[GRASS-SVN] r58889 - grass/branches/develbranch_6/raster/r.li/r.li.setup
Wed Feb 5 14:01:10 PST 2014
Author: hamish
Date: 2014-02-05 14:01:09 -0800 (Wed, 05 Feb 2014)
New Revision: 58889
   grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh
script cleanups, more to come for this file
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-05 21:06:08 UTC (rev 58888)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-05 22:01:09 UTC (rev 58889)
@@ -2,131 +2,153 @@
 # This program is free software under the GPL (>=v2)
 # Read the COPYING file that comes with GRASS for details.
-#%Module
-#% description: Create sample area from a vector map
+#%Module
+#% description: Create sample area from a vector map
 #%End
 #%option
 #% key: raster
 #% type: string
-#% description: raster map to to analyse
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Raster map to to analyse
 #% required: yes
 #%end
 #%option
 #% key: vector
 #% type: string
-#% description: vector map where areas are defined
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Vector map where areas are defined
 #% required: yes
 #%end
 #%option
 #% key: conf
 #% type: string
-#% description: name of configuration file where insert areas
+#% key_desc: name
+#% gisprompt: new_file,file,output
+#% description: Name of configuration file where areas are to be saved
 #% required: yes
 #%end
-# Check if we have grass
-if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
- fi
+# Check if we are in a GRASS session
+if [ -z "$GISBASE" ] ; then
+   echo "You must be in GRASS GIS to run this program." 1>&2
+   exit 1
+fi
 if [ "$1" != "@ARGS_PARSED@" ] ; then
-  exec g.parser "$0" "$@"
+   exec g.parser "$0" "$@"
 fi
 #### set temporary files
 TMP="`g.tempfile pid=$$`"
 if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-    echo "ERROR: unable to create temporary files" 1>&2
-    exit 1
+   echo "ERROR: unable to create temporary files" 1>&2
+   exit 1
 fi
 #### environment variables
-g.gisenv LOCATION_NAME > $TMP.var
-read LOCATION < $TMP.var
-g.gisenv GISDBASE > $TMP.var
-read GISDBASE < $TMP.var
-g.gisenv MAPSET > $TMP.var
-read MAPSET < $TMP.var
+GISDBASE=`g.gisenv get=GISDBASE`
+LOCATION=`g.gisenv get=LOCATION_NAME`
+MAPSET=`g.gisenv get=MAPSET`
+: ${GISDBASE?} ${LOCATION?} ${MAPSET?}
 f_path="$GISBASE/etc/r.li.setup"
-#read categories from input vector, extract,
-#convert to raster and save the bounds to configuration file
+# read categories from input vector, extract,
+# convert to raster and save the bounds to configuration file
-#using v.category instead of v.build with cdump
-v.category input=$GIS_OPT_vector option=print | sort | uniq > $TMP.cat
+# using v.category instead of v.build with cdump
+v.category input=$GIS_OPT_vector option=print | sort | uniq > "$TMP.cat"
-#get input vector name
+# get input vector name
 GIS_OPT_input_vector=`echo $GIS_OPT_vector| cut -d'@' -f 1`
-#get input vector mapset
+# get input vector mapset
 GIS_OPT_input_mapset=`echo $GIS_OPT_vector| cut -d'@' -f 2`
-#read input vector categories into CAT_LIST array
+# read input vector categories into CAT_LIST array
 IFS=$'\r\n' CAT_LIST=($(cat $TMP.cat))
-TMP_REGION="reg`g.tempfile pid=$$`"
-#save the current region settings temporarily to avoid surpirses later.
-g.region save=$TMP_REGION
+# save the current region settings temporarily to avoid surpirses later.
+TMP_REGION="tmp_rlisetup.sampvect.$$"
+g.region save="$TMP_REGION"
-#process each feature in the vector having category values in the CAT_LIST array
-for CAT in "${CAT_LIST[@]}"
+# find a free Xmonitor
+XMON=x1
+for i in 1 2 3 4 5 6 7 ; do
+   result=`d.mon -L | grep -w "^x$i"`
+   if [ `echo "$result" | grep -c 'not'` -eq 1 ] ; then
+      XMON="x$i"
+      break
+   fi
+done
+# process each feature in the vector having category values in the CAT_LIST array
+for CAT in "${CAT_LIST[@]}"
 do
-    #vector to store a feature fro $GIS_OPT_vector with category value $CAT.
-    #This temporary vector will be removed at the end.
