[GRASS-SVN] r63779 - in grass-addons/grass7: display/d.frame general/g.cloud general/g.cloud/test general/g.compare.md5 gui/wxpython/newgui gui/wxpython/wx.stream/gui_modules imagery/i.edge imagery/i.fusion.brovey imagery/i.histo.match imagery/i.segment.gsoc imagery/i.spec.unmix raster raster/r.basin raster/r.convergence raster/r.edm.eval raster/r.geomorphon raster/r.grow.shrink raster/r.hants raster/r.hazard.flood raster/r.lake.series raster/r.le.patch raster/r.le.pixel raster/r.lfp raster/r.los raster/r.mess raster/r.northerness.easterness raster/r.segment raster/r.skyview raster/r.stream.basins raster/r.stream.channel raster/r.stream.distance raster/r.stream.order raster/r.stream.segment raster/r.stream.slope raster/r.stream.snap raster/r.stream.stats raster/r.surf.nnbathy raster/r.to.vect.lines raster/r.traveltime raster/r.univar2 raster/r.valley.bottom raster/r.vif vector/v.area.weigh vector/v.colors2 vector/v.habitat.dem vector/v.isochrones vector/v.surf.mass vector/v.surf .nnbathy vector/v.transects
Sat Dec 27 05:30:46 PST 2014
Author: neteler
Date: 2014-12-27 05:30:46 -0800 (Sat, 27 Dec 2014)
New Revision: 63779
   grass-addons/grass7/display/d.frame/d.frame.html
   grass-addons/grass7/general/g.cloud/cloud_collect.sh
   grass-addons/grass7/general/g.cloud/test/test_morevariables_raster.sh
   grass-addons/grass7/general/g.cloud/test/test_onevariable.sh
   grass-addons/grass7/general/g.cloud/test/test_onevariable_raster.sh
   grass-addons/grass7/general/g.cloud/test/test_onevariable_sun.sh
   grass-addons/grass7/general/g.compare.md5/g.compare.md5.html
   grass-addons/grass7/gui/wxpython/newgui/render2.py
   grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
   grass-addons/grass7/imagery/i.edge/i.edge.html
   grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.html
   grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py
   grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
   grass-addons/grass7/imagery/i.segment.gsoc/i.segment.gsoc.html
   grass-addons/grass7/imagery/i.spec.unmix/i.spec.unmix.html
   grass-addons/grass7/raster/Makefile
   grass-addons/grass7/raster/r.basin/r.basin.html
   grass-addons/grass7/raster/r.convergence/memory.c
   grass-addons/grass7/raster/r.edm.eval/r.edm.eval
   grass-addons/grass7/raster/r.geomorphon/memory.c
   grass-addons/grass7/raster/r.grow.shrink/r.grow.shrink.html
   grass-addons/grass7/raster/r.hants/r.hants.html
   grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html
   grass-addons/grass7/raster/r.lake.series/r.lake.series.html
   grass-addons/grass7/raster/r.le.patch/driver.c
   grass-addons/grass7/raster/r.le.pixel/driver.c
   grass-addons/grass7/raster/r.lfp/r.lfp.py
   grass-addons/grass7/raster/r.los/r.los.html
   grass-addons/grass7/raster/r.mess/r.mess
   grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html
   grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py
   grass-addons/grass7/raster/r.segment/r.segment.html
   grass-addons/grass7/raster/r.skyview/r.skyview.html
   grass-addons/grass7/raster/r.stream.basins/io.c
   grass-addons/grass7/raster/r.stream.channel/io.c
   grass-addons/grass7/raster/r.stream.channel/r.stream.channel.html
   grass-addons/grass7/raster/r.stream.distance/io.c
   grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
   grass-addons/grass7/raster/r.stream.order/io.c
   grass-addons/grass7/raster/r.stream.order/r.stream.order.html
   grass-addons/grass7/raster/r.stream.segment/io.c
   grass-addons/grass7/raster/r.stream.segment/r.stream.segment.html
   grass-addons/grass7/raster/r.stream.slope/main.c
   grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html
   grass-addons/grass7/raster/r.stream.snap/io.c
   grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html
   grass-addons/grass7/raster/r.stream.stats/io.c
   grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html
   grass-addons/grass7/raster/r.surf.nnbathy/r.surf.nnbathy.html
   grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.html
   grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
   grass-addons/grass7/raster/r.traveltime/r.traveltime.html
   grass-addons/grass7/raster/r.univar2/r.univar2.html
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
   grass-addons/grass7/raster/r.vif/r.vif
   grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html
   grass-addons/grass7/vector/v.colors2/v.colors2.html
   grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.html
   grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
   grass-addons/grass7/vector/v.isochrones/v.isochrones.html
   grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html
   grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html
   grass-addons/grass7/vector/v.transects/v.transects.html
Addons: update some calls to use new element names (#2409)
Modified: grass-addons/grass7/display/d.frame/d.frame.html
--- grass-addons/grass7/display/d.frame/d.frame.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/display/d.frame/d.frame.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -32,7 +32,7 @@
 d.mon cairo out=/tmp/map.png width=600 height=540 --o
 # set up region
-g.region rast=elevation
+g.region raster=elevation
 # remove all frames and erase the current graphics monitor
 d.frame -e
Modified: grass-addons/grass7/general/g.cloud/cloud_collect.sh
--- grass-addons/grass7/general/g.cloud/cloud_collect.sh	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.cloud/cloud_collect.sh	2014-12-27 13:30:46 UTC (rev 63779)
@@ -103,21 +103,21 @@
 for mapset in $LIST ; do
     MAPS=`g.list rast mapset=$mapset`
     for map in $MAPS ; do
-        g.copy rast=$map@$mapset,$map --o
+        g.copy raster=$map@$mapset,$map --o
     done
 done
     MAPS=`g.list rast3d mapset=$mapset`
     done
 done
     MAPS=`g.list vect mapset=$mapset`
-        g.copy vect=$map@$mapset,$map --o
+        g.copy vector=$map@$mapset,$map --o
     done
 done
Modified: grass-addons/grass7/general/g.cloud/test/test_morevariables_raster.sh
--- grass-addons/grass7/general/g.cloud/test/test_morevariables_raster.sh	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.cloud/test/test_morevariables_raster.sh	2014-12-27 13:30:46 UTC (rev 63779)
