[GRASS-SVN] r63585 - grass/branches/releasebranch_7_0/vector/v.in.ascii
Thu Dec 18 07:08:45 PST 2014
Author: mmetz
Date: 2014-12-18 07:08:45 -0800 (Thu, 18 Dec 2014)
New Revision: 63585
   grass/branches/releasebranch_7_0/vector/v.in.ascii/local_proto.h
   grass/branches/releasebranch_7_0/vector/v.in.ascii/main.c
   grass/branches/releasebranch_7_0/vector/v.in.ascii/points.c
v.in.ascii: sync to trunk
Modified: grass/branches/releasebranch_7_0/vector/v.in.ascii/local_proto.h
--- grass/branches/releasebranch_7_0/vector/v.in.ascii/local_proto.h	2014-12-18 15:06:27 UTC (rev 63584)
+++ grass/branches/releasebranch_7_0/vector/v.in.ascii/local_proto.h	2014-12-18 15:08:45 UTC (rev 63585)
@@ -5,10 +5,10 @@
 #include <grass/gis.h>
 #include <grass/dbmi.h>
-int points_analyse(FILE *, FILE *, char *, int *, int *, int *, int *, int **,
-		   int **, int, int, int, int);
+int points_analyse(FILE *, FILE *, char *, char *, int *, int *, int *, int *, int **,
+		   int **, int, int, int, int, int, int, int);
 int points_to_bin(FILE *, int, struct Map_info *, dbDriver *,
-		  char *, char *, int, int, int *, int, int, int, int, int);
+		  char *, char *, char *, int, int *, int, int, int, int, int);
 #endif /* __LOCAL_PROTO_H__ */
Modified: grass/branches/releasebranch_7_0/vector/v.in.ascii/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.ascii/main.c	2014-12-18 15:06:27 UTC (rev 63584)
+++ grass/branches/releasebranch_7_0/vector/v.in.ascii/main.c	2014-12-18 15:08:45 UTC (rev 63585)
@@ -8,7 +8,7 @@
  * PURPOSE:      Converts a vector map in ASCII format to a vector map
  *               in binary format
- * COPYRIGHT:    (C) 2000-2009 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2000-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -27,17 +27,36 @@
 #define	A_DIR	"dig_ascii"
+static char *get_td(const struct Option *option)
+    char* sep;
+    if (option->answer == NULL)
+        return NULL;
+    if (strcmp(option->answer, "doublequote") == 0)
+        sep = G_store("\"");
+    else if (strcmp(option->answer, "singlequote") == 0)
+        sep = G_store("\'");
+    else
+        sep = G_store(option->answer);
+    return sep;
 int main(int argc, char *argv[])
     FILE *ascii;
     struct GModule *module;
-    struct Option *old, *new, *delim_opt, *columns_opt, *xcol_opt,
-	*ycol_opt, *zcol_opt, *catcol_opt, *format_opt, *skip_opt;
+    struct Option *old, *new, *delim_opt, *tdelim_opt, *columns_opt,
+	          *xcol_opt, *ycol_opt, *zcol_opt, *catcol_opt,
+		  *format_opt, *skip_opt;
     int xcol, ycol, zcol, catcol, format, skip_lines;
     struct Flag *zcoorf, *t_flag, *e_flag, *noheader_flag, *notopol_flag,
-	*region_flag;
+	*region_flag, *ignore_flag;
     char *table;
-    char *fs;
+    char *fs, *td;
     char *desc;
     int zcoor = WITHOUT_Z, make_table;
@@ -78,6 +97,13 @@
     delim_opt = G_define_standard_option(G_OPT_F_SEP);
     delim_opt->guisection = _("Input format");
+    tdelim_opt = G_define_standard_option(G_OPT_F_SEP);
+    tdelim_opt->key = "text";
+    tdelim_opt->label = "text delimiter";
+    tdelim_opt->answer = "doublequote";
+    tdelim_opt->description = _("Special characters: doublequote, singlequote");
+    tdelim_opt->guisection = _("Input format");
     skip_opt = G_define_option();
     skip_opt->key = "skip";
     skip_opt->type = TYPE_INTEGER;
@@ -171,6 +197,11 @@
 	_("Only import points falling within current region (points mode)");
     region_flag->guisection = _("Points");
+    ignore_flag = G_define_flag();
+    ignore_flag->key = 'i';
+    ignore_flag->description = _("Ignore broken line(s) in points mode");
