[GRASS-SVN] r58964 - grass/trunk/raster/r.li/r.li.setup
Sat Feb 8 22:05:24 PST 2014
Author: hamish
Date: 2014-02-08 22:05:24 -0800 (Sat, 08 Feb 2014)
New Revision: 58964
   grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
   grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
   grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
sync old r.li.setup scripts with devbr6 (up to r58914)
Modified: grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-02-09 05:57:12 UTC (rev 58963)
+++ grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-02-09 06:05:24 UTC (rev 58964)
@@ -9,25 +9,33 @@
 #%option
 #% key: raster
 #% type: string
+#% gisprompt: old,cell,raster
+#% key_desc: name
 #% description: Raster map to to analyse
 #% required: yes
 #%end
 #%option
 #% key: vector
 #% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
 #% description: Vector map to overlay
 #% required: no
 #%end
 #%option
 #% key: site
 #% type: string
+#% key_desc: name
 #% description: Vector points map to overlay
 #% required: no
 #%end
 #%option
 #% key: config
 #% type: string
-#% description: Name of configuration file where insert areas
+#% gisprompt: new_file,file,output
+#% key_desc: filename
+#% description: Name of configuration file where areas are to be saved
 #% required: yes
 #%end
 #%option
@@ -90,27 +98,53 @@
     exit 1
 fi
+cleanup()
+   # remove temporary region
+   eval `g.findfile elem=windows file="tmp_rli_selmsk.$$" | grep '^name='`
+   if [ -n "$name" ] ; then
+      g.region region="tmp_rli_selmsk.$$"
+      g.remove region="tmp_rli_selmsk.$$" --quiet
+   fi
-# FIXME: use WIND_OVERRIDE
+   rm -f "$TMP" "$TMP".val
+trap "cleanup" 2 3 15
-# show the sampling frame
+# setup internal region
+#  (WIND_OVERRIDE is already present by the main r.li.setup script)
+g.region save="tmp_rli_selmsk.$$"
+# ?show the sampling frame
 if [ "$GIS_FLAG_f" -eq 1 ] ; then
-    g.region n="$GIS_OPT_north" s="$GIS_OPT_south" e="$GIS_OPT_east" w="$GIS_OPT_west"
+    g.region n="$GIS_OPT_north" s="$GIS_OPT_south" \
+	     e="$GIS_OPT_east" w="$GIS_OPT_west"
 else
     g.region rast="$GIS_OPT_raster"
 fi
-# open x1 Xmonitor
-d.mon stop=x1
-d.mon start=x1
+# find a free Xmonitor
+XMON=x1
+for i in 1 2 3 4 5 6 7 ; do
+   result=`d.mon -L | grep -w "^x$i"`
+   if [ `echo "$result" | grep -c 'not'` -eq 1 ] ; then
+      XMON="x$i"
+      break
+   fi
+done
+# open the Xmonitor
+d.mon stop="$XMON"
+d.mon start="$XMON"
 d.rast -o map="$GIS_OPT_raster"
 if [ -n "$GIS_OPT_vector" ] ; then
     d.vect map="$GIS_OPT_vector"
 fi
 if [ -n "$GIS_OPT_site" ] ; then
-    d.vect map="$GIS_OPT_site"
+    d.vect map="$GIS_OPT_site" color=red fcolor=red size=5 icon=basic/circle
 fi
 # setup for drawing area
@@ -127,56 +161,49 @@
 # show the selected area
 d.rast -o map="tmp_rli_mask.$$"
-name=$$.val
+name="$TMP.val"
 export name
+# ask if it's ok, save 0,1 to "$name" temp file
 "$GRASS_WISH" "$f_path/area_query"
-    cat $name | cut -f1 -d ' ' > $name.var
-    read ok < $name.var
-    cat $name | cut -f2 -d' ' > $name.var
-    r_name=""
-    read r_name < $name.var
-    if [ $ok -eq 1 ] ; then
-	r.to.vect input="$$" output="v$$" feature=area
-	g.region vect="v$$"
-	v.to.rast input="v$$" output=$r_name value=1 use=val
-	#write info in configuration file
-	g.region -g| grep "n=" | cut -f2 -d'='> $name.var
-	read north < $name.var
-	g.region -g| grep "s=" | cut -f2 -d'='  > $name.var
-	read south < $name.var
-	g.region -g| grep "e=" | cut -f2 -d'=' > $name.var
-	read east < $name.var
-	g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
-	read west < $name.var
-	echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >>\
-	    $GIS_OPT_conf
-	#remove tmp raster and vector
-	g.remove rast=$$
-	g.remove vect=v$$
-        #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cats/"$$"
-	#rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell/"$$"
-	#rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cellhd/"$$"
-	#rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell_misc/"$$"
-	#rm -f  "$GISDBASE"/"$LOCATION"/"$MAPSET"/colr/"$$"
-	#rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/hist/"$$"
-	#rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/"v$$"
-	echo DROP TABLE "v$$" | db.execute
-	if [ $GIS_FLAG_f -eq 1 ] ; then
-	    g.region n=$GIS_OPT_north s=$GIS_OPT_south e=$GIS_OPT_east w=$GIS_OPT_west
-	else
-	    g.region rast=$GIS_OPT_raster
-	fi
+ok=`cat "$name" | cut -f1 -d ' '`
+r_name=`cat "$name" | cut -f2 -d' '`
+if [ "$ok" -eq 1 ] ; then
+    # r.mask + 'g.region zoom= align=' + 'r.mapcalc cropmap=map' would be cleaner?
