[GRASS-SVN] r58955 - grass/branches/develbranch_6/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Sat Feb 8 16:55:09 PST 2014
Author: hamish
Date: 2014-02-08 16:55:09 -0800 (Sat, 08 Feb 2014)
New Revision: 58955
grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
grass/branches/develbranch_6/raster/r.li/r.li.daemon/ipc.c
grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
trivial whitespace
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-08 10:54:38 UTC (rev 58954)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-09 00:55:09 UTC (rev 58955)
@@ -205,6 +205,7 @@
while (j < num_workers && donePid != child[j].pid)
j++;
send(child[j].channel, &m);
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/ipc.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/ipc.c 2014-02-08 10:54:38 UTC (rev 58954)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/ipc.c 2014-02-09 00:55:09 UTC (rev 58955)
@@ -23,19 +23,20 @@
#include "ipc.h"
-int send(int pipe, msg * m)
+int send(int pipe, msg *m)
int check;
/* write on pipe */
check = write(pipe, m, sizeof(msg));
if (check > 0)
return 1;
else
return 0;
-int receive(int pipe, msg * m)
+int receive(int pipe, msg *m)
return read(pipe, m, sizeof(msg));
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c 2014-02-08 10:54:38 UTC (rev 58954)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c 2014-02-09 00:55:09 UTC (rev 58955)
@@ -69,6 +69,7 @@
/* read data type to allocate cache */
data_type = G_raster_map_type(raster, mapset);
/* calculate rows in cache */
switch (data_type) {
case CELL_TYPE:{