+    ignore_flag->guisection = _("Points");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -200,18 +231,21 @@
     catcol = atoi(catcol_opt->answer) - 1;
-    if (xcol+1 < 1 || ycol+1 < 1 || zcol+1 < 0 || catcol+1 < 0)
+    if (xcol < 0 || ycol < 0 || zcol + 1 < 0 || catcol + 1 < 0)
 	G_fatal_error(_("Column numbers must not be negative"));
     ascii = G_open_option_file(old);
     fs = G_option_to_separator(delim_opt);
+    td = get_td(tdelim_opt);
     /* check dimension */
     if (zcoorf->answer) {
 	zcoor = 1;
-    Vect_open_new(&Map, new->answer, zcoor);
+    if (Vect_open_new(&Map, new->answer, zcoor) < 0)
+	G_fatal_error(_("Unable to create vector map <%s>"), new->answer);
     Vect_set_error_handler_io(NULL, &Map);
     Vect_hist_command(&Map);
@@ -238,9 +272,9 @@
 	unlink(tmp);
-	points_analyse(ascii, tmpascii, fs, &rowlen, &ncols, &minncols,
+	points_analyse(ascii, tmpascii, fs, td, &rowlen, &ncols, &minncols,
 		       &nrows, &coltype, &collen, skip_lines, xcol, ycol,
-		       region_flag->answer);
+		       zcol, catcol, region_flag->answer, ignore_flag->answer);
 	G_verbose_message(_("Maximum input row length: %d"), rowlen);
         if (ncols != minncols) {
@@ -248,8 +282,10 @@
             G_message(_("Minimum number of columns: %d"), minncols);
         else {
-               G_message(_("Number of columns: %d"), ncols);
+	   G_message(_("Number of columns: %d"), ncols);
+        G_message(_("Number of rows: %d"), nrows);
 	/* check column numbers */
 	if (xcol >= minncols) {
@@ -476,11 +512,7 @@
 	    if (catcol < 0) {
 		key = GV_KEY_COLUMN;
-	    else if (!columns_opt->answer) {
 	    if (db_create_index2(driver, Fi->table, key) != DB_OK)
 		G_warning(_("Unable to create index for table <%s>, key <%s>"),
 			  Fi->table, key);
@@ -496,13 +528,13 @@
 	    table = NULL;
-	points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, nrows, ncols,
+	points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, td, nrows,
 		      coltype2, xcol, ycol, zcol, catcol, skip_lines);
 	if (driver) {
 	    G_message(_("Populating table..."));
 	    db_commit_transaction(driver);
-	    if(db_close_database_shutdown_driver(driver) == DB_FAILED)
+	    if (db_close_database_shutdown_driver(driver) == DB_FAILED)
 #ifdef __MINGW32__
 		G_warning("FIXME: db_close_database_shutdown_driver() fails on WinGrass. Ignoring...");
 #else
Modified: grass/branches/releasebranch_7_0/vector/v.in.ascii/points.c
--- grass/branches/releasebranch_7_0/vector/v.in.ascii/points.c	2014-12-18 15:06:27 UTC (rev 63584)
+++ grass/branches/releasebranch_7_0/vector/v.in.ascii/points.c	2014-12-18 15:08:45 UTC (rev 63585)
@@ -51,14 +51,15 @@
  * column_length: column lengths (string only)
-int points_analyse(FILE * ascii_in, FILE * ascii, char *fs,
+int points_analyse(FILE * ascii_in, FILE * ascii, char *fs, char *td,
 		   int *rowlength, int *ncolumns, int *minncolumns,
 		   int *nrows, int **column_type, int **column_length,
-		   int skip_lines, int xcol, int ycol, int region_flag)
+		   int skip_lines, int xcol, int ycol, int zcol, int catcol,
+		   int region_flag, int ignore_flag)
     int i;
     int buflen;			/* buffer length */
-    char *buf, *buf_raw;	/* buffer */
+    char *buf;			/* buffer */
     int row = 1;		/* line number, first is 1 */
     int ncols = 0;		/* number of columns */
     int minncols = -1;
@@ -70,23 +71,27 @@
     struct Cell_head window;
     double northing = .0;
     double easting = .0;
-    char *coorbuf, *tmp_token, *sav_buf;
+    char *xtoken, *ytoken, *sav_buf;
     int skip = FALSE, skipped = 0;
     buflen = 4000;
     buf = (char *)G_malloc(buflen);
-    buf_raw = (char *)G_malloc(buflen);
-    coorbuf = (char *)G_malloc(256);
