[GRASS-SVN] r57721 - grass/trunk/raster/r.water.outlet
Tue Sep 17 00:17:32 PDT 2013
Author: hcho
Date: 2013-09-17 00:17:32 -0700 (Tue, 17 Sep 2013)
New Revision: 57721
   grass/trunk/raster/r.water.outlet/r.water.outlet.html
Corrected parameter names
Modified: grass/trunk/raster/r.water.outlet/r.water.outlet.html
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html	2013-09-17 06:30:05 UTC (rev 57720)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html	2013-09-17 07:17:32 UTC (rev 57721)
@@ -7,7 +7,7 @@
 <h3>Selected Parameters</h3>
 <dl>
-<dt><b>drainage=</b><em>name</em>
+<dt><b>input=</b><em>name</em>
 <dd>Input map: drainage direction. Indicates the "aspect" for each
 cell. Multiplying positive values by 45 will give the direction in
@@ -19,7 +19,7 @@
 direction of flow. This map is generated from
 <em><a href="r.watershed.html">r.watershed</a></em>.
-<dt><b>basin=</b><em>name</em>
+<dt><b>output=</b><em>name</em>
 <dd>Output map: Values of one (1) indicate the watershed
 basin. Values of zero are not in the watershed basin.
@@ -51,8 +51,8 @@
 # the watershed outlet position should be placed on a stream (from
 # accumulation map):
 r.watershed elev_lid792_1m thresh=5000 accum=accum_5K \
-  drain=draindir_5K basin=basin_5K
-r.water.outlet drainage=draindir_5K basin=basin_A30 \
+  drain=draindir_5K output=basin_5K
+r.water.outlet input=draindir_5K output=basin_A30 \
   east=638741.43125 north=220269.7
 d.mon x0
 d.rast accum_5K
