[GRASS-SVN] r59948 - grass/branches/releasebranch_7_0/lib/python/pygrass/docs
Sat Apr 26 06:59:51 PDT 2014
Author: neteler
Date: 2014-04-26 06:59:51 -0700 (Sat, 26 Apr 2014)
New Revision: 59948
   grass/branches/releasebranch_7_0/lib/python/pygrass/docs/Makefile
   grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst
pygrass docs: enable 'make html' in virtual GRASS session; update copyright year/version; fix progman link
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/Makefile
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/Makefile	2014-04-26 13:59:08 UTC (rev 59947)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/Makefile	2014-04-26 13:59:51 UTC (rev 59948)
@@ -1,5 +1,8 @@
 # Makefile for Sphinx documentation
+MODULE_TOPDIR=../../../..
+include $(MODULE_TOPDIR)/include/Make/Vars.make
+include $(MODULE_TOPDIR)/include/Make/Rules.make
 # You can set these variables from the command line.
 SPHINXOPTS    =
@@ -12,6 +15,8 @@
 PAPER         =
 BUILDDIR      = _build
+MYGISBASE = $(GISBASE)
 # Internal variables.
 PAPEROPT_a4     = -D latex_paper_size=a4
 PAPEROPT_letter = -D latex_paper_size=letter
@@ -21,6 +26,8 @@
 .PHONY: help clean html dirhtml singlehtml pickle json htmlhelp qthelp devhelp epub latex latexpdf text man changes linkcheck doctest gettext
+.DEFAULT_GOAL := help
 help:
 	@echo "Please use \`make <target>' where <target> is one of"
 	@echo "  html       to make standalone HTML files"
@@ -47,38 +54,38 @@
 	-rm -rf $(BUILDDIR)/*
 html:
-	$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
+	$(call run_grass,$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html)
 	@echo
-	@echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/html/"
 dirhtml:
-	$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
+	$(call run_grass,$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml)
 	@echo
-	@echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml/"
 singlehtml:
-	$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
+	$(call run_grass,$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml)
 	@echo
-	@echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
+	@echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml/"
 pickle:
-	$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
+	$(call run_grass,$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle)
 	@echo
-	@echo "Build finished; now you can process the pickle files."
+	@echo "Build finished; now you can process the pickle files in $(BUILDDIR)/pickle/."
 json:
-	$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
+	$(call run_grass,$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json)
 	@echo
-	@echo "Build finished; now you can process the JSON files."
+	@echo "Build finished; now you can process the JSON files in $(BUILDDIR)/json/"
 htmlhelp:
-	$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
+	$(call run_grass,$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp)
 	@echo
 	@echo "Build finished; now you can run HTML Help Workshop with the" \
-	      ".hhp project file in $(BUILDDIR)/htmlhelp."
+	      ".hhp project file in $(BUILDDIR)/htmlhelp/"
 qthelp:
-	$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
+	$(call run_grass,$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp)
 	@echo
 	@echo "Build finished; now you can run "qcollectiongenerator" with the" \
 	      ".qhcp project file in $(BUILDDIR)/qthelp, like this:"
@@ -87,7 +94,7 @@
 	@echo "# assistant -collectionFile $(BUILDDIR)/qthelp/PyGrass.qhc"
 devhelp:
-	$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
+	$(call run_grass,$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp)
 	@echo
 	@echo "Build finished."
 	@echo "To view the help file:"
@@ -96,63 +103,63 @@
 	@echo "# devhelp"
 epub:
-	$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
+	$(call run_grass,$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub)
 	@echo
-	@echo "Build finished. The epub file is in $(BUILDDIR)/epub."
+	@echo "Build finished. The epub file is in $(BUILDDIR)/epub/"
 latex:
-	$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
+	$(call run_grass,$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex)
 	@echo
 	@echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
 	@echo "Run \`make' in that directory to run these through (pdf)latex" \
 	      "(use \`make latexpdf' here to do that automatically)."
 latexpdf:
 	@echo "Running LaTeX files through pdflatex..."
 	$(MAKE) -C $(BUILDDIR)/latex all-pdf
-	@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
+	@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex/"
 text:
-	$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
+	$(call run_grass,$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text)
 	@echo
-	@echo "Build finished. The text files are in $(BUILDDIR)/text."
+	@echo "Build finished. The text files are in $(BUILDDIR)/text/"
 man:
-	$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
+	$(call run_grass,$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man)
 	@echo
-	@echo "Build finished. The manual pages are in $(BUILDDIR)/man."
+	@echo "Build finished. The manual pages are in $(BUILDDIR)/man/"
 texinfo:
-	$(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo
+	$(call run_grass,$(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo)
 	@echo
 	@echo "Build finished. The Texinfo files are in $(BUILDDIR)/texinfo."
 	@echo "Run \`make' in that directory to run these through makeinfo" \
 	      "(use \`make info' here to do that automatically)."
 info:
 	@echo "Running Texinfo files through makeinfo..."
 	make -C $(BUILDDIR)/texinfo info
-	@echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo."
+	@echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo/"
 gettext:
-	$(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale
+	$(call run_grass,$(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale)
 	@echo
-	@echo "Build finished. The message catalogs are in $(BUILDDIR)/locale."
+	@echo "Build finished. The message catalogs are in $(BUILDDIR)/locale/"
 changes:
-	$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
+	$(call run_grass,$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes)
 	@echo
-	@echo "The overview file is in $(BUILDDIR)/changes."
+	@echo "The overview file is in $(BUILDDIR)/changes/"
 linkcheck:
-	$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
+	$(call run_grass,$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck)
 	@echo
 	@echo "Link check complete; look for any errors in the above output " \
 	      "or in $(BUILDDIR)/linkcheck/output.txt."
 doctest:
-	$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
+	$(call run_grass,$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest)
 	@echo "Testing of doctests in the sources finished, look at the " \
 	      "results in $(BUILDDIR)/doctest/output.txt."
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py	2014-04-26 13:59:08 UTC (rev 59947)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py	2014-04-26 13:59:51 UTC (rev 59948)
@@ -43,14 +43,14 @@
 # General information about the project.
 project = u'PyGrass'
-copyright = u'2012, Pietro Zambelli'
+copyright = u'2012-2014, Pietro Zambelli'
 # The version info for the project you're documenting, acts as replacement for
 # |version| and |release|, also used in various other places throughout the
 # built documents.
 # The short X.Y version.
-version = '0.1'
+version = '0.2'
 # The full version, including alpha/beta/rc tags.
 release = 'alpha'
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst	2014-04-26 13:59:08 UTC (rev 59947)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst	2014-04-26 13:59:51 UTC (rev 59948)
@@ -392,7 +392,7 @@
 .. autoclass:: pygrass.raster.category.Category
     :members:
-.. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html/
+.. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html
 .. _RowIO library: http://grass.osgeo.org/programming7/rowiolib.html
 .. _Segmentation library: http://grass.osgeo.org/programming7/segmentlib.html
 .. _numpy.memmap: http://docs.scipy.org/doc/numpy/reference/generated/numpy.memmap.html
