[GRASS-SVN] r57866 - grass-addons/grass7/raster/r.local.relief
    svn_grass at osgeo.org
    Sun Sep 29 19:12:02 PDT 2013
Author: wenzeslaus
Date: 2013-09-29 19:12:02 -0700 (Sun, 29 Sep 2013)
New Revision: 57866
   grass-addons/grass7/raster/r.local.relief/r.local.relief.html
   grass-addons/grass7/raster/r.local.relief/r.local.relief.py
adding flag -i for saving some of the intermediate results; changing default size of the window to 11 to be closer to Hesse 2010; docs update (author: Eric Goddard)
Modified: grass-addons/grass7/raster/r.local.relief/r.local.relief.html
--- grass-addons/grass7/raster/r.local.relief/r.local.relief.html	2013-09-30 01:42:09 UTC (rev 57865)
+++ grass-addons/grass7/raster/r.local.relief/r.local.relief.html	2013-09-30 02:12:02 UTC (rev 57866)
@@ -5,39 +5,39 @@
 <p>Generating the LRM is accomplished in 7 steps (Hesse 2010:69):</p>
 <ol>
     <li>Creation of the DEM from the LIDAR data. Buildings, trees and other objects on the earth's surface should be removed.</li>
-    <li>Apply a low pass filter to the DEM. The low pass filter approximates the large-scale landscape forms. The kernel size of the low pass filter determines the scale of features that will be visible in the LRM. A default kernel size of 25 is used.</li>
+    <li>Apply a low pass filter to the DEM. The low pass filter approximates the large-scale landforms. The neighborhood size of the low pass filter determines the scale of features that will be visible in the LRM. A default neighborhood size of 11 is used.</li>
     <li>Subtract the low-pass filter result from the DEM to get the local relief.</li>
     <li>Extract the zero contour lines from the difference map.</li>
-    <li>Extract the point elevations from the DEM along the zero contour lines.</li>
-    <li>Create a purged DEM from the point elevations extracted in the last step. This layer represents the large-scale landscape forms that will be removed to expose the local relief in the final step. v.surf.bspline is used to interpolate the points to a raster.</li>
+    <li>Extract the input DEM's elevation values along the zero contour lines.</li>
+    <li>Create a purged DEM by interpolating the null values between the rasterized contours generated in the previous step. This layer represents the large-scale landforms that will be removed to expose the local relief in the final step. This step is performed by the <a href="r.fillnulls.html">r.fillnulls</a> module using cubic spline interpolation.</li>
     <li>Subtract the purged DEM from the original DEM to get the local relief model.
 </ol>
-Note that these steps are not completely valid for Vaclav's implementation which uses <a href="r.fillnulls.html">r.fillnulls</a> module.
 <h2>OUTPUT</h2>
 <p>
-The final local relief model gets the name specified by the <em>output</em> parameter.
-When the <em>-i</em> is specified <em>r.local.relief</em> creates six additional output files one for each step in the LRM creation process. The names consist of the user-specified <em>output</em> parameter and the following suffixes:</p>
+The final local relief model is named according to the <em>output</em> parameter.
+When the <em>-i</em> flag is specified, <em>r.local.relief</em> creates four additional output files representing the intermediate steps in the LRM generation process. The names of the intermediate fiels are composed of the user-specified <em>output</em> parameter and the following suffixes:</p>
 <ul>
     <li><tt>_smooth_elevation</tt>: The result of running the low pass filter on the DEM.</li>
-    <li><tt>_subtracted_smooth_elevation:s</tt> The result of subtracting the low pass filter map from the DEM.</li>
-    <li><tt>_vector_contours:s</tt> The zero contours extracted from the subtracted smooth elevation map.</li>
-    <li><tt>raster_contours</tt>: The rasterized zero contours.</li>
+    <li><tt>_subtracted_smooth_elevation</tt>: The result of subtracting the low pass filter map from the DEM.</li>
     <li><tt>raster_contours_with_values</tt>: The rasterized zero contours with the values from elevation map.</li>
-    <li><tt>_purged_elevation:s</tt> The raster interpolated from the raster map based on zero contours map.</li>
+    <li><tt>_purged_elevation</tt>: The raster interpolated from the raster map based on zero contours map.</li>
 </ul>
-Note that this is not implemented yet, you must change the variable save_intermediates in the code itself.
