[GRASS-SVN] r59614 - grass/branches/releasebranch_7_0/vector/v.out.svg
Sun Apr 6 15:03:57 PDT 2014
Author: neteler
Date: 2014-04-06 15:03:56 -0700 (Sun, 06 Apr 2014)
New Revision: 59614
   grass/branches/releasebranch_7_0/vector/v.out.svg/main.c
v.out.svg: fix msg string format
Modified: grass/branches/releasebranch_7_0/vector/v.out.svg/main.c
--- grass/branches/releasebranch_7_0/vector/v.out.svg/main.c	2014-04-06 22:02:55 UTC (rev 59613)
+++ grass/branches/releasebranch_7_0/vector/v.out.svg/main.c	2014-04-06 22:03:56 UTC (rev 59614)
@@ -214,7 +214,7 @@
     /* extract areas if any or requested */
     if (type == TYPE_POLY) {
 	if (Vect_get_num_areas(&In) == 0) {
-	    G_warning(_("No areas found, skipping %"), "type=poly");
+	    G_warning(_("No areas found, skipping %s"), "type=poly");
 	else {
             int nareas;
