[GRASS-SVN] r57724 - grass/trunk/gui/wxpython/iclass
Tue Sep 17 03:07:31 PDT 2013
Author: turek
Date: 2013-09-17 03:07:31 -0700 (Tue, 17 Sep 2013)
New Revision: 57724
   grass/trunk/gui/wxpython/iclass/dialogs.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iclass/plots.py
   grass/trunk/gui/wxpython/iclass/toolbars.py
wx.iclass: support for any name of subgroup, not just same name as group
Modified: grass/trunk/gui/wxpython/iclass/dialogs.py
--- grass/trunk/gui/wxpython/iclass/dialogs.py	2013-09-17 10:04:24 UTC (rev 57723)
+++ grass/trunk/gui/wxpython/iclass/dialogs.py	2013-09-17 10:07:31 UTC (rev 57724)
@@ -28,7 +28,7 @@
 from core               import globalvar
 from core.utils import _
 from core.settings      import UserSettings
-from core.gcmd          import GMessage
+from core.gcmd          import GError, RunCommand, GMessage
 from gui_core.dialogs   import SimpleDialog, GroupDialog
 from gui_core           import gselect
 from gui_core.widgets   import SimpleValidator
@@ -38,7 +38,8 @@
 class IClassGroupDialog(SimpleDialog):
     """!Dialog for imagery group selection"""
-    def __init__(self, parent, group = None, title = _("Select imagery group"), id = wx.ID_ANY):
+    def __init__(self, parent, group = None, subgroup = None,
+                 title = _("Select imagery group"), id = wx.ID_ANY):
         Does post init and layout.
@@ -48,16 +49,33 @@
         SimpleDialog.__init__(self, parent, title)
-        self.element = gselect.Select(parent = self.panel, type = 'group',
+        self.use_subg = True
+        self.groupSelect = gselect.Select(parent = self.panel, type = 'group',
                                       mapsets = [grass.gisenv()['MAPSET']],
                                       size = globalvar.DIALOG_GSELECT_SIZE,
                                       validator = SimpleValidator(callback = self.ValidatorCallback))
-        self.element.SetFocus()
+        self.subg_panel = wx.Panel(self.panel)
+        # TODO use when subgroup will be optional
+        #self.subg_chbox = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+        #                              label = _("Use subgroup"))
+        self.subGroupSelect = gselect.SubGroupSelect(parent = self.subg_panel)
+        self.groupSelect.SetFocus()
         if group:
-            self.element.SetValue(group)
+            self.groupSelect.SetValue(group)
+            self.GroupSelected()
+        if subgroup:
+            self.subGroupSelect.SetValue(subgroup)
         self.editGroup = wx.Button(parent = self.panel, id = wx.ID_ANY,
                                    label = _("Create/edit group..."))
         self.editGroup.Bind(wx.EVT_BUTTON, self.OnEditGroup)
+        self.groupSelect.GetTextCtrl().Bind(wx.EVT_TEXT,
+                                           lambda event : wx.CallAfter(self.GroupSelected))
         self.warning = _("Name of imagery group is missing.")