-    tmp_token = (char *)G_malloc(256);
-    sav_buf = NULL;
+    xtoken = (char *)G_malloc(256);
+    ytoken = (char *)G_malloc(256);
     G_message(_("Scanning input for column types..."));
     /* fetch projection for LatLong test */
     G_get_window(&window);
+    /* points_to_bin() would be faster if we would write out
+     * clean data to ascii
+     * points_to_bin() would then not need G_chop() and
+     * for latlon not G_scan_[easting|northing]() */
     while (1) {
 	len = 0;		/* not really needed, but what the heck */
 	skip = FALSE;		/* reset out-of-region check */
+	sav_buf = NULL;
 	if (G_getl2(buf, buflen - 1, ascii_in) == 0)
 	    break;		/* EOF */
@@ -113,22 +118,43 @@
 	/* no G_chop() as first/last column may be empty fs=tab value */
 	G_debug(3, "row %d : %d chars", row, (int)strlen(buf));
-	/* G_tokenize() will modify the buffer, so we make a copy */
-	strcpy(buf_raw, buf);
+	tokens = G_tokenize2(buf, fs, td);
+	ntokens = G_number_of_tokens(tokens);
+	if (ntokens == 0) {
+	    continue;
+	if (ncols > 0 && ntokens != ncols) {
+	    /* these rows can not be imported into the attribute table */
+	    if (ignore_flag) {
+		G_warning(_("Row %d: '%s' can not be imported into the attribute table"),
+		          row, buf);
+	    else {
+		G_fatal_error(_("Broken row %d: '%s'"), row, buf);
+	if (xcol >= ntokens || ycol >= ntokens || zcol >= ntokens ||
+	    catcol >= ntokens) {
+		G_debug(3, "Skipping broken row %d: '%s'", row, buf);
+		continue;
+	    else {
 	len = strlen(buf) + 1;
 	if (len > rowlen)
 	    rowlen = len;
-	tokens = G_tokenize(buf, fs);
-	ntokens = G_number_of_tokens(tokens);
 	if (ntokens > ncols) {
-	    int c;
 	    coltype = (int *)G_realloc(coltype, ntokens * sizeof(int));
 	    collen = (int *)G_realloc(collen, ntokens * sizeof(int));
-	    for (c = ncols; c < ntokens; c++) {
-		coltype[c] = DB_C_TYPE_INT;	/* default type */
-		collen[c] = 0;
+	    for (i = ncols; i < ntokens; i++) {
+		coltype[i] = DB_C_TYPE_INT;	/* default type */
+		collen[i] = 0;
 	    ncols = ntokens;
@@ -138,6 +164,7 @@
 	/* Determine column types */
 	for (i = 0; i < ntokens; i++) {
+	    G_chop(tokens[i]);
 	    if ((G_projection() == PROJECTION_LL)) {
 		if (i == xcol || i == ycol) {
 		    if (i == 0) {	/* Save position of original internal token buffer */
@@ -145,15 +172,12 @@
 			sav_buf = tokens[0];
 		    /* check if coordinates are DMS or decimal or not latlong at all */
-		    sprintf(coorbuf, "%s", tokens[i]);
-		    G_debug(4, "token: %s", coorbuf);
 		    if (i == xcol) {
-			if (G_scan_easting(coorbuf, &easting, window.proj)) {
-			    G_debug(4, "is_latlong east: %f", easting);
-			    sprintf(tmp_token, "%.12f", easting);
+			if (G_scan_easting(tokens[i], &easting, window.proj)) {
+			    G_debug(4, "is_latlong east: %g", easting);
+			    sprintf(xtoken, "%.15g", easting);
 			    /* replace current DMS token by decimal degree */
-			    tokens[i] = tmp_token;
+			    tokens[i] = xtoken;
 			    if (region_flag) {
 				if ((window.east < easting) ||
 				    (window.west > easting))
@@ -161,18 +185,18 @@
 			else {
-                            fprintf(stderr, _("Current row %d:\n%s\n"), row, buf_raw);
-			    G_fatal_error(_("Unparsable longitude value in column num %d: %s"),
+                            fprintf(stderr, _("Current row %d:\n%s\n"), row, buf);
+			    G_fatal_error(_("Unparsable longitude value in column %d: %s"),
 					  i + 1, tokens[i]);
 		    if (i == ycol) {
-			if (G_scan_northing(coorbuf, &northing, window.proj)) {
-			    G_debug(4, "is_latlong north: %f", northing);
-			    sprintf(tmp_token, "%.12f", northing);
+			if (G_scan_northing(tokens[i], &northing, window.proj)) {
