[GRASS-SVN] r57850 - grass-addons/grass7/raster/r.fidimo
Fri Sep 27 00:48:12 PDT 2013
Author: jradinger
Date: 2013-09-27 00:48:11 -0700 (Fri, 27 Sep 2013)
New Revision: 57850
   grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Implementation of fixed seed (for calculation of internal fishmove probability)
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2013-09-27 00:18:12 UTC (rev 57849)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2013-09-27 07:48:11 UTC (rev 57850)
@@ -149,6 +149,14 @@
 #% guisection: Optional
 #%End
 #%Option
+#% key: seed
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: fixed seed for generating dispersal parameters via fishmove
+#% guisection: Optional
+#%End
+#%Option
 #% key: output
 #% type: string
 #% required: no
@@ -185,7 +193,6 @@
 import grass.script.setup as gsetup
 import grass.script.array as garray
-#import random
 # import required numpy/scipy modules
 import numpy
@@ -273,8 +280,13 @@
 		interval = "prediction"
 	else:
 		interval = "confidence"
+	#Set fixed seed if specified
+	if options['seed']:
+		seed = ",seed="+str(options['seed'])
+	else:
+		seed = ""
 	#Output
 	output_fidimo = options['output']
 	if (grass.find_file(name = output_fidimo+"_"+"fit", element = 'cell')['file'] and not grass.overwrite()):
@@ -311,10 +323,11 @@
 	##### Calculating 'fishmove' depending on species or L & AR
 	if species == "Custom species":
-		fishmove = fm.fishmove(L=L,AR=AR,SO=SO,T=T,interval=interval)
+		fishmove = eval("fm.fishmove(L=L,AR=AR,SO=SO,T=T,interval=interval,rep=200%s)"%(seed))
 	else:
-		fishmove = fm.fishmove(species=species,SO=SO,T=T,interval=interval)
 	# using only part of fishmove results (only regression coeffients)
 	fishmove = fishmove[1]
 	nrun = ['fit','lwr','upr']