@@ -10,6 +10,6 @@
 # TEST 2: all-to-all: use var with size 3 and 7; use corr with size 3 and 7
 # - g.cloud -c conf=~/.diss server=giscluster grass=/PATH/TO/g.cloud/test/test_morevariables_raster.sh qsub=/PATH/TO/g.cloud/test/test_launch_SGE_grassjob.sh variables="{'TEXTURE' : ['var','corr'], 'SIZE' : [3,7]}" raster=lsat7_2002_40
-g.region rast=lsat7_2002_40
+g.region raster=lsat7_2002_40
 r.texture input=lsat7_2002_40 prefix=lsat7_2002_40_$SIZE method=$TEXTURE size=$SIZE
Modified: grass-addons/grass7/general/g.cloud/test/test_onevariable.sh
--- grass-addons/grass7/general/g.cloud/test/test_onevariable.sh	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.cloud/test/test_onevariable.sh	2014-12-27 13:30:46 UTC (rev 63779)
@@ -8,5 +8,5 @@
 # using PID ($$) as name suffix
 v.random output=random$$_$NPOINT n=$NPOINT
-g.region vect=random$$_$NPOINT
+g.region vector=random$$_$NPOINT
 v.buffer input=random$$_$NPOINT output=buffer$$ distance=1
Modified: grass-addons/grass7/general/g.cloud/test/test_onevariable_raster.sh
--- grass-addons/grass7/general/g.cloud/test/test_onevariable_raster.sh	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.cloud/test/test_onevariable_raster.sh	2014-12-27 13:30:46 UTC (rev 63779)
@@ -6,5 +6,5 @@
 # - g.cloud conf=~/.gc_loginfile.txt server=giscluster grass=/PATH/TO/g.cloud/test/test_onevariable_raster.sh qsub=/PATH/TO/g.cloud/test/test_launch_SGE_grassjob.sh variables="{'TEXTURE' : ['var','corr']}" raster=lsat7_2002_40
 r.texture input=lsat7_2002_40 prefix=lsat7_2002_40 method=$TEXTURE
Modified: grass-addons/grass7/general/g.cloud/test/test_onevariable_sun.sh
--- grass-addons/grass7/general/g.cloud/test/test_onevariable_sun.sh	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.cloud/test/test_onevariable_sun.sh	2014-12-27 13:30:46 UTC (rev 63779)
@@ -12,7 +12,7 @@
 ELEV=elevation
-g.region rast=$ELEV
+g.region raster=$ELEV
 # r.sun memory requirements: 4 bytes per raster cell
 #  rows,cols: rows and columns of current region (find out with g.region)
Modified: grass-addons/grass7/general/g.compare.md5/g.compare.md5.html
--- grass-addons/grass7/general/g.compare.md5/g.compare.md5.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/general/g.compare.md5/g.compare.md5.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -10,7 +10,7 @@
 <div class="code"><pre>
 # copy a raster map
-g.copy rast=elevation,dem
+g.copy raster=elevation,dem
 # now check and return TRUE
 g.md5sum ain=elevation bin=dem
@@ -23,7 +23,6 @@
 # but when adding the -c flag (ignore color table), TRUE is returned
 g.md5sum -c ain=elevation bin=dem
 </pre></div>
 <h2>AUTHOR</h2>
Modified: grass-addons/grass7/gui/wxpython/newgui/render2.py
--- grass-addons/grass7/gui/wxpython/newgui/render2.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/gui/wxpython/newgui/render2.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -360,7 +360,7 @@
         @param id overlay id (for PseudoDC)
         @param type overlay type ('barscale', 'legend', etc.)
         @param cmd GRASS command to render overlay,
-        given as list, e.g. ['d.legend', 'rast=elevation at PERMANENT']
+        given as list, e.g. ['d.legend', 'raster=elevation at PERMANENT']
         @param Map render.Map instance
         @param active layer is active, will be rendered only if True
         @param hidden layer is hidden, won't be listed in Layer Manager if True
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -314,7 +314,7 @@
         # Add the box for choosing the map
         self.select1 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
-                               type = 'rast', multiple = False)
+                               type = 'raster', multiple = False)
         self.select.Add(item = self.select1, pos = (2,0), span = wx.DefaultSpan)
         # binder
@@ -342,7 +342,7 @@
         # Box to insert name of acc map
         self.select2 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
-                               type = 'rast', multiple = False) # select existing map
+                               type = 'raster', multiple = False) # select existing map
         self.select.Add(item = self.select2, pos = (5,0), span = wx.DefaultSpan)
         self.textOne = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
         self.select.Add(item = self.textOne, flag = wx.LEFT | wx.EXPAND , pos = (6,0), span = wx.DefaultSpan)
@@ -372,7 +372,7 @@
         self.select3 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
         self.select.Add(item = self.select3, pos = (8,0), span = wx.DefaultSpan)
         # binder
Modified: grass-addons/grass7/imagery/i.edge/i.edge.html
--- grass-addons/grass7/imagery/i.edge/i.edge.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.edge/i.edge.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -73,7 +73,7 @@
 # set the region (resolution) to Landsat image
-g.region rast=lsat7_2000_20 at landsat
+g.region raster=lsat7_2000_20 at landsat
 # set the region to experimetal area
 g.region n=224016 s=220981 w=637589 e=641223
Modified: grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.html
--- grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -28,7 +28,7 @@
 Calculation of Brovey fusion map from North Carolina Landsat scene:
-g.region rast=lsat7_2002_20 -p
+g.region raster=lsat7_2002_20 -p
 # R, G, B composite at 28.5m
 d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
@@ -39,7 +39,7 @@
                    outputprefix=brovey
 # display at 14.25m
-g.region rast=brovey.blue -p
+g.region raster=brovey.blue -p
 d.rgb b=brovey.blue g=brovey.green r=brovey.red
 </pre></div>
Modified: grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py
--- grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -160,7 +160,7 @@
 	grass.message(_("%s.%s") % (out, ch))
     grass.verbose("To visualize output, run:")
-    grass.verbose("g.region -p rast=%s.red" % out)
+    grass.verbose("g.region -p raster=%s.red" % out)
     grass.verbose("d.rgb r=%s.red g=%s.green b=%s.blue" % (out, out, out))
     grass.verbose("If desired, combine channels with 'r.composite' to a single map.")
