt',
++                                            key='selection',
++                                            subkey='sel_pol')
++        style['sel_pol_vertex'] = UserSettings.Get(group='scatt',
++                                                   key='selection',
++                                                   subkey='sel_pol_vertex')
++        style['sel_pol'] = [i / 255.0 for i in style['sel_pol']]
++        style['sel_pol_vertex'] = [i / 255.0 for i in style['sel_pol_vertex']]
++        return style
++    def _getSnapTresh(self):
++        return UserSettings.Get(group='scatt',
++                                key='selection',
++                                subkey='snap_tresh')
 +    def SetMode(self, mode):
 +        self.mode = mode
@@ -5229,6 +3612,11 @@
 +        self.canvas.draw()
 +    def draw_callback(self, event):
++        style=self._getPolygonStyle()
++        self.pol.set_facecolor(style['sel_pol'])
++        self.line.set_markerfacecolor(style['sel_pol_vertex'])
 +        self.background = self.canvas.copy_from_bbox(self.ax.bbox)
 +        self.ax.draw_artist(self.pol)
 +        self.ax.draw_artist(self.line)
@@ -5241,7 +3629,7 @@
 +        self.line.set_visible(vis)  # don't use the pol visibility state
 +    def get_ind_under_point(self, event):
-+        'get the index of the vertex under point if within epsilon tolerance'
++        'get the index of the vertex under point if within treshold'
 +        # display coords
 +        xy = np.asarray(self.pol.xy)
@@ -5251,7 +3639,7 @@
 +        indseq = np.nonzero(np.equal(d, np.amin(d)))[0]
 +        ind = indseq[0]
-+        if d[ind]>=self.epsilon:
++        if d[ind]>=self._getSnapTresh():
 +            ind = None
 +        return ind
@@ -5269,6 +3657,8 @@
 +            self._addVertexOnBoundary(event)
 +        elif self.mode == "add_vertex":
 +            self._addVertex(event)
++        elif self.mode == "remove_polygon":
++            self.SetEmpty()
 +        self.moving_ver_idx = self.get_ind_under_point(event)
 +    def button_release_callback(self, event):
@@ -5320,7 +3710,7 @@
 +            s1 = xys[i+1]
 +            d = dist_point_to_segment(p, s0, s1)
-+            if d<=self.epsilon:
++            if d<=self._getSnapTresh():
 +                self.pol.xy = np.array(
 +                    list(self.pol.xy[:i + 1]) +
 +                    [(event.xdata, event.ydata)] +
@@ -5633,7 +4023,7 @@
 --- gui/wxpython/scatt_plot/controllers.py	(revision 0)
 +++ gui/wxpython/scatt_plot/controllers.py	(working copy)
-@@ -0,0 +1,773 @@
+@@ -0,0 +1,816 @@
 + at package scatt_plot.controllers
@@ -5664,12 +4054,12 @@
 +from scatt_plot.dialogs import AddScattPlotDialog, ExportCategoryRaster
 +from scatt_plot.gthreading import gThread
 +from core.gconsole import EVT_CMD_DONE
 +class ScattsManager(wx.EvtHandler):
 +    def __init__(self, guiparent, giface, iclass_mapwin):
 +        #TODO remove iclass parameter
@@ -5729,6 +4119,8 @@
 +                            'export_cat_rast' : []
++        self._initSettings()
 +        self.Bind(EVT_CMD_DONE, self.OnThreadDone)
 +        self.modeSet = Signal("ScattsManager.mondeSet")
@@ -5741,6 +4133,27 @@
 +        for scatt_id, scatt in self.plots.items():
 +            scatt.CleanUp()
++    def _initSettings(self):
++        """!Initialization of settings (if not already defined)"""
++        # initializes default settings
++        initSettings = [
++                        ['selection', 'sel_pol', (255,255,0)],
++                        ['selection', 'sel_pol_vertex', (255,0,0)],
++                        ['selection', 'sel_area', (0,255,19)],
++                        ['selection', "snap_tresh", 10],
++                        ['selection', 'sel_area_opacty', 50],
++                        ['ellipses', 'show_ellips', True],
++        for init in initSettings:
++            UserSettings.ReadSettingsFile()
++            UserSettings.Append(dict = UserSettings.userSettings,
++                                    group ='scatt',
++                                    key = init[0],
++                                    subkey =init[1],
++                                    value = init[2],
++                                    overwrite = False)
 +    def OnThreadDone(self, event):
 +        if event.exception:
@@ -5798,21 +4211,23 @@
 +    def SetData(self, bands):
 +        "setting datas"
 +        self.CleanUp()
 +        self.data_set = False
 +        if self.show_add_scatt_plot:
 +            self.tasks_pids['set_data_add'] = self.thread.GetId()
-+            print 'set_data_add'
 +        else:
 +            self.tasks_pids['set_data'] = self.thread.GetId()
-+            print 'set_data'
 +        self.thread.Run(callable=self.core.SetData, bands=bands)
 +    def SetDataDone(self, event):
 +        self.data_set = True
 +        self.iclass_conn.SyncCats()
++    def SettingsUpdated(self, event):
++        #TODO optimization
++        self.RenderScattPlts()
 +    def OnOutput(self, event):
 +        """!Print thread output according to debug level.
