[GRASS-SVN] r57803 - in grass/trunk: gui/wxpython/gui_core raster/r.colors tools
svn_grass at osgeo.org
Sun Sep 22 02:11:05 PDT 2013
Author: martinl
Date: 2013-09-22 02:11:04 -0700 (Sun, 22 Sep 2013)
New Revision: 57803
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/raster/r.colors/Makefile
grass/trunk/tools/thumbnails.py
r.colors: move colortable thumbnails to the separate directory (similarly to barscales)
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2013-09-22 09:00:25 UTC (rev 57802)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2013-09-22 09:11:04 UTC (rev 57803)
@@ -1247,7 +1247,7 @@
Used in r(3).colors dialog."""
def _getPath(self, name):
- return os.path.join(os.getenv("GISBASE"), "docs", "html", "Colortable_%s.png" % name)
+ return os.path.join(os.getenv("GISBASE"), "docs", "html", "colortables", "%s.png" % name)
class BarscalesComboBox(PictureComboBox):
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile 2013-09-22 09:00:25 UTC (rev 57802)
+++ grass/trunk/raster/r.colors/Makefile 2013-09-22 09:11:04 UTC (rev 57803)
@@ -15,19 +15,22 @@
# Insert thumbnail previews
r.colors.tmp.html: $(BIN)/r.colors$(EXE) thumbnails
$(call htmldesc,$<,$@)
- sed 's!^<dd><b>\([a-z0-9._]*\)</b>:!<dd><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
+ sed 's!^<dd><b>\([a-z0-9._]*\)</b>:!<dd><img width="80" height="12" src="colortables/\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
mv -f "$@.tmp" "$@"
$(MAKE) thumbnails
r3.colors.tmp.html: $(BIN)/r3.colors$(EXE) thumbnails
mv -f "$@.tmp" "$@"
$(MAKE) thumbnails
-thumbnails: $(BIN)/r.mapcalc$(EXE)
+thumbnails: $(BIN)/r.mapcalc$(EXE) $(HTMLDIR)/colortables
-$(call run_grass, $(GRASS_HOME)/tools/thumbnails.py)
+$(HTMLDIR)/colortables: $(HTMLDIR)
+ $(MKDIR) $@
$(BIN)/r.mapcalc$(EXE):
$(MAKE) -C ../r.mapcalc
Modified: grass/trunk/tools/thumbnails.py
--- grass/trunk/tools/thumbnails.py 2013-09-22 09:00:25 UTC (rev 57802)
+++ grass/trunk/tools/thumbnails.py 2013-09-22 09:11:04 UTC (rev 57803)
@@ -151,7 +151,7 @@
grass.run_command("r.colors", map = grad, color = table, quiet = True)
grass.run_command("d.colortable", flags = 'n', map = grad,
lines = lines, cols = cols, quiet = True)
- outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
+ outfile = os.path.join(output_dir, "colortables", "%s.png" % table)
convert_and_rotate(tmp_img, outfile, discrete)
def main():
