[GRASS-SVN] r58952 - grass/trunk/lib/python/temporal
Fri Feb 7 17:34:58 PST 2014
Author: huhabla
Date: 2014-02-07 17:34:58 -0800 (Fri, 07 Feb 2014)
New Revision: 58952
   grass/trunk/lib/python/temporal/core.py
Better error message in case the temporal database version is outdated.
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2014-02-08 01:33:53 UTC (rev 58951)
+++ grass/trunk/lib/python/temporal/core.py	2014-02-08 01:34:58 UTC (rev 58952)
@@ -64,7 +64,7 @@
 # Profiling function provided by the temporal framework
 def profile_function(func):
     do_profiling = os.getenv("GRASS_TGIS_PROFILE")
     if do_profiling is "True" or do_profiling is "1":
         import cProfile, pstats, StringIO
         pr = cProfile.Profile()
@@ -85,7 +85,7 @@
 tgis_backend = None
 def get_tgis_backend():
     """!Return the temporal GIS backend as string
        return either "sqlite" or "pg"
     global tgis_backend
@@ -115,7 +115,7 @@
 def get_tgis_dbmi_paramstyle():
     """!Return the temporal database backend parameter style
        @return "qmark" or ""
     global tgis_dbmi_paramstyle
@@ -150,7 +150,7 @@
     global current_location
     return current_location
 def get_current_gisdbase():
@@ -167,13 +167,13 @@
 # If this global variable is set True, then maps can only be registered in space time datasets
 # with the same mapset. In addition, only maps in the current mapset can be inserted, updated or deleted from
-# the temporal database.
+# the temporal database.
 # Overwrite this global variable by: g.gisenv set="TGIS_DISABLE_MAPSET_CHECK=True"
 # ATTENTION: Be aware to face corrupted temporal database in case this global variable is set to False.
 #            This feature is highly experimental and violates the grass permission guidance.
 enable_mapset_check = True
 # If this global variable is set True, the timestamps of maps will be written as textfiles
-# for each map that will be inserted or updated in the temporal database using the C-library
+# for each map that will be inserted or updated in the temporal database using the C-library
 # timestamp interface.
 # Overwrite this global variable by: g.gisenv set="TGIS_DISABLE_TIMESTAMP_WRITE=True"
@@ -183,29 +183,29 @@
 def get_enable_mapset_check():
     """!Return True if the mapsets should be checked while insert, updatem delete requests
        and space time dataset registration.
-       the temporal database.
+       the temporal database.
     global enable_mapset_check
     return enable_mapset_check
 def get_enable_timestamp_write():
     """!Return True if the map timestamps should be written to the spatial database metadata as well.
-       for each map that will be inserted or updated in the temporal database using the C-library
+       for each map that will be inserted or updated in the temporal database using the C-library
        ATTENTION: Be aware that C-libraries can not access timestamp informations if they are not
-                  written as spatial database metadata, hence modules that make use of timestamps
-                  using the C-library interface will not work with maps that were created without
+                  written as spatial database metadata, hence modules that make use of timestamps
+                  using the C-library interface will not work with maps that were created without
                   writing the timestamps.
     global enable_timestamp_write
@@ -225,7 +225,7 @@
     global message_interface
     from grass.pygrass import messages
-    message_interface = messages.Messenger(raise_on_error)
+    message_interface = messages.get_msgr(raise_on_error=raise_on_error)
 def get_tgis_message_interface():
     """!Return the temporal GIS message interface which is of type
@@ -262,21 +262,21 @@
-# Set this variable True to raise a FatalError exception
-# in case a fatal error occurs using the messenger interface
+# Set this variable True to raise a FatalError exception
+# in case a fatal error occurs using the messenger interface
 raise_on_error = False
 def set_raise_on_error(raise_exp=True):
     """!Define behavior on fatal error, invoked using the tgis messenger
     interface (msgr.fatal())
     The messenger interface will be restarted using the new error policy
     @param raise_exp True to raise a FatalError exception instead of calling
     sys.exit(1) when using the tgis messenger interface
     @code
     >>> import grass.temporal as tgis
     >>> tgis.init()
     >>> ignore = tgis.set_raise_on_error(False)
@@ -288,7 +288,7 @@
       File "__init__.py", line 239, in fatal
         sys.exit(1)
     SystemExit: 1
     >>> tgis.set_raise_on_error(True)
     False
     >>> msgr.fatal("Ohh no no no!")
@@ -296,7 +296,7 @@
       File "__init__.py", line 241, in fatal
         raise FatalError(message)
     FatalError: Ohh no no no!
