[GRASS-SVN] r57819 - grass/branches/develbranch_6/vector/v.voronoi
Mon Sep 23 07:10:28 PDT 2013
Author: mmetz
Date: 2013-09-23 07:10:27 -0700 (Mon, 23 Sep 2013)
New Revision: 57819
   grass/branches/develbranch_6/vector/v.voronoi/sw_defs.h
   grass/branches/develbranch_6/vector/v.voronoi/sw_geometry.c
   grass/branches/develbranch_6/vector/v.voronoi/sw_main.c
   grass/branches/develbranch_6/vector/v.voronoi/sw_output.c
   grass/branches/develbranch_6/vector/v.voronoi/vo_extend.c
   grass/branches/develbranch_6/vector/v.voronoi/vo_main.c
   grass/branches/develbranch_6/vector/v.voronoi/vo_write.c
v.voronoi: backport fixes for #957, #1682, #2019
Modified: grass/branches/develbranch_6/vector/v.voronoi/sw_defs.h
--- grass/branches/develbranch_6/vector/v.voronoi/sw_defs.h	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/sw_defs.h	2013-09-23 14:10:27 UTC (rev 57819)
@@ -110,6 +110,7 @@
 int makevertex(struct Site *);
 int deref(struct Site *);
 int ref(struct Site *);
+double d_ulp(double);
 /* sw_heap.c */
 int PQinsert(struct Halfedge *, struct Site *, double);
Modified: grass/branches/develbranch_6/vector/v.voronoi/sw_geometry.c
--- grass/branches/develbranch_6/vector/v.voronoi/sw_geometry.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/sw_geometry.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include <math.h>
+#include <grass/gis.h>
 #include "sw_defs.h"
 int geominit(void)
@@ -32,12 +33,22 @@
     newedge->ep[0] = (struct Site *)NULL;
     newedge->ep[1] = (struct Site *)NULL;
-    dx = s2->coord.x - s1->coord.x;
-    dy = s2->coord.y - s1->coord.y;
+    if (s1->coord.x < s2->coord.x ||
+        (s1->coord.x == s2->coord.x && s1->coord.y < s2->coord.y)) {
+	dx = s2->coord.x - s1->coord.x;
+	dy = s2->coord.y - s1->coord.y;
+	newedge->c =
+	    s1->coord.x * dx + s1->coord.y * dy + (dx * dx + dy * dy) * 0.5;
+    else {
+	dx = s1->coord.x - s2->coord.x;
+	dy = s1->coord.y - s2->coord.y;
+	newedge->c =
+	    s2->coord.x * dx + s2->coord.y * dy + (dx * dx + dy * dy) * 0.5;
     adx = dx > 0 ? dx : -dx;
     ady = dy > 0 ? dy : -dy;
-    newedge->c =
-	s1->coord.x * dx + s1->coord.y * dy + (dx * dx + dy * dy) * 0.5;
     if (adx > ady) {
 	newedge->a = 1.0;
 	newedge->b = dy / dx;
@@ -55,12 +66,29 @@
     return (newedge);
+/* single precision ULP */
+double d_ulp(double d)
+    int exp;
+    if (d == 0)
+	return GRASS_EPSILON;
+    if (d < 0)
+	d = fabs(d);
+    d = frexp(d, &exp);
+    exp -= 22;
+    d = ldexp(d, exp);
+    return d;
 struct Site *intersect(struct Halfedge *el1, struct Halfedge *el2)
     struct Edge *e1, *e2, *e;
     struct Halfedge *el;
-    double d, xint, yint;
+    double d, dt, xint, yint;
     int right_of_site;
     struct Site *v;
@@ -72,9 +100,21 @@
 	return ((struct Site *)NULL);
     d = e1->a * e2->b - e1->b * e2->a;
-    if (-1.0e-10 < d && d < 1.0e-10)
+    if (fabs(e1->a * e2->b) > fabs(e1->b * e2->a)) {
+	dt = fabs(e1->a * e2->b);
+    else
+	dt = fabs(e1->b * e2->a);
+    if (dt != dt)
+    dt = d_ulp(dt);
+    G_debug(4, "dt = %g", dt);
+    if (-dt < d && d < dt)
+	return ((struct Site *)NULL);
     xint = (e1->c * e2->b - e2->c * e1->b) / d;
     yint = (e2->c * e1->a - e1->c * e2->a) / d;
Modified: grass/branches/develbranch_6/vector/v.voronoi/sw_main.c
