[GRASS-SVN] r58926 - grass/branches/develbranch_6/raster/r.li/r.li.setup
Fri Feb 7 00:01:06 PST 2014
Author: hamish
Date: 2014-02-07 00:01:06 -0800 (Fri, 07 Feb 2014)
New Revision: 58926
   grass/branches/develbranch_6/raster/r.li/r.li.setup/area_query
   grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh
pre-seed vector overlay cat raster mask names (#2024)
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/area_query
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/area_query	2014-02-07 07:34:20 UTC (rev 58925)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/area_query	2014-02-07 08:01:06 UTC (rev 58926)
@@ -13,7 +13,7 @@
     pack .label
     frame .buttons
     pack .buttons
-    set val ""
+    set val "$env(input_vector)_$env(CAT)"
     button .buttons.ok -text "Ok" -command {
 	frame .name
 	pack .name
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-07 07:34:20 UTC (rev 58925)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-07 08:01:06 UTC (rev 58926)
@@ -112,7 +112,7 @@
 if [ "$NUM_CATS" -gt 30 ] ; then
     g.message -w "<$GIS_OPT_vector> contains $NUM_CATS areas. Manual selection may be time consuming."
     # TODO: d.menu [Continue][Abort] on screen display
-elif [ "$NUM_CATS" -gt 0 ] ; then
+elif [ "$NUM_CATS" -eq 0 ] ; then
     g.message -w "<$GIS_OPT_vector> doesn't contain any areas. Aborting selection."
     # TODO: d.menu [Ok] on screen display
 fi
@@ -152,7 +152,7 @@
     # ask the user to analyse this vector and a name for raster in a Tcl GUI
     name="$TMP.val" # where find the answer
-    export name
+    export name input_vector CAT
     # ask if it's ok, save 0,1 to "$name" temp file
     "$GRASS_WISH" "$f_path/area_query"
@@ -165,7 +165,7 @@
     if [ "$ok" -eq 1 ] ; then
 	#area selected, create mask
-	mask_name="rli_samp_${input_vector}_${CAT}_${r_name}"
+	mask_name="rli_samp_${r_name}"
 	v.to.rast input="$EXTRACT" output="$mask_name" use=cat --quiet
 	# save the region settings into the configuration file
