[GRASS-SVN] r63506 - in grass/branches/releasebranch_7_0: . gui/wxpython/vdigit
svn_grass at osgeo.org
Fri Dec 12 07:04:34 PST 2014
Author: martinl
Date: 2014-12-12 07:04:34 -0800 (Fri, 12 Dec 2014)
New Revision: 63506
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/vdigit/wxdigit.py
wxGUI: don't use tabs in the code (introduced in r63341)
(merge r63505 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,
63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63473,63482,63497
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,
63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63473,63482,63497,63505
Modified: grass/branches/releasebranch_7_0/gui/wxpython/vdigit/wxdigit.py
--- grass/branches/releasebranch_7_0/gui/wxpython/vdigit/wxdigit.py 2014-12-12 15:01:52 UTC (rev 63505)
+++ grass/branches/releasebranch_7_0/gui/wxpython/vdigit/wxdigit.py 2014-12-12 15:04:34 UTC (rev 63506)
@@ -371,10 +371,10 @@
def _addChangeset(self):
- # disable redo
- changesetLast = len(self.changesets) - 1
- if self.changesetCurrent < changesetLast and len(self.changesets) > 0:
- del self.changesets[self.changesetCurrent + 1:changesetLast + 1]
+ # disable redo
+ changesetLast = len(self.changesets) - 1
+ if self.changesetCurrent < changesetLast and len(self.changesets) > 0:
+ del self.changesets[self.changesetCurrent + 1:changesetLast + 1]
self.toolbar.EnableRedo(False)
data = list()
@@ -405,7 +405,7 @@
ret = 0
actions = self.changesets[changeset]
if undo:
firstaction = 0
lastaction = len(actions)
@@ -1782,7 +1782,7 @@
self._error.WriteLine()
return (-1, None)
- fids.append(newline)
+ fids.append(newline)
# add centroids for left/right area
if ftype & GV_AREA:
