[GRASS-SVN] r57767 - grass/branches/releasebranch_6_4/vector/v.transform
Fri Sep 20 16:23:05 PDT 2013
Author: hamish
Date: 2013-09-20 16:23:05 -0700 (Fri, 20 Sep 2013)
New Revision: 57767
   grass/branches/releasebranch_6_4/vector/v.transform/main.c
minor sync with devbr6 (move -w flag placement, guisection)
Modified: grass/branches/releasebranch_6_4/vector/v.transform/main.c
--- grass/branches/releasebranch_6_4/vector/v.transform/main.c	2013-09-20 23:21:53 UTC (rev 57766)
+++ grass/branches/releasebranch_6_4/vector/v.transform/main.c	2013-09-20 23:23:05 UTC (rev 57767)
@@ -86,28 +86,29 @@
     tozero_flag->description = _("Shift all z values to bottom=0");
     tozero_flag->guisection = _("Custom");
+    swap_flag = G_define_flag();
+    swap_flag->key = 'w';
+    swap_flag->description =
+	_("Swap coordinates x, y and then apply other parameters");
+    swap_flag->guisection = _("Custom");
     print_mat_flag = G_define_flag();
     print_mat_flag->key = 'm';
     print_mat_flag->description =
 	_("Print the transformation matrix to stdout");
     shift_flag = G_define_flag();
     shift_flag->key = 's';
     shift_flag->description =
 	_("Instead of points use transformation parameters "
 	  "(xshift, yshift, zshift, xscale, yscale, zscale, zrot)");
     shift_flag->guisection = _("Custom");
-    swap_flag = G_define_flag();
-    swap_flag->key = 'w';
-    swap_flag->description =
-	_("Swap coordinates x, y and then apply other parameters");
     vold = G_define_standard_option(G_OPT_V_INPUT);
     field = G_define_standard_option(G_OPT_V_FIELD);
     field->answer = "-1";
     vnew = G_define_standard_option(G_OPT_V_OUTPUT);
     pointsfile = G_define_standard_option(G_OPT_F_INPUT);
