[GRASS-SVN] r61565 - grass/trunk/lib/raster3d
Fri Aug 8 10:08:05 PDT 2014
Author: annakrat
Date: 2014-08-08 10:08:05 -0700 (Fri, 08 Aug 2014)
New Revision: 61565
   grass/trunk/lib/raster3d/gradient.c
libraster3d/gradient: do not ignore nulls completely
Modified: grass/trunk/lib/raster3d/gradient.c
--- grass/trunk/lib/raster3d/gradient.c	2014-08-08 17:05:30 UTC (rev 61564)
+++ grass/trunk/lib/raster3d/gradient.c	2014-08-08 17:08:05 UTC (rev 61565)
@@ -35,61 +35,115 @@
 			    RASTER3D_Array_double *grad_z)
     int col, row, depth;
+    double val;
     for (depth = 0; depth < array->sz; depth++) {
 	for (row = 0; row < array->sy; row++) {
-	    RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth) =
-		(-3 * RASTER3D_ARRAY_ACCESS(array, 0, row, depth) +
-		 4 * RASTER3D_ARRAY_ACCESS(array, 1, row, depth) -
-		 RASTER3D_ARRAY_ACCESS(array, 2, row, depth)) / (2 * step[0]);
+	    /* row start */
+	    val = RASTER3D_ARRAY_ACCESS(array, 0, row, depth);
+	    if (Rast_is_d_null_value(&val))
+		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth),
+				    1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth) =
+			(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, 1, row, depth) -
+			 RASTER3D_ARRAY_ACCESS(array, 2, row, depth)) / (2 * step[0]);
-	    RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth) =
-		(3 * RASTER3D_ARRAY_ACCESS(array, array->sx - 1, row, depth) -
-		 4 * RASTER3D_ARRAY_ACCESS(array, array->sx - 2, row, depth) +
-		 RASTER3D_ARRAY_ACCESS(array, array->sx - 3, row, depth)) / (2 * step[0]);
+	    /* row end */
+	    val = RASTER3D_ARRAY_ACCESS(array, array->sx - 1, row, depth);
+			&RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth),
+			1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth) =
+			(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, array->sx - 2, row, depth) +
+			 RASTER3D_ARRAY_ACCESS(array, array->sx - 3, row, depth)) / (2 * step[0]);
+	    /* row */
 	    for (col = 1; col < array->sx - 1; col++) {
-		RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth) =
-		    (RASTER3D_ARRAY_ACCESS(array, col + 1, row, depth) -
-		     RASTER3D_ARRAY_ACCESS(array, col - 1, row, depth)) / (2 * step[0]);
+		val = RASTER3D_ARRAY_ACCESS(array, col, row, depth);
+			    &RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth),
+			    1, DCELL_TYPE);
+		else
+		    RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth) =
+			    (RASTER3D_ARRAY_ACCESS(array, col + 1, row, depth) -
+			     RASTER3D_ARRAY_ACCESS(array, col - 1, row, depth)) / (2 * step[0]);
 	for (col = 0; col < array->sx; col++) {
-	    RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth) =
-		-(-3 * RASTER3D_ARRAY_ACCESS(array, col, 0, depth) +
-		  4 * RASTER3D_ARRAY_ACCESS(array, col, 1, depth) -
-		  RASTER3D_ARRAY_ACCESS(array, col, 2, depth)) / (2 * step[1]);
+	    /* col start */
+	    val = RASTER3D_ARRAY_ACCESS(array, col, 0, depth);
+		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth),
+				    1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth) =
+			-(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, col, 1, depth) -
+			  RASTER3D_ARRAY_ACCESS(array, col, 2, depth)) / (2 * step[1]);
-	    RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth) =
-		-(3 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 1, depth) -
-		  4 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 2, depth) +
-		  RASTER3D_ARRAY_ACCESS(array, col, array->sy - 3, depth)) / (2 * step[1]);
+	    /* col end */
+	    val = RASTER3D_ARRAY_ACCESS(array, col, array->sy - 1, depth);
+			&RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth),
+			1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth) =
+			-(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 2, depth) +
+			  RASTER3D_ARRAY_ACCESS(array, col, array->sy - 3, depth)) / (2 * step[1]);
+	    /* col */
 	    for (row = 1; row < array->sy - 1; row++) {
-		RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth) =
-		    -(RASTER3D_ARRAY_ACCESS(array, col, row + 1, depth) -
-		      RASTER3D_ARRAY_ACCESS(array, col, row - 1, depth)) / (2 * step[1]);
+			    &RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth),
+			    1, DCELL_TYPE);
+		else
+		    RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth) =
+			    -(RASTER3D_ARRAY_ACCESS(array, col, row + 1, depth) -
+			      RASTER3D_ARRAY_ACCESS(array, col, row - 1, depth)) / (2 * step[1]);
-	    RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0) =
-		(-3 * RASTER3D_ARRAY_ACCESS(array, col, row, 0) +
-		 4 * RASTER3D_ARRAY_ACCESS(array, col, row, 1) -
-		 RASTER3D_ARRAY_ACCESS(array, col, row, 2)) / (2 * step[2]);
+	    /* vertical col start */
+	    val = RASTER3D_ARRAY_ACCESS(array, col, row, 0);
+		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0),
+				    1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0) =
+			(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, col, row, 1) -
+			 RASTER3D_ARRAY_ACCESS(array, col, row, 2)) / (2 * step[2]);
-	    RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1) =
-		(3 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 1) -
-		 4 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 2) +
-		 RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 3)) / (2 * step[2]);
+	    /* vertical col end */
+	    val = RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 1);
+			&RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1),
+			1, DCELL_TYPE);
+	    else
+		RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1) =
+			(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 2) +
+			 RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 3)) / (2 * step[2]);
+	    /* vertical col */
 	    for (depth = 1; depth < array->sz - 1; depth++) {
-		RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth) =
-		    (RASTER3D_ARRAY_ACCESS(array, col, row, depth + 1) -
-		     RASTER3D_ARRAY_ACCESS(array, col, row, depth - 1)) / (2 * step[2]);
+			    &RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth),
+			    1, DCELL_TYPE);
+		else
+		    RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth) =
+			    (RASTER3D_ARRAY_ACCESS(array, col, row, depth + 1) -
+			     RASTER3D_ARRAY_ACCESS(array, col, row, depth - 1)) / (2 * step[2]);
