[GRASS-SVN] r58830 - grass-addons/grass7/vector/v.centerpoint
Sat Feb 1 13:20:32 PST 2014
Author: mmetz
Date: 2014-02-01 13:20:32 -0800 (Sat, 01 Feb 2014)
New Revision: 58830
   grass-addons/grass7/vector/v.centerpoint/areas.c
   grass-addons/grass7/vector/v.centerpoint/lines.c
   grass-addons/grass7/vector/v.centerpoint/main.c
   grass-addons/grass7/vector/v.centerpoint/points.c
   grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html
v.centerpoint: fix areas and category transfer
Modified: grass-addons/grass7/vector/v.centerpoint/areas.c
--- grass-addons/grass7/vector/v.centerpoint/areas.c	2014-02-01 21:17:30 UTC (rev 58829)
+++ grass-addons/grass7/vector/v.centerpoint/areas.c	2014-02-01 21:20:32 UTC (rev 58830)
@@ -11,7 +11,7 @@
     int area, nareas, isle, nisles, nisles_alloc;
     struct line_pnts *Points, **IPoints, *OPoints;
-    struct line_cats *Cats;
+    struct line_cats *Cats, *ICats;
     struct bound_box box;
     double x, y, z, meanx, meany, meanz;
     double *xp, *yp;
@@ -21,6 +21,7 @@
     Points = Vect_new_line_struct();
     OPoints = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
+    ICats = Vect_new_cats_struct();
     nisles_alloc = 10;
     IPoints = G_malloc(nisles_alloc * sizeof (struct line_pnts *));
@@ -42,10 +43,14 @@
 	for (area = 1; area <= nareas; area++) {
 	    Vect_reset_cats(Cats);
-	    if (layer > 1) {
-		Vect_get_area_cats(In, area, Cats);
-	        if (!Vect_cats_in_constraint(Cats, layer, cat_list))
-		    continue;
+	    if (Vect_get_area_cats(In, area, ICats) != 0)
+		continue;
+	    if (!Vect_cats_in_constraint(ICats, layer, cat_list))
+		continue;
+	    for (i = 0; i < ICats->n_cats; i++) {
+		if (ICats->field[i] == layer)
+		    Vect_cat_set(Cats, 1, ICats->cat[i]);
 	    Vect_get_area_points(In, area, Points);
@@ -59,9 +64,10 @@
 		nisles_alloc = nisles;
-	    for (isle = 1; isle < nisles; isle++) {
-		Vect_get_isle_points(In, isle, IPoints[isle - 1]);
-		Vect_line_prune(IPoints[isle - 1]);
+	    for (isle = 0; isle < nisles; isle++) {
+		Vect_get_isle_points(In, Vect_get_area_isle(In, area, isle),
+		                     IPoints[isle]);
+		Vect_line_prune(IPoints[isle]);
 	    /* surveyor's / shoelace formula */
@@ -104,6 +110,7 @@
 	    if (Out) {
 		Vect_reset_line(OPoints);
 		Vect_append_point(OPoints, x, y, z);
+		Vect_cat_set(Cats, 2, 7);
 		Vect_write_line(Out, GV_POINT, OPoints, Cats);
 	    else
@@ -136,10 +143,14 @@
-	    if (layer > 1) {
-		    continue;
+		continue;
+		continue;
@@ -154,10 +165,11 @@
-		nwc += IPoints[isle - 1]->n_points - 1;
+		                     IPoints[isle]);
+		nwc += IPoints[isle]->n_points - 1;
 	    if (nwc_alloc < nwc) {
@@ -378,6 +390,7 @@
 	    if (Out) {
 		Vect_append_point(OPoints, x, y, 0);
+		Vect_cat_set(Cats, 2, 8);
 	    else
@@ -410,10 +423,14 @@
-	    if (layer > 1) {
-		    continue;
+		continue;
+		continue;
@@ -428,10 +445,11 @@
-		nw += IPoints[isle - 1]->n_points - 1;
+		                     IPoints[isle]);
+		nw += IPoints[isle]->n_points - 1;
 	    if (nw_alloc < nw) {
@@ -547,6 +565,7 @@
 	    if (Out) {
+		Vect_cat_set(Cats, 2, 9);
 	    else
Modified: grass-addons/grass7/vector/v.centerpoint/lines.c
--- grass-addons/grass7/vector/v.centerpoint/lines.c	2014-02-01 21:17:30 UTC (rev 58829)
+++ grass-addons/grass7/vector/v.centerpoint/lines.c	2014-02-01 21:20:32 UTC (rev 58830)
@@ -10,14 +10,15 @@
                  struct cat_list *cat_list, int n_primitives, int mode)
     struct line_pnts *Points, *OPoints;
     double x, y, z;
     int type;
-    int counter;
+    int i, counter;
     /* mid point */
     if (mode & L_MID) {
@@ -33,10 +34,14 @@
 	    if (!(type & GV_LINE))
 		continue;
-	    if (layer > 0 &&
-	        !Vect_cats_in_constraint(Cats, layer, cat_list))
 		continue;
 	    Vect_line_prune(Points);
 	    len = Vect_line_length(Points) / 2.;
@@ -46,6 +51,7 @@
 	    if (Out) {
+		Vect_cat_set(Cats, 2, 4);
 	    else
@@ -58,7 +64,6 @@
     if (mode & L_MEAN) {
 	double len, slen;
 	double dx, dy, dz;
-	int i;
 	G_message(_("Calculating centers of gravity for lines..."));