+    r.to.vect input="tmp_rli_mask.$$" output="tmp_rli_mask_v$$" feature=area
+    g.region vect="tmp_rli_mask_v$$"
+    v.to.rast input="tmp_rli_mask_v$$" output="$r_name" value=1 use=val
+    # write info in configuration file
+    eval `g.region -g`
+    north="$n"
+    south="$s"
+    east="$e"
+    west="$w"
+    echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >> \
+	    "$GIS_OPT_conf"
+    # remove tmp raster and vector
+    g.remove rast="tmp_rli_mask.$$" --quiet
+    g.remove vect="tmp_rli_mask_v$$" --quiet
+    if [ "$GIS_FLAG_f" -eq 1 ] ; then
     else
-	echo 0 >> $GIS_OPT_conf
+    	g.region rast="$GIS_OPT_raster"
     fi
-d.mon stop=x1
+else
+    echo 0 >> "$GIS_OPT_conf"
+fi
+d.mon stop="$XMON"
 # clean tmp files
-#FIXME: use g.tempfile
-rm -f "$$"*
-rm -f "$TMP"*
+cleanup
Modified: grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-09 05:57:12 UTC (rev 58963)
+++ grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-09 06:05:24 UTC (rev 58964)
@@ -1,4 +1,4 @@
-#!/bin/sh -x
+#!/bin/sh
 # This program is free software under the GPL (>=v2)
 # Read the COPYING file that comes with GRASS for details.
@@ -24,7 +24,7 @@
 #% required: yes
 #%end
 #%option
-#% key: config
+#% key: conf
 #% type: string
 #% key_desc: name
@@ -43,12 +43,6 @@
    exec g.parser "$0" "$@"
 fi
-#### set temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-   echo "ERROR: unable to create temporary files" 1>&2
-   exit 1
-fi
 #### environment variables
 GISDBASE=`g.gisenv get=GISDBASE`
@@ -56,29 +50,34 @@
 MAPSET=`g.gisenv get=MAPSET`
 : ${GISDBASE?} ${LOCATION?} ${MAPSET?}
-f_path="$GISBASE/etc/r.li.setup"
-# read categories from input vector, extract,
-# convert to raster and save the bounds to configuration file
+#### set temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+   echo "ERROR: unable to create temporary files" 1>&2
+   exit 1
+fi
-# using v.category instead of v.build with cdump
-v.category input=$GIS_OPT_vector option=print | sort | uniq > "$TMP.cat"
-# get input vector name
-GIS_OPT_input_vector=`echo $GIS_OPT_vector| cut -d'@' -f 1`
+cleanup()
+   eval `g.findfile elem=windows file="tmp_rli_sampvect.$$" | grep '^name='`
+      g.region region="tmp_rli_sampvect.$$"
+      g.remove region="tmp_rli_sampvect.$$" --quiet
+   fi
-# get input vector mapset
-GIS_OPT_input_mapset=`echo $GIS_OPT_vector| cut -d'@' -f 2`
+   rm -f "$TMP"*
-# read input vector categories into CAT_LIST array
-IFS=$'\r\n' CAT_LIST=($(cat $TMP.cat))
-# save the current region settings temporarily to avoid surpirses later.
