[GRASS-SVN] r61745 - grass/branches/releasebranch_7_0/vector/v.distance
Mon Aug 25 22:47:37 PDT 2014
Author: neteler
Date: 2014-08-25 22:47:37 -0700 (Mon, 25 Aug 2014)
New Revision: 61745
   grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html
v.distance manual: more examples
Modified: grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html
--- grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html	2014-08-26 05:47:28 UTC (rev 61744)
+++ grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html	2014-08-26 05:47:37 UTC (rev 61745)
@@ -101,6 +101,7 @@
 points from a vector map as input instead of stdin. A new vector map
 with query points has to be created before the map can be analysed.
 <p>
 Create query map (if not present):
 <div class="code"><pre>
@@ -159,15 +160,47 @@
 v.univar vdistance_vectors column=length
 </pre></div>
+<h3>Print distance between points</h3>
+Example for a Latitude-longitude location (EPSG 4326):
+<div class="code"><pre>
+# points along the equator
+echo "0|-61|1" | v.in.ascii output=pnt1 input=-
+echo "0|-58|1" | v.in.ascii output=pnt2 input=-
+# here, distances is in degree units
+v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
+from_cat|distance
+1|3
+</pre></div>
 <h3>Print distance matrix</h3>
+Note: Matrix-style output is enabled only for flag <em>-a</em> and one
+given upload option.
+<p>
+Spearfish sample data location:
 v.distance -pa from=archsites to=archsites upload=dist col=dist
 </pre></div>
-Note: Matrix-like output is enabled only for flag <b>-a</b> and one
-given upload option.
+<p>
+North Carolina sample data location:
+v.distance -pa from=hospitals to=hospitals upload=dist \
+  col=dist separator=comma
+from_cat to_cat       dist
+              1          2          3          4          5 ...
+1             0    7489.10  339112.17   70900.39   70406.23 ...
+2       7489.10          0  345749.12   76025.46   75538.87 ...
+3     339112.17  345749.12          0  274153.19  274558.98 ...
+4      70900.39   76025.46  274153.19          0     501.11 ...
+5      70406.23   75538.87  274558.98     501.11          0 ...
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
@@ -177,7 +210,7 @@
 </em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
 Janne Soimasuo 1994, University of Joensuu, Faculty of Forestry, Finland<br>
 Cmd line coordinates support: Markus Neteler, ITC-irst, Trento, Italy<br>