@@ -5881,13 +4296,21 @@
 +                continue
 +            scatt_dt = self.scatts_dt.GetScatt(i_scatt_id)
-+            ellipses_dt = self.scatts_dt.GetEllipses(i_scatt_id, cats_attrs)
++            if self._showConfEllipses():
++                ellipses_dt = self.scatts_dt.GetEllipses(i_scatt_id, cats_attrs)
++            else:
++                ellipses_dt = {}
 +            if self.pol_sel_mode[0]:
 +                self._getSelectedAreas(cats, i_scatt_id, scatt_dt, cats_attrs)
 +            scatt.Plot(cats_order = cats, scatts = scatt_dt, ellipses = ellipses_dt, styles = cats_attrs)
++    def _showConfEllipses(self):
++                                key="ellipses",
++                                subkey="show_ellips")
 +    def _getSelectedAreas(self, cats_order, scatt_id, scatt_dt, cats_attrs):
 +        cat_id = self.cats_mgr.GetSelectedCat()
@@ -5901,8 +4324,18 @@
 +            return
 +        cats_order.append(sel_a_cat_id)
-+        cats_attrs[sel_a_cat_id] = {'color' : "255:255:0",
-+                                    'opacity' : 0.7,
++        col = UserSettings.Get(group='scatt',
++                                 key='selection',
++                                 subkey='sel_area')
++        col = ":".join(map(str, col))
++        opac = UserSettings.Get(group='scatt',
++                                key='selection',
++                                subkey='sel_area_opacty') / 100.0
++        cats_attrs[sel_a_cat_id] = {'color' : col,
++                                    'opacity' : opac,
 +                                    'show' : True}
 +        scatt_dt[sel_a_cat_id] = s[cat_id]
@@ -6408,6 +4841,608 @@
 +            bands = res.split('\n')
 +            self.scatt_mgr.SetData(bands)
+Index: gui/wxpython/vnet/dialogs.py
+--- gui/wxpython/vnet/dialogs.py	(revision 57633)
++++ gui/wxpython/vnet/dialogs.py	(working copy)
+@@ -1218,7 +1218,7 @@
+                       pos = (row, 1))
+         row += 1
+-        gridSizer.Add(item = self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
++        gridSizer.Add(item=self.settings["invert_colors"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+         styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+Index: gui/wxpython/vnet/toolbars.py
+--- gui/wxpython/vnet/toolbars.py	(revision 57633)
++++ gui/wxpython/vnet/toolbars.py	(working copy)
+@@ -19,9 +19,9 @@
+ import wx
+-from icon              import MetaIcon
++from icons.icon import MetaIcon
+ from gui_core.toolbars import BaseToolbar, BaseIcons
+-from core.gcmd         import RunCommand
++from core.gcmd import RunCommand
+ from core.utils import _
+ class PointListToolbar(BaseToolbar):
+Index: gui/wxpython/Makefile
+--- gui/wxpython/Makefile	(revision 57633)
++++ gui/wxpython/Makefile	(working copy)
+@@ -13,7 +13,7 @@
+ 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
+ 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
+ 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
+-	vnet/*.py web_services/*.py wxplot/*.py) \
++	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
+ 	gis_set.py gis_set_error.py wxgui.py README
+ DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
+@@ -21,8 +21,9 @@
+ PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
+ 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
+-	mapswipe vdigit wxplot web_services rlisetup vnet timeline)
++	mapswipe vdigit wxplot web_services rlisetup vnet timeline scatt_plot)
+ DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
+ default: $(DSTFILES)
+Index: gui/wxpython/vdigit/wxdigit.py
+--- gui/wxpython/vdigit/wxdigit.py	(revision 57633)
++++ gui/wxpython/vdigit/wxdigit.py	(working copy)
+@@ -17,7 +17,7 @@
+ (and NumPy would be an excellent candidate for acceleration via
+ e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
+-(C) 2007-2011 by the GRASS Development Team
++(C) 2007-2011, 2013 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+@@ -27,6 +27,8 @@
+ import grass.script.core as grass
++from grass.pydispatch.signal import Signal
+ from core.gcmd        import GError
+ from core.debug       import Debug
+ from core.settings    import UserSettings
+@@ -176,7 +178,21 @@
+         if self.poMapInfo:
+             self.InitCats()
++        self.emit_signals = False
++        # signals which describes features changes during digitization,
++        # activate them using EmitSignals method
++        #TODO signal for errors?
++        self.featureAdded = Signal('IVDigit.featureAdded')
++        self.areasDeleted = Signal('IVDigit.areasDeleted')
++        self.vertexMoved = Signal('IVDigit.vertexMoved')
++        self.vertexAdded = Signal('IVDigit.vertexAdded')
++        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
++        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
++        self.featuresMoved = Signal('IVDigit.featuresMoved')
++        self.lineEdited = Signal('IVDigit.lineEdited')
+     def __del__(self):
+         Debug.msg(1, "IVDigit.__del__()")
+         Vect_destroy_line_struct(self.poPoints)
+@@ -188,7 +204,12 @@
+             Vect_close(self.poBgMapInfo)
+             self.poBgMapInfo = self.popoBgMapInfo = None
+             del self.bgMapInfo
++    def EmitSignals(self, emit):
++        """!Activate/deactivate signals which describes features changes during digitization.