Modified: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -105,7 +105,7 @@
         curs.execute(query_create)
         # set the region on the raster
         grass.use_temp_region()
-        grass.run_command('g.region', rast=i)
+        grass.run_command('g.region', raster=i)
         # calculate statistics
         stats_out = grass.pipe_command('r.stats', flags='cin', input=i,
                                        separator=':')
@@ -193,7 +193,7 @@
     for i in images:
         iname = i.split('@')[0]
         # write average rules file
         outfile = open(grass.tempfile(), 'w')
         new_grey = 0
@@ -233,7 +233,7 @@
     db.close()
     if mosaic:
-        grass.run_command('g.region', rast=all_images)
+        grass.run_command('g.region', raster=all_images)
         grass.run_command('r.patch', input=output_names, output=mosaic)
 if __name__ == "__main__":
Modified: grass-addons/grass7/imagery/i.segment.gsoc/i.segment.gsoc.html
--- grass-addons/grass7/imagery/i.segment.gsoc/i.segment.gsoc.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.segment.gsoc/i.segment.gsoc.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -123,7 +123,7 @@
 threshold may be required. <br>
-g.region rast=ortho_2001_t792_1m at PERMANENT n=220400 s=220200 e=639000 w=638800
+g.region raster=ortho_2001_t792_1m at PERMANENT n=220400 s=220200 e=639000 w=638800
 </pre></div>
 Try out a first threshold and check the results.<br>
@@ -152,7 +152,7 @@
 machine.  Now that we are satisfied with the settings, we'll process
 the entire image:
-g.region rast=ortho_2001_t792_1m at PERMANENT<br>
+g.region raster=ortho_2001_t792_1m at PERMANENT<br>
 i.segment -w -l --overwrite group=ortho_group output=ortho_segs \
           threshold=10 method=region_growing minsize=5 endt=5000
 </pre></div>
Modified: grass-addons/grass7/imagery/i.spec.unmix/i.spec.unmix.html
--- grass-addons/grass7/imagery/i.spec.unmix/i.spec.unmix.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/imagery/i.spec.unmix/i.spec.unmix.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -14,7 +14,7 @@
 <!-- see sample/run.sh, update to NC sample data set -->
-g.region rast=lsat7_2002_10 -p
+g.region raster=lsat7_2002_10 -p
 # Find pure endmembers, they are supposed to be in the corners of
 # the PCA feature space (or use spectral measurement data)
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/Makefile	2014-12-27 13:30:46 UTC (rev 63779)
@@ -10,6 +10,9 @@
 #	r.le.setup \
 #	r.le.trace
+# unclear
+	r.convert \
 SUBDIRS = \
 	r.agent \
 	r.area \
@@ -17,7 +20,6 @@
 	r.bioclim \
 	r.bitpattern \
 	r.convergence \
-	r.convert \
 	r.crater \
 	r.damflood \
 	r.diversity \
Modified: grass-addons/grass7/raster/r.basin/r.basin.html
--- grass-addons/grass7/raster/r.basin/r.basin.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.basin/r.basin.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -124,7 +124,7 @@
 North Carolina sample dataset example:
-g.region rast=elevation -p
+g.region raster=elevation -p
 r.basin map=elevation prefix=my_basin coord=637500.0,221750.0 dir=/tmp/bla threshold=1000
 # visualize some results
Modified: grass-addons/grass7/raster/r.convergence/memory.c
--- grass-addons/grass7/raster/r.convergence/memory.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.convergence/memory.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -20,7 +20,7 @@
     rast->raster_type = Rast_map_type(rast->elevname, mapset);
     if (window.ew_res < cellhd.ew_res || window.ns_res < cellhd.ns_res)
-	G_fatal_error(_("Region resolution shoudn't be lesser than map %s resolution. Run g.region rast=%s to set proper resolution"),
+	G_fatal_error(_("Region resolution shoudn't be lesser than map %s resolution. Run g.region raster=%s to set proper resolution"),
 		      rast->elevname, rast->elevname);
     tmp_buf = Rast_allocate_buf(rast->raster_type);
Modified: grass-addons/grass7/raster/r.edm.eval/r.edm.eval
--- grass-addons/grass7/raster/r.edm.eval/r.edm.eval	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.edm.eval/r.edm.eval	2014-12-27 13:30:46 UTC (rev 63779)
@@ -231,8 +231,8 @@
     fft <- execGRASS("g.findfile", flags="quiet", element="cell", file=rast, mapset=mpst, Sys_ignore.stdout=TRUE)
     if(fft==0){
         rname <- rand.name()
-        execGRASS("g.copy", rast=paste(rast, rname, sep=","))
-        if(remove.orig){execGRASS("g.remove", flags="f", type="rast", name=rast)}
+        execGRASS("g.copy", raster=paste(rast, rname, sep=","))
+        if(remove.orig){execGRASS("g.remove", flags="f", type="raster", name=rast)}
         return(rname)
     }else{
         print("the selected file does not exist")
@@ -265,7 +265,7 @@
 	sink("reclass.rules"); cat("1:1:1:1"); cat("\n"); cat("2:2:0:0"); cat("\n"); sink()
     execGRASS("r.recode", flags="overwrite", input=tmp.b, output=tmp.a, rules="reclass.rules")
 	obsmap <- tmp.a
-	execGRASS("g.remove", flags="f", type="rast", name=tmp.b); unlink("reclass.rules")
+	execGRASS("g.remove", flags="f", type="raster", name=tmp.b); unlink("reclass.rules")
 if(bufpres>0){
@@ -275,7 +275,7 @@
     execGRASS("r.buffer", flags=c("z","overwrite"), input=tmp.b, output=tmp.c, distances=bufpres, units="kilometers")
     execGRASS("r.mapcalc", flags="overwrite", expression=paste(tmp.b, " = if(", tmp.c, "==2,1,", obsmap, ")", sep=""))
     obsmap <- tmp.b
-    execGRASS("g.remove", flags="f", type="rast", name=tmp.c)
+    execGRASS("g.remove", flags="f", type="raster", name=tmp.c)
 # Prevalence
@@ -303,7 +303,7 @@
     execGRASS("r.random", input=tmp.g, n=as.character(abs.req), raster_output=tmp.h, Sys_wait=TRUE)
     execGRASS("r.patch", input=paste(tmp.f, tmp.h, sep=","), output=tmp.i, flags="overwrite", Sys_wait=TRUE)
     obsmap <- tmp.i
-    execGRASS("g.remove", flags="f", type="rast", name=paste(tmp.f, tmp.g, tmp.h, tmp.e, sep=","), Sys_wait=TRUE)
+    execGRASS("g.remove", flags="f", type="raster", name=paste(tmp.f, tmp.g, tmp.h, tmp.e, sep=","), Sys_wait=TRUE)
 }else{
     # Set number of presence and absence points
     if(num.pres > 0 | num.abs > 0){
@@ -340,7 +340,7 @@
         tmp.j <- "tmp_r_model_evaluation_0987654321j"
         execGRASS("r.patch", input=paste(tmp.f, tmp.h, sep=","), output=tmp.j, flags="overwrite", Sys_wait=TRUE)
         obsmap <- tmp.j
@@ -365,7 +365,7 @@
     # Based on presence / absence
     a <- execGRASS("r.stats", flags=c("c","n"), input=paste(obsmap, tmp.d, sep=","), intern=TRUE)
     a <- get_output.GRASS(a, separator=" ")
-    execGRASS("g.remove", flags="f", type="rast", name=tmp.d)
+    execGRASS("g.remove", flags="f", type="raster", name=tmp.d)
 }else{
     # Based on presence / background
     tmp.k <- "tmp_r_model_evaluation_0987654321k"
@@ -384,21 +384,21 @@
     a <- rbind(a1, a3)
     # Clean up
-    execGRASS("g.remove", flags="f", type="rast", name=paste(tmp.k, tmp.m, sep=","))
+    execGRASS("g.remove", flags="f", type="raster", name=paste(tmp.k, tmp.m, sep=","))
 # Clean up
-execGRASS("g.remove", flags="f", type="rast", name=tmp.d)
-if(bufabs>0){execGRASS("g.remove", flags="f", type="rast", name=tmp.a)}
-if(bufabs>0){execGRASS("g.remove", flags="f", type="rast", name=tmp.b)}
-if(preval>0){execGRASS("g.remove", flags="f", type="rast", name=tmp.i)}
-if(num.abs > 0 | num.pres > 0){execGRASS("g.remove", flags="f", type="rast", name=tmp.j)}
+execGRASS("g.remove", flags="f", type="raster", name=tmp.d)
+if(bufabs>0){execGRASS("g.remove", flags="f", type="raster", name=tmp.a)}
+if(bufabs>0){execGRASS("g.remove", flags="f", type="raster", name=tmp.b)}
+if(preval>0){execGRASS("g.remove", flags="f", type="raster", name=tmp.i)}
+if(num.abs > 0 | num.pres > 0){execGRASS("g.remove", flags="f", type="raster", name=tmp.j)}