-TMP_REGION="tmp_rlisetup.sampvect.$$"
-g.region save="$TMP_REGION"
+g.region save="tmp_rli_sampvect.$$"
 XMON=x1
@@ -89,48 +88,66 @@
    fi
 done
+# open Xmonitor
+d.mon stop="$XMON"
-# process each feature in the vector having category values in the CAT_LIST array
-for CAT in "${CAT_LIST[@]}"
-do
-    # vector to store a feature fro $GIS_OPT_vector with category value $CAT.
-    # This temporary vector will be removed at the end.
-    EXTRACT=$GIS_OPT_input_vector"_"$CAT"_part@"$GIS_OPT_input_mapset
-    # extract only a part of $GIS_OPT_vector where category = $CAT and store in $EXTRACT
-    v.extract input=$GIS_OPT_vector output=$EXTRACT \
-       type=point,line,boundary,centroid,area,face \
-       new=-1 -d where='CAT='$CAT
+f_path="$GISBASE/etc/r.li.setup"
-    # open Xmonitor
-    d.mon stop="$XMON"
-    d.mon start="$XMON"
+# read categories from input vector, extract,
+# convert to raster and save the bounds to configuration file
+# using v.category instead of v.build with cdump
+v.category input="$GIS_OPT_vector" option=print | \
+  sort -n | uniq > "$TMP.cat"
+# crop away @mapset part, if present
+input_vector=`echo "$GIS_OPT_vector" | cut -d'@' -f 1`
+# process each feature in the vector that has a cat
+while read CAT ; do
+   # skip blank lines..
+    if [ -z "$CAT" ] ; then
+       continue
+    fi
+    # Temporary vector map to store an individual feature from the input vector
+    #  It will be removed at the end of the iteration.
+    EXTRACT="tmp_$$_${input_vector}_${CAT}"
+    v.extract input="$GIS_OPT_vector" output="$EXTRACT" \
+       type=point,line,centroid,area \
+       new=-1 -d list="$CAT"  # where="CAT = $CAT"
     # set region with raster resolution
     g.region vect="$EXTRACT" align="$GIS_OPT_raster"
+    d.erase
     d.rast -o "$GIS_OPT_raster"
-    # render extracted vector map
+    # render extracted vector map  (prehaps fcolor=none for areas?)
     d.vect "$EXTRACT"
     # ask the user to analyse this vector and a name for raster in a Tcl GUI
     name="$TMP.val" # where find the answer
     export name
+    # ask if it's ok, save 0,1 to "$name" temp file
-    #cat "$name" | cut -f1 -d ' ' > "$name.var"
-    #read ok < "$name.var"
-    #cat "$name" | cut -f2 -d' ' > "$name.var"
-    #r_name=""
-    #read r_name < "$name.var"
+    # debug or needed?
     echo "$r_name"
 	#area selected, create mask
-	v.to.rast input="$EXTRACT" output="$r_name" use=cat value=1 rows=4096
+	v.to.rast input="$EXTRACT" output="$r_name" use=cat
 	# save the region settings into the configuration file
 	eval `g.region -g`
@@ -138,17 +155,13 @@
     fi
     #remove temporary vector map created from v.extract
-    g.remove vect="$EXTRACT"
-    #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/$GIS_OPT_vector"part"$I
-    #echo DROP TABLE $GIS_OPT_vector"part"$I | db.execute
-done
+    g.remove vect="$EXTRACT" --quiet
+done < "$TMP.cat"
 d.mon stop="$XMON"
-# restore the region (which itself is a WIND_OVERRIDE temporary region by
-#  the r.li.setup main script)
-g.region region="$TMP_REGION"
-g.remove region="$TMP_REGION"
-# clean tmp files
-rm -f "$TMP"*
+# clean tmp files and restore region
+cleanup
Modified: grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-02-09 05:57:12 UTC (rev 58963)
+++ grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-02-09 06:05:24 UTC (rev 58964)
@@ -69,7 +69,7 @@
 # Check if we are in a GRASS session
 if test "$GISBASE" = ""; then
-   echo "You must be in GRASS GIS to run this program." >&2
+   echo "You must be in GRASS GIS to run this program." 1>&2
    exit 1
  fi
@@ -77,14 +77,6 @@
 fi
-# open x1 Xmonitor
-d.mon stop=x1
-d.mon start=x1
-g.region rast=$GIS_OPT_raster
 #### create temporary file
@@ -92,21 +84,51 @@
     exit 1
 fi
-#saving starting values
-g.region -g | grep "n=" | cut -f2 -d'=' > $TMP.var
-read s_n < $TMP.var
-g.region -g | grep "s=" | cut -f2 -d'=' > $TMP.var
-read s_s < $TMP.var
-g.region -g | grep "e=" | cut -f2 -d'=' > $TMP.var
-read s_e < $TMP.var
-g.region -g | grep "w=" | cut -f2 -d'=' > $TMP.var
-read s_w < $TMP.var
-g.region -g | grep "nsres=" | cut -f2 -d'=' > $TMP.var
-read s_nsres < $TMP.var
-g.region -g | grep "ewres=" | cut -f2 -d'=' > $TMP.var
-read s_ewres < $TMP.var
-echo "START $s_n|$s_s|$s_e|$s_w|$s_nsres|$s_ewres" >> $GIS_OPT_conf
+cleanup()
+   eval `g.findfile elem=windows file="tmp_rli_sq.$$" | grep '^name='`
+      g.region region="tmp_rli_sq.$$"
+      g.remove region="tmp_rli_sq.$$" --quiet
+   fi
+   rm -f "$TMP" "$TMP.var"
+XMON=x1
+      XMON="x$i"
+      break
+   fi
+done
+d.mon stop="$XMON"
+g.region save="tmp_rli_sq.$$"
+g.region rast="$GIS_OPT_raster"
+# store starting values
+eval `g.region -g`
+s_n="$n"
+s_s="$s"
+s_e="$e"
+s_w="$w"
+s_nsres="$nsres"
+s_ewres="$ewres"
+echo "START $s_n|$s_s|$s_e|$s_w|$s_nsres|$s_ewres" >> "$GIS_OPT_conf"
@@ -122,41 +144,42 @@
 fi
-# let draw area
+# have the user selected the area of interest with the mouse
+# TODO: popup message? (d.menu: "Draw box now: [ok]")
+#d.menu bcolor=aqua tcolor=black << EOF
+#.T 20
+#.L 20
+#Next select area with mouse
+#          [ Ok ]
+#EOF
 d.zoom
 # ask if the selected area is right
-name="$TMP"  # file where write the answer
+name="$TMP.var"  # temp file where the answer is written to by the tcl pop-up
 export name
+# ask if it's ok, save 0,1 to the "$name" tmp file
 "$GRASS_WISH" "$f_path/square_query"
 read ok < "$TMP.var"
 if [ "$ok" -eq 0 ] ; then
     echo "NO" >> "$GIS_OPT_conf"
+elif [ "$ok" -eq 1 ] ; then
+    # write the square boundaries
+    echo "SQUAREAREA $n|$s|$e|$w|$nsres|$ewres" >> "$GIS_OPT_conf"
+else
+    g.message -e "Unable to ascertain if the selected area was ok or not"
 fi
-if [ $ok -eq 1 ] ; then
-    #write the square boundaries
-    g.region -g | grep "n=" | cut -f2 -d'=' > $TMP.var
-    read n < $TMP.var
-    g.region -g | grep "s=" | cut -f2 -d'=' > $TMP.var
-    read s < $TMP.var
-    g.region -g | grep "e=" | cut -f2 -d'=' > $TMP.var
-    read e < $TMP.var
-    g.region -g | grep "w=" | cut -f2 -d'=' > $TMP.var
-    read w < $TMP.var
-    g.region -g | grep "nsres=" | cut -f2 -d'=' > $TMP.var
-    read nsres < $TMP.var
-    g.region -g | grep "ewres=" | cut -f2 -d'=' > $TMP.var
-    read ewres < $TMP.var
-    echo "SQUAREAREA $n|$s|$e|$w|$nsres|$ewres" >> $GIS_OPT_conf
-fi
 # close the Xmonitor
-d.mon stop=x1
+d.mon stop="$XMON"
-# clean tmp files
-rm -f $TMP*
+# clean tmp files and temporary region
+cleanup