++        self.emit_signals = emit
+     def CloseBackgroundMap(self):
+         """!Close background vector map"""
+         if not self.poBgMapInfo:
+@@ -394,7 +415,6 @@
+         @return tuple (number of added features, feature ids)
+         layer = self._getNewFeaturesLayer()
+         cat = self._getNewFeaturesCat()
+@@ -419,10 +439,14 @@
+             return (-1, None)
+         self.toolbar.EnableUndo()
+-        return self._addFeature(vtype, points, layer, cat,
+-                                self._getSnapMode(), self._display.GetThreshold())
++        ret = self._addFeature(vtype, points, layer, cat,
++                               self._getSnapMode(), self._display.GetThreshold())
++        if ret[0] > -1 and self.emit_signals:
++            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
++        return ret
+     def DeleteSelectedLines(self):
+         """!Delete selected features
+@@ -434,16 +458,27 @@
+         # collect categories for deleting if requested
+         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
+         catDict = dict()
++        old_bboxs = []
++        old_areas_cats = []
+         if deleteRec:
+             for i in self._display.selected['ids']:
+                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
+                     self._error.ReadLine(i)
+-                cats = self.poCats.contents
+-                for j in range(cats.n_cats):
+-                    if cats.field[j] not in catDict.keys():
+-                        catDict[cats.field[j]] = list()
+-                    catDict[cats.field[j]].append(cats.cat[j])
++                if self.emit_signals:
++                    ret = self._getLineAreaBboxCats(i)
++                    if ret:
++                        old_bboxs += ret[0]
++                        old_areas_cats += ret[1]
++                # catDict was not used -> put into comment
++                #cats = self.poCats.contents
++                #for j in range(cats.n_cats):
++                #    if cats.field[j] not in catDict.keys():
++                #        catDict[cats.field[j]] = list()
++                #    catDict[cats.field[j]].append(cats.cat[j])
+         nlines = Vedit_delete_lines(self.poMapInfo, poList)
+@@ -456,7 +491,10 @@
+                 self._deleteRecords(catDict)
+             self._addChangeset()
++                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
+         return nlines
+     def _deleteRecords(self, cats):
+@@ -512,22 +550,173 @@
+         @return number of deleted
++        if len(self._display.selected['ids']) < 1:
++            return 0
+         nareas = 0
++        old_bboxs = []
+         for i in range(cList.n_values):
+             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
+                 continue
++                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
++                if area > 0:
++                    bbox, cats = self._getaAreaBboxCats(area)
++                    old_bboxs += bbox
++                    old_areas_cats += cats
+             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
+         if nareas > 0:
++                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
++        return nareas
++    def _getLineAreaBboxCats(self, ln_id):
++        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
++        if ltype == GV_CENTROID:
++            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
++            return self._getCentroidAreaBboxCats(ln_id)
++        else:
++            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
++    def _getCentroidAreaBboxCats(self, centroid):
++        if not Vect_line_alive(self.poMapInfo, centroid):
++            return None
++        area = Vect_get_centroid_area(self.poMapInfo, centroid)
++        if area > 0:
++            return self._getaAreaBboxCats(area)
++        else:
++            return None
++    def _getaAreaBboxCats(self, area):
++        po_b_list = Vect_new_list()
++        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
++        b_list = po_b_list.contents
++        geoms = []
++        areas_cats = []
++        if b_list.n_values > 0:
++            for i_line in range(b_list.n_values):
++                line = b_list.value[i_line];
++                geoms.append(self._getBbox(abs(line)))
++                areas_cats.append(self._getLineAreasCategories(abs(line)))
+-        return nareas
++        Vect_destroy_list(po_b_list);
++        return geoms, areas_cats
++    def _getLineAreasCategories(self, ln_id):
++        if not Vect_line_alive (self.poMapInfo, ln_id):
++            return []
++        if ltype != GV_BOUNDARY:
++            return []
++        cats = [None, None]
++        left = c_int()
++        right = c_int()
++        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
++            areas = [left.value, right.value]
++            for i, a in enumerate(areas):
++                if a > 0:
++                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
++                    if centroid <= 0:
++                        continue
++                    c = self._getCategories(centroid)
++                    if c:
++                        cats[i] = c
++        return cats
++    def _getCategories(self, ln_id):
++            return none
++        poCats = Vect_new_cats_struct()
++        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
++            Vect_destroy_cats_struct(poCats)
++            return None
++        cCats = poCats.contents
++        cats = {}
++        for j in range(cCats.n_cats):
++            if cats.has_key(cCats.field[j]):
++                cats[cCats.field[j]].append(cCats.cat[j])
++            else:
++                cats[cCats.field[j]] = [cCats.cat[j]]
++        return cats
++    def _getBbox(self, ln_id):
++            return None
++        poPoints = Vect_new_line_struct()
++        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
++            Vect_destroy_line_struct(poPoints)
++            return []
++        geom = self._convertGeom(poPoints)
++        bbox = self._createBbox(geom)
++        return bbox
++    def _createBbox(self, points):
++        bbox = {}
++        for pt in points:
++            if not bbox.has_key('maxy'):
++                bbox['maxy'] = pt[1]
++                bbox['miny'] = pt[1]
++                bbox['maxx'] = pt[0]
++                bbox['minx'] = pt[0]