 # the temporary files do not always get cleaned up, need to check why
 # this is a temporary fix!
-aa <- execGRASS("g.list", type="rast", pattern="tmp_r_model_evaluation_*", intern=TRUE)
+aa <- execGRASS("g.list", type="raster", pattern="tmp_r_model_evaluation_*", intern=TRUE)
 if(length(aa)>0){
-    execGRASS("g.remove", type="rast", pattern="tmp_r_model_evaluation_*", flags="f")
+    execGRASS("g.remove", type="raster", pattern="tmp_r_model_evaluation_*", flags="f")
 # Calculate evaluation stats
Modified: grass-addons/grass7/raster/r.geomorphon/memory.c
--- grass-addons/grass7/raster/r.geomorphon/memory.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.geomorphon/memory.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -20,7 +20,7 @@
-	G_warning(_("Region resolution shoudn't be lesser than map %s resolution. Run g.region rast=%s to set proper resolution"),
+	G_warning(_("Region resolution shoudn't be lesser than map %s resolution. Run g.region raster=%s to set proper resolution"),
Modified: grass-addons/grass7/raster/r.grow.shrink/r.grow.shrink.html
--- grass-addons/grass7/raster/r.grow.shrink/r.grow.shrink.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.grow.shrink/r.grow.shrink.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -62,7 +62,7 @@
 # North Carolina sample dataset
-g.region rast=lakes
+g.region raster=lakes
 r.grow.shrink in=lakes out=lakes.shrunken radius=-2.01
 r.colors lakes.shrunken rast=lakes
 </pre></div>
Modified: grass-addons/grass7/raster/r.hants/r.hants.html
--- grass-addons/grass7/raster/r.hants/r.hants.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.hants/r.hants.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -88,13 +88,13 @@
 # set computational region to one of the maps
-g.region rast=2004_03_tempmean -p
+g.region raster=2004_03_tempmean -p
 </pre></div>
 Visualize the time series as animation:
 # note: color table is different from standard "celsius"
-g.gui.animation rast=`g.list rast pattern="*tempmean" sep=comma`
+g.gui.animation rast=`g.list type=raster pattern="*tempmean" sep=comma`
 </pre></div>
 <p>
@@ -106,13 +106,13 @@
 # just wildly guessing the parameters for a test run:
 # generate and check list of input maps (the order matters!)
-g.list rast pattern="20??_??_tempmean" output=tempmean.csv
+g.list type=raster pattern="20??_??_tempmean" output=tempmean.csv
 r.hants file=tempmean.csv \
   nf=6 fet=0.1 dod=5 delta=0.1 base_period=12
 # assign reasonable color tables for temperature
-for map in `g.list rast pattern="*tempmean_hants"` ; do
+for map in `g.list type=raster pattern="*tempmean_hants"` ; do
     r.colors $map color=celsius
 done
@@ -139,7 +139,7 @@
 # see HANTS time series as animation
-g.gui.animation rast=`g.list rast pattern="*tempmean_hants" sep=comma`
+g.gui.animation rast=`g.list type=raster pattern="*tempmean_hants" sep=comma`
 # Check HANTS behaviour in a given point
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -44,7 +44,7 @@
 <h2>EXAMPLE</h2>
-g.region rast=elevation -ap
+g.region raster=elevation -ap
 r.hazard.flood map=elevation flood=flood mti=mti
 </pre></div>
Modified: grass-addons/grass7/raster/r.lake.series/r.lake.series.html
--- grass-addons/grass7/raster/r.lake.series/r.lake.series.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.lake.series/r.lake.series.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -25,7 +25,7 @@
 Carolina sample dataset and included also visualization examples.
-g.region rast=elev_lid792_1m
+g.region raster=elev_lid792_1m
 # prepare input data
 v.to.rast -d input=streams output=rural_streams use=val val=1
Modified: grass-addons/grass7/raster/r.le.patch/driver.c
--- grass-addons/grass7/raster/r.le.patch/driver.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.le.patch/driver.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -549,49 +549,49 @@
        rather than floating point or int */
     if (choice->att[1]) {
 	if (G_find_raster("a1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a1,a1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a1,a1bak");
 	    system(cmdbuf);
 	a1 = Rast_open_new("a1", DCELL_TYPE);
     if (choice->att[2]) {
 	if (G_find_raster("a2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a2,a2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a2,a2bak");
 	    system(cmdbuf);
 	a2 = Rast_open_new("a2", DCELL_TYPE);
     if (choice->att[3]) {
 	if (G_find_raster("a3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a3,a3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a3,a3bak");
 	    system(cmdbuf);
 	a3 = Rast_open_new("a3", DCELL_TYPE);
     if (choice->att[4]) {
 	if (G_find_raster("a4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a4,a4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a4,a4bak");
 	    system(cmdbuf);
 	a4 = Rast_open_new("a4", DCELL_TYPE);
     if (choice->att[5]) {
 	if (G_find_raster("a5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a5,a5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a5,a5bak");
 	    system(cmdbuf);
 	a5 = Rast_open_new("a5", DCELL_TYPE);
     if (choice->att[6]) {
 	if (G_find_raster("a6", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a6,a6bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a6,a6bak");
 	    system(cmdbuf);
 	a6 = Rast_open_new("a6", DCELL_TYPE);
     if (choice->att[7]) {
 	if (G_find_raster("a7", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a7,a7bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a7,a7bak");
 	    system(cmdbuf);
 	a7 = Rast_open_new("a7", DCELL_TYPE);
@@ -599,7 +599,7 @@
     if (choice->att[8]) {
 	if (G_find_raster("a8", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a8,a8bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=a8,a8bak");
 	    system(cmdbuf);
 	a8 = Rast_open_new("a8", DCELL_TYPE);
@@ -607,42 +607,42 @@
     if (choice->size[1]) {
 	if (G_find_raster("s1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s1,s1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s1,s1bak");
 	    system(cmdbuf);
 	s1 = Rast_open_new("s1", DCELL_TYPE);
     if (choice->size[2]) {
 	if (G_find_raster("s2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s2,s2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s2,s2bak");
 	    system(cmdbuf);
 	s2 = Rast_open_new("s2", DCELL_TYPE);
     if (choice->size[3]) {
 	if (G_find_raster("s3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s3,s3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s3,s3bak");
 	    system(cmdbuf);
 	s3 = Rast_open_new("s3", DCELL_TYPE);
     if (choice->size[4]) {
 	if (G_find_raster("s4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s4,s4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s4,s4bak");
 	    system(cmdbuf);
 	s4 = Rast_open_new("s4", DCELL_TYPE);
     if (choice->size[5]) {
 	if (G_find_raster("s5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s5,s5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s5,s5bak");
 	    system(cmdbuf);
 	s5 = Rast_open_new("s5", DCELL_TYPE);
     if (choice->size[6]) {
 	if (G_find_raster("s6", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s6,s6bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s6,s6bak");
 	    system(cmdbuf);
 	s6 = Rast_open_new("s6", DCELL_TYPE);
@@ -650,7 +650,7 @@
     if (choice->size[7]) {
 	if (G_find_raster("s7", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s7,s7bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s7,s7bak");
