[GRASS-SVN] r59571 - grass/trunk/gui/wxpython/gui_core
Fri Apr 4 07:10:42 PDT 2014
Author: annakrat
Date: 2014-04-04 07:10:42 -0700 (Fri, 04 Apr 2014)
New Revision: 59571
   grass/trunk/gui/wxpython/gui_core/dialogs.py
wxGUI/import dlg: fix closing dialog, #2243
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-04-03 15:46:25 UTC (rev 59570)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-04-04 14:10:42 UTC (rev 59571)
@@ -1792,6 +1792,11 @@
         pass
+    def OnCmdDone(self, cmd, returncode):
+        """!Do what has to be done after importing"""
+        pass
 class GdalImportDialog(ImportDialog):
     def __init__(self, parent, giface, ogr = False, link = False):
         """!Dialog for bulk import of various raster/vector data
@@ -1855,12 +1860,12 @@
         ext  = self.dsnInput.GetFormatExt()
         # determine data driver for PostGIS links
-        popOGR = False
+        self.popOGR = False
         if self.importType == 'ogr' and \
                 self.dsnInput.GetType() == 'db' and \
                 self.dsnInput.GetFormat() == 'PostgreSQL' and \
                 'GRASS_VECTOR_OGR' not in os.environ:
-            popOGR = True
+            self.popOGR = True
             os.environ['GRASS_VECTOR_OGR'] = '1'
         for layer, output in data:
@@ -1904,14 +1909,21 @@
                 cmd.append('--overwrite')
             # run in Layer Manager
-            self._giface.RunCmd(cmd, onDone=self.AddLayers)
-        if popOGR:
+            self._giface.RunCmd(cmd, onDone=self.OnCmdDone)
+        """!Load layers and close if required"""
+        if not hasattr(self, 'AddLayers'):
+            return
+        self.AddLayers(cmd, returncode)
+        if self.popOGR:
             os.environ.pop('GRASS_VECTOR_OGR')
-        if self.closeOnFinish.IsChecked():
+        if returncode == 0 and self.closeOnFinish.IsChecked():
             self.Close()
     def _getCommand(self):
         """!Get command"""
         if self.link:
@@ -2066,10 +2078,18 @@
-        self.Close()
+            return
+        if self.closeOnFinish.IsChecked():
+            self.Close()
     def OnSetDsn(self, event):
         """!Input DXF file defined, update list of layer widget"""
         path = event.GetString()