++                continue
++            if   bbox['maxy'] < pt[1]:
++            elif bbox['miny'] > pt[1]:
++            if   bbox['maxx'] < pt[0]:
++            elif bbox['minx'] > pt[0]:
++        return bbox
++    def _convertGeom(self, poPoints):
++        Points = poPoints.contents
++        pts_geom = []
++        for j in range(Points.n_points):
++            pts_geom.append((Points.x[j], Points.y[j]))
++        return pts_geom
+     def MoveSelectedLines(self, move):
+         """!Move selected features
+@@ -536,16 +725,45 @@
+         if not self._checkMap():
+             return -1
++        nsel = len(self._display.selected['ids'])
++        if nsel < 1:
++            return -1
+         thresh = self._display.GetThreshold()
+         snap   = self._getSnapMode()
++            old_bboxs = []
++            for sel_id in self._display.selected['ids']:
++                ret = self._getLineAreaBboxCats(sel_id)
++                if ret:
++            Vect_set_updated(self.poMapInfo, 1)
++            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
+         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList,
+                                   move[0], move[1], 0,
+                                   snap, thresh)
+         Vect_destroy_list(poList)
++        if nlines > 0 and self.emit_signals:
++            new_bboxs = []
++            new_areas_cats = []
++            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
++            for i in range(n_up_lines_old, n_up_lines):
++                new_id = Vect_get_updated_line(self.poMapInfo, i)
++                ret = self._getLineAreaBboxCats(new_id)
++                if ret:
++                    new_bboxs += ret[0]
++                    new_areas_cats += ret[1]
+         if nlines > 0 and self._settings['breakLines']:
+             for i in range(1, nlines):
+                 self._breakLineAtIntersection(nlines + i, None, changeset)
+@@ -553,7 +771,13 @@
+         if nlines > 0:
++                self.featuresMoved.emit(new_bboxs = new_bboxs,
++                                        old_bboxs = old_bboxs,
++                                        old_areas_cats = old_areas_cats,
++                                        new_areas_cats = new_areas_cats)
+         return nlines
+     def MoveSelectedVertex(self, point, move):
+@@ -571,12 +795,21 @@
+         if len(self._display.selected['ids']) != 1:
+             return -1
++        # move only first found vertex in bbox
++        poList = self._display.GetSelectedIList()
++            cList = poList.contents
++            old_bboxs = [self._getBbox(cList.value[0])]
++            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
+         Vect_reset_line(self.poPoints)
+         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
+-        # move only first found vertex in bbox
+-        poList = self._display.GetSelectedIList()
+         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList, self.poPoints,
+                                   self._display.GetThreshold(type = 'selectThresh'),
+@@ -584,7 +817,17 @@
+                                   move[0], move[1], 0.0,
+                                   1, self._getSnapMode())
++        if moved > 0 and self.emit_signals:
++            new_bboxs = []
++                new_bboxs.append(self._getBbox(new_id))
++                new_areas_cats.append(self._getLineAreasCategories(new_id))
+         if moved > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
+                                           None)
+@@ -592,7 +835,13 @@
+         if moved > 0:
++                self.vertexMoved.emit(new_bboxs = new_bboxs,
++                                      new_areas_cats = new_areas_cats,
++                                      old_bboxs = old_bboxs)
+         return moved
+     def AddVertex(self, coords):
+@@ -681,6 +930,10 @@
+             self._error.ReadLine(line)
+             return -1
++            old_bboxs = [self._getBbox(line)]
++            old_areas_cats = [self._getLineAreasCategories(line)]
+         # build feature geometry
+         for p in coords:
+@@ -696,6 +949,9 @@
+         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
+                                     self.poPoints, self.poCats)
++        if newline > 0 and self.emit_signals:
++            new_geom = [self._getBbox(newline)]
++            new_areas_cats = [self._getLineAreasCategories(newline)]
+         if newline > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(newline, None)
+@@ -703,7 +959,13 @@
+         if newline > 0:
++                self.lineEdited.emit(old_bboxs = old_bboxs,
++                                     new_bboxs = new_bboxs,
+         return newline
+     def FlipLine(self):
+@@ -1514,6 +1776,16 @@
+             return 0
+         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
+@@ -1525,15 +1797,35 @@
+         else:
+             ret = Vedit_remove_vertex(self.poMapInfo, poList,
+                                       self.poPoints, thresh)
++        if ret > 0 and self.emit_signals:
++            new_bboxs = []
+         if not add and ret > 0 and self._settings['breakLines']:
+                                           None)
+         if ret > 0:
++            if add:
++                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
++            else:
++                self.vertexRemoved.emit(old_bboxs = old_bboxs,
+         return 1
+     def GetLineCats(self, line):
+Index: gui/wxpython/vdigit/toolbars.py
+--- gui/wxpython/vdigit/toolbars.py	(revision 57633)
++++ gui/wxpython/vdigit/toolbars.py	(working copy)
+@@ -17,6 +17,7 @@
+ import wx
+ from grass.script import core as grass
+ from gui_core.dialogs   import CreateNewVector
+@@ -42,6 +43,8 @@
+         self.digit         = None
+         self._giface       = giface
++        self.editingStarted = Signal("VDigitToolbar.editingStarted")
+         # currently selected map layer for editing (reference to MapLayer instance)
+         self.mapLayer = None
+         # list of vector layers from Layer Manager (only in the current mapset)
+@@ -860,6 +863,7 @@
+             alpha = int(opacity * 255)
+             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
++        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
+         return True
+     def StopEditing(self):
 Index: gui/icons/grass/polygon.png
 Cannot display: file marked as a binary type.