 	counter = 0;
@@ -69,10 +74,14 @@
 	    counter++;
 		continue;
-	    if (layer > 0 &&
 		continue;
 	    len = 0.;
@@ -100,6 +109,7 @@
 	    if (Out) {
+		Vect_cat_set(Cats, 2, 5);
 	    else
@@ -117,7 +127,7 @@
 	double xmean, ymean, zmean;
 	double medx, medy, medz;
 	double dist, distsum, dist2all, lastdist2all;
-	int i, j, iter, maxiter = 100;
+	int j, iter, maxiter = 100;
 	SPoints = Vect_new_line_struct();
@@ -130,10 +140,14 @@
 	    counter++;
 		continue;
-	    if (layer > 0 &&
 		continue;
 	    len = G_malloc((Points->n_points - 1) * sizeof(double));
@@ -235,6 +249,7 @@
 	    if (Out) {
+		Vect_cat_set(Cats, 2, 6);
 	    else
Modified: grass-addons/grass7/vector/v.centerpoint/main.c
--- grass-addons/grass7/vector/v.centerpoint/main.c	2014-02-01 21:17:30 UTC (rev 58829)
+++ grass-addons/grass7/vector/v.centerpoint/main.c	2014-02-01 21:20:32 UTC (rev 58830)
@@ -62,7 +62,7 @@
     type_opt->answer = "point,line,area";
     type_opt->guisection = _("Selection");
-    lyr_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+    lyr_opt = G_define_standard_option(G_OPT_V_FIELD);
     lyr_opt->guisection = _("Selection");
     cats_opt = G_define_standard_option(G_OPT_V_CATS);
@@ -174,14 +174,14 @@
     if (1 > Vect_open_old(&In, old->answer, mapset))
 	G_fatal_error(_("Unable to open vector map <%s>"), old->answer);
-    layer = -1;
-    if (lyr_opt->answer)
-	layer = Vect_get_field_number(&In, lyr_opt->answer);
+    layer = Vect_get_field_number(&In, lyr_opt->answer);
-    if (layer > 0)
-	cat_list = Vect_cats_set_constraint(&In, layer, where_opt->answer,
-                                            cats_opt->answer);
+    if (layer < 1)
+	G_fatal_error(_("Invalid %s answer: %s"), lyr_opt->key, lyr_opt->answer);
+    cat_list = Vect_cats_set_constraint(&In, layer, where_opt->answer,
+					cats_opt->answer);
     out3d = Vect_is_3d(&In);
     Outp = NULL;
@@ -228,7 +228,7 @@
     if (nlines) {
 	lines_center(&In, Outp, layer, cat_list, nprimitives, mode);
-	Vect_copy_tables(&In, &Out, layer);
+	Vect_copy_table(&In, &Out, layer, 1, NULL, GV_1TABLE);
     Vect_close(&In);
@@ -240,10 +240,12 @@
 	    G_warning(_("Unable to open vector map <%s> with topology"), old->answer);
 	else {
-	    int nareas = Vect_get_num_areas(&In);
-	    if (nareas)
+	    if (Vect_get_num_areas(&In) > 0) {
 		areas_center(&In, Outp, layer, cat_list, mode);
+	    else
+		G_warning(_("No areas in input vector <%s>"), old->answer);
 	    Vect_close(&In);
Modified: grass-addons/grass7/vector/v.centerpoint/points.c
--- grass-addons/grass7/vector/v.centerpoint/points.c	2014-02-01 21:17:30 UTC (rev 58829)
+++ grass-addons/grass7/vector/v.centerpoint/points.c	2014-02-01 21:20:32 UTC (rev 58830)
@@ -48,7 +48,8 @@
 	if (!(type & GV_POINT))
 	    continue;
-	if (layer > 0 && !Vect_cats_in_constraint(Cats, layer, cat_list))
+	if (layer > 0 &&
+	    !Vect_cats_in_constraint(Cats, layer, cat_list))
 	    continue;
 	xsum += Points->x[0];
@@ -71,7 +72,7 @@
 	    Vect_reset_cats(OCats);
-	    Vect_cat_set(OCats, 1, 1);
+	    Vect_cat_set(OCats, 2, 1);
 	else
@@ -161,7 +162,7 @@
-		Vect_cat_set(OCats, 1, 2);
+		Vect_cat_set(OCats, 2, 2);
 	    else
@@ -216,7 +217,7 @@
-	    Vect_cat_set(OCats, 1, 3);
+	    Vect_cat_set(OCats, 2, 3);
 	else
Modified: grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html
--- grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html	2014-02-01 21:17:30 UTC (rev 58829)
+++ grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html	2014-02-01 21:20:32 UTC (rev 58830)
@@ -25,8 +25,9 @@
   <li><b>8</b> - median of each area using area triangulation</li>
   <li><b>9</b> - median of each area using boundaries</li>
 </ul>
-If an output vector is given, center points inherit the categories of
-the respective lines and areas. For points, the category is set to 1
+If an output vector is given, categories of the respective lines and
+areas are transferred from the selected layer to layer 1. Layer 2 holds
+the same category values as for output to stdout.
 <h4>Point centers</h4>
 <ul>