+			    G_debug(4, "is_latlong north: %g", northing);
+			    sprintf(ytoken, "%.15g", northing);
+			    tokens[i] = ytoken;
 			    if (region_flag) {
 				if ((window.north < northing) ||
 				    (window.south > northing))
@@ -180,21 +204,24 @@
 			else {
-			    G_fatal_error(_("Unparsable latitude value in column num %d: %s"),
-					  i, tokens[i]);
+			    G_fatal_error(_("Unparsable latitude value in column %d: %s"),
+					  i + 1, tokens[i]);
 		}		/* if (x or y) */
-		if (i == ntokens - 1 && sav_buf != NULL) {
-		    /* Restore original token buffer so free_tokens works */
-		    /* Only do this if tokens[0] was re-assigned */
-		    tokens[0] = sav_buf;
-		    sav_buf = NULL;
 	    }			/* PROJECTION_LL */
 	    else {
+		if (strlen(tokens[i]) == 0) {
+		    if (i == xcol) {
+		    if (i == ycol) {
 		if (region_flag) {
 		    /* consider z range if -z flag is used? */
 		    /* change to if(>= east,north){skip=1;} to allow correct tiling */
@@ -218,10 +245,10 @@
 	    len = strlen(tokens[i]);
 	    /* do not guess column type for missing values */
 	    if (len == 0)
-		continue;
+		continue;
 	    G_debug(4, "row %d col %d: '%s' is_int = %d is_double = %d",
-		    row, i, tokens[i], is_int(tokens[i]),
+		    row + 1, i + 1, tokens[i], is_int(tokens[i]),
 		    is_double(tokens[i]));
 	    if (is_int(tokens[i])) {
@@ -241,10 +268,17 @@
 	/* write dataline to tmp file */
 	if (!skip)
-	    fprintf(ascii, "%s\n", buf_raw);
+	    fprintf(ascii, "%s\n", buf);
 	else
 	    skipped++;
+	if (sav_buf != NULL) {
+	    /* Restore original token buffer so free_tokens works */
+	    /* Only do this if tokens[0] was re-assigned */
+	    tokens[0] = sav_buf;
+	    sav_buf = NULL;
 	G_free_tokens(tokens);
 	row++;
@@ -257,9 +291,8 @@
     *nrows = row - 1;		/* including skipped lines */
     G_free(buf);
-    G_free(buf_raw);
-    G_free(coorbuf);
-    G_free(tmp_token);
+    G_free(xtoken);
+    G_free(ytoken);
     if (region_flag)
 	G_message(_n("Skipping %d of %d row falling outside of current region",
@@ -280,13 +313,13 @@
  * Note: column types (both in header or coldef) must be supported by driver
 int points_to_bin(FILE * ascii, int rowlen, struct Map_info *Map,
-		  dbDriver * driver, char *table, char *fs, int nrows,
-		  int ncols, int *coltype, int xcol, int ycol, int zcol,
+		  dbDriver * driver, char *table, char *fs, char *td,
+		  int nrows, int *coltype, int xcol, int ycol, int zcol,
 		  int catcol, int skip_lines)
     char *buf, buf2[4000];
     int cat = 0;
-    int row = 1;
+    int row = 0;
     struct line_pnts *Points;
     struct line_cats *Cats;
     dbString sql, val;
@@ -317,12 +350,14 @@
 	char **tokens;
 	int ntokens;		/* number of tokens */
+	G_percent(row, nrows, 2);
+	row++;
 	if (row <= skip_lines) {
 	    G_debug(4, "writing skip line %d to hist : %d chars", row,
 		    (int)strlen(buf));
 	    Vect_hist_write(Map, buf);
 	    Vect_hist_write(Map, "\n");
-	    row++;
 	    continue;
@@ -332,9 +367,12 @@
 	G_debug(4, "row: %s", buf);
+	G_chop(tokens[xcol]);
+	G_chop(tokens[ycol]);
 	    G_scan_easting(tokens[xcol], &x, window.proj);
 	    G_scan_northing(tokens[ycol], &y, window.proj);
@@ -345,13 +383,17 @@
 	G_debug(4, "x: %f, y: %f", x, y);
-	if (zcol >= 0)
+	if (zcol >= 0) {
+	    G_chop(tokens[zcol]);
 	    z = atof(tokens[zcol]);
 	else
 	    z = 0.0;
-	if (catcol >= 0)
+	if (catcol >= 0) {
+	    G_chop(tokens[catcol]);
 	    cat = atof(tokens[catcol]);
 	else
 	    cat++;
@@ -374,6 +416,7 @@
 		if (i > 0)
 		    db_append_string(&sql, ", ");
@@ -411,12 +454,9 @@
-	G_percent(row, nrows, 2);
-	row++;
+    G_percent(nrows, nrows, 2);
     return 0;
