[GRASS-SVN] r63453 - in grass/trunk: imagery/i.smap imagery/i.topo.corr misc/m.cogo raster/r.carve raster/r.colors raster/r.colors.out raster/r.rescale raster/r.rescale.eq vector/v.colors vector/v.colors.out vector/v.vect.stats
Tue Dec 9 10:39:37 PST 2014
Author: neteler
Date: 2014-12-09 10:39:37 -0800 (Tue, 09 Dec 2014)
New Revision: 63453
   grass/trunk/imagery/i.smap/i.smap.html
   grass/trunk/imagery/i.topo.corr/i.topo.corr.html
   grass/trunk/misc/m.cogo/m.cogo.html
   grass/trunk/raster/r.carve/main.c
   grass/trunk/raster/r.carve/r.carve.html
   grass/trunk/raster/r.colors.out/r3.colors.out.html
   grass/trunk/raster/r.colors/r3.colors.html
   grass/trunk/raster/r.rescale.eq/r.rescale.eq.html
   grass/trunk/raster/r.rescale/r.rescale.html
   grass/trunk/vector/v.colors.out/v.colors.out.html
   grass/trunk/vector/v.colors/v.colors.html
   grass/trunk/vector/v.vect.stats/v.vect.stats.html
manual: some cleanup of HTML and examples
Modified: grass/trunk/imagery/i.smap/i.smap.html
--- grass/trunk/imagery/i.smap/i.smap.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/imagery/i.smap/i.smap.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -155,7 +155,7 @@
 # Now digitize training areas "training" with the digitizer
 # and convert to raster model with v.to.rast
-v.to.rast training out=training use=cat labelcolumn=label
+v.to.rast input=training output=training use=cat label_column=label
 # calculate statistics
 i.gensigset trainingmap=training group=my_lsat7_2002 subgroup=my_lsat7_2002 \
Modified: grass/trunk/imagery/i.topo.corr/i.topo.corr.html
--- grass/trunk/imagery/i.topo.corr/i.topo.corr.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/imagery/i.topo.corr/i.topo.corr.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -90,10 +90,10 @@
 <div class="code"><pre>
 # first pass: create illumination model
-i.topo.corr -i base=SRTM zenith=33.3631 azimuth=59.8897 out=SRTM.illumination
+i.topo.corr -i base=SRTM zenith=33.3631 azimuth=59.8897 output=SRTM.illumination
 # second pass: apply illumination model
-i.topo.corr base=SRTM.illumination input=toar.5,toar.4,toar.3 out=tcor \
+i.topo.corr base=SRTM.illumination input=toar.5,toar.4,toar.3 output=tcor \
   zenith=33.3631 method=c-factor
 </pre></div>
Modified: grass/trunk/misc/m.cogo/m.cogo.html
--- grass/trunk/misc/m.cogo/m.cogo.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/misc/m.cogo/m.cogo.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -107,19 +107,19 @@
 <p>
 Round trip:
-   m.cogo -l in=cogo.dat | m.cogo -rl in="-"
+   m.cogo -l input=cogo.dat | m.cogo -rl in="-"
 </pre></div>
 <p>
 Import as a vector points map:
-   m.cogo -l in=cogo.dat | v.in.ascii out=cogo_points x=1 y=2 separator=space
+   m.cogo -l input=cogo.dat | v.in.ascii output=cogo_points x=1 y=2 separator=space
 </pre></div>
 <p>
 Shell script to import as a vector line map:
-   m.cogo -l in=cogo.dat | tac | awk '
+   m.cogo -l input=cogo.dat | tac | awk '
        BEGIN { FS=" " ; R=0 }
        $1~/\d*\.\d*/ { printf(" %.8f %.8f\n", $1, $2) ; ++R }
        END { printf("L %d\n", R) }' | tac | \
@@ -130,10 +130,10 @@
 Convert that lines map into an area:
    # Add the -c flag to the above example to close the loop:
-   m.cogo -l -c in=cogo.dat | ...
+   m.cogo -l -c input=cogo.dat | ...
    v.type input=cogo_line output=cogo_boundary from_type=line to_type=boundary
-   v.centroids in=cogo_boundary out=cogo_area
+   v.centroids input=cogo_boundary output=cogo_area
 </pre></div>
 If necessary, snap the boundary closed with the <em>v.clean</em> module.
