[GRASS-SVN] r63621 - in grass/trunk: general/g.rename temporal/t.rast.to.rast3 temporal/t.rast3d.extract/testsuite temporal/t.rast3d.list/testsuite temporal/t.rast3d.mapcalc temporal/t.rast3d.univar/testsuite temporal/t.register
Fri Dec 19 11:52:53 PST 2014
Author: neteler
Date: 2014-12-19 11:52:53 -0800 (Fri, 19 Dec 2014)
New Revision: 63621
   grass/trunk/general/g.rename/g.rename.html
   grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
   grass/trunk/temporal/t.rast3d.extract/testsuite/test.t.rast3d.extract.sh
   grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh
   grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
   grass/trunk/temporal/t.rast3d.univar/testsuite/test.t.rast3d.univar.sh
   grass/trunk/temporal/t.register/test.t.register.raster3d.sh
update shell scripts to use new element names (#2409)
Modified: grass/trunk/general/g.rename/g.rename.html
--- grass/trunk/general/g.rename/g.rename.html	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/general/g.rename/g.rename.html	2014-12-19 19:52:53 UTC (rev 63621)
@@ -21,7 +21,7 @@
 <div class="code"><pre>
        raster   raster map(s) to be renamed
-     3draster   3D raster map(s) to be renamed
+    raster_3d   3D raster map(s) to be renamed
        vector   vector map(s) to be renamed
     oldvector   old  (GRASS 5.0) vector map(s) to be renamed
   asciivector   ASCII vector map(s) to be renamed
Modified: grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
--- grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -30,56 +30,56 @@
 t.info type=strds input=precip_abs
 t.rast.to.rast3 --o input=precip_abs output=precipitation
-t.info type=3draster input=precipitation
+t.info type=raster_3d input=precipitation
 r3.info precipitation
 t.register --o --v -i type=raster input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="2 months"
 t.register --o --v -i type=raster input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="8 days"
 t.register --o --v -i type=raster input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="6 hours"
 t.register --o --v -i type=raster input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="30 minutes"
 t.register --o --v -i type=raster input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="1 seconds"
 t.register --o --v -i type=raster input=precip_abs file=${n1}
 t.register --o --v -i type=raster input=precip_rel maps=prec_4,prec_5,prec_6 start=1000 increment=100 unit=years
 t.info type=strds input=precip_rel
 t.rast.to.rast3 --o input=precip_rel output=precipitation
 t.unregister type=raster maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.rast3d.extract/testsuite/test.t.rast3d.extract.sh
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test.t.rast3d.extract.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test.t.rast3d.extract.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -15,12 +15,12 @@
 r3.mapcalc --o expr="prec_6 = rand(0, 650)" -s
 t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=3draster input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+t.register -i type=raster_3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
 # The @test
 t.rast3d.extract --o input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec
 t.info type=str3ds input=precip_abs2
-t.unregister type=3draster maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=raster_3d maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.remove type=str3ds input=precip_abs1,precip_abs2
Modified: grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh
--- grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -74,36 +74,36 @@
 t.create type=str3ds temporaltype=absolute output=volume_abs5 title="A test with input files" descr="A test with input files"
 # The first @test
-t.register type=3draster   input=volume_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=raster_3d   input=volume_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 t.rast3d.list    separator=" | " method=comma     input=volume_abs1
 t.rast3d.list input=volume_abs1
 t.rast3d.list separator=" | " method=cols      input=volume_abs1
 t.rast3d.list separator=" | " method=delta     input=volume_abs1
 t.rast3d.list separator=" | " method=deltagaps input=volume_abs1
-t.register -i type=3draster input=volume_abs2 file="${n2}"
+t.register -i type=raster_3d input=volume_abs2 file="${n2}"
 t.rast3d.list    separator=" | " method=comma     input=volume_abs2
 t.rast3d.list input=volume_abs2
 t.rast3d.list separator=" | " method=cols      input=volume_abs2
 t.rast3d.list separator=" | " method=delta     input=volume_abs2
 t.rast3d.list separator=" | " method=deltagaps input=volume_abs2
-t.register -i type=3draster input=volume_abs3 file="${n3}"
+t.register -i type=raster_3d input=volume_abs3 file="${n3}"
 t.rast3d.list    separator=" | " method=comma     input=volume_abs3
 t.rast3d.list separator=" | " method=delta     input=volume_abs3
 t.rast3d.list separator=" | " method=deltagaps input=volume_abs3
-t.register -i type=3draster input=volume_abs4 file="${n4}"
+t.register -i type=raster_3d input=volume_abs4 file="${n4}"
 t.rast3d.list    separator=" | " method=comma     input=volume_abs4
 t.rast3d.list separator=" | " method=delta     input=volume_abs4
 t.rast3d.list separator=" | " method=deltagaps input=volume_abs4
