[GRASS-SVN] r57717 - grass/trunk/display/d.barscale
Mon Sep 16 21:52:55 PDT 2013
Author: hamish
Date: 2013-09-16 21:52:55 -0700 (Mon, 16 Sep 2013)
New Revision: 57717
Removed:
   grass/trunk/display/d.barscale/draw_n_arrow.c
   grass/trunk/display/d.barscale/d.barscale.html
   grass/trunk/display/d.barscale/main.c
   grass/trunk/display/d.barscale/options.h
remove north arrow code (now in d.northarrow), bugfix font size scanning to allow sub-integer sizes
Modified: grass/trunk/display/d.barscale/d.barscale.html
--- grass/trunk/display/d.barscale/d.barscale.html	2013-09-17 04:44:05 UTC (rev 57716)
+++ grass/trunk/display/d.barscale/d.barscale.html	2013-09-17 04:52:55 UTC (rev 57717)
@@ -2,17 +2,12 @@
 <em>d.barscale</em> displays a barscale on the graphics monitor at the
 given screen coordinates. If no coordinates are given it will draw the
-barscale in the bottom left of the display. It can draw the scale or
-north arrow in a number of styles (see
-the <a href="http://grasswiki.osgeo.org/wiki/Cartography#Display_monitors">wiki
+barscale in the bottom left of the display. It can draw the scale in a
+number of styles (see the
+ <a href="http://grasswiki.osgeo.org/wiki/Cartography#Display_monitors">wiki
 page</a> for details).
-<p>
-If the <b>-n</b> flag is given, <em>d.barscale</em> draws a north arrow
-instead of a barscale. The style of north arrow can be controlled using
-the <b>north_arrow</b> parameter.
 <h2>NOTE</h2>
 <em>d.barscale</em> will not work in Lat/Lon locations as the horizontal
@@ -26,9 +21,11 @@
 <a href="d.graph.html">d.graph</a>,
 <a href="d.grid.html">d.grid</a>,
 <a href="d.legend.html">d.legend</a>,
+<a href="d.northarrow.html">d.northarrow</a>,
 <a href="g.region.html">g.region</a>
 </em>
 <h2>AUTHOR</h2>
 unknown, but from USACE/CERL.<br>
Deleted: grass/trunk/display/d.barscale/draw_n_arrow.c
--- grass/trunk/display/d.barscale/draw_n_arrow.c	2013-09-17 04:44:05 UTC (rev 57716)
+++ grass/trunk/display/d.barscale/draw_n_arrow.c	2013-09-17 04:52:55 UTC (rev 57717)
@@ -1,144 +0,0 @@
- * draw_n_arrow() places a north arrow somewhere in the display frame
-#include <stdio.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/display.h>
-#include <grass/symbol.h>
-#include <grass/colors.h>
-#include <grass/glocale.h>
-#include "options.h"
-int draw_n_arrow(double east, double north, double fontsize, char *n_arrow_num)
-    double x_pos, y_pos;
-    double t, b, l, r;
-    double tt, tb, tl, tr; /* text box*/
-    SYMBOL *Symb;
-    RGBA_Color *line_color, *fill_color;
-    int R, G, B;
-    double x0, y0;
-    char icon[64];
-    double symbol_size;
-    /* Establish text size */
-    if (fontsize > 0)
-	D_text_size(fontsize, fontsize);
-    D_setup_unity(0);
-    D_get_src(&t, &b, &l, &r);
-    x_pos = east * (r - l) / 100.;
-    y_pos = (100. - north) * (b - t) / 100.;
-    if (fontsize > 0) {
-    	/* draw the "N" */
-    	D_get_text_box("N", &tt, &tb, &tl, &tr);
-    	D_use_color(fg_color);
-    	/* positions manually tuned */
-    	switch (n_arrow_num[0]) {
-    	case '1':
-    	    D_pos_abs(x_pos - (tr + tl) / 2, y_pos - 45);
-    	    D_text("N");
-    	    break;
-    	case '3':
-    	    D_pos_abs(x_pos - (tr + tl) / 2, y_pos - 60);
-    	    D_text("N");
-    	    break;
-    	case '4':
-    	    D_text("N");
-    	    break;
-    	case '7':
-    	    D_pos_abs(x_pos - (tr + tl) / 2, y_pos - 70);
-    	    D_text("N");
-    	    break;
-    	case '9':
-    	    D_pos_abs(x_pos - (tr + tl) / 2, y_pos - 55);
-    	    D_text("N");
-    	case '2':
-    	case '5':
-    	case '6':
-    	case '8':
-    	    break;
-    	default:
-    	    G_fatal_error(_("Could not parse symbol"));
-    /* display the north arrow symbol */
-    line_color = G_malloc(sizeof(RGBA_Color));
-    fill_color = G_malloc(sizeof(RGBA_Color));
-    if (D_color_number_to_RGB(fg_color, &R, &G, &B) == 0)
-    	/* fall back to black on failure */
-    	G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
-    line_color->r = (unsigned char)R;
-    line_color->g = (unsigned char)G;
-    line_color->b = (unsigned char)B;
-    line_color->a = RGBA_COLOR_OPAQUE;
-    fill_color->r = (unsigned char)R;
-    fill_color->g = (unsigned char)G;
-    fill_color->b = (unsigned char)B;
-    fill_color->a = RGBA_COLOR_OPAQUE;
-    if (n_arrow_num[0] == '2' || n_arrow_num[0] == '9')
-    	fill_color->a = RGBA_COLOR_TRANSPARENT;
-    /* sizes manually tuned */
-    case '1':
-    	symbol_size = 35.;
-    	break;
-    case '2':