@@ -6423,3 +5458,1232 @@
 ## -0,0 +1 ##
 +application/octet-stream
 \ No newline at end of property
+Index: lib/imagery/scatt_sccats.c
+--- lib/imagery/scatt_sccats.c	(revision 0)
++++ lib/imagery/scatt_sccats.c	(working copy)
+@@ -0,0 +1,405 @@
++   \file lib/imagery/scatt_cat_rast.c
++   \brief Imagery library - functions for manipulation with scatter plot structs.
++   Copyright (C) 2013 by the GRASS Development Team
++   This program is free software under the GNU General Public License
++   (>=v2).  Read the file COPYING that comes with GRASS for details.
++   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++   \brief Compute band ids from scatter plot id.
++    Scatter plot id describes which bands defines the scatter plot.
++    Let say we have 3 bands, their ids are 0, 1 and 2.
++    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
++    All scatter plots:
++    scatt_id b_1_id b_2_id
++    0        0      1
++    1        0      2
++    2        1      2
++   \param scatt_id scatter plot id
++   \param n_bands number of bands
++   \param [out] b_1_id id of band1
++   \param[out] b_2_id id of band2
++   \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++    int n_b1 = n_bands - 1;
++    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++    return 0;
++   \brief Compute scatter plot id from band ids.
++    See also I_id_scatt_to_bands().
++   \param b_1_id id of band1
++   \param b_1_id id of band2
++   \param [out] scatt_id scatter plot id
++   \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++    return 0;
++   \brief Initialize structure for storing scatter plots data.
++   \param cats pointer to scCats struct
++   \param type SC_SCATT_DATA - stores scatter plots
++   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
++    int i_cat;
++    cats->type = type;
++    cats->n_cats = 100;
++    cats->n_a_cats = 0;
++    cats->n_bands = n_bands;
++    cats->n_scatts = (n_bands - 1) * n_bands / 2;
++    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
++    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
++    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++        cats->cats_idxs[i_cat] = -1;
++    return;
++   \brief Free data of struct scCats, the structure itself remains alocated.
++   \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++    int i_cat;
++    for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
++        if(cats->cats_arr[i_cat])
++            G_free(cats->cats_arr[i_cat]->scatt_idxs);
++            G_free(cats->cats_arr[i_cat]->scatts_bands);
++            G_free(cats->cats_arr[i_cat]->scatts_arr);
++            G_free(cats->cats_arr[i_cat]);
++    G_free(cats->cats_ids);
++    G_free(cats->cats_idxs);
++    G_free(cats->cats_arr);
++    cats->n_cats = 0;
++    cats->n_bands = 0;
++    cats->n_scatts = 0;
++    cats->type = -1;
++    return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++    a_cats_ids = cats->cats_ids;
++    * n_a_cats = cats->n_a_cats;
++#endif
++   \brief Add category.
++    Category represents group of scatter plots.
++   \return assigned category id (starts with 0)
++   \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++    int i_scatt, i_cat_id, cat_id;
++    int n_a_cats = cats->n_a_cats;
++    if(cats->n_a_cats >= cats->n_cats)
++        return -1;
++    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++        if(cats->cats_idxs[i_cat_id] < 0) {
++            cat_id = i_cat_id;
++            break;
++    cats->cats_ids[n_a_cats] = cat_id;
++    cats->cats_idxs[cat_id] = n_a_cats;
++    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++    ++cats->n_a_cats;
++    return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
++    int cat_idx, i_cat;
++    if(cat_id < 0 || cat_id >= cats->n_cats)
++        return -1;
++    cat_idx = cats->cats_idxs[cat_id];
++    if(cat_idx < 0)
++        return -1;
++    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++    G_free(cats->cats_arr[cat_idx]->scatts_bands);
++    G_free(cats->cats_arr[cat_idx]->scatts_arr);
++    G_free(cats->cats_arr[cat_idx]);
++    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++    cats->cats_idxs[cat_id] = -1;
++    --cats->n_a_cats;
++    return 0;
++#endif
++   \brief Insert scatter plot data .
++    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
++   \param cat_id id number of category.
++   \param scatt_id id number of scatter plot.
++   \return  0 on success
++   \return -1 on failure
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int band_1, band_2, cat_idx, n_a_scatts;
++    struct scScatts * scatts;
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++        return -1;
++    scatts = cats->cats_arr[cat_idx];
++    if(scatts->scatt_idxs[scatt_id] >= 0)
++        return -1;
++    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++        return -1;
++    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++        return -1;
++    n_a_scatts = scatts->n_a_scatts;
++    scatts->scatt_idxs[scatt_id] = n_a_scatts;
++    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++    scatts->scatts_bands[n_a_scatts * 2] = band_1;
++    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++    scatts->scatts_arr[n_a_scatts] = scatt_data;
++    ++scatts->n_a_scatts;
++    return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++    if(cat_id < 0 && cat_id >= cats->n_cats)
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++        return -1;
++    if(scatts->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_data = scatts->scatts_arr[scatt_idx];
++    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++    scatts->scatt_idxs[scatt_id] = -1;
++    scatt_data = scatts->scatts_arr[scatt_id];
++    scatts->n_a_scatts--;
++    return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++    int cat_idx, scatt_idx, ret;
++    if(cat_idx < 0)
++        return -1;
++    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++    return 0;
++#endif
++   \brief Insert scatter plot data.