--- grass/branches/develbranch_6/vector/v.voronoi/sw_main.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/sw_main.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -3,6 +3,7 @@
 #include <unistd.h>
 #include <grass/Vect.h>
+#include <grass/glocale.h>
 #include "defs.h"
@@ -41,10 +42,8 @@
 void removeDuplicates()
     int i, j;
-    int foundDupe;
     i = j = 1;
-    foundDupe = 0;
     while (i < nsites)
 	if (mode3d) {
 	    if (sites[i].coord.x == sites[i - 1].coord.x &&
@@ -80,23 +79,27 @@
 /* read all sites, sort, and compute xmin, xmax, ymin, ymax */
 int readsites(void)
-    int nlines, line;
+    int nlines, ltype;
     struct line_pnts *Points;
+    struct line_cats *Cats;
     Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    nlines = Vect_get_num_primitives(&In, GV_POINTS);
-    nlines = Vect_get_num_lines(&In);
     nsites = 0;
     sites = (struct Site *)G_malloc(nlines * sizeof(struct Site));
-    for (line = 1; line <= nlines; line++) {
-	int type;
+    while(TRUE) {
+	ltype = Vect_read_next_line(&In, Points, Cats);
+	if(ltype == -2)
+	    break;
-	type = Vect_read_line(&In, Points, NULL, line);
-	if (!(type & GV_POINTS))
+	if (!(ltype & GV_POINTS))
 	    continue;
+	/* G_percent(Vect_get_next_line_id(&In), nlines, 2); */
 	if (!All) {
 	    if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &Box))
 		continue;
@@ -131,7 +134,14 @@
 	nsites++;
-    if (nsites < nlines - 1)
+    if (nsites < 2) {
+	const char *name = Vect_get_full_name(&In);
+	Vect_close(&In);
+	G_fatal_error(_("Found %d points/centroids in <%s>, but at least 2 are needed"),
+	              nsites, name);
+    if (nsites < nlines)
 	sites =
 	    (struct Site *)G_realloc(sites,
 				     (nsites) * sizeof(struct Site));
@@ -139,6 +149,9 @@
     qsort(sites, nsites, sizeof(struct Site), scomp);
     removeDuplicates();
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_cats_struct(Cats);
     return 0;
Modified: grass/branches/develbranch_6/vector/v.voronoi/sw_output.c
--- grass/branches/develbranch_6/vector/v.voronoi/sw_output.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/sw_output.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -47,17 +47,9 @@
 int out_ep(struct Edge *e)
-    static struct line_pnts *Points = NULL;
-    static struct line_cats *Cats = NULL;
-    if (!Points) {
-	Points = Vect_new_line_struct();
-	Cats = Vect_new_cats_struct();
-    if (!triangulate & plot)
+    if ((!triangulate) & plot)
 	clip_line(e);
-    if (!triangulate & !plot) {
+    if ((!triangulate) & !plot) {
 	   fprintf (stdout,"e %d", e->edgenbr);
 	   fprintf (stdout," %d ", e->ep[le] != (struct Site *)NULL ? e->ep[le]->sitenbr : -1);
@@ -85,7 +77,7 @@
 int out_site(struct Site *s)
-    if (!triangulate & plot & !debug)
+    if ((!triangulate) & plot & (!debug))
 	circle(s->coord.x, s->coord.y, cradius);
Modified: grass/branches/develbranch_6/vector/v.voronoi/vo_extend.c
--- grass/branches/develbranch_6/vector/v.voronoi/vo_extend.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/vo_extend.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -33,7 +33,7 @@
     double nx, ny;		/* intersection coordinates */
-    if (x > w && x < e && y > s && y < n) {
+    if (x >= w && x <= e && y >= s && y <= n) {
 	/* vertical line? */
 	if (a == 0) {
 	    *c_x = knownPointAtLeft ? e : w;
Modified: grass/branches/develbranch_6/vector/v.voronoi/vo_main.c
