[GRASS-SVN] r59812 - in grass/branches/releasebranch_7_0: man tools
Sat Apr 19 11:38:08 PDT 2014
Author: martinl
Date: 2014-04-19 11:38:08 -0700 (Sat, 19 Apr 2014)
New Revision: 59812
   grass/branches/releasebranch_7_0/man/build_html.py
   grass/branches/releasebranch_7_0/man/grassdocs.css
   grass/branches/releasebranch_7_0/tools/mkhtml.py
Backport TOC manual generation from trunk
Modified: grass/branches/releasebranch_7_0/man/build_html.py
--- grass/branches/releasebranch_7_0/man/build_html.py	2014-04-19 18:33:48 UTC (rev 59811)
+++ grass/branches/releasebranch_7_0/man/build_html.py	2014-04-19 18:38:08 UTC (rev 59812)
@@ -48,7 +48,7 @@
 header2_tmpl = string.Template(\
 r""" <link rel="stylesheet" href="grassdocs.css" type="text/css">
 </head>
-<body bgcolor="#FFFFFF">
+<body style="width: 99%">
 <!-- this file is generated by man/build_html.py -->
@@ -249,7 +249,7 @@
 r"""
 </head>
-<body bgcolor="white">
 <img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
 <h2>Topics</h2>
@@ -261,7 +261,7 @@
 r"""
 </head>
 <h2>Keywords - Index of GRASS GIS modules</h2>
Modified: grass/branches/releasebranch_7_0/man/grassdocs.css
--- grass/branches/releasebranch_7_0/man/grassdocs.css	2014-04-19 18:33:48 UTC (rev 59811)
+++ grass/branches/releasebranch_7_0/man/grassdocs.css	2014-04-19 18:38:08 UTC (rev 59812)
@@ -14,6 +14,7 @@
     background: white;
     color: black;
     font-family: arial,sans-serif;
+    width: 80%;
 h1{
@@ -49,7 +50,7 @@
 div.code{
-    width: 95%;
+    width: 100%;
     color : black;
     background-color: rgb(90%, 90%, 90%);
     padding-left: 1em;
@@ -86,3 +87,32 @@
 td {
     padding: 5px;
+div.toc{
+    background-color: transparent;
+    position: fixed;
+    border: solid 1px rgb(25%, 60%, 25%);
+    top: 5px;
+    right: 5px;
+    width: 17%;
+    line-height: 120%;
+    font-weight: bold;
+    font-size: small;
+    font-family: arial,sans-serif;
+li.toc {
+   margin-left: -15px;
+   padding: 3px 3px; 3px; 3px;
+   color: rgb(25%, 60%, 25%);
+ul.toc {
+   margin-top: 3px;
+   margin-bottom: 3px;
+a.toc {
+    text-decoration: none;
Modified: grass/branches/releasebranch_7_0/tools/mkhtml.py
--- grass/branches/releasebranch_7_0/tools/mkhtml.py	2014-04-19 18:33:48 UTC (rev 59811)
+++ grass/branches/releasebranch_7_0/tools/mkhtml.py	2014-04-19 18:38:08 UTC (rev 59812)
@@ -2,12 +2,12 @@
-# MODULE:       mkhtml.py
+# MODULE:       Builds manual pages
 # AUTHOR(S):    Markus Neteler
 #               Glynn Clements
 #               Martin Landa <landa.martin gmail.com>
 # PURPOSE:      Create HTML manual page snippets
-# COPYRIGHT:    (C) 2007, 2009, 2011-2012 by Glynn Clements
+# COPYRIGHT:    (C) 2007-2014 by Glynn Clements
 #                and the GRASS Development Team
 #               This program is free software under the GNU General
@@ -21,6 +21,7 @@
 import string
 import re
 from datetime import datetime
+from HTMLParser import HTMLParser
 pgm = sys.argv[1]
@@ -61,6 +62,7 @@
 </html>
 def read_file(name):
     try:
         f = open(name, 'rb')
@@ -70,11 +72,101 @@
     except IOError:
         return ""
+def create_toc(src_data):
+    class MyHTMLParser(HTMLParser):
+        def __init__(self):
+            self.reset()
+            self.idx = 1
+            self.tag_curr = ''
+            self.tag_last = ''
+            self.process_text = False
+            self.data = []
+            self.tags_allowed = ('h1', 'h2', 'h3')
+            self.tags_ignored = ('img')
+            self.text = ''
+        def handle_starttag(self, tag, attrs):
+            if tag in self.tags_allowed:
+                self.process_text = True
+            self.tag_last = self.tag_curr
+            self.tag_curr = tag
+        def handle_endtag(self, tag):
+                self.data.append((tag, '%s_%d' % (tag, self.idx),
+                                  self.text))
+                self.idx += 1
+                self.text = ''
+            self.tag_curr = self.tag_last
+        def handle_data(self, data):