++   \param scatt_data pointer to existing struct scdScattData
++   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++   \param n_vals number of data values
++   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++    scatt_data->n_vals = n_vals;
++    if(type == SC_SCATT_DATA)
++        if(data)
++            scatt_data->scatt_vals_arr = (unsigned int *) data;
++        else {
++            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++        scatt_data->b_conds_arr = NULL;
++    else if(type == SC_SCATT_CONDITIONS)
++        if(data)
++            scatt_data->b_conds_arr = (unsigned char *) data;
++        else {
++            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++        scatt_data->scatt_vals_arr = NULL;
++    return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++    return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++    if(!scatt_data->b_conds_arr)
++        return scatt_data->b_conds_arr;
++    else if(!scatt_data->scatt_vals_arr)
++        return scatt_data->scatt_vals_arr;
++    return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
++        return -1;
++    if(scatt_data->b_conds_arr)
++        scatt_data->b_conds_arr[val_idx] = val;
++    else if(scatt_data->scatt_vals_arr)
++        scatt_data->scatt_vals_arr[val_idx] = val;
++    else
++        return -1;
++    return 0;
++#endif
+Index: lib/imagery/scatt.c
+--- lib/imagery/scatt.c	(revision 0)
++++ lib/imagery/scatt.c	(working copy)
+@@ -0,0 +1,799 @@
++   \file lib/imagery/scatt.c
++   \brief Imagery library - functions for wx Scatter Plot Tool.
++   Low level functions used by wx Scatter Plot Tool.
++#include <grass/glocale.h>
++#include <math.h>
++struct rast_row
++    CELL * row;
++    char * null_row;
++    struct Range rast_range; /*Range of whole raster.*/
++   \brief Create pgm header.
++   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
++   \param region region to be pgm header generated for
++   \param [out] header header of pgm file
++static int get_cat_rast_header(struct Cell_head * region, char * header){
++    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
++   \brief Create category raster conditions file.
++   \param cat_rast_region region to be file generated for
++   \param cat_rast path of generated category raster file
++int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
++    FILE * f_cat_rast;
++    char cat_rast_header[1024];//TODO magic number
++    int i_row, i_col;
++    int head_nchars;
++    unsigned char * row_data;
++    f_cat_rast = fopen(cat_rast, "wb");
++    if(!f_cat_rast) {
++        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
++        return -1;
++    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
++    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
++    if (ferror(f_cat_rast)){
++        fclose(f_cat_rast);
++        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
++        return -1;
++    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
++    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
++        row_data[i_col] = 0 & 255;
++    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
++        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
++            return -1;
++    return 0;
++static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
++    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
++               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
++   \brief Find intersection region of two regions.
++   \param A pointer to intersected region
++   \param B pointer to intersected region
++   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
++   \return  0 if interection exists
++   \return -1 if regions does not intersect
++static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
++    if(B->north < A->south) return -1;
++    else if(B->north > A->north) intersec->north = A->north;
++    else intersec->north = B->north;
++    if(B->south > A->north) return -1;
++    else if(B->south < A->south) intersec->south = A->south;
++    else intersec->south = B->south;
++    if(B->east < A->west) return -1;
++    else if(B->east > A->east) intersec->east = A->east;
++    else intersec->east = B->east;
++    if(B->west > A->east) return -1;
++    else if(B->west < A->west) intersec->west = A->west;
++    else intersec->west = B->west;
++    if(intersec->north == intersec->south) return -1;
++    if(intersec->east == intersec->west) return -1;
++    return 0;
++   \brief Get rows and cols numbers, which defines intersection of the regions.
++   \param B pointer to intersected region (A and B must have same resolution)
++   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
++   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
++   \return -1 if regions do not intersect
++   \return -2 resolution of regions is not same
++static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
++    float ns_res, ew_res;
++    struct Cell_head intersec;
++    /* TODO is it right check? */
++    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
++        return -2;
++    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
++        return -2;
++    ns_res = A->ns_res;
++    ew_res = A->ew_res;
++    if(regions_intersecion(A, B, &intersec) == -1)
++        return -1;
++    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
++    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
++    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
++    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
++    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
++    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
++    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
++    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
++    return 0;
++   \brief Insert raster map patch into pgm file.
