[GRASS-SVN] r63762 - in grass/branches/releasebranch_7_0: . gui/wxpython/mapdisp gui/wxpython/mapwin
Thu Dec 25 08:33:41 PST 2014
Author: annakrat
Date: 2014-12-25 08:33:41 -0800 (Thu, 25 Dec 2014)
New Revision: 63762
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py
wxGUI/legend: avoid opening legend window when entering command from gui command line and fix after renaming parameters (merge from trunk, r63761)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
 ,63721-63727,63731,63733,63740-63742,63747-63749,63751-63752,63756,63758
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 ,63721-63727,63731,63733,63740-63742,63747-63749,63751-63752,63756,63758,63761
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2014-12-25 16:32:43 UTC (rev 63761)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2014-12-25 16:33:41 UTC (rev 63762)
@@ -1172,14 +1172,14 @@
                             continue
                         param, val = param_val
                         if param == 'raster':
-                            self.legend.cmd[idx] = 'rast={rast}'.format(rast=layer.maplayer.name)
+                            self.legend.cmd[idx] = 'raster={rast}'.format(rast=layer.maplayer.name)
                             isMap = True
                         elif param in ('use', 'range'):
                             # clear range or use to avoid problems
                             del self.legend.cmd[idx]
                     if not isMap:  # for the first time
-                        self.legend.cmd.append('rast=%s' % layer.maplayer.name)
+                        self.legend.cmd.append('raster=%s' % layer.maplayer.name)
                     break
         if not showDialog and self.legend.CmdIsValid():
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py	2014-12-25 16:32:43 UTC (rev 63761)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py	2014-12-25 16:33:41 UTC (rev 63762)
@@ -232,14 +232,17 @@
     def CmdIsValid(self):
         inputs = 0
-        for param in self._cmd:
+        for param in self._cmd[1:]:
             param = param.split('=')
-            if param[0] == 'raster' and len(param) == 2:
+            if len(param) == 1:
                 inputs += 1
-            elif param[0] == 'raster_3d' and len(param) == 2:
-                inputs += 1
-            if inputs == 1:
-                return True
+            else:
+                if param[0] == 'raster' and len(param) == 2:
+                    inputs += 1
+                elif param[0] == 'raster_3d' and len(param) == 2:
+                    inputs += 1
+        if inputs == 1:
+            return True
         return False
     def ResizeLegend(self, begin, end, screenSize):