+    # vector to store a feature fro $GIS_OPT_vector with category value $CAT.
+    # This temporary vector will be removed at the end.
     EXTRACT=$GIS_OPT_input_vector"_"$CAT"_part@"$GIS_OPT_input_mapset
-    #extract only a part of $GIS_OPT_vector where category = $CAT and store in $EXTRACT
-    v.extract input=$GIS_OPT_vector output=$EXTRACT type=point,line,boundary,centroid,area,face new=-1 -d where='CAT='$CAT
-    #TODO: anyway to check if x1 is in use?
-    #opening monitor x1
-    d.mon stop=x1
-    d.mon start=x1
-    #setting region with raster resolution
-    g.region vect=$EXTRACT align=$GIS_OPT_raster
-    d.rast -o $GIS_OPT_raster
-    #render extracted vector map
-    d.vect $EXTRACT
-    #ask the user if he wants to analyse this vector and a name for raster
-    #in graphical mode using wish
-    export name=$TMP.val # where find the answer
-    $GRASS_WISH $f_path/area_query
-    cat $name | cut -f1 -d ' ' > $name.var
-    read ok < $name.var
-    cat $name | cut -f2 -d' ' > $name.var
-    r_name=""
-    read r_name < $name.var
-    echo $r_name
-    if [ $ok -eq 1 ] ; then
+    # extract only a part of $GIS_OPT_vector where category = $CAT and store in $EXTRACT
+    v.extract input=$GIS_OPT_vector output=$EXTRACT \
+       type=point,line,boundary,centroid,area,face \
+       new=-1 -d where='CAT='$CAT
+    # open Xmonitor
+    d.mon stop="$XMON"
+    d.mon start="$XMON"
+    # set region with raster resolution
+    g.region vect="$EXTRACT" align="$GIS_OPT_raster"
+    d.rast -o "$GIS_OPT_raster"
+    # render extracted vector map
+    d.vect "$EXTRACT"
+    # ask the user to analyse this vector and a name for raster in a Tcl GUI
+    name="$TMP.val" # where find the answer
+    export name
+    "$GRASS_WISH" "$f_path/area_query"
+    ok=`cat "$name" | cut -f1 -d ' '`
+    #cat "$name" | cut -f1 -d ' ' > "$name.var"
+    #read ok < "$name.var"
+    r_name=`cat "$name" | cut -f2 -d' '`
+    #cat "$name" | cut -f2 -d' ' > "$name.var"
+    #r_name=""
+    #read r_name < "$name.var"
+    echo "$r_name"
+    if [ "$ok" -eq 1 ] ; then
 	#area selected, create mask
-	v.to.rast input=$EXTRACT output=$r_name use=cat value=1 rows=4096
-	#read the region settings to save to configuration file
-	g.region -g| grep "n=" | cut -f2 -d'='> $name.var
-	read north < $name.var
-	g.region -g| grep "s=" | cut -f2 -d'='  > $name.var
-	read south < $name.var
-	g.region -g| grep "e=" | cut -f2 -d'=' > $name.var
-	read east < $name.var
-	g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
-	read west < $name.var
-	#write info in configuration file
-	echo "MASKEDOVERLAYAREA $r_name|$north|$south|$east|$west" >> $GIS_OPT_conf
+	v.to.rast input="$EXTRACT" output="$r_name" use=cat value=1 rows=4096
+	# save the region settings into the configuration file
+	eval `g.region -g`
+	echo "MASKEDOVERLAYAREA $r_name|$n|$s|$e|$w" >> "$GIS_OPT_conf"
     fi
     #remove temporary vector map created from v.extract
-    g.remove vect=$EXTRACT
+    g.remove vect="$EXTRACT"
     #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/$GIS_OPT_vector"part"$I
-    #echo DROP TABLE $GIS_OPT_vector"part"$I | db.execute
+    #echo DROP TABLE $GIS_OPT_vector"part"$I | db.execute
 done
-d.mon stop=x1
-#restore user region
-g.region region=$TMP_REGION
-#remove temporary region, $TMP_REGION
-g.remove region=$TMP_REGION
-# clean tmp files
-rm -f $TMP*
+d.mon stop="$XMON"
+# restore the region (which itself is a WIND_OVERRIDE temporary region by
+#  the r.li.setup main script)
+g.region region="$TMP_REGION"
+g.remove region="$TMP_REGION"
+# clean tmp files
+rm -f "$TMP"*