 <h2>EXAMPLE</h2>
-Basic example using the default kernel size of 5:
+Basic example using the default neighborhood size of 11:
 <div class="code"><pre>
-r.local.relief input=elevation output=lrm5
+r.local.relief input=elevation output=lrm11
 </pre></div>
-Example with a custom kernel size of 11:
+Example with a custom neighborhood size of 25:
-r.local.relief input=elevation output_prefix=lrm11 neighborhood_size=11
+r.local.relief input=elevation output=lrm25 neighborhood_size=25
 </pre></div>
+Example using the default neighborhood size of 11 and saving the intermediate maps:
+<div class="code"><pre>
+r.local.relief -i input=elevation output=lrm11
+</pre></div>
 <h2>SEE ALSO</h2>
Modified: grass-addons/grass7/raster/r.local.relief/r.local.relief.py
--- grass-addons/grass7/raster/r.local.relief/r.local.relief.py	2013-09-30 01:42:09 UTC (rev 57865)
+++ grass-addons/grass7/raster/r.local.relief/r.local.relief.py	2013-09-30 02:12:02 UTC (rev 57866)
@@ -5,7 +5,7 @@
 # MODULE:    r.local.relief
 # AUTHOR(S): Vaclav Petras <wenzeslaus gmail.com>,
 #            Eric Goddard <egoddard memphis.edu>
-# PURPOSE:   Create a local relief models from elevation map
+# PURPOSE:   Create a local relief model from elevation map
 # COPYRIGHT: (C) 2013 by the GRASS Development Team
 #            This program is free software under the GNU General Public
@@ -15,11 +15,13 @@
 #%module
-#% description: Creates a local relief models from elevation map.
+#% description: Creates a local relief model from elevation map.
 #% keywords: raster
 #% keywords: elevation
 #% keywords: terrain
 #% keywords: relief
+#% keywords: LRM
+#% keywords: visualization
 #%end
 #%option
 #% type: string
@@ -40,15 +42,17 @@
 #% type: integer
 #% description: Neighborhood size used when smoothing the elevation model
 #% options: 0-
-#% answer: 3
+#% answer: 11
 #%end
+#%flag
+#% key: i
+#% description: Save intermediate maps
+#%end
 # TODO: The step 5 (contours to smooth elevation) can be replaced by using
 # vector tools (v.surf.*), this needs further testing.
 # Note, that quality of interpolation highly determines the result.
-# TODO: implement save intermediate results flag
-# (code is ready, but consider also outputting only some useful ones)
 import os
 import atexit
@@ -71,7 +75,7 @@
 def create_tmp_map_name(name):
-    return '{mod}_{pid}_{map_}_tmp'.format(mod='r_shaded_pca',
+    return '{mod}_{pid}_{map_}_tmp'.format(mod='r_local_relief',
                                            pid=os.getpid(),
                                            map_=name)
@@ -89,15 +93,15 @@
 def main():
     atexit.register(cleanup)
-    options, unused = gscript.parser()
+    options, flags = gscript.parser()
     elevation_input = options['input']
     local_relief_output = options['output']
     neighborhood_size = int(options['neighborhood_size'])
+    save_intermediates = flags['i']
     fill_method = 'cubic'
     color_table = 'differences'
-    save_intermediates = True
     if save_intermediates:
         def local_create(name):
@@ -115,7 +119,11 @@
     raster_contours_with_values = create_map_name('raster_contours_with_values')
     purged_elevation = create_map_name('purged_elevation')
-    if not save_intermediates:
+    # if saving intermediates, keep only 1 contour layer
+    if save_intermediates:
+        RREMOVE.append(raster_contours)
+        VREMOVE.append(vector_contours)
+    else:
         RREMOVE.append(smooth_elevation)
         RREMOVE.append(subtracted_smooth_elevation)