 	    system(cmdbuf);
 	s7 = Rast_open_new("s7", DCELL_TYPE);
@@ -658,7 +658,7 @@
     if (choice->size[8]) {
 	if (G_find_raster("s8", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s8,s8bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=s8,s8bak");
 	    system(cmdbuf);
 	s8 = Rast_open_new("s8", DCELL_TYPE);
@@ -666,70 +666,70 @@
     if (choice->core[1]) {
 	if (G_find_raster("c1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c1,c1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c1,c1bak");
 	    system(cmdbuf);
 	c1 = Rast_open_new("c1", DCELL_TYPE);
     if (choice->core[2]) {
 	if (G_find_raster("c2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c2,c2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c2,c2bak");
 	    system(cmdbuf);
 	c2 = Rast_open_new("c2", DCELL_TYPE);
     if (choice->core[3]) {
 	if (G_find_raster("c3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c3,c3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c3,c3bak");
 	    system(cmdbuf);
 	c3 = Rast_open_new("c3", DCELL_TYPE);
     if (choice->core[4]) {
 	if (G_find_raster("c4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c4,c4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c4,c4bak");
 	    system(cmdbuf);
 	c4 = Rast_open_new("c4", DCELL_TYPE);
     if (choice->core[5]) {
 	if (G_find_raster("c5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c5,c5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c5,c5bak");
 	    system(cmdbuf);
 	c5 = Rast_open_new("c5", DCELL_TYPE);
     if (choice->core[6]) {
 	if (G_find_raster("c6", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c6,c6bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c6,c6bak");
 	    system(cmdbuf);
 	c6 = Rast_open_new("c6", DCELL_TYPE);
     if (choice->core[7]) {
 	if (G_find_raster("c7", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c7,c7bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c7,c7bak");
 	    system(cmdbuf);
 	c7 = Rast_open_new("c7", DCELL_TYPE);
     if (choice->core[8]) {
 	if (G_find_raster("c8", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c8,c8bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c8,c8bak");
 	    system(cmdbuf);
 	c8 = Rast_open_new("c8", DCELL_TYPE);
     if (choice->core[9]) {
 	if (G_find_raster("c9", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c9,c9bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c9,c9bak");
 	    system(cmdbuf);
 	c9 = Rast_open_new("c9", DCELL_TYPE);
     if (choice->core[10]) {
 	if (G_find_raster("c10", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c10,c10bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=c10,c10bak");
 	    system(cmdbuf);
 	c10 = Rast_open_new("c10", DCELL_TYPE);
@@ -737,42 +737,42 @@
     if (choice->shape[1]) {
 	if (G_find_raster("h1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h1,h1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h1,h1bak");
 	    system(cmdbuf);
 	h1 = Rast_open_new("h1", DCELL_TYPE);
     if (choice->shape[2]) {
 	if (G_find_raster("h2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h2,h2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h2,h2bak");
 	    system(cmdbuf);
 	h2 = Rast_open_new("h2", DCELL_TYPE);
     if (choice->shape[3]) {
 	if (G_find_raster("h3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h3,h3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h3,h3bak");
 	    system(cmdbuf);
 	h3 = Rast_open_new("h3", DCELL_TYPE);
     if (choice->shape[4]) {
 	if (G_find_raster("h4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h4,h4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h4,h4bak");
 	    system(cmdbuf);
 	h4 = Rast_open_new("h4", DCELL_TYPE);
     if (choice->shape[5]) {
 	if (G_find_raster("h5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h5,h5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h5,h5bak");
 	    system(cmdbuf);
 	h5 = Rast_open_new("h5", DCELL_TYPE);
     if (choice->shape[6]) {
 	if (G_find_raster("h6", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h6,h6bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=h6,h6bak");
 	    system(cmdbuf);
 	h6 = Rast_open_new("h6", DCELL_TYPE);
@@ -780,7 +780,7 @@
     if (choice->boundary[1]) {
 	if (G_find_raster("n1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n1,n1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=n1,n1bak");
 	    system(cmdbuf);
 	n1 = Rast_open_new("n1", DCELL_TYPE);
@@ -788,7 +788,7 @@
     if (choice->boundary[2]) {
 	if (G_find_raster("n2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n2,n2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=n2,n2bak");
 	    system(cmdbuf);
 	n2 = Rast_open_new("n2", DCELL_TYPE);
@@ -796,7 +796,7 @@
     if (choice->boundary[3]) {
 	if (G_find_raster("n3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n3,n3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=n3,n3bak");
 	    system(cmdbuf);
 	n3 = Rast_open_new("n3", DCELL_TYPE);
@@ -804,7 +804,7 @@
     if (choice->boundary[4]) {
 	if (G_find_raster("n4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n4,n4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=n4,n4bak");
 	    system(cmdbuf);
 	n4 = Rast_open_new("n4", DCELL_TYPE);
@@ -812,42 +812,42 @@
     if (choice->perim[1]) {
 	if (G_find_raster("p1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p1,p1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p1,p1bak");
 	    system(cmdbuf);
 	p1 = Rast_open_new("p1", DCELL_TYPE);
     if (choice->perim[2]) {
 	if (G_find_raster("p2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p2,p2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p2,p2bak");
 	    system(cmdbuf);
 	p2 = Rast_open_new("p2", DCELL_TYPE);
     if (choice->perim[3]) {
 	if (G_find_raster("p3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p3,p3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p3,p3bak");
 	    system(cmdbuf);
 	p3 = Rast_open_new("p3", DCELL_TYPE);
     if (choice->perim[4]) {
 	if (G_find_raster("p4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p4,p4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p4,p4bak");
 	    system(cmdbuf);
 	p4 = Rast_open_new("p4", DCELL_TYPE);
     if (choice->perim[5]) {
 	if (G_find_raster("p5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p5,p5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p5,p5bak");
 	    system(cmdbuf);
 	p5 = Rast_open_new("p5", DCELL_TYPE);
     if (choice->perim[6]) {
 	if (G_find_raster("p6", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p6,p6bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=p6,p6bak");
 	    system(cmdbuf);
 	p6 = Rast_open_new("p6", DCELL_TYPE);
Modified: grass-addons/grass7/raster/r.le.pixel/driver.c
--- grass-addons/grass7/raster/r.le.pixel/driver.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.le.pixel/driver.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -195,28 +195,28 @@
 	if (G_find_raster("b1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b1,b1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=b1,b1bak");
 	    system(cmdbuf);
 	b1 = Rast_open_new("b1", DCELL_TYPE);
 	if (G_find_raster("b2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b2,b2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=b2,b2bak");
 	    system(cmdbuf);
 	b2 = Rast_open_new("b2", DCELL_TYPE);
 	if (G_find_raster("b3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b3,b3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=b3,b3bak");