     @endcode
     @return current status
@@ -367,15 +367,15 @@
-# The temporal database string set with t.connect
+# The temporal database string set with t.connect
 # with substituted GRASS variables gisdbase, location and mapset
 tgis_database_string = None
 def get_tgis_database_string():
     """!Return the preprocessed temporal database string
        This string is the temporal database string set with t.connect
-       that was processed to substitue location, gisdbase and mapset
+       that was processed to substitue location, gisdbase and mapset
        varibales.
     global tgis_database_string
@@ -432,12 +432,12 @@
         ATTENTION: This functions must be called before any spatio-temporal processing
                    can be started
-        @param raise_fatal_error Set this True to assure that the init() function
+        @param raise_fatal_error Set this True to assure that the init() function
                                  does not kill a persistent process like the GUI.
-                                 If set True a grass.pygrass.messages.FatalError
-                                 exception will be raised in case a fatal error occurs
+                                 If set True a grass.pygrass.messages.FatalError
+                                 exception will be raised in case a fatal error occurs
                                  in the init process, otherwise sys.exit(1) will be called.
     # We need to set the correct database backend and several global variables
@@ -452,7 +452,7 @@
     global current_mapset
     global current_gisdbase
     raise_on_error = raise_fatal_error
     # We must run t.connect at first to create the temporal database and to
@@ -470,11 +470,11 @@
     if os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "True" or os.getenv("GRASS_TGIS_RAISE_ON_ERROR") == "1":
         raise_on_error = True
-    # Check if the script library raises on error,
+    # Check if the script library raises on error,
     # if so we do the same
     if core.get_raise_on_error() is True:
     # Start the GRASS message interface server
     _init_tgis_message_interface(raise_on_error)
     # Start the C-library interface server
@@ -561,6 +561,17 @@
         if dbif.cursor.fetchone()[0]:
             db_exists = True
+    backup_howto = "Your temporal database format is not supported any more. "\
+                   "Unfortunately you have to restore your previous grass version "\
+                   "to make a backup of your existing temporal database and to avoid the loss of your temporal data. "\
+                   "You can use t.rast.export and t.vect.export to make a backup of your existing space time datasets. "\
+                   "Use t.rast.list, t.vect.list and t.rast3d.list to safe the time "\
+                   "stamps of your existing maps and space time datasets. "\
+                   "You can register the exitsing time stamped maps easily if you write columns=id,start_time,end_time "\
+                   "into text files and use t.register to register them again in new created space time datasets (t.create). "\
+                   "After the backup remove the existing temporal database, a new one will be created automatically. "
     if db_exists == True:
         # Check the version of the temporal database
         dbif.close()
@@ -569,22 +580,18 @@
         dbif.close()
         if metadata is None:
             msgr.fatal(_("Unable to receiving temporal database metadata.\n"
-                         "Your temporal database is not supported.\n"
-                         "Please remove your temporal database. A new one will be cerated automatically.\n"
                          "Current temporal database info:%(info)s")%({"info":get_database_info_string()}))
         for entry in metadata:
             if "tgis_version" in entry and entry[1] != str(get_tgis_version()):
-                msgr.fatal(_("Unsupported temporal database. Version mismatch.\n"
+                msgr.fatal(_("Unsupported temporal database. Version mismatch.\n %(backup)s"
                              "Supported temporal API version is: %(api)i.\n"
                              "Please update your GRASS installation to the latest svn version.\n"
-                             "Current temporal database info:%(info)s")%({"api":get_tgis_version(),
+                             "Current temporal database info:%(info)s")%({"backup":backup_howto, "api":get_tgis_version(),
             if "tgis_db_version" in entry and entry[1] != str(get_tgis_db_version()):
                              "Supported temporal database version is: %(tdb)i\n"
-                             "Please remove your old temporal database. \n"
-                             "A new one will be created automatically.\n"
-                             "Current temporal database info:%(info)s")%({"tdb":get_tgis_version(),
+                             "Current temporal database info:%(info)s")%({"backup":backup_howto,"tdb":get_tgis_version(),
         return
@@ -594,7 +601,7 @@
 def get_database_info_string():
     dbif = SQLDatabaseInterfaceConnection()
     info  = "\nDBMI interface:..... " + str(dbif.dbmi.__name__)
     info += "\nTemporal database:.. " + str( get_tgis_database_string())
     return info
@@ -794,7 +801,7 @@
            Supported backends are sqlite3 and postgresql
         if self.dbmi.__name__ == "sqlite3":
             self.connection = self.dbmi.connect(tgis_database_string,
                     detect_types = self.dbmi.PARSE_DECLTYPES | self.dbmi.PARSE_COLNAMES)
@@ -964,7 +971,7 @@
     """!This method checks if the database interface connection exists,
         if not a new one will be created, connected and True will be returned.
         If the database interface exists but is connected, the connection will be established.
         @return the tuple (dbif, True|False)
         Usage code sample:
