[GRASS-SVN] r57797 - grass/branches/releasebranch_6_4/scripts/v.db.dropcol
Sun Sep 22 01:26:33 PDT 2013
Author: hamish
Date: 2013-09-22 01:26:32 -0700 (Sun, 22 Sep 2013)
New Revision: 57797
   grass/branches/releasebranch_6_4/scripts/v.db.dropcol/description.html
minor whitespace, html (sync with devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/v.db.dropcol/description.html
--- grass/branches/releasebranch_6_4/scripts/v.db.dropcol/description.html	2013-09-22 08:22:00 UTC (rev 57796)
+++ grass/branches/releasebranch_6_4/scripts/v.db.dropcol/description.html	2013-09-22 08:26:32 UTC (rev 57797)
@@ -5,12 +5,14 @@
 layer. <em>v.db.dropcol</em> omits to delete the 'cat' column which is
 relevant to keep the connection between vector map and table.
 <h2>NOTES</h2>
 v.db.dropcol is a front-end to <em>db.execute</em> to allow easier usage.
 The existing database connection(s) can be verified with <em>v.db.connect</em>.
 <h2>EXAMPLES</h2>
 Dropping a column:<br>
@@ -19,20 +21,24 @@
 v.info -c sentiero_brenta_points
 </pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="db.droptable.html">db.droptable</a></em>,
-<em><a href="db.execute.html">db.execute</a></em>,
-<em><a href="v.db.addcol.html">v.db.addcol</a></em>,
-<em><a href="v.db.addtable.html">v.db.addtable</a></em>,
-<em><a href="v.db.connect.html">v.db.connect</a></em>,
-<em><a href="v.db.droptable.html">v.db.droptable</a></em>,
-<em><a href="v.db.select.html">v.db.select</a></em>,
-<em><a href="v.db.update.html">v.db.update</a></em>
+<em>
+<a href="db.droptable.html">db.droptable</a>,
+<a href="db.execute.html">db.execute</a>,
+<a href="v.db.addcol.html">v.db.addcol</a>,
+<a href="v.db.addtable.html">v.db.addtable</a>,
+<a href="v.db.connect.html">v.db.connect</a>,
+<a href="v.db.droptable.html">v.db.droptable</a>,
+<a href="v.db.select.html">v.db.select</a>,
+<a href="v.db.update.html">v.db.update</a>
+</em>
 <h2>AUTHOR</h2>
 Markus Neteler
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