--- grass/branches/develbranch_6/vector/v.voronoi/vo_main.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/vo_main.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -108,11 +108,14 @@
     struct GModule *module;
+    struct bound_box box;
     int node, nnodes;
     COOR *coor;
+    int verbose;
     int ncoor, acoor;
     int line, nlines, type, ctype, area, nareas;
     int err_boundaries, err_centr_out, err_centr_dupl, err_nocentr;
+    double snap_thresh;
     G_gisinit(argv[0]);
@@ -190,7 +193,10 @@
     voronoi(triangulate, nextone);
     /* Close free ends by current region */
+    verbose = G_verbose();
+    G_set_verbose(0);
     Vect_build_partial(&Out, GV_BUILD_BASE);
+    G_set_verbose(verbose);
     ncoor = 0;
     acoor = 100;
@@ -336,7 +342,7 @@
 	    if (fields[i] == 0)
 		continue;
-	    G_message(_("Layer %d"), fields[i]);
+	    G_debug(1, "Layer %d", fields[i]);
 	    /* Make a list of categories */
 	    IFi = Vect_get_field(&In, fields[i]);
@@ -369,7 +375,9 @@
     Vect_close(&In);
     /* cleaning part 1: count errors */
+    G_set_verbose(0);
     Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
     err_boundaries = err_centr_out = err_centr_dupl = err_nocentr = 0;
     nlines = Vect_get_num_lines(&Out);
@@ -409,11 +417,22 @@
     /* cleaning part 2: snap */
+    /* TODO: adjust snapping treshold to ULP */
+    Vect_get_map_box(&Out, &box);
+    snap_thresh = fabs(box.W);
+    if (snap_thresh < fabs(box.E))
+	snap_thresh = fabs(box.E);
+    if (snap_thresh < fabs(box.N))
+	snap_thresh = fabs(box.N);
+    if (snap_thresh < fabs(box.S))
+	snap_thresh = fabs(box.S);
+    snap_thresh = d_ulp(snap_thresh);
     if (err_nocentr || err_centr_dupl || err_centr_out) {
 	int nmod;
 	G_important_message(_("Output needs topological cleaning"));
-	Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+	Vect_snap_lines(&Out, GV_BOUNDARY, snap_thresh, NULL);
 	do {
 	    Vect_break_lines(&Out, GV_BOUNDARY, NULL);
 	    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
Modified: grass/branches/develbranch_6/vector/v.voronoi/vo_write.c
--- grass/branches/develbranch_6/vector/v.voronoi/vo_write.c	2013-09-23 14:07:38 UTC (rev 57818)
+++ grass/branches/develbranch_6/vector/v.voronoi/vo_write.c	2013-09-23 14:10:27 UTC (rev 57819)
@@ -42,23 +42,43 @@
 	    Vect_write_line(&Out, Type, Points, Cats);
 	else {
-	    int knownPointAtLeft;
+	    int knownPointAtLeft = -1;
 	    if (e->ep[le] != NULL) {
 		x1 = e->ep[le]->coord.x;
 		y1 = e->ep[le]->coord.y;
 		knownPointAtLeft = 1;
-	    else {
+	    else if (e->ep[re] != NULL) {
 		x1 = e->ep[re]->coord.x;
 		y1 = e->ep[re]->coord.y;
 		knownPointAtLeft = 0;
+	    if (knownPointAtLeft == -1) {
+		G_warning("Dead edge!");
+		return 1;
+		x2 = (e->reg[le]->coord.x + e->reg[re]->coord.x) / 2.0;
+		y2 = (e->reg[le]->coord.y + e->reg[re]->coord.y) / 2.0;
+		knownPointAtLeft = 0;
+		if (!extend_line(Box.S, Box.N, Box.W, Box.E,
+				 e->a, e->b, e->c, x2, y2, &x1, &y1,
+				 knownPointAtLeft)) {
+		    G_warning("Undefined edge, unable to extend line");
+		    return 0;
+		G_debug(0, "x1 = %g, y1 = %g, x2 = %g, y2 = %g", x1, y1, x2, y2);
+		knownPointAtLeft = 1;
 	    if (extend_line(Box.S, Box.N, Box.W, Box.E,
 			    e->a, e->b, e->c, x1, y1, &x2, &y2,
-			    knownPointAtLeft)
 		/* Don't write zero length */
 		if (x1 == x2 && y1 == y2)
 		    return 0;
