[GRASS-SVN] r63465 - grass/trunk/display/d.mon
Wed Dec 10 01:28:58 PST 2014
Author: martinl
Date: 2014-12-10 01:28:58 -0800 (Wed, 10 Dec 2014)
New Revision: 63465
   grass/trunk/display/d.mon/start.c
d.mon: use always full path for output files (even if using default file name) - #2509
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2014-12-10 09:21:11 UTC (rev 63464)
+++ grass/trunk/display/d.mon/start.c	2014-12-10 09:28:58 UTC (rev 63465)
@@ -2,6 +2,7 @@
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/spawn.h>
+#include <grass/display.h>
 #include <grass/glocale.h>
 #include "proto.h"
@@ -14,11 +15,23 @@
 void start(const char *name, const char *output)
     char *env_name, output_path[GPATH_MAX];
+    const char *output_name;
-    if (!output)
-	return;
+    if (!output) {
+        if (D_open_driver() != 0)
+            G_fatal_error(_("No graphics device selected. "
+                            "Use d.mon to select graphics device."));
+        output_name = D_get_file();
+        if (!output_name)
+            return;
+        D_close_driver();
+    else {
+        output_name = output;
-    if (!strchr(output, HOST_DIRSEP)) { /* relative path */
+    if (!strchr(output_name, HOST_DIRSEP)) { /* relative path */
         char *ptr;
         if (!getcwd(output_path, PATH_MAX))
@@ -28,13 +41,13 @@
             *(ptr++) = HOST_DIRSEP;
             *(ptr) = '\0';
-        strcat(output_path, output);
+        strcat(output_path, output_name);
         G_message(_("Output file: %s"), output_path);
     else {
-        strcpy(output_path, output); /* already full path */
+        strcpy(output_path, output_name); /* already full path */
     env_name = NULL;
     G_asprintf(&env_name, "MONITOR_%s_MAPFILE", G_store_upper(name));
     G_setenv(env_name, output_path);