         self._layout()
@@ -65,30 +83,148 @@
     def _layout(self):
         """!Do layout"""
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
         self.dataSizer.Add(wx.StaticText(self.panel, id = wx.ID_ANY,
                                          label = _("Name of imagery group:")),
-                           proportion = 0, flag = wx.EXPAND | wx.ALL, border = 5)
-        self.dataSizer.Add(self.element, proportion = 0,
+                                         proportion = 0,
+                                         flag = wx.EXPAND | wx.BOTTOM | wx.LEFT | wx.RIGHT,
+                                         border = 5)
+        self.dataSizer.Add(self.groupSelect, proportion = 0,
+        #self.dataSizer.Add(self.subg_chbox, proportion = 0,
+        #              flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
+        subg_sizer = wx.BoxSizer(wx.VERTICAL)
+        subg_sizer.Add(wx.StaticText(self.subg_panel, id = wx.ID_ANY,
+                                    label = _("Name of imagery subgroup:")),
+                                    proportion = 0, flag = wx.EXPAND | wx.BOTTOM,
+                                    border = 5)
+        subg_sizer.Add(self.subGroupSelect, proportion = 0,
+                       flag = wx.EXPAND)
+        self.subg_panel.SetSizer(subg_sizer)
+        self.dataSizer.Add(self.subg_panel, proportion = 0,
+                           flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
         self.dataSizer.Add(self.editGroup, proportion = 0,
                       flag = wx.ALL, border = 5)
         self.panel.SetSizer(self.sizer)
+        mainSizer.Add(self.panel, proportion = 1,
+                     flag = wx.ALL, border = 5)
+        self.SetSizer(mainSizer)
         self.sizer.Fit(self)
-    def GetGroup(self):
-        """!Returns selected group"""
-        return self.element.GetValue()
+        #TODO use when subgroup will be optional
+        #self.subg_panel.Show(False)
+        #self.subg_chbox.Bind(wx.EVT_CHECKBOX, self.OnSubgChbox)
+    def OnSubgChbox(self, event):
+        self.use_subg = self.subg_chbox.GetValue()
+        if self.use_subg:
+            self.subg_panel.Show()
+            #self.SubGroupSelected()
+        else:
+            self.subg_panel.Hide()
+            #self.GroupSelected()
+        self.SetMinSize(self.GetBestSize())
+        self.Layout()
+    def GetData(self):
+        """!Returns selected group and subgroup"""
+        if self.use_subg:
+            ret = (self.groupSelect.GetValue(), self.subGroupSelect.GetValue())
+        else:
+            ret = (self.groupSelect.GetValue(), None)
+        return ret
     def OnEditGroup(self, event):
         """!Launch edit group dialog"""
-        dlg = GroupDialog(parent = self, defaultGroup = self.element.GetValue())
+        g, s = self.GetData()
+        dlg = GroupDialog(parent=self, defaultGroup=g, defaultSubgroup=s)
         dlg.ShowModal()
-        gr = dlg.GetSelectedGroup()
+        gr, s = dlg.GetSelectedGroup()
         if gr in dlg.GetExistGroups():
-            self.element.SetValue(gr)
+            self.groupSelect.SetValue(gr)
+            wx.CallAfter(self.subGroupSelect.SetValue, s)
         dlg.Destroy()
+    def GroupSelected(self):
+        group = self.GetSelectedGroup()
+        self.subGroupSelect.Insert(group)
+    def GetSelectedGroup(self):
+        """!Return currently selected group (without mapset)"""
+        return self.groupSelect.GetValue().split('@')[0]
+    def GetGroupBandsErr(self, parent):
+        """!Get list of raster bands which are in the soubgroup of group with both having same name.
+           If the group does not exists or it does not contain any bands in subgoup with same name,
+           error dialog is shown.
+        gr, s = self.GetData()
+        group = grass.find_file(name=gr, element='group')
+        bands = []
+        g = group['name']
+        if g:
+            if self.use_subg:
+                if s == '':
+                    GError(_("Please choose a subgroup."), parent=parent)
+                    return bands
+                if s not in self.GetSubgroups(g):
+                    GError(_("Subgroup <%s> not found in group <%s>") % (s, g), parent=parent)
+                    return bands
+            bands = self.GetGroupBands(g, s)
+            if not bands:
+                if self.use_subg:
+                    GError(_("No data found in subgroup <%s> of group <%s>.\n" \
+                               % (s, g), parent=parent)
+                else:
+                    GError(_("No data found in group <%s>.\n" \
+                               % g, parent=parent)
+        else:
+            GError(_("Group <%s> not found") % gr, parent=parent)
+        return bands
+    def GetGroupBands(self, group, subgroup):
+        """!Get list of raster bands which are in the soubgroup of group with both having same name."""
+        kwargs = {}
+        if subgroup:
+            kwargs['subgroup'] = subgroup
+        res = RunCommand('i.group',
+                         flags='g',
+                         group=group,
+                         read = True, **kwargs).strip()
+        bands = None
+        if res.split('\n')[0]:
+            bands = res.split('\n')
+        return bands
+    def GetSubgroups(self, group):
+        return RunCommand('i.group', group=group,
+                           read=True, flags='sg').splitlines()
 class IClassMapDialog(SimpleDialog):
     """!Dialog for adding raster/vector map"""
     def __init__(self, parent, title, element):
@@ -425,7 +561,8 @@
         return None
 class IClassSignatureFileDialog(wx.Dialog):
-    def __init__(self, parent, group, file = None, title = _("Save signature file"), id = wx.ID_ANY,
+    def __init__(self, parent, group, subgroup,
+                 file = None, title = _("Save signature file"), id = wx.ID_ANY,
                  style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
                  **kwargs):
         """!Dialog for saving signature file
@@ -447,7 +584,7 @@
                                          env['LOCATION_NAME'],
                                          env['MAPSET'],
                                          'group', group,
-                                         'subgroup', group,
+                                         'subgroup', subgroup,
                                          'sig')
         self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-09-17 10:04:24 UTC (rev 57723)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-09-17 10:07:31 UTC (rev 57724)
@@ -477,20 +477,23 @@
         self.Render(self.GetFirstWindow())
-    def OnAddBands(self, event):
+    def AddBands(self):
         """!Add imagery group"""
-        dlg = IClassGroupDialog(self, group = self.group)
-        if dlg.ShowModal() == wx.ID_OK:
-            self.SetGroup(dlg.GetGroup())
+        dlg = IClassGroupDialog(self, group=self.g['group'])
+        while True:
+            if dlg.ShowModal() == wx.ID_OK:
+                if dlg.GetGroupBandsErr(parent=self):
+                    g, s = dlg.GetData()
+                    group = grass.find_file(name=g, element='group')
+                    self.g['group'] = group['name']
+                    self.g['subgroup'] = s
+                    break
+            else:
+                break
         dlg.Destroy()
-    def SetGroup(self, name):
-        """!Set imagery group"""
-        group = grass.find_file(name = name, element = 'group')
-        if group['name']:
-            self.group = group['name']
-        else:
-            GError(_("Group <%s> not found") % name, parent = self)
     def OnImportAreas(self, event):
         """!Import training areas"""
@@ -699,7 +702,7 @@
                    "color varchar(11)",
                    "n_cells integer",]
-        nbands = len(self.GetGroupLayers(self.group))
+        nbands = len(self.GetGroupLayers(self.g['group'], self.g['subgroup']))
         for statistic, format in (("min", "integer"), ("mean", "double precision"), ("max", "integer")):
             for i in range(nbands):
                 # 10 characters limit?
@@ -867,8 +870,8 @@
         """!Run analysis and update plots"""
         if self.RunAnalysis():
             currentCat = self.GetCurrentCategoryIdx()
-            self.plotPanel.UpdatePlots(group = self.group, currentCat = currentCat,
-                                       stats_data = self.stats_data)
+            self.plotPanel.UpdatePlots(group = self.g['group'], subgroup = self.g['subgroup'],
+                                       currentCat = currentCat, stats_data = self.stats_data)
     def RunAnalysis(self):
         """!Run analysis
@@ -876,7 +879,7 @@
         Calls C functions to compute all statistics and creates raster maps.
         Signatures are created but signature file is not.
-        if not self.CheckInput(group = self.group, vector = self.trainingAreaVector):
+        if not self.CheckInput(group = self.g['group'], vector = self.trainingAreaVector):
             return
         for statistic in self.cStatisticsDict.values():
@@ -885,9 +888,8 @@
         # init Ref struct with the files in group */
         I_free_group_ref(self.refer)
-        # we expect the subgroup name to be the same as the group name
-        subgroup = self.group
-        if (not I_iclass_init_group(self.group, subgroup, self.refer)):
+        if (not I_iclass_init_group(self.g['group'], self.g["subgroup"], self.refer)):
             return False
         I_free_signatures(self.signatures)
@@ -910,7 +912,7 @@
                                      stats.nstd)
             ret = I_iclass_analysis(statistics, self.refer, self.poMapInfo, "1",
-                                 self.group, stats.rasterName)
+                                 self.g['group'], stats.rasterName)
             if ret > 0:
                 # tests
                 self.cStatisticsDict[i] = statistics
@@ -939,7 +941,7 @@
     def OnSaveSigFile(self, event):
         """!Asks for signature file name and saves it."""
