[GRASS-SVN] r63557 - in grass/branches/releasebranch_7_0: . lib/display temporal
Mon Dec 15 05:03:18 PST 2014
Author: martinl
Date: 2014-12-15 05:03:18 -0800 (Mon, 15 Dec 2014)
New Revision: 63557
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/lib/display/raster.c
   grass/branches/releasebranch_7_0/temporal/
display: doxygen cosmetics
         (merge r63556 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63307,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63524,63526,63536-63537,63551-63552,63554
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63307,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63524,63526,63536-63537,63551-63552,63554,63556
Modified: grass/branches/releasebranch_7_0/lib/display/raster.c
--- grass/branches/releasebranch_7_0/lib/display/raster.c	2014-12-15 12:54:15 UTC (rev 63556)
+++ grass/branches/releasebranch_7_0/lib/display/raster.c	2014-12-15 13:03:18 UTC (rev 63557)
@@ -45,7 +45,7 @@
   \param colors pointer to Colors structure
   \param data_type raster type (CELL, FCELL, DCELL)
-  \return next row number needed for next pixel row
+  \return row number needed for next pixel row
   \return -1 nothing to draw (on error or end of raster)
 int D_draw_raster(int A_row,
@@ -72,11 +72,12 @@
   \brief Draw raster row (FCELL)
-  \param A_row row number
-  \param farray
+  \param A_row row number (starts at 0)
+  \param farray data buffer
-  \return
+  \return -1 nothing to draw (on error or end of raster)
 int D_draw_f_raster(int A_row, const FCELL * farray, struct Colors *colors)
@@ -86,11 +87,12 @@
   \brief Draw raster row (CELL)
-  \param carray
+  \param carray data buffer
-  \return
 int D_draw_c_raster(int A_row, const CELL * carray, struct Colors *colors)
@@ -162,10 +164,9 @@
   The raster display subsystem establishes conversion parameters based
   on the screen extent defined by <b>top, bottom, left</b>, and
-  <b>right</b>, all of which are obtainable from <i>D_get_dst for the
-  current frame.</i>
+  <b>right</b>, all of which are obtainable from D_get_dst() for the
+  current frame.
 void D_cell_draw_begin(void)
     /* Set up the screen for drawing map */
@@ -177,7 +178,7 @@
   \brief Draw raster row in RGB mode
   \param r_raster red data buffer
   \param g_raster green data buffer
   \param b_raster blue data buffer
@@ -188,7 +189,8 @@
   \param g_type raster type used for red channel
   \param b_type raster type used for red channel
-  \return
 int D_draw_raster_RGB(int A_row,
 		      const void *r_raster, const void *g_raster,
Property changes on: grass/branches/releasebranch_7_0/temporal
   - /grass/trunk:62868,62873
/grass/trunk/temporal:59684,59915-59916,60017-60018,60024,60026,60173-60174,60213,60547-60548,60732-60733,60817,61031,61066,61071-61072,61083,61096,61141,61157-61158,61179-61180,61186,61191-61194,61215,61239-61243,61274-61275,61282-61288,61301,61429-61433,61455,61457,61732,61734,61759-61762,61806-61807,61848,61885,61955-61957,61983-61985,61997-62000,62016,62021-62022,62025,62111-62113,62120-62121,62179-62180,62182,62343,62361,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62594-62597,62603,62606,62608-62609,62613-62614,62616,62618,62625-62628,62631-62632,62635-62638,62640-62642,62644,62646-62649,62652,62654-62657,62666,62691,62703-62705,62709-62712,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62775,62785,62798,62800-62801,62803,62805,62812,62814-62815,62822,62824,62831,62838,62847,62856,62868,62871,62873,62875,62904,63035,63085,63087,63
 089,63091,63093,63170,63345,63391,63393,63554
   + /grass/trunk:62868,62873
 089,63091,63093,63170,63345,63391,63393,63554,63556