+            if not self.process_text:
+                return
+            if self.tag_curr in self.tags_allowed or self.tag_curr in self.tags_ignored:
+                self.text += data
+            else:
+                self.text += '<%s>%s</%s>' % (self.tag_curr, data, self.tag_curr)
+    # instantiate the parser and fed it some HTML
+    parser = MyHTMLParser()
+    parser.feed(src_data)
+    return parser.data
+def write_toc(data):
+    if not data:
+        return
+    fd = sys.stdout
+    fd.write('<div class="toc">\n')
+    fd.write('<ul class="toc">\n')
+    first = True
+    in_h3 = False
+    indent = 4
+    for tag, href, text in data:
+        if tag == 'h3' and not in_h3:
+            fd.write('\n%s<ul class="toc">\n' % (' ' * indent))
+            indent += 4
+            in_h3 = True
+        elif not first:
+            fd.write('</li>\n')
+        if tag == 'h2' and in_h3:
+            indent -= 4
+            fd.write('%s</ul></li>\n' % (' ' * indent))
+            in_h3 = False
+        fd.write('%s<li class="toc"><a href="#%s" class="toc">%s</a>' % \
+                     (' ' * indent, href, text))
+        first = False
+    fd.write('</li>\n</ul>\n')
+    fd.write('</div>\n')
+def update_toc(data):
+    ret_data = []
+    pat = re.compile(r'(<(h\d)>)(.+)(</h\d>)')
+    idx = 1
+    for line in data.splitlines():
+        if pat.search(line):
+            xline = pat.split(line)
+            line = xline[1] + '<a name="%s_%d">' % (xline[2], idx) + xline[3] + '</a>' + xline[4]
+            idx += 1
+        ret_data.append(line)
+    return '\n'.join(ret_data)
+# process header
 src_data = read_file(src_file)
 name = re.search('(<!-- meta page name:)(.*)(-->)', src_data, re.IGNORECASE)
 if name:
     pgm = name.group(2).strip().split('-', 1)[0].strip()
-desc = re.search('(<!-- meta page description:)(.*)(-->)', src_data, re.IGNORECASE)
+desc = re.search('(<!-- meta page description:)(.*)(-->)', src_data,
+                 re.IGNORECASE)
 if desc:
     pgm = desc.group(2).strip()
     header_tmpl = string.Template(header_base + header_nopgm)
@@ -84,14 +176,18 @@
 if not re.search('<html>', src_data, re.IGNORECASE):
     tmp_data = read_file(tmp_file)
     if not re.search('<html>', tmp_data, re.IGNORECASE):
-        sys.stdout.write(header_tmpl.substitute(PGM = pgm))
+        sys.stdout.write(header_tmpl.substitute(PGM=pgm))
     if tmp_data:
         for line in tmp_data.splitlines(True):
             if not re.search('</body>|</html>', line, re.IGNORECASE):
                 sys.stdout.write(line)
-sys.stdout.write(src_data)
+# create TOC
+write_toc(create_toc(src_data))
+# process body
+sys.stdout.write(update_toc(src_data))
 # if </html> is found, suppose a complete html is provided.
 # otherwise, generate module class reference:
 if re.search('</html>', src_data, re.IGNORECASE):
@@ -112,6 +208,7 @@
     'v' : 'vector'
+# process footer
 index = re.search('(<!-- meta page index:)(.*)(-->)', src_data, re.IGNORECASE)
 if index:
     index_name_cap = index_name = index.group(2).strip()
@@ -120,13 +217,16 @@
     index_name = index_names.get(mod_class, '')
     index_name_cap = index_name.title()
-grass_version = os.getenv("VERSION_NUMBER", "unknown")
+grass_version = os.getenv("VERSION_NUMBER", "unknown")
 year = os.getenv("VERSION_DATE")
 if not year:
     year = str(datetime.now().year)
 if index_name:
-    sys.stdout.write(footer_index.substitute(INDEXNAME = index_name, INDEXNAMECAP = index_name_cap,
-                                             YEAR = year, GRASS_VERSION = grass_version))
+    sys.stdout.write(footer_index.substitute(INDEXNAME=index_name,
+                                             INDEXNAMECAP=index_name_cap,
+                                             YEAR=year,
+                                             GRASS_VERSION=grass_version))
 else:
-    sys.stdout.write(footer_noindex.substitute(YEAR = year, GRASS_VERSION = grass_version))
+    sys.stdout.write(footer_noindex.substitute(YEAR=year,
