[GRASS-SVN] r57794 -	grass/branches/releasebranch_6_4/scripts/d.shadedmap
    svn_grass at osgeo.org
    Sun Sep 22 01:00:55 PDT 2013
Author: hamish
Date: 2013-09-22 01:00:55 -0700 (Sun, 22 Sep 2013)
New Revision: 57794
   grass/branches/releasebranch_6_4/scripts/d.shadedmap/d.shadedmap
   grass/branches/releasebranch_6_4/scripts/d.shadedmap/description.html
add option to save result to a new raster map (merge r57732 from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/d.shadedmap/d.shadedmap
--- grass/branches/releasebranch_6_4/scripts/d.shadedmap/d.shadedmap	2013-09-22 07:51:30 UTC (rev 57793)
+++ grass/branches/releasebranch_6_4/scripts/d.shadedmap/d.shadedmap	2013-09-22 08:00:55 UTC (rev 57794)
@@ -5,7 +5,7 @@
 # MODULE:	d.shadedmap
 # AUTHOR(S):	Unknown; updated to GRASS 5.7 by Michael Barton
 # PURPOSE:	Uses d.his to drape a color raster over a shaded relief map
-# COPYRIGHT:	(C) 2004 by the GRASS Development Team
+# COPYRIGHT:	(C) 2004-2013 by the GRASS Development Team
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -15,7 +15,7 @@
 #%Module
-#% description: Drapes a color raster over a shaded relief map using d.his
+#% description: Drapes a color raster over a shaded relief map using d.his.
 #%End
 #%option
 #% key: reliefmap
@@ -38,16 +38,39 @@
 #% options: -99-99
 #% answer: 0
 #%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% key_desc: name
+#% description: Create raster map from result (optional)
+#% required: no
+#%end
 if  [ -z "$GISBASE" ] ; then
-  echo "You must be in GRASS GIS to run this program." 1>&2
-  exit 1
+   echo "You must be in GRASS GIS to run this program." 1>&2
+   exit 1
 fi
 if [ "$1" != "@ARGS_PARSED@" ] ; then
-  exec g.parser "$0" "$@"
+   exec g.parser "$0" "$@"
 fi
-exec d.his "h_map=$GIS_OPT_DRAPEMAP" "i_map=$GIS_OPT_RELIEFMAP" \
-	"brighten=$GIS_OPT_BRIGHTEN"
+if [ -n "$GIS_OPT_OUTPUT" ] ; then
+   TMPBASE="tmp_drape.$$"
+   TMP_R="$TMPBASE.r"
+   TMP_G="$TMPBASE.g"
+   TMP_B="$TMPBASE.b"
+   r.his h_map="$GIS_OPT_DRAPEMAP" i_map="$GIS_OPT_RELIEFMAP" \
+      r_map="$TMP_R" g_map="$TMP_G" b_map="$TMP_B"
+   r.composite red="$TMP_R" green="$TMP_G" blue="$TMP_B" \
+      output="$GIS_OPT_OUTPUT"
+   g.remove rast="$TMP_R,$TMP_G,$TMP_B" --quiet
+fi
+exec d.his h_map="$GIS_OPT_DRAPEMAP" i_map="$GIS_OPT_RELIEFMAP" \
+	brighten="$GIS_OPT_BRIGHTEN"
Modified: grass/branches/releasebranch_6_4/scripts/d.shadedmap/description.html
--- grass/branches/releasebranch_6_4/scripts/d.shadedmap/description.html	2013-09-22 07:51:30 UTC (rev 57793)
+++ grass/branches/releasebranch_6_4/scripts/d.shadedmap/description.html	2013-09-22 08:00:55 UTC (rev 57794)
@@ -2,31 +2,55 @@
 <em>d.shadedmap</em> will drape a color raster map over a shaded relief map.
 <h2>NOTES</h2>
-refer to the <em>d.his</em> help page for more details; <em>d.shadedmap</em>
+Refer to the <em>d.his</em> help page for more details; <em>d.shadedmap</em>
 is simply a frontend to that module.
+<p>
+If the <b>output</b> option is given the rendering will be written to a
+new raster map. The <b>output</b> map does not respect the <b>brighten</b>
+parameter. <!-- at this time. -->
-<h2>EXAMPLE</h2>
-In this example, the aspect map in the North Carolina sample
-dataset location is used to hillshade the elevation map:
+<h2>EXAMPLES</h2>
+In this example, the <tt>aspect</tt> map in the North Carolina sample
+dataset location is used to hillshade the <tt>elevation</tt> map:
 <div class="code"><pre>
 g.region rast=aspect -p
 d.shadedmap reliefmap=aspect drapemap=elevation
 </pre></div>
+In this next example, a shaded relief raster map is created in
+the Spearfish sample dataset and used to create a colorized hillshade
+raster map for later use:
+<div class="code"><pre>
+g.region rast=elevation.10m
+r.colors -e map=elevation.10m color=haxby
+r.shaded.relief elevation.10m
+d.shadedmap reliefmap=elevation.10m.shade drapemap=elevation.10m \
+   output=elevation.10m.shade.colorized
+r.colors -r map=elevation.10m
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="d.his.html">d.his</a>,
 <a href="g.pnmcomp.html">g.pnmcomp</a>,
-<a href="nviz.html">NVIZ</a>,
+<a href="r.his.html">r.his</a>,
 <a href="r.slope.aspect.html">r.slope.aspect</a>,
-<a href="r.shaded.relief.html">r.shaded.relief</a>
+<a href="r.shaded.relief.html">r.shaded.relief</a><br>
+<a href="nviz.html">NVIZ</a>
 </em>
 <h2>AUTHORS</h2>