Modified: grass/trunk/raster/r.carve/main.c
--- grass/trunk/raster/r.carve/main.c	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.carve/main.c	2014-12-09 18:39:37 UTC (rev 63453)
@@ -210,7 +210,8 @@
 	*wrap_ncols =
 	    (360.0 - (window->east - window->west)) / window->ew_res + 1.1;
 #else
-	G_fatal_error(_("lat/lon projection not supported at this time."));
+	G_fatal_error(_("Lat/Long location is not supported by %s. Please reproject map first."),
+		      G_program_name());
 #endif
     else {
Modified: grass/trunk/raster/r.carve/r.carve.html
--- grass/trunk/raster/r.carve/r.carve.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.carve/r.carve.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -1,16 +1,16 @@
 <h2>DESCRIPTION</h2>
 <em>r.carve</em> accepts vector stream data as input, transforms them to
-raster, and subtracts a defaultdepth+additionaldepth from a DEM. If
+raster, and subtracts a default-depth + additional-depth from a DEM. If
 the given width is more than 1 cell, it will carve the stream with the
-given width. With the -n flag it should eliminate all flat cells within
+given width. With the <b>-n</b> flag it should eliminate all flat cells within
 the stream, so when and if the water gets into the stream it will
 flow. The <em>points</em> option generates x,y,z for points which define the stream
 with the z-value of the bottom of the carved-in stream. These points
 can then be combined with contours to interpolate a new DEM with
 better representation of valleys.
-<h2>NOTE</h2>
+<h2>NOTES</h2>
 <em>r.carve</em> does not create a depressionless DEM because many
 depressions are in flat areas and not in the streams.
@@ -18,9 +18,11 @@
 <h2>EXAMPLE</h2>
+North Carolina sample dataset:
-g.region rast=elevation.10m -p
-r.carve rast=elevation.10m vect=streams out=carve_dem width=20 depth=5
+g.region rast=elevation -p
+r.carve rast=elevation vect=streams out=carve_dem width=20 depth=5
 </pre></div>
 <h2>BUGS</h2>
@@ -37,10 +39,13 @@
 M.  Johnston, GMSL (Report for CERL 1999)
 <h2>SEE ALSO</h2>
-<em><a href="r.flow.html">r.flow</a></em>,
-<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<em><a href="r.watershed.html">r.watershed</a></em>
+<em>
+<a href="r.flow.html">r.flow</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.watershed.html">r.watershed</a>
+</em>
 <h2>AUTHOR</h2>
 Bill Brown (GMSL)<br>
 GRASS 6 update: Brad Douglas
Modified: grass/trunk/raster/r.colors/r3.colors.html
--- grass/trunk/raster/r.colors/r3.colors.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.colors/r3.colors.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -1,19 +1,32 @@
 <em>r3.colors</em> has exactly the same functionality
-as <em>r.colors</em> but for volume maps. Please refer
+as <em>r.colors</em> but for 3D raster maps. Please refer
 to <em><a href="r.colors.html">r.colors</a></em>.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+r3.colors map=volume_1 color=gyr
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
-  <a href="r.colors.html">r.colors</a>,
-  <a href="r.colors.out.html">r.colors.out</a>,
-  <a href="r3.colors.out.html">r3.colors.out</a>,
-  <a href="v.colors.html">v.colors</a>,
-  <a href="v.colors.out.html">v.colors.out</a>
+<a href="r.colors.html">r.colors</a>,
+<a href="r.colors.out.html">r.colors.out</a>,
+<a href="r3.colors.out.html">r3.colors.out</a>,
+<a href="v.colors.html">v.colors</a>,
+<a href="v.colors.out.html">v.colors.out</a>
 </em>
+<p>See also wiki
+page <a href="http://grasswiki.osgeo.org/wiki/Color_tables">Color
+tables</a> (from GRASS User Wiki)
+<p><a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
+help people select good color schemes for maps and other graphics.
 <h2>AUTHORS</h2>
 Michael Shapiro and David Johnson
Modified: grass/trunk/raster/r.colors.out/r3.colors.out.html
--- grass/trunk/raster/r.colors.out/r3.colors.out.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.colors.out/r3.colors.out.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -1,7 +1,7 @@
 <em>r3.colors.out</em> allows the user to export the color table for a
-raster3d map to a file which is suitable as input
+3D raste map to a file which is suitable as input
 to <em><a href="r3.colors.html">r3.colors</a></em>.
 <h2>EXAMPLES</h2>
@@ -14,11 +14,15 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="r3.colors.html">r3.colors</a>
-  <a href="r.colors.out.html">r.colors</a>
+<a href="r3.colors.html">r3.colors</a>
 </em>
 <h2>AUTHOR</h2>
 Glynn Clements
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.rescale/r.rescale.html
--- grass/trunk/raster/r.rescale/r.rescale.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.rescale/r.rescale.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -1,7 +1,7 @@
 The <em>r.rescale</em> program rescales the range of
-category values appearing in a raster map layer.  A new
+category values appearing in a raster map layer. A new
 raster map layer, and an appropriate category file and
 color table based upon the original raster map layer, are
 generated with category labels that reflect the original
@@ -10,7 +10,7 @@
 number of categories from a raster map layer with a large
 range of category values (e.g., elevation).