 	    system(cmdbuf);
 	b3 = Rast_open_new("b3", DCELL_TYPE);
 	if (G_find_raster("b4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b4,b4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=b4,b4bak");
 	    system(cmdbuf);
 	b4 = Rast_open_new("b4", DCELL_TYPE);
@@ -224,28 +224,28 @@
     if (choice->div[1]) {
 	if (G_find_raster("d1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d1,d1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=d1,d1bak");
 	    system(cmdbuf);
 	d1 = Rast_open_new("d1", DCELL_TYPE);
     if (choice->div[2]) {
 	if (G_find_raster("d2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d2,d2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=d2,d2bak");
 	    system(cmdbuf);
 	d2 = Rast_open_new("d2", DCELL_TYPE);
     if (choice->div[3]) {
 	if (G_find_raster("d3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d3,d3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=d3,d3bak");
 	    system(cmdbuf);
 	d3 = Rast_open_new("d3", DCELL_TYPE);
     if (choice->div[4]) {
 	if (G_find_raster("d4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d4,d4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=d4,d4bak");
 	    system(cmdbuf);
 	d4 = Rast_open_new("d4", DCELL_TYPE);
@@ -253,35 +253,35 @@
     if (choice->te2[1]) {
 	if (G_find_raster("t1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t1,t1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=t1,t1bak");
 	    system(cmdbuf);
 	t1 = Rast_open_new("t1", DCELL_TYPE);
     if (choice->te2[2]) {
 	if (G_find_raster("t2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t2,t2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=t2,t2bak");
 	    system(cmdbuf);
 	t2 = Rast_open_new("t2", DCELL_TYPE);
     if (choice->te2[3]) {
 	if (G_find_raster("t3", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t3,t3bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=t3,t3bak");
 	    system(cmdbuf);
 	t3 = Rast_open_new("t3", DCELL_TYPE);
     if (choice->te2[4]) {
 	if (G_find_raster("t4", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t4,t4bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=t4,t4bak");
 	    system(cmdbuf);
 	t4 = Rast_open_new("t4", DCELL_TYPE);
     if (choice->te2[5]) {
 	if (G_find_raster("t5", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t5,t5bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=t5,t5bak");
 	    system(cmdbuf);
 	t5 = Rast_open_new("t5", DCELL_TYPE);
@@ -289,28 +289,28 @@
     if (choice->jux[1]) {
 	if (G_find_raster("j1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=j1,j1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=j1,j1bak");
 	    system(cmdbuf);
 	j1 = Rast_open_new("j1", DCELL_TYPE);
     if (choice->jux[2]) {
 	if (G_find_raster("j2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=j2,j2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=j2,j2bak");
 	    system(cmdbuf);
 	j2 = Rast_open_new("j2", DCELL_TYPE);
     if (choice->edg[1]) {
 	if (G_find_raster("e1", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=e1,e1bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=e1,e1bak");
 	    system(cmdbuf);
 	e1 = Rast_open_new("e1", DCELL_TYPE);
     if (choice->edg[2]) {
 	if (G_find_raster("e2", G_mapset()) != NULL) {
-	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=e2,e2bak");
+	    sprintf(cmdbuf, "%s %s", "g.rename --o", "raster=e2,e2bak");
 	    system(cmdbuf);
 	e2 = Rast_open_new("e2", DCELL_TYPE);
Modified: grass-addons/grass7/raster/r.lfp/r.lfp.py
--- grass-addons/grass7/raster/r.lfp/r.lfp.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.lfp/r.lfp.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -104,7 +104,7 @@
         grass.fatal(_("Cannot create longest flow path raster map"))
     grass.run_command("g.remove", flags="f",
-            type="rast,vect", pattern="%s*" % prefix)
+            type="raster,vector", pattern="%s*" % prefix)
     options, flags = grass.parser()
Modified: grass-addons/grass7/raster/r.los/r.los.html
--- grass-addons/grass7/raster/r.los/r.los.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.los/r.los.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -58,10 +58,10 @@
 on top of a mountain:
-g.region rast=elevation.dem -p
+g.region raster=elevation.dem -p
 r.los elevation.dem out=los coord=598869,4916642 obs_elev=50 max_dist=10000
 r.colors -e los color=bgyr
-d.shadedmap relief=aspect drape=los bright=10
+d.shade shade=aspect color=los bright=10
 echo "symbol extra/target 25 598869 4916642 red" | d.graph -m
 </pre></div>
Modified: grass-addons/grass7/raster/r.mess/r.mess
--- grass-addons/grass7/raster/r.mess/r.mess	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.mess/r.mess	2014-12-27 13:30:46 UTC (rev 63779)
@@ -376,7 +376,7 @@
 		citiam <- system("g.findfile --quiet element=cell file=MASK", ignore.stdout = TRUE)
         if(citiam==0){
            rname <- paste("MASK",paste(sample(c(0:9, letters, LETTERS), 12, replace=TRUE), collapse=""), sep="_")
-           execGRASS("g.copy", rast=paste("MASK", rname, sep=","))
+           execGRASS("g.copy", raster=paste("MASK", rname, sep=","))
            system("g.remove -bf type=rast name=MASK")
@@ -421,7 +421,7 @@
         # geographic areas outside the current region
         if(citiam==0){
             execGRASS("r.mask", flags="overwrite", raster=rname)
-            execGRASS("g.remove", flags="f", type="rast", name=rname)
+            execGRASS("g.remove", flags="f", type="raster", name=rname)
         }else{
             execGRASS("r.mask", flags="r")
@@ -441,7 +441,7 @@
         calcc <- paste(z1, z2, z3, z4, sep="")
         execGRASS("r.mapcalc", expression=paste(opi[i], " = ", calcc, sep=""), flags="overwrite")
         execGRASS("r.mapcalc", expression=paste(opi[i], " = ", opi[i], "/", digits2, ".0", sep=""), flags="overwrite")
-        execGRASS("g.remove", flags="bf", type="rast", name=paste(tmpf0, tmpf1, tmpf2, tmpf3, sep=","))
+        execGRASS("g.remove", flags="bf", type="raster", name=paste(tmpf0, tmpf1, tmpf2, tmpf3, sep=","))
         unlink(tmp.rule)
 }else{
@@ -505,7 +505,7 @@
         z4 <- paste(", (", envmax, ".0- double(",  ipl2[i], "))/(", envmax, ".0-", envmin, ".0) * 100.0)))", sep="")
         execGRASS("r.mapcalc", expression=paste(opi[i], "=", calcc), flags="overwrite")
-        execGRASS("g.remove", flags="f", type="rast", name=tmpv1)
+        execGRASS("g.remove", flags="f", type="raster", name=tmpv1)
         unlink(tmp.rule)
Modified: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html
--- grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -38,7 +38,7 @@
 <div class="code">
  <pre>
   # align region to DEM and habitat vector
-  g.region -a rast=DEM align=DEM
+  g.region -a raster=DEM align=DEM
   # run <em>r.northerness.easterness</em>
   r.northerness.easterness elevation=DEM
@@ -64,4 +64,4 @@
 <p>
 <i>Last changed: $Date$</i>
-</p>
\ No newline at end of file
+</p>
Modified: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py
--- grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -114,11 +114,11 @@
     # clean up some temporay files and maps
     grass.message( "Some clean up ..." )
-    grass.run_command("g.remove", flags="f", type="rast", name= r_slope,
+    grass.run_command("g.remove", flags="f", type="raster", name= r_slope,
                                      quiet = True)
-    grass.run_command("g.remove", flags="f", type="rast", name= r_aspect,
