[GRASS-SVN] r57884 - grass/branches/releasebranch_6_4/ps/ps.map
Mon Sep 30 12:01:00 PDT 2013
Author: neteler
Date: 2013-09-30 12:00:59 -0700 (Mon, 30 Sep 2013)
New Revision: 57884
   grass/branches/releasebranch_6_4/ps/ps.map/vect.c
ps.map: avoid namespace pollution on AIX (backport from trunk); comments sync
Modified: grass/branches/releasebranch_6_4/ps/ps.map/vect.c
--- grass/branches/releasebranch_6_4/ps/ps.map/vect.c	2013-09-30 19:00:32 UTC (rev 57883)
+++ grass/branches/releasebranch_6_4/ps/ps.map/vect.c	2013-09-30 19:00:59 UTC (rev 57884)
@@ -1,9 +1,9 @@
 /* Functions: adjust_line
- ** Author: Radim Blazek Feb 2000
+ * Author: Radim Blazek Feb 2000
 #include <stdlib.h>
 #include <math.h>
 #include <grass/Vect.h>
@@ -13,7 +13,7 @@
 #define LENGTH(DX, DY)  (  sqrt( (DX*DX)+(DY*DY) )  )
 /* nearest returns nearest longitude coordinate, copy from src/libes */
-static double nearest(double e0, double e1)
+static double nearest_longitude(double e0, double e1)
     while (e0 - e1 > 180)
 	e1 += 360.0;
@@ -23,7 +23,8 @@
 /* if projection is PROJECTION_LL adjust_line will change
- **   longitudes to nearest form previous point */
+ *   longitudes to nearest form previous point
 void adjust_line(struct line_pnts *Points)
     int i, np;
@@ -31,7 +32,7 @@
     if (G_projection() == PROJECTION_LL) {
 	np = Points->n_points;
 	for (i = 1; i < np; i++) {
-	    Points->x[i] = nearest(Points->x[i - 1], Points->x[i]);
+	    Points->x[i] = nearest_longitude(Points->x[i - 1], Points->x[i]);
