[GRASS-SVN] r58930 - grass/branches/develbranch_6/raster/r.li/r.li.daemon
Fri Feb 7 02:58:03 PST 2014
Author: hamish
Date: 2014-02-07 02:58:02 -0800 (Fri, 07 Feb 2014)
New Revision: 58930
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
fix mask mapset bug, disable too-brittle check for fully-qualified-name in the config file: the map name there doesn't always have an @mapset part
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2014-02-07 10:40:45 UTC (rev 58929)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2014-02-07 10:58:02 UTC (rev 58930)
@@ -316,7 +316,7 @@
     struct stat s;
     struct Cell_head cellhd;
-    char *buf, *token, *raster_fqn, *mapset;
+    char *buf, *token, *mapset; /* *raster_fqn, */
     int setup;
     int letti;
     double rel_x, rel_y, rel_rl, rel_cl;
@@ -349,7 +349,7 @@
     /* find raster map */
     mapset = G_find_cell(raster, "");
-    raster_fqn = G_fully_qualified_name(raster, mapset);
+/*    raster_fqn = G_fully_qualified_name(raster, mapset); */
     if (G_get_cellhd(raster, mapset, &cellhd) == -1)
 	G_fatal_error(_("Cannot read raster header file"));
@@ -513,12 +513,12 @@
 	       (strcmp(token, "MASKEDOVERLAYAREA") == 0));
 	if (strcmp(token, "RASTERMAP") != 0)
-	    G_fatal_error(_("Irregular maskedoverlay areas definition"));
+	    G_fatal_error(_("Irregular MASKEDOVERLAY areas definition"));
 	token = strtok(NULL, "\n");
-	if (strcmp(token, raster_fqn) != 0)
+/*	if (strcmp(token, raster_fqn) != 0)
 	    G_fatal_error(_("The configuration file can be used only with "
-			"rasterfile <%s> and not with <%s>"), token, raster_fqn);
+			"rasterfile <%s> and not with <%s>"), token, raster_fqn); */
 	close(setup);
 	return NORMAL;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c	2014-02-07 10:40:45 UTC (rev 58929)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c	2014-02-07 10:58:02 UTC (rev 58930)
@@ -235,15 +235,16 @@
     G_debug(3, "daemon mask preproc: raster=[%s] mask=[%s]  rl=%d cl=%d",
 	    raster, mask, rl, cl);
-/* BUG/TODO: mask variable already contains the @mapset, but it after this line switches to @PERMANENT */
     /* mapset is used hold the mapset of input raster */
     /* open raster */
     if (G_get_cellhd(raster, mapset, &cell) == -1)
 	return NULL;
     mask_mapset = G_find_cell(mask, "");
     /* open raster */
     if (G_get_cellhd(mask, mask_mapset, &oldcell) == -1)
 	return NULL;
@@ -253,8 +254,10 @@
     tmp_file = G_tempfile();
     mask_fd = open(tmp_file, O_RDWR | O_CREAT, 0755);
-    old_fd = G_open_cell_old(mask, mapset);
-    G_debug(1,"worker.c: mask <%s@%s>", mask, mapset);
+    old_fd = G_open_cell_old(mask, mask_mapset);
+    G_debug(1, "worker.c: mask <%s@%s>", mask, mask_mapset);
     old = G_allocate_cell_buf();
     for (i = 0; i < rl; i++) {