-t.register -i type=3draster input=volume_abs5 file="${n5}"
+t.register -i type=raster_3d input=volume_abs5 file="${n5}"
 t.rast3d.list    separator=" | " method=comma     input=volume_abs5
 t.rast3d.list input=volume_abs5
 t.rast3d.list separator=" | " method=cols      input=volume_abs5
 t.rast3d.list separator=" | " method=delta     input=volume_abs5
 t.rast3d.list separator=" | " method=deltagaps input=volume_abs5
-t.unregister type=3draster maps=vol_1,vol_2,vol_3,vol_4,vol_5,vol_6
+t.unregister type=raster_3d maps=vol_1,vol_2,vol_3,vol_4,vol_5,vol_6
 t.remove type=str3ds input=volume_abs1,volume_abs2,volume_abs3,volume_abs4,volume_abs5
Modified: grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
--- grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -16,8 +16,8 @@
 t.create --o type=str3ds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
-t.register --o type=3draster input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.register --o type=raster_3d input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.info type=str3ds input=precip_abs1
@@ -33,6 +33,6 @@
            method=equal nprocs=6
 t.info type=str3ds input=precip_abs4
-t.unregister type=3draster maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
+t.unregister type=raster_3d maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
 t.remove type=str3ds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.rast3d.univar/testsuite/test.t.rast3d.univar.sh
--- grass/trunk/temporal/t.rast3d.univar/testsuite/test.t.rast3d.univar.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.rast3d.univar/testsuite/test.t.rast3d.univar.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -17,7 +17,7 @@
 r3.mapcalc expr="prec_6 = rand(0, 650)" -s
 t.create type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register type=3draster --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+t.register type=raster_3d --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
 # The first @test
Modified: grass/trunk/temporal/t.register/test.t.register.raster3d.sh
--- grass/trunk/temporal/t.register/test.t.register.raster3d.sh	2014-12-19 19:21:34 UTC (rev 63620)
+++ grass/trunk/temporal/t.register/test.t.register.raster3d.sh	2014-12-19 19:52:53 UTC (rev 63621)
@@ -30,12 +30,12 @@
 t.create --v --o type=str3ds temporaltype=absolute output=volume_abs6 title="A test" descr="A test"
 t.create --v --o type=str3ds temporaltype=absolute output=volume_abs7 title="A test" descr="A test"
-t.register type=3draster --o --v -i input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="1 seconds"
+t.register type=raster_3d --o --v -i input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="1 seconds"
 t.info type=str3ds input=volume_abs1
-t.unregister --v type=3draster input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+t.unregister --v type=raster_3d input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
-t.register type=3draster --o --v -i input=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.register type=raster_3d --o --v -i input=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
 t.info type=str3ds input=volume_abs2
 r3.info volume_1
 r3.info volume_2
@@ -44,28 +44,28 @@
 r3.info volume_5
 r3.info volume_6
-t.register type=3draster --o --v -i input=volume_abs3 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="8 hours"
+t.register type=raster_3d --o --v -i input=volume_abs3 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="8 hours"
 t.info type=str3ds input=volume_abs3
-t.unregister --v type=3draster maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+t.unregister --v type=raster_3d maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
-t.register type=3draster --o input=volume_abs4 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="3 days"
+t.register type=raster_3d --o input=volume_abs4 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="3 days"
 t.info type=str3ds input=volume_abs4
-t.register type=3draster --o input=volume_abs5 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="4 weeks"
+t.register type=raster_3d --o input=volume_abs5 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="4 weeks"
 t.info type=str3ds input=volume_abs5
-t.register type=3draster --o input=volume_abs6 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-08-01" increment="2 months"
+t.register type=raster_3d --o input=volume_abs6 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-08-01" increment="2 months"
 t.info type=str3ds input=volume_abs6
-t.register type=3draster --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.register type=raster_3d --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
 t.info type=str3ds input=volume_abs7
 # Register with different valid time again
-t.register type=3draster --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.register type=raster_3d --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 # Register with different valid time again creating intervals
-t.register type=3draster -i --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.register type=raster_3d -i --o input=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 t.remove --v type=str3ds input=volume_abs1,volume_abs2,volume_abs3,volume_abs4,volume_abs5,volume_abs6,volume_abs7
