[GRASS-SVN] r58958 - in grass/trunk/raster/r.li: . r.li.patchdensity r.li.pielou r.li.shape
Sat Feb 8 17:55:27 PST 2014
Author: hamish
Date: 2014-02-08 17:55:26 -0800 (Sat, 08 Feb 2014)
New Revision: 58958
   grass/trunk/raster/r.li/TODO
   grass/trunk/raster/r.li/r.li.patchdensity/main.c
   grass/trunk/raster/r.li/r.li.pielou/pielou.c
   grass/trunk/raster/r.li/r.li.shape/main.c
minor comment cosmetics sync with devbr6
Modified: grass/trunk/raster/r.li/TODO
--- grass/trunk/raster/r.li/TODO	2014-02-09 01:47:52 UTC (rev 58957)
+++ grass/trunk/raster/r.li/TODO	2014-02-09 01:55:26 UTC (rev 58958)
@@ -17,7 +17,7 @@
 A few remaining things should be done soon:
 - add relevant references
-- use english variable names in C code
+- use English variable names in C code
 Please change the examples to Spearfish wherever possible:
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c	2014-02-09 01:47:52 UTC (rev 58957)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c	2014-02-09 01:55:26 UTC (rev 58958)
@@ -47,7 +47,7 @@
     output = G_define_standard_option(G_OPT_R_OUTPUT);
-	/**add other options for index parameters here */
+	/** add other options for index parameters here */
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
Modified: grass/trunk/raster/r.li/r.li.pielou/pielou.c
--- grass/trunk/raster/r.li/r.li.pielou/pielou.c	2014-02-09 01:47:52 UTC (rev 58957)
+++ grass/trunk/raster/r.li/r.li.pielou/pielou.c	2014-02-09 01:55:26 UTC (rev 58958)
@@ -146,7 +146,7 @@
     double t;
     double logaritmo;
-    /*add to compute the number of class */
+    /* add to compute the number of class */
     long *array_copy;
     int totNumClass = 1;
     double logTotNumClass;
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c	2014-02-09 01:47:52 UTC (rev 58957)
+++ grass/trunk/raster/r.li/r.li.shape/main.c	2014-02-09 01:55:26 UTC (rev 58958)
@@ -88,6 +88,7 @@
+	/* todo? free(mask_buf); */
     /* calculate distance */