++   \param patch_rast name of raster map
++   \param cat_rast_region region of category raster file
++   \param cat_rast path to category raster file
++int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
++    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
++    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
++    int head_nchars, ret;
++    int fd_patch_rast, init_shift, step_shift;
++    unsigned char * patch_data;
++    char * null_chunk_row;
++    const char *mapset;
++    struct Cell_head patch_lines, cat_rast_lines;
++    f_cat_rast = fopen(cat_rast, "rb+");
++        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
++        return -1;
++    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
++        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
++        return -1;
++    Rast_get_cellhd(patch_rast, mapset, &patch_region);
++    Rast_set_window(&patch_region);
++    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
++        return -1;
++    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
++    if(ret == -2) {
++        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
++        Rast_close(fd_patch_rast);
++        return -1;
++    else if (ret == -1){
++        return 0;
++    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
++    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
++    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
++    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
++    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
++        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
++        G_free(null_chunk_row);
++        return -1;
++    step_shift = cat_rast_region->cols - ncols;
++    null_chunk_row =  Rast_allocate_null_buf();
++    for(i_row = 0; i_row < nrows; i_row++) {
++        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
++        for(i_col = 0; i_col < ncols; i_col++) {
++            patch_col = patch_bounds.west + i_col;
++            if(null_chunk_row[patch_col] != 1)
++                patch_data[i_col] = 1 & 255;
++            else {
++                patch_data[i_col] = 0 & 255;
++        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
++            return -1;
++        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
++            return -1;
++    return 0;
++   \brief Updates scatter plots data in category by pixels which meets category conditions.
++   \param bands_rows data represents data describig one row from raster band
++   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
++static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
++    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    char * b_1_null_row,* b_2_null_row;
++    struct rast_row b_1_rast_row, b_2_rast_row;
++    struct Range b_1_range, b_2_range;
++    int b_1_range_size;
++    int row_size = Rast_window_cols();
++    int * scatts_bands = scatts->scatts_bands;
++    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
++        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
++        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
++        b_1_row = b_1_rast_row.row;
++        b_2_row = b_2_rast_row.row;
++        b_1_null_row =  b_1_rast_row.null_row;
++        b_2_null_row =  b_2_rast_row.null_row;
++        b_1_range = b_1_rast_row.rast_range;
++        b_2_range = b_2_rast_row.rast_range;
++        b_1_range_size = b_1_range.max - b_1_range.min + 1;
++        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
++        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
++            /* pixel does not belongs to scatter plot or has null value in one of the bands */
++            if(!belongs_pix[i_chunk_rows_pix] ||
++                b_1_null_row[i_chunk_rows_pix] == 1 ||
++                b_2_null_row[i_chunk_rows_pix] == 1)
++                continue;
++            /* index in scatter plot array */
++            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
++            if(array_idx < 0 || array_idx >= max_arr_idx) {
++                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
++                continue;
++            /* increment scatter plot value */
++            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
++   \brief Computes scatter plots data from chunk_rows.
++   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
++   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
++   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
++   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
++   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
++   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
++   \param region analysis region
++static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
++                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
++                                                struct scCats * scatts, int * fd_cats_rasts)
++    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
++    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
++    CELL * cat_rast_row;
++    struct scScatts * scatts_conds;
++    struct scScatts * scatts_scatt_plts;
++    struct scdScattData * conds;
++    int * scatts_bands;
++    struct scdScattData ** scatts_arr;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    unsigned char * i_scatt_conds;
++    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
++    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
++    cat_rast_row =  Rast_allocate_c_buf();
++    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
++        scatts_conds = scatt_conds->cats_arr[i_cat];
++        cat_id = scatt_conds->cats_ids[i_cat];
++        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
++        if(scatt_plts_cat_idx < 0)
++            continue;
++        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
++        G_zero(belongs_pix, row_size * sizeof(unsigned short));
++        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
++        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
++            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
++                /* all pixels belongs */
++                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
++                    belongs_pix[i_rows_pix] = 1;
++        /* compute belonging pixels for defined conditions */
++        else
++            scatts_bands = scatts_conds->scatts_bands;
++            /* check conditions from category raster condtitions file */
++            if(f_cats_rasts_conds[i_cat]) {
++                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
++                if (ferror(f_cats_rasts_conds[i_cat]))
++                    G_free(rast_pixs);
++                    G_free(belongs_pix);
++                    G_warning(_("Unable to read from category raster condtition file."));
++                    return -1;
++                if (n_pixs != n_pixs) {
++                    G_warning(_("Invalid size of category raster conditions file."));
++                    return -1;
++                    if(rast_pixs[i_rows_pix] != 0 & 255)
++            /* check condtions defined in scatter plots*/
++            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
++                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
++                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
++                    if(belongs_pix[i_rows_pix] ||
++                       b_1_null_row[i_rows_pix] == 1 ||
++                       b_2_null_row[i_rows_pix] == 1)
++                        continue;
++                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
++                        continue;
++                    /* pixels meets condtion defined in scatter plot */
++                    if(i_scatt_conds[array_idx])
++        /* update category raster with belonging pixels */
++        if(fd_cats_rasts[i_cat] >= 0) {
++            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
++                if(belongs_pix[i_rows_pix])
++                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
++            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
++        /* update scatter plots with belonging pixels */
++        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
++    G_free(cat_rast_row);
++    return 0;
++   \brief Get list if bands needed to be opened for analysis from scCats struct.
++static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
++    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
++    int i_cat, i_scatt, cat_id;
++        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
++            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
++    return;
++   \brief Helper function for clean up.