+    grass.run_command("g.remove", flags="f", type="raster", name= r_aspect,
                                      quiet = True)
-    grass.run_command("g.remove", flags="f", type="rast", name= r_aspect_compass,
+    grass.run_command("g.remove", flags="f", type="raster", name= r_aspect_compass,
                                      quiet = True)
     grass.message( "Clean up done." )
     grass.message( "----" )
Modified: grass-addons/grass7/raster/r.segment/r.segment.html
--- grass-addons/grass7/raster/r.segment/r.segment.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.segment/r.segment.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -94,7 +94,7 @@
 <div><pre class="code">
 # set the region to match the <em>ortho_2001_t792_1m</em> raster map:
-g.region rast=ortho_2001_t792_1m -p
+g.region raster=ortho_2001_t792_1m -p
 # select a smaller region:
 g.region n=221725 s=220225 w=638350 e=639550 -p
Modified: grass-addons/grass7/raster/r.skyview/r.skyview.html
--- grass-addons/grass7/raster/r.skyview/r.skyview.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.skyview/r.skyview.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -16,7 +16,7 @@
 dataset <tt>elevation</tt> map:
 r.skyview input=elevation output=elevation_skyview ndir=8
 </pre></div>
Modified: grass-addons/grass7/raster/r.stream.basins/io.c
--- grass-addons/grass7/raster/r.stream.basins/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.basins/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
 	if (this_window.ew_res != cellhd.ew_res ||
 	    this_window.ns_res != cellhd.ns_res)
           G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
-                          "Run 'g.region rast=%s' to set proper region resolution."),
+                          "Run 'g.region raster=%s' to set proper region resolution."),
                         input_map_name, input_map_name);
     /* checking if input map is of required type */
@@ -426,7 +426,7 @@
     if (check_data_type != seg->data_type)
Modified: grass-addons/grass7/raster/r.stream.channel/io.c
--- grass-addons/grass7/raster/r.stream.channel/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.channel/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.channel/r.stream.channel.html
--- grass-addons/grass7/raster/r.stream.channel/r.stream.channel.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.channel/r.stream.channel.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -90,7 +90,7 @@
 stream of the catchment:
-g.region -p -a rast=elevation
+g.region -p -a raster=elevation
 r.watershed elevation=elevation threshold=10000 drainage=direction stream=streams
 r.stream.order streams=streams direction=direction hack=hack
 r.stream.channel streams=hack direction=direction elevation=elevation \
Modified: grass-addons/grass7/raster/r.stream.distance/io.c
--- grass-addons/grass7/raster/r.stream.distance/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.distance/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
--- grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -144,7 +144,7 @@
 # Set the region to match with elevation map
-g.region -ap rast=elevation
+g.region -pa raster=elevation
 # Calculate flow direction and stream network
Modified: grass-addons/grass7/raster/r.stream.order/io.c
--- grass-addons/grass7/raster/r.stream.order/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.order/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.order/r.stream.order.html
--- grass-addons/grass7/raster/r.stream.order/r.stream.order.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.order/r.stream.order.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -296,7 +296,7 @@
 <h2>EXAMPLE</h2>
 r.stream.order stream_rast=streams direction=direction strahler=riverorder_strahler \
   horton=riverorder_horton shreve=riverorder_shreve hack=riverorder_hack \
Modified: grass-addons/grass7/raster/r.stream.segment/io.c
--- grass-addons/grass7/raster/r.stream.segment/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.segment/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.segment/r.stream.segment.html
--- grass-addons/grass7/raster/r.stream.segment/r.stream.segment.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.segment/r.stream.segment.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -176,7 +176,7 @@
 <h2>EXAMPLE</h2>
 r.stream.order stream_vect=streams direction=direction strahler=riverorder_strahler
 r.stream.segment stream_rast=riverorder_strahler direction=direction \
Modified: grass-addons/grass7/raster/r.stream.slope/main.c
--- grass-addons/grass7/raster/r.stream.slope/main.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.slope/main.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -120,7 +120,7 @@
     Rast_get_cellhd(in_dir_opt->answer, mapset, &cellhd);
     if (window.ew_res != cellhd.ew_res || window.ns_res != cellhd.ns_res)
                         in_dir_opt->answer, in_dir_opt->answer);
     if (Rast_map_type(in_dir_opt->answer, mapset) != CELL_TYPE)
Modified: grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html
--- grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -47,7 +47,7 @@
 <h2>EXAMPLE</h2>
 r.watershed elevation=elevation threshold=10000 drainage=dirs stream=streams
 r.stream.slope dir=dirs elevation=elevation difference=downstream_elev_difference \
   gradient=downstream_gradient maxcurv=downstream_maxcurv mincurv=downstream_mincurv
Modified: grass-addons/grass7/raster/r.stream.snap/io.c
--- grass-addons/grass7/raster/r.stream.snap/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.snap/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html
--- grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -96,7 +96,7 @@
 <h2>EXAMPLE</h2>
 r.watershed elevation=elevation threshold=10000 drainage=dirs stream=streams accumulation=accum
 # snap a point sampled in the riverine landscape to the calculated river network
 r.stream.snap input=mysampleoutlet output=mysampleoutlet_snapped stream_rast=streams accumulation=accum
Modified: grass-addons/grass7/raster/r.stream.stats/io.c
--- grass-addons/grass7/raster/r.stream.stats/io.c	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.stats/io.c	2014-12-27 13:30:46 UTC (rev 63779)
@@ -77,7 +77,7 @@
@@ -426,7 +426,7 @@
Modified: grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html
--- grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -164,7 +164,7 @@
 external program (like R) to be visualised:
 r.stream.stats stream_rast=horton direction=direction elevation=elevation
 # export for processing in R
Modified: grass-addons/grass7/raster/r.surf.nnbathy/r.surf.nnbathy.html
--- grass-addons/grass7/raster/r.surf.nnbathy/r.surf.nnbathy.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.surf.nnbathy/r.surf.nnbathy.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -53,7 +53,7 @@
 <h2>EXAMPLE</h2>
-g.region rast=elevation at PERMANENT -p
+g.region raster=elevation at PERMANENT -p
 r.random input=elevation at PERMANENT n=100000 raster_output=random_points
 r.surf.nnbathy input=random_points output=raster_map
 d.rast map=raster_map
Modified: grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.html
--- grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -22,7 +22,7 @@
 (Spearfish dataset)
 r.to.vect.lines.py in=elevation.dem out=wiggle_lines
 eval `v.info -g wiggle_lines`
 r.mapcalc "floor = $bottom"
Modified: grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
--- grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -13,7 +13,7 @@
 # To make a wiggle line plot in NVIZ:
-#   g.region rast=elevation.dem
+#   g.region raster=elevation.dem
 #   r.to.vect.lines.py in=elevation.dem out=wiggle_lines
 #   eval `v.info -g wiggle_lines`
 #   r.mapcalc "floor = $bottom"
Modified: grass-addons/grass7/raster/r.traveltime/r.traveltime.html
--- grass-addons/grass7/raster/r.traveltime/r.traveltime.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.traveltime/r.traveltime.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -32,7 +32,7 @@
 <i>This example uses the North Carolina sample dataset.</i>
 <p>
-g.region rast=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
+g.region raster=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
 r.watershed elev_lid792_1m thresh=5000 accum=accum_5K   drain=draindir_5K
 r.fill.dir elev_lid792_1m output=elev_filled outdir=elev_dir
Modified: grass-addons/grass7/raster/r.univar2/r.univar2.html
--- grass-addons/grass7/raster/r.univar2/r.univar2.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.univar2/r.univar2.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -41,7 +41,7 @@
 #### set the raster region to match the map
-g.region vect=fields res=10 -ap
+g.region vector=fields res=10 -ap
 #### create rasterized version of vector map
 v.to.rast in=fields out=fields.10m use=cat type=area labelcolumn=label
@@ -55,7 +55,7 @@
 #### populate vector DB with stats
 # create working copy of vector map
-g.copy vect=fields,fields_stats
+g.copy vector=fields,fields_stats
 # create new attribute columns to hold output
 v.db.addcol map=fields_stats \
@@ -90,7 +90,7 @@
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -16,7 +16,7 @@
 <div class="code">
  <pre>
   # run <em>r.valley.bottom</em>
   r.r.valley.bottom elevation=DEM
@@ -51,4 +51,4 @@
 <p>
-</p>
+</p>
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -99,7 +99,7 @@
     grass.message( "..." )
-    grass.run_command("g.remove", flags="f", type="rast", name= r_slope_degree,
+    grass.run_command("g.remove", flags="f", type="raster", name= r_slope_degree,
                                      quiet = True)
     grass.message( "Step 1: Calculation of slope done." )
@@ -231,7 +231,7 @@
         expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
     grass.mapcalc( expr2 )
-    grass.run_command("g.remove", flags="f", type="rast", name= "elevation_step1",
+    grass.run_command("g.remove", flags="f", type="raster", name= "elevation_step1",
                                      quiet = True)
     grass.message( "Step 2: Calculation of elevation percentile PCTL2 done" )
Modified: grass-addons/grass7/raster/r.vif/r.vif
--- grass-addons/grass7/raster/r.vif/r.vif	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/raster/r.vif/r.vif	2014-12-27 13:30:46 UTC (rev 63779)
@@ -159,7 +159,7 @@
     eval `g.findfile element=cell file=MASK mapset=$MAPSET`
     remove_mask=1
     if [ $file ] ; then
-        g.copy rast=MASK,mask_r_vif_backup
+        g.copy raster=MASK,mask_r_vif_backup
         mask_exists=1
         unset file
     fi
Modified: grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html
--- grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -19,7 +19,7 @@
 # set computational region to raster ...
-g.region -p rast=...
+g.region -p raster=...
 # extract urban areas
 r.mapcalc "urban = if(...)"
Modified: grass-addons/grass7/vector/v.colors2/v.colors2.html
--- grass-addons/grass7/vector/v.colors2/v.colors2.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.colors2/v.colors2.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -41,7 +41,7 @@
 <p>
 Colorizing the roads map in Spearfish:
-g.copy vect=roads,myroads
+g.copy vector=roads,myroads
 echo "1 red
 2 yellow
 3 orange
Modified: grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.html
--- grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -191,7 +191,7 @@
 <div class="code">
  <pre>
-  g.region -a rast=DEM vect=myhabitats align=DEM
+  g.region -a raster=DEM vect=myhabitats align=DEM
   # run <em>v.habitat.dem</em>
   v.habitat.dem elevation=DEM vector=myhabitats column=Id prefix=a dir=C:\wd
@@ -240,4 +240,4 @@
 <p>
-</p>
+</p>
Modified: grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
--- grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py	2014-12-27 13:30:46 UTC (rev 63779)
@@ -513,8 +513,8 @@
     grass.run_command("g.remove", flags="f", type="region", name= saved_region)
-    grass.run_command("g.remove", flags="f", type="rast", name= r_flow_accum)
-    grass.run_command("g.remove", flags="f", type="rast", name= r_habitat)
+    grass.run_command("g.remove", flags="f", type="raster", name= r_flow_accum)
+    grass.run_command("g.remove", flags="f", type="raster", name= r_habitat)
     grass.run_command("db.droptable", flags = 'f',
                                      table = t_habitat_geomorphons)
Modified: grass-addons/grass7/vector/v.isochrones/v.isochrones.html
--- grass-addons/grass7/vector/v.isochrones/v.isochrones.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.isochrones/v.isochrones.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -26,13 +26,13 @@
 <h2>EXAMPLE</h2>
-g.copy vect=roadsmajor,roads
+g.copy vector=roadsmajor,roads
 v.db.addcolumn roads col="speed int"
 v.db.update roads col=speed value=120 where="ROAD_NAME='US-1'"
 v.db.update roads col=speed value=90 where="(ROAD_NAME like 'US%' AND ROAD_NAME <> 'US-1') OR ROAD_NAME like 'I-%'"
 v.db.update roads col=speed value=50 where="speed is null"
-g.region vect=roads res=100 -a -p
+g.region vector=roads res=100 -a -p
 echo "634637|224663" | v.in.ascii input=- output=start x=1 y=2
Modified: grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html
--- grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -23,7 +23,7 @@
 # setting the region
-g.region -p rast=elev_state_500m
+g.region -p raster=elev_state_500m
 # create Voronoi diagram based on meteorological stations
 v.voronoi input=precip_30ynormals output=precip_annual
Modified: grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html
--- grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.surf.nnbathy/v.surf.nnbathy.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -53,7 +53,7 @@
 <h2>EXAMPLE</h2>
-g.region rast=elevationelev_lid792_randpts at PERMANENT -p
+g.region raster=elevationelev_lid792_randpts at PERMANENT -p
 v.surf.nnbathy input=elevation_lid792_randpts at PERMANENT output=raster_map column=value
 </pre></div>
Modified: grass-addons/grass7/vector/v.transects/v.transects.html
--- grass-addons/grass7/vector/v.transects/v.transects.html	2014-12-27 12:51:00 UTC (rev 63778)
+++ grass-addons/grass7/vector/v.transects/v.transects.html	2014-12-27 13:30:46 UTC (rev 63779)
@@ -28,7 +28,8 @@
 <p>Generate 20 cross-shore transects along 2008 shoreline (1m contour)
 <br>
-<div class=code><pre>g.region rast=NH_2008_1m
+<div class=code><pre>
+g.region raster=NH_2008_1m
 r.contour input=NH_2008_1m output=NH_2008_1m level=1 cut=100
 v.report map=NH_2008_1m option=length
 # cat|level|length
@@ -44,7 +45,8 @@
 Generate longer, more parallel transects by specifying dleft and dright and
 smoothing the input line
 <br>
 v.generalize input=NH_2008_1m output=NH_2008_1m_smoothed \
   method=sliding_averaging look_ahead=201
@@ -58,7 +60,8 @@
 <p>
 smoothing the input line<br>
 v.transects input=NH_2008_1m output=NH_2008_areas \
   transect_spacing=52 dleft=20 dright=300 type=area
