[GRASS-SVN] r57684 - grass/branches/releasebranch_6_4/lib/db/dbmi_client
Fri Sep 13 22:59:09 PDT 2013
Author: hamish
Date: 2013-09-13 22:59:09 -0700 (Fri, 13 Sep 2013)
New Revision: 57684
   grass/branches/releasebranch_6_4/lib/db/dbmi_client/copy_tab.c
avoid 'format not a string literal and no format arguments' warnings (merge r57353 from devbr6)
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_client/copy_tab.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_client/copy_tab.c	2013-09-14 05:56:11 UTC (rev 57683)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_client/copy_tab.c	2013-09-14 05:59:09 UTC (rev 57684)
@@ -193,7 +193,7 @@
 	db_append_string(&sql, " where 0 = 1");	/* to get no data */
-    G_debug(3, db_get_string(&sql));
+    G_debug(3, "db__copy_table: %s", db_get_string(&sql));
     if (db_open_select_cursor(from_driver, &sql, &cursor, DB_SEQUENTIAL) !=
 	DB_OK) {
 	G_warning(_("Unable to open select cursor: '%s'"),
@@ -270,7 +270,7 @@
 	DB_OK) {
@@ -361,7 +361,7 @@
 	if (!select)
 	    continue;
 	db_append_string(&sql, ")");
 	if (db_execute_immediate(to_driver, &sql) != DB_OK) {
 	    G_warning("Unable to insert new record: '%s'",
