[GRASS-SVN] r61652 - grass/trunk/lib/python/gunittest
Fri Aug 15 12:55:26 PDT 2014
Author: wenzeslaus
Date: 2014-08-15 12:55:26 -0700 (Fri, 15 Aug 2014)
New Revision: 61652
   grass/trunk/lib/python/gunittest/invoker.py
   grass/trunk/lib/python/gunittest/loader.py
gunittest: do not import test file, support also sh files
Implemented quickly and simply on the cost of loosing support for unittest-like discovery and execution. It can be added back again using the old code.
Also the support for different location tests was dropped for now because parsing of the file to get the location type is missing (attribute access after import was used before). This has to be implemented anyway. However, for now support for scripts seems to be a more important feature.
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py	2014-08-15 18:59:59 UTC (rev 61651)
+++ grass/trunk/lib/python/gunittest/invoker.py	2014-08-15 19:55:26 UTC (rev 61652)
@@ -149,12 +149,17 @@
         self.reporter.start_file_test(module)
         # TODO: we might clean the directory here before test if non-empty
-        # TODO: use some grass function to run?
-        # add also '-Qwarn'?
-        p = subprocess.Popen([sys.executable, '-tt', '-3',
-                              module.abs_file_path],
-                             cwd=cwd, env=env,
-                             stdout=stdout, stderr=stderr)
+        if module.file_type == 'py':
+            # add also '-Qwarn'?
+            p = subprocess.Popen([sys.executable, '-tt', '-3',
+                                  module.abs_file_path],
+                                 cwd=cwd, env=env,
+                                 stdout=stdout, stderr=stderr)
+        else:
+            p = subprocess.Popen([module.abs_file_path],
+                                 cwd=cwd, env=env,
         returncode = p.wait()
         stdout.close()
         stderr.close()
@@ -192,7 +197,7 @@
         # TODO: move constants out of loader class or even module
         modules = discover_modules(start_dir=self.start_dir,
                                    grass_location=location_type,
-                                   file_pattern=GrassTestLoader.files_in_testsuite,
+                                   file_regexp=r'.*\.(py|sh)$',
                                    skip_dirs=GrassTestLoader.skip_dirs,
                                    testsuite_dir=GrassTestLoader.testsuite_dir,
                                    all_locations_value=GrassTestLoader.all_tests_value,
Modified: grass/trunk/lib/python/gunittest/loader.py
--- grass/trunk/lib/python/gunittest/loader.py	2014-08-15 18:59:59 UTC (rev 61651)
+++ grass/trunk/lib/python/gunittest/loader.py	2014-08-15 19:55:26 UTC (rev 61652)
@@ -12,26 +12,27 @@
 import os
-import sys
 import fnmatch
 import unittest
 import collections
-import importlib
+import re
 # TODO: resolve test file versus test module
 GrassTestPythonModule = collections.namedtuple('GrassTestPythonModule',
                                                ['name', 'module',
+                                                'file_type',
                                                 'tested_dir',
                                                 'file_dir',
                                                 'abs_file_path'])
 # TODO: implement loading without the import
-def discover_modules(start_dir, file_pattern, skip_dirs, testsuite_dir,
+def discover_modules(start_dir, skip_dirs, testsuite_dir,
                      grass_location,
                      all_locations_value, universal_location_value,
-                     import_modules, add_failed_imports=True):
+                     import_modules, add_failed_imports=True,
+                     file_pattern=None, file_regexp=None):
     """Find all test files (modules) in a directory tree.
     The function is designed specifically for GRASS testing framework
@@ -69,32 +70,50 @@
         if testsuite_dir in dirs:
             dirs.remove(testsuite_dir)  # do not recurse to testsuite
             full = os.path.join(root, testsuite_dir)
-            files = fnmatch.filter(os.listdir(full), file_pattern)
+            all_files = os.listdir(full)
+            if file_pattern:
+                files = fnmatch.filter(all_files, file_pattern)
+            if file_regexp:
+                files = [f for f in all_files if re.match(file_regexp, f)]
             # get test/module name without .py
             # extecting all files to end with .py
             # this will not work for invoking bat files but it works fine
             # as long as we handle only Python files (and using Python
             # interpreter for invoking)
-            # we always ignore __init__.py
-            module_names = [f[:-3] for f in files if not f == '__init__.py']
-            # TODO: warning (in what way?) about no tests in testsuite
-            for name in module_names:
-                # TODO: rewrite to use import_module and search the file if not
-                # TODO: do it without importing
-                # TODO: check if there is some main
+            # TODO: warning about no tests in a testsuite
+            # (in what way?)
+            for file_name in files:
+                # TODO: add also import if requested
+                # (see older versions of this file)
+                # TODO: check if there is some main in .py
                 # otherwise we can have successful test just because
                 # everything was loaded into Python
+                # TODO: check if there is set -e or exit !0 or ?
+                # otherwise we can have successful because nothing was reported
                 abspath = os.path.abspath(full)
-                sys.path.insert(0, abspath)
+                abs_file_path = os.path.join(abspath, file_name)
+                if file_name.endswith('.py'):
+                    if file_name == '__init__.py':
+                        # we always ignore __init__.py
+                        continue
+                    file_type = 'py'
+                    name = file_name[:-3]
+                elif file_name.endswith('.sh'):
+                    file_type = 'sh'
+                else:
+                    file_type = None  # alternative would be '', now equivalent
+                    name = file_name
                 add = False
                 try:
-                    m = importlib.import_module(name)
-                    # TODO: now we are always importing but also always setting module to None
                     if grass_location == all_locations_value:
                         add = True
                     else:
                         try:
-                            locations = m.LOCATIONS
+                            locations = ['nc']
                         except AttributeError:
                             add = True  # test is universal
                         else:
@@ -102,6 +121,8 @@
                                 add = True  # cases when it is explicit
                             if grass_location in locations:
                                 add = True  # standard case with given location
+                            if not locations:
+                                add = True  # count not specified as universal
                 except ImportError as e:
                     if add_failed_imports:
                         add = True
@@ -114,7 +135,7 @@
                 if add:
                     modules.append(GrassTestPythonModule(
                         name=name, module=None, tested_dir=root, file_dir=full,
-                        abs_file_path=os.path.join(abspath, name + '.py')))
+                        abs_file_path=abs_file_path, file_type=file_type))
                 # in else with some verbose we could tell about skiped test
     return modules