 <em>Rescaled</em> map layers are appropriate for use in
-such GRASS programs as
+such GRASS GIS commands as
 <em><a href="r.stats.html">r.stats</a></em>,
 <em><a href="r.report.html">r.report</a></em>, and
@@ -21,7 +21,7 @@
 To rescale an elevation raster map layer with category
 values ranging from 1090 meters to 1800 meters into the
 range 0-255, the following command line could be used
-(without the <em>from</em> parameter, the full value range will
+(without the <em>from</em> parameter, the full value range will
 be used):
@@ -45,15 +45,17 @@
 <h2>SEE ALSO</h2>
-<em><a href="r.coin.html">r.coin</a></em>,
-<em><a href="r.describe.html">r.describe</a></em>,
-<em><a href="r.info.html">r.info</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.reclass.html">r.reclass</a></em>,
-<em><a href="r.rescale.eq.html">r.rescale.eq</a></em>,
-<em><a href="r.report.html">r.report</a></em>,
-<em><a href="r.resample.html">r.resample</a></em>,
-<em><a href="r.stats.html">r.stats</a></em>
+<em>
+<a href="r.coin.html">r.coin</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.rescale.eq.html">r.rescale.eq</a>,
+<a href="r.report.html">r.report</a>,
+<a href="r.resample.html">r.resample</a>,
+<a href="r.stats.html">r.stats</a>
+</em>
 <h2>AUTHOR</h2>
 Michael Shapiro,
Modified: grass/trunk/raster/r.rescale.eq/r.rescale.eq.html
--- grass/trunk/raster/r.rescale.eq/r.rescale.eq.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/raster/r.rescale.eq/r.rescale.eq.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -10,7 +10,7 @@
@@ -46,15 +46,17 @@
 <h2>SEE ALSO</h2>
-<em><a href="r.rescale.html">r.rescale</a></em>,
+<em>
+<a href="r.rescale.html">r.rescale</a>,
+</em>
 <h2>AUTHOR</h2>
 Michael Shapiro,
Modified: grass/trunk/vector/v.colors/v.colors.html
--- grass/trunk/vector/v.colors/v.colors.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/vector/v.colors/v.colors.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -110,12 +110,12 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="d.vect.html">d.vect</a>,
-  <a href="v.colors.out.html">v.colors.out</a>,
-  <a href="r3.colors.html">r3.colors</a>,
+<a href="d.vect.html">d.vect</a>,
+<a href="r3.colors.html">r3.colors</a>,
 </em>
 <p>See also wiki
Modified: grass/trunk/vector/v.colors.out/v.colors.out.html
--- grass/trunk/vector/v.colors.out/v.colors.out.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/vector/v.colors.out/v.colors.out.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -14,11 +14,11 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.vect.stats/v.vect.stats.html
--- grass/trunk/vector/v.vect.stats/v.vect.stats.html	2014-12-09 17:31:29 UTC (rev 63452)
+++ grass/trunk/vector/v.vect.stats/v.vect.stats.html	2014-12-09 18:39:37 UTC (rev 63453)
@@ -16,52 +16,40 @@
 <p><dl>
 <dt><b>sum</b>
 <dd>The sum of values.
 <dt><b>average</b>
 <dd>The average value of all point attributes (sum / count).
 <dt><b>median</b>
 <dd>The value found half-way through a list of the
 attribute values, when these are ranged in numerical order.
 <dt><b>mode</b>
 <dd>The most frequently occurring value.
 <dt><b>minimum</b>
 <dd>The minimum observed value.
 <dt><b>min_cat</b>
 <dd>The point category corresponding to the minimum observed value.
 <dt><b>maximum</b>
 <dd>The maximum observed value.
 <dt><b>max_cat</b>
 <dd>The point category corresponding to the maximum observed value.
 <dt><b>range</b>
 <dd>The range of the observed values.
 <dt><b>stddev</b>
 <dd>The statistical standard deviation of the attribute values.
 <dt><b>variance</b>
 <dd>The statistical variance of the attribute values.
 <dt><b>diversity</b>
 <dd>The number of different attribute values.
 </dl>
@@ -75,8 +63,20 @@
 (zero) and the statistics result to "null".
 <p>The columns <em>count_column</em> and <em>stats_column</em> are created if not
 existing. If they do already exist, the <em>count_column</em> must be of
-type integer and the <em>stats_column</em> of type double.
+type integer and the <em>stats_column</em> of type double precision.
+<!-- TODO
+<h2>EXAMPLE</h2>
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