-    	symbol_size = 19.;
-    	break;
-    case '3':
-    	symbol_size = 20.;
-    	break;
-    case '4':
-    	symbol_size = 15.;
-    	break;
-    case '5':
-    case '6':
-    	symbol_size = 14.;
-    	break;
-    case '7':
-    	symbol_size = 23.;
-    	break;
-    case '8':
-    case '9':
-    	symbol_size = 17.;
-    	break;
-    default:
-    x0 = D_d_to_u_col(x_pos);
-    y0 = D_d_to_u_row(y_pos);
-    strcpy(icon, "n_arrows/n_arrow");
-    strncat(icon, n_arrow_num, 32);
-    Symb = S_read(icon);
-    if(!Symb)
-    	G_fatal_error(_("Could not read symbol \"%s\""), icon);
-    S_stroke(Symb, symbol_size, 0.0, 0);
-    D_symbol(Symb, x0, y0, line_color, fill_color);
-    G_free(Symb);
-    G_free(line_color);
-    G_free(fill_color);
-    return 0;
Modified: grass/trunk/display/d.barscale/main.c
--- grass/trunk/display/d.barscale/main.c	2013-09-17 04:44:05 UTC (rev 57716)
+++ grass/trunk/display/d.barscale/main.c	2013-09-17 04:52:55 UTC (rev 57717)
@@ -13,7 +13,7 @@
  *               Jan-Oliver Wagner <jan intevation.de>
  *		 Major rewrite for GRASS 7 by Hamish Bowman, June 2013
- * PURPOSE:      Displays a barscale or north arrow on graphics monitor
+ * PURPOSE:      Displays a barscale on graphics monitor
  * COPYRIGHT:    (C) 1999-2013 by the GRASS Development Team
@@ -40,8 +40,8 @@
     struct GModule *module;
     struct Option *bg_color_opt, *fg_color_opt, *coords, *fsize,
-		 *barstyle, *text_placement, *n_arrow;
-    struct Flag *feet, *northarrow, *no_text;
+		 *barstyle, *text_placement;
+    struct Flag *feet, *no_text;
     struct Cell_head W;
     double east, north;
     double fontsize;
@@ -53,17 +53,12 @@
     module = G_define_module();
     G_add_keyword(_("display"));
     G_add_keyword(_("cartography"));
-    module->description = _("Displays a barscale or north arrow on the graphics monitor.");
+    module->description = _("Displays a barscale on the graphics monitor.");
     feet = G_define_flag();
     feet->key = 'f';
     feet->description = _("Use feet/miles instead of meters");
-    northarrow = G_define_flag();
-    northarrow->key = 'n';
-    northarrow->description = _("Draw a north arrow only");
-    northarrow->guisection = _("Style");
     no_text = G_define_flag();
     no_text->key = 't';
     no_text->description = _("Draw the scale bar without text");
@@ -89,7 +84,7 @@
     coords->description = _("(0,0) is lower-left of the display frame");
     fg_color_opt = G_define_standard_option(G_OPT_C_FG);
-    fg_color_opt->label = _("Bar scale, text, and north arrow color");
+    fg_color_opt->label = _("Bar scale and text color");
     fg_color_opt->guisection = _("Colors");
     bg_color_opt = G_define_standard_option(G_OPT_C_BG);
@@ -112,19 +107,12 @@
     fsize->description = _("Font size");
     fsize->guisection = _("Text");
-    n_arrow = G_define_option();
-    n_arrow->key = "north_arrow";
-    n_arrow->description = _("North arrow style (used only with the -n flag)");
-    n_arrow->options = "1a,1b,2,3,4,5,6,7a,7b,8a,8b,9";
-    n_arrow->answer = "1a";
-    n_arrow->guisection = _("Style");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     G_get_window(&W);
-    if (W.proj == PROJECTION_LL && !northarrow->answer)
+    if (W.proj == PROJECTION_LL)
 	G_fatal_error(_("%s does not work with a latitude-longitude location"),
 		      argv[0]);
@@ -171,10 +159,6 @@
 	G_fatal_error(_("Programmer error"));
-    if (northarrow->answer)
-	bar_style = STYLE_NONE;
     switch (text_placement->answer[0]) {
     case 'u':
 	text_position = TEXT_UNDER;
@@ -195,7 +179,7 @@
     sscanf(coords->answers[0], "%lf", &east);
     sscanf(coords->answers[1], "%lf", &north);
-    fontsize = atoi(fsize->answer);
+    fontsize = atof(fsize->answer);
     if (no_text->answer)
 	fontsize = -1;
@@ -214,10 +198,7 @@
     D_setup(0);
-    if (bar_style == STYLE_NONE)
-	draw_n_arrow(east, north, fontsize, n_arrow->answer);
-    else
-	draw_scale(east, north, bar_style, text_position, fontsize);
+    draw_scale(east, north, bar_style, text_position, fontsize);
     D_save_command(G_recreate_command());
Modified: grass/trunk/display/d.barscale/options.h
--- grass/trunk/display/d.barscale/options.h	2013-09-17 04:44:05 UTC (rev 57716)
+++ grass/trunk/display/d.barscale/options.h	2013-09-17 04:52:55 UTC (rev 57717)
@@ -28,6 +28,3 @@
 /* draw_scale.c */
 int draw_scale(double, double, int, int, double);
-/* draw_n_arrow.c */
-int draw_n_arrow(double, double, double, char *);
