[GRASS-SVN] r59673 - in grass/trunk: man raster/r.in.gdal tools
Thu Apr 10 11:09:49 PDT 2014
Author: martinl
Date: 2014-04-10 11:09:48 -0700 (Thu, 10 Apr 2014)
New Revision: 59673
   grass/trunk/man/grassdocs.css
   grass/trunk/raster/r.in.gdal/r.in.gdal.html
   grass/trunk/tools/mkhtml.py
write toc for manuals
Modified: grass/trunk/man/grassdocs.css
--- grass/trunk/man/grassdocs.css	2014-04-10 17:31:53 UTC (rev 59672)
+++ grass/trunk/man/grassdocs.css	2014-04-10 18:09:48 UTC (rev 59673)
@@ -14,6 +14,7 @@
     background: white;
     color: black;
     font-family: arial,sans-serif;
+    width: 80%;
 h1{
@@ -49,7 +50,7 @@
 div.code{
-    width: 95%;
+    width: 100%;
     color : black;
     background-color: rgb(90%, 90%, 90%);
     padding-left: 1em;
@@ -86,3 +87,19 @@
 td {
     padding: 5px;
+table.toc{
+    background-color: transparent;
+    position: fixed;
+    border: solid 1px rgb(25%, 60%, 25%);
+    top: 5px;
+    right: 5px;
+    width: 17%;
+    font-weight: bold;
+    font-family: arial,sans-serif;
+a.toc {
+    color: rgb(25%, 60%, 25%);
+    text-decoration: none;
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html	2014-04-10 17:31:53 UTC (rev 59672)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html	2014-04-10 18:09:48 UTC (rev 59673)
@@ -4,12 +4,10 @@
 or imagery group, from any GDAL supported raster map format, with an optional
 title. The imported file may also be optionally used to create a new location.
-<!--<h2>OPTIONS</h2>
 Extended explanations:
-<h3>Flags:</h3>
 <dt><b>-e</b>
 <dd>Extend the DEFAULT_WIND in PERMANENT mapset to include the region of
 the new map layer.  Old resolution is preserved, but the region, and rows/cols
Modified: grass/trunk/tools/mkhtml.py
--- grass/trunk/tools/mkhtml.py	2014-04-10 17:31:53 UTC (rev 59672)
+++ grass/trunk/tools/mkhtml.py	2014-04-10 18:09:48 UTC (rev 59673)
@@ -2,12 +2,12 @@
-# MODULE:       mkhtml.py
+# MODULE:       Builds manual pages
 # AUTHOR(S):    Markus Neteler
 #               Glynn Clements
 #               Martin Landa <landa.martin gmail.com>
 # PURPOSE:      Create HTML manual page snippets
-# COPYRIGHT:    (C) 2007, 2009, 2011-2012 by Glynn Clements
+# COPYRIGHT:    (C) 2007-2014 by Glynn Clements
 #                and the GRASS Development Team
 #               This program is free software under the GNU General
@@ -21,6 +21,7 @@
 import string
 import re
 from datetime import datetime
+from HTMLParser import HTMLParser
 pgm = sys.argv[1]
@@ -70,6 +71,53 @@
     except IOError:
         return ""
+def create_toc(src_data):
+    class MyHTMLParser(HTMLParser):
+        def __init__(self):
+            self.reset()
+            self.idx = 1
+            self.tag = ''
+            self.data = []
+        def handle_starttag(self, tag, attrs):
+            self.tag = tag
+        def handle_endtag(self, tag):
+            self.tag = ''
+        def handle_data(self, data):
+            if self.tag in ('h1', 'h2', 'h3'):
+                self.data.append((self.tag, '%s_%d' % (self.tag, self.idx), data))
+                self.idx += 1
+    # instantiate the parser and fed it some HTML
+    parser = MyHTMLParser()
+    parser.feed(src_data)
+    return parser.data
+def write_toc(data):
+    fd = sys.stdout
+    fd.write('<table class="toc">\n')
+    for tag, href, text in data:
+        fd.write('<tr><td>%s <a href="#%s" class="toc">%s</a></td></tr>\n' % \
+                     ('  ' if tag == 'h3' else '', href, text))
+    fd.write('</table>\n')
+def update_toc(data):
+    ret_data = []
+    pat = re.compile(r'(<(h\d)>)(.+)(</h\d>)')
+    idx = 1
+    for line in data.splitlines():
+        if pat.search(line):
+            xline = pat.split(line)
+            line = xline[1] + '<a name="%s_%d">' % (xline[2], idx) + xline[3] + '</a>' + xline[4]
+            idx += 1
+        ret_data.append(line)
+    return '\n'.join(ret_data)
+# process header
 src_data = read_file(src_file)
 name = re.search('(<!-- meta page name:)(.*)(-->)', src_data, re.IGNORECASE)
 if name:
@@ -90,8 +138,12 @@
             if not re.search('</body>|</html>', line, re.IGNORECASE):
                 sys.stdout.write(line)
-sys.stdout.write(src_data)
+# create TOC
+write_toc(create_toc(src_data))
+# process body
+sys.stdout.write(update_toc(src_data))
 # if </html> is found, suppose a complete html is provided.
 # otherwise, generate module class reference:
 if re.search('</html>', src_data, re.IGNORECASE):
@@ -112,6 +164,7 @@
     'v' : 'vector'
+# process footer
 index = re.search('(<!-- meta page index:)(.*)(-->)', src_data, re.IGNORECASE)
 if index:
     index_name_cap = index_name = index.group(2).strip()