-        if not self.group:
+        if not self.g['group']:
             GMessage(parent = self, message = _("No imagery group selected."))
             return
@@ -956,7 +958,10 @@
                 qdlg.Destroy()
                 return
-        dlg = IClassSignatureFileDialog(self, group = self.group, file = self.sigFile)
+        dlg = IClassSignatureFileDialog(self,
+                                        group = self.g['group'],
+                                        subgroup = self.g['subgroup'],
+                                        file = self.sigFile)
             if os.path.exists(dlg.GetFileName(fullPath = True)):
@@ -971,7 +976,7 @@
                     qdlg.Destroy()
                     return
             self.sigFile = dlg.GetFileName()
-            self.WriteSignatures(self.signatures, self.group, self.sigFile)
+            self.WriteSignatures(self.signatures, self.g['group'], self.g['subgroup'], self.sigFile)
         dlg.Destroy()
@@ -979,7 +984,7 @@
         """!Initialize variables and c structures neccessary for
         computing statistics.
-        self.group = None
+        self.g = {'group' : None, 'subgroup' : None}
         self.sigFile = None
         self.stats_data = StatisticsData()
@@ -994,25 +999,26 @@
         self.refer = pointer(refer_obj)
         I_init_group_ref(self.refer) # must be freed on exit
-    def WriteSignatures(self, signatures, group, filename):
+    def WriteSignatures(self, signatures, group, subgroup, filename):
         """!Writes current signatures to signature file
         @param signatures signature (c structure)
         @param group imagery group
         @param filename signature file name
-        I_iclass_write_signatures(signatures, group, group, filename)
+        I_iclass_write_signatures(signatures, group, subgroup, filename)
     def CheckInput(self, group, vector):
         """!Check if input is valid"""
         # check if group is ok
+        #TODO check subgroup
         if not group:
                      message = _("No imagery group selected. "
                                  "Operation canceled."))
             return False
-        groupLayers = self.GetGroupLayers(group)
+        groupLayers = self.GetGroupLayers(self.g['group'], self.g['subgroup'])
         nLayers = len(groupLayers)
         if nLayers <= 1:
@@ -1056,15 +1062,19 @@
                 count += 1
         return count
-    def GetGroupLayers(self, group):
+    def GetGroupLayers(self, group, subgroup=None):
         """!Get layers in subgroup (expecting same name for group and subgroup)
         @todo consider moving this function to core module for convenient
+        kwargs = {}
+        if subgroup:
                          flags = 'g',
-                         group = group, subgroup = group,
-                         read = True).strip()
+                         group = group,
             return res.split('\n')
         return []
Modified: grass/trunk/gui/wxpython/iclass/plots.py
--- grass/trunk/gui/wxpython/iclass/plots.py	2013-09-17 10:04:24 UTC (rev 57723)
+++ grass/trunk/gui/wxpython/iclass/plots.py	2013-09-17 10:07:31 UTC (rev 57724)
@@ -115,16 +115,17 @@
         self.SetVirtualSize(self.GetBestVirtualSize())
         self.Layout()
-    def UpdatePlots(self, group, currentCat, stats_data):
+    def UpdatePlots(self, group, subgroup, currentCat, stats_data):
         """!Update plots after new analysis
+        @param subgroup imagery group
         @param currentCat currently selected category (class)
         @param stats_data StatisticsData instance (defined in statistics.py)
         self.stats_data = stats_data
         self.currentCat = currentCat
-        self.bandList = self.parent.GetGroupLayers(group)
+        self.bandList = self.parent.GetGroupLayers(group, subgroup)
         graphType = self.plotSwitch.GetSelection()
Modified: grass/trunk/gui/wxpython/iclass/toolbars.py
--- grass/trunk/gui/wxpython/iclass/toolbars.py	2013-09-17 10:04:24 UTC (rev 57723)
+++ grass/trunk/gui/wxpython/iclass/toolbars.py	2013-09-17 10:07:31 UTC (rev 57724)
@@ -156,7 +156,7 @@
         """!Toolbar data"""
         icons = iClassIcons
         return self._getToolbarData((("selectGroup", icons['selectGroup'],
-                                      self.parent.OnAddBands),
+                                      lambda event : self.parent.AddBands()),
                                       (None, ),
                                       ("classManager", icons['classManager'],
                                       self.parent.OnCategoryManager),