++static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
++                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
++    int i, band_id;
++    for(i = 0; i < n_a_bands; i++)
++        band_id = bands_ids[i];
++        if(band_id >= 0) {
++            Rast_close(fd_bands[i]);
++            G_free(bands_rows[band_id].row);
++            G_free(bands_rows[band_id].null_row);
++    if(f_cats_rasts_conds)
++        for(i = 0; i < n_a_cats; i++)
++            if(f_cats_rasts_conds[i])
++                fclose(f_cats_rasts_conds[i]);
++    if(fd_cats_rasts)
++            if(fd_cats_rasts[i] >= 0)
++                Rast_close(fd_cats_rasts[i]);
++   \brief Compute scatter plots data.
++    If category has not defined no category raster condition file and no scatter plot with consdtion,
++    default scatter plot is computed.
++   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
++   \param region function calls Rast_set_window for this region
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
++   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
++   \param cats_rasts_conds index in array represents corresponding category id
++   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
++   \param bands names of analyzed bands, order of bands is defined by their id
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
++int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
++                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
++    char header[1024];
++    int fd_cats_rasts[scatt_conds->n_a_cats];
++    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
++    struct rast_row bands_rows[n_bands];
++    RASTER_MAP_TYPE data_type;
++    int nrows, i_band, n_a_bands, band_id,
++        i, i_row, head_nchars, i_cat, id_cat;
++    int fd_bands[n_bands];
++    int bands_ids[n_bands];
++    int b_needed_bands[n_bands];
++    Rast_set_window(region);
++    for(i_band = 0; i_band < n_bands; i_band++)
++        fd_bands[i_band] = -1;
++        bands_ids[i_band] = -1;
++    if (n_bands != scatts->n_bands ||
++        n_bands != scatt_conds->n_bands)
++        return -1;
++    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
++    get_needed_bands(scatt_conds, &b_needed_bands[0]);
++    get_needed_bands(scatts, &b_needed_bands[0]);
++    n_a_bands = 0;
++    /* open band rasters, which are needed for computation */
++    for(band_id = 0; band_id < n_bands; band_id++)
++        if(b_needed_bands[band_id])
++            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
++            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
++                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
++                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
++                return -1;
++            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
++                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
++                return -1;
++            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
++            if(data_type != CELL_TYPE) {
++                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
++                return -1;
++            bands_rows[band_id].row =  Rast_allocate_c_buf();
++            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
++            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
++                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
++                return -1;
++            bands_ids[n_a_bands] = band_id;
++            ++n_a_bands;
++    /* open category rasters condition files and category rasters */
++    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
++        id_cat = scatts->cats_ids[i_cat];
++        if(cats_rasts[id_cat]) {
++            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
++        else
++            fd_cats_rasts[i_cat] = -1;
++        if(cats_rasts_conds[id_cat]) {
++            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
++            if(!f_cats_rasts_conds[i_cat]) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
++                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
++                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
++                return -1;
++        else
++            f_cats_rasts_conds[i_cat] = NULL;
++    head_nchars =  get_cat_rast_header(region, header);
++            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
++                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
++                return -1;
++    nrows = Rast_window_rows();
++    /* analyze bands by rows */
++    for (i_row = 0; i_row < nrows; i_row++)
++        for(i_band = 0; i_band < n_a_bands; i_band++)
++            band_id = bands_ids[i_band];
++            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
++            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
++        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
++            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
++                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
++            return -1;
++                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
++    return 0;
++int I_merge_arrays(unsigned char *  merged_arr, unsigned char *  overlay_arr, unsigned rows, unsigned cols, double alpha)
++    unsigned int i_row, i_col, i_b;
++    unsigned int row_idx, col_idx, idx;
++    unsigned int c_a_i, c_a;
++    for(i_row = 0; i_row < rows; i_row++)
++        row_idx = i_row * cols;
++        for(i_col = 0; i_col < cols; i_col++)
++                col_idx = 4 * (row_idx + i_col);
++                idx = col_idx + 3;
++                c_a = overlay_arr[idx] * alpha;
++                c_a_i = 255 - c_a;
++                merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * 255) / 255;
++                for(i_b = 0; i_b < 3; i_b++)
++                    idx = col_idx + i_b;
++                    merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * (int)overlay_arr[idx]) / 255;
++    return 0;
++int I_apply_colormap(unsigned char * vals, unsigned char * vals_mask, unsigned vals_size, unsigned char * colmap, unsigned char * col_vals){
++    unsigned int i_val;
++    int v, i, i_cm;
++    for(i_val = 0; i_val < vals_size; i_val++){
++        i_cm = 4 * i_val;
++        v = vals[i_val];
++        if(vals_mask[i_val])
++            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[258 * 4 + i];
++        else if(v > 255)
++            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[257 * 4 + i];
++        else if(v < 0)
++            for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[256 * 4 + i];
++        else
++            for(i = 0; i < 4; i++){ col_vals[i_cm + i] = colmap[v * 4 + i];
++    return 0;
+Index: lib/vector/Vlib/open.c
+--- lib/vector/Vlib/open.c	(revision 57633)
++++ lib/vector/Vlib/open.c	(working copy)
+@@ -240,7 +240,9 @@
+         else {
+             char file_path[GPATH_MAX];
++            /* reduce to current mapset if search path was set */
++            if(strcmp(Map->mapset, "") == 0)
++                Map->mapset = G_store(G_mapset());
+             /* temporary map: reduce to current mapset if search path
+              * was set */
+             if (strcmp(Map->mapset, "") == 0)
