[GRASS-SVN] r61666 - in grass/branches/releasebranch_7_0/raster/r.li: . r.li.cwed r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.setup r.li.shannon r.li.shape r.li.simpson
Sun Aug 17 11:02:29 PDT 2014
Author: neteler
Date: 2014-08-17 11:02:29 -0700 (Sun, 17 Aug 2014)
New Revision: 61666
   grass/branches/releasebranch_7_0/raster/r.li/r.li.cwed/r.li.cwed.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.setup/r.li.setup.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html
r.li manual: describe where config files are stored; minor cleanup
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.cwed/r.li.cwed.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.cwed/r.li.cwed.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -22,10 +22,13 @@
 <h2>NOTES</h2>
-Do not use absolute path names for the <b>output</b> map/file.
+Do not use absolute path names for the <b>config</b> and <b>output</b>
+file/map parameters.
 If the "moving window" method was selected in <b>g.gui.rlisetup</b>, then the
 output will be a raster map, otherwise an ASCII file will be generated in
-the <tt>$HOME/.grass7/r.li/output/</tt> folder.
+the folder <tt>C:\Users\normal\AppData\Roaming\GRASS7\r.li\output\</tt>
+(MS-Windows) or <tt>$HOME/.grass7/r.li/output/</tt> (GNU/Linux).
 <p>
 <!-- TODO: verify next: -->
 If the sample area contains only NULL values it is considered to
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.dominance/r.li.dominance.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -12,10 +12,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -24,10 +24,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.edgedensity</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -2,10 +2,12 @@
 <h2>DESCRIPTION</h2>
 The <em>r.li</em> suite is a toolset for multiscale analysis of landscape structure.
-<!-- rephrase reference to r.le which is long time ago ...-->
+<!-- rephrase reference to r.le which is long time ago ...
 It aims at replacing the <em>r.le</em> suite of modules through a client-server,
-multiprocess implementation. External software for quantitative measures of landscape
-structure is for example FRAGSTATS (McGarigal and Marks 1995).
+multiprocess implementation.
+It aims at implementing metrics as found in external software for quantitative
+measures of landscape structure like FRAGSTATS (McGarigal and Marks 1995).
 <p>
 The <em>r.li</em> suite offers a set of patch and diversity indices.
 It supports analysis of landscapes composed of a mosaic of
@@ -27,30 +29,28 @@
 (e.g. frequency distribution of patch sizes in the sampling area). The
 results are stored as raster maps.
-<p>
+<h2>NOTES</h2>
 The general procedure to calculate an index from a raster map is two-fold:
 <ol>
-<li>run <em>g.gui.rlisetup</em>: create a configuration file selecting the parts of
-    raster to analyze.
+<li>run <em>g.gui.rlisetup</em>: create a configuration file selecting
+    the parts of raster map to be analyzed. This file allows to re-run
+    an analysis easily. It is stored on Windows in the directory <tt>C:\Users\normal\AppData\Roaming\GRASS7\r.li\</tt>, on GNU/Linux in
+    <tt>$HOME/.grass7/r.li/</tt>. <!-- TODO: and Mac OSX? -->
 <li>run one or more of the <em>r.li.<b>[index]</b></em> modules (e.g.,
     <em>r.li.<b>patchdensity</b></em>) to calculate the selected index
     using on the areas selected on configuration file.
 </ol>
-<h2>NOTE</h2>
-The <em>r.li.daemon</em> module also has a "main" function front-end
+<!-- mhh ??:
+The <em>r.li.daemon</em> source code has a "main" function front-end
 which can be run, but it is only a template for development of new
-indices so not built by default.
-<!-- mhh ??:
-The function itself has no meaning, it is only useful as an example and
-for debugging.
+indices.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
 Calculate a patch density index on the entire 'geology' raster map
 in the Spearfish sample dataset, using a 5x5 moving window:
@@ -116,7 +116,7 @@
 <b>Core modules</b>:
 <ul>
-  <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon</li>
+  <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon (not visible to the user)</li>
   <li> <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>: Configuration editor for r.li.'index'</li>
 </ul>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.mpa/r.li.mpa.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -13,10 +13,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.mpa</em> considers to
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.mps/r.li.mps.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -23,10 +23,13 @@
 <h2>NOTES</h2>
 <p>
 If the sample area contains only NULL value cells, <em>r.li.mps</em>
 returns 0 (zero). <br>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padcv/r.li.padcv.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -14,10 +14,13 @@
 <h2>NOTES</h2>
 <p>
 The result is NULL if the sample area contains only NULL values.
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padrange/r.li.padrange.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -15,10 +15,13 @@
 <h2>NOTES</h2>
 <p>
 If the sample area contains only NULL values then <em>r.li.padrange</em>
 returns NULL.<br>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.padsd/r.li.padsd.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -16,10 +16,13 @@
 <h2>NOTES</h2>
 <p>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -18,10 +18,13 @@
 <h2>NOTES</h2>
 <p>
 A sample area of only NULL values is considered to have zero patches,
 that is, the result is always ≥ 0.
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -9,10 +9,13 @@
 <h2>NOTES</h2>
 <p>
 If the sample area contains only NULL values then it is considered to
 have zero patches. <br>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.pielou/r.li.pielou.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -11,10 +11,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster contains NULL value cells, <em>r.li.pielou</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.renyi/r.li.renyi.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -14,10 +14,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.renyi</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.richness/r.li.richness.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -12,10 +12,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.richness</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.setup/r.li.setup.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.setup/r.li.setup.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.setup/r.li.setup.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -1,6 +1,9 @@
-<em>g.gui.rlisetup</em>  creates and shows configuration files for the
+<b>DEPRECATED: merge into gui/wxpython/rlisetup/g.gui.rlisetup.html</b>
+<p></p>
+<em>r.li.setup/</em>  creates and shows configuration files for the
 other analytical <em>r.li</em> modules. For a general introduction, see
 <a href="r.li.html">r.li</a>.
 <br>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.shannon/r.li.shannon.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -12,10 +12,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.shannon</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.shape/r.li.shape.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -13,10 +13,13 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.shape</em>
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html	2014-08-17 18:01:28 UTC (rev 61665)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.simpson/r.li.simpson.html	2014-08-17 18:02:29 UTC (rev 61666)
@@ -12,10 +12,12 @@
 <h2>NOTES</h2>
 <p>
 If the input raster map contains only NULL values then <em>r.li.simpson</em>
