[GRASS-SVN] r58994 - grass/branches/develbranch_6/raster/r.li/r.li.dominance
Tue Feb 11 06:04:11 PST 2014
Author: neteler
Date: 2014-02-11 06:04:10 -0800 (Tue, 11 Feb 2014)
New Revision: 58994
   grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c
r.li.dominance: code style updated to that of r.li.simpson
Modified: grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c
--- grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c	2014-02-11 14:04:03 UTC (rev 58993)
+++ grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c	2014-02-11 14:04:10 UTC (rev 58994)
@@ -6,7 +6,7 @@
  *   This program is free software under the GPL (>=v2)
  *   Read the COPYING file that comes with GRASS for details.
 #include <grass/gis.h>
@@ -44,8 +44,8 @@
     conf = G_define_option();
     conf->key = "conf";
     conf->description = _("Configuration file");
-    conf->gisprompt = "old_file,file,input";
     conf->type = TYPE_STRING;
+    conf->gisprompt = "old_file,file,input";
     conf->required = YES;
     output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -61,35 +61,29 @@
 int dominance(int fd, char **par, struct area_entry *ad, double *result)
     char *mapset;
     int ris = RLI_OK;
     double indice = 0;
     struct Cell_head hd;
     mapset = G_find_cell(ad->raster, "");
     if (G_get_cellhd(ad->raster, mapset, &hd) == -1)
 	return RLI_ERRORE;
     switch (ad->data_type) {
     case CELL_TYPE:
-	    calculate(fd, ad, &indice);
+	    ris = calculate(fd, ad, &indice);
 	    break;
     case DCELL_TYPE:
-	    calculateD(fd, ad, &indice);
+	    ris = calculateD(fd, ad, &indice);
 	    break;
     case FCELL_TYPE:
-	    calculateF(fd, ad, &indice);
+	    ris = calculateF(fd, ad, &indice);
 	    break;
     default:
@@ -97,12 +91,12 @@
 	    G_fatal_error("data type unknown");
 	    return RLI_ERRORE;
-    if (ris != RLI_OK) {
-	return RLI_ERRORE;
+    if (ris != RLI_OK)
+	   return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
@@ -135,12 +129,10 @@
     double t;
     double logaritmo;
-    generic_cell cc;
     avl_tree albero = NULL;
     AVL_table *array;
+    generic_cell cc;
     cc.t = CELL_TYPE;
@@ -156,15 +148,9 @@
 	masked = TRUE;
     G_set_c_null_value(&precCell, 1);
-    /*for each row */
-    for (j = 0; j < ad->rl; j++) {
-	buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
+    for (j = 0; j < ad->rl; j++) {	/* for each row */
 	if (masked) {
 	    if (read(mask_fd, mask_buf, (ad->cl * sizeof(int))) < 0) {
 		G_fatal_error("mask read failed");
@@ -172,12 +158,12 @@
+	buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
 	for (i = 0; i < ad->cl; i++) {	/* for each cell in the row */
 	    area++;
 	    corrCell = buf[i + ad->x];
-	    if (masked && mask_buf[i + ad->x] == 0) {
+	    if ((masked) && (mask_buf[i + ad->x] == 0)) {
 		G_set_c_null_value(&corrCell, 1);
 		area--;
@@ -187,7 +173,6 @@
 		if (G_is_null_value(&precCell, cc.t)) {
 		    precCell = corrCell;
 		if (corrCell != precCell) {
 		    if (albero == NULL) {
 			cc.val.c = precCell;
@@ -197,6 +182,7 @@
 			    G_fatal_error("avl_make error");
 			    return RLI_ERRORE;
+			/* TODO missing?: else  - see r.li.simpson/simpson.c */
 			m++;
 		    else {
@@ -235,10 +221,8 @@
 	}			/* end for */
     }				/* end for */
+    /*last closing */
     if (a != 0) {
-	/*last closing */
 	    albero = avl_make(cc, totCorr);
@@ -306,25 +290,18 @@
     else			/*if a is 0, that is all cell are null, i put index=-1 */
 	indice = (double)(-1);
-    *result = indice;
-    if (masked) {
+    if (masked)
 	G_free(mask_buf);
+    *result = indice;
     return RLI_OK;
 int calculateD(int fd, struct area_entry *ad, double *result)
     DCELL *buf;
     DCELL corrCell;
     DCELL precCell;
@@ -367,14 +344,9 @@
 	masked = TRUE;
     G_set_d_null_value(&precCell, 1);
-    /*for each row */
-	buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
 	if (masked) {
@@ -382,6 +354,7 @@
+	buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
 	for (i = 0; i < ad->cl; i++) {	/* for each dcell in the row */
 	    area++;
@@ -447,9 +420,8 @@
 	G_free(mask_buf);
-    if (a != 0) {
 	/*last closing */
+    if (a != 0) {
 	    cc.val.dc = precCell;
@@ -528,7 +500,6 @@
 int calculateF(int fd, struct area_entry *ad, double *result)
     FCELL *buf;
     FCELL corrCell;
     FCELL precCell;
@@ -571,15 +542,10 @@
 	masked = TRUE;
     G_set_f_null_value(&precCell, 1);
-    /*for each row */
-	buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
 	if (masked) {
@@ -587,10 +553,13 @@
+	buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
 	for (i = 0; i < ad->cl; i++) {	/* for each fcell in the row */
 	    area++;
 		G_set_f_null_value(&corrCell, 1);
 		area--;
@@ -648,7 +617,6 @@
     /*last closing */
     if (a != 0) {
@@ -715,18 +683,15 @@
 	G_free(array);
-	indice = (double)(-1);
+	  indice = (double)(-1);
-    *result = indice;
     if (masked) {
 	G_free(mask_buf);
+    *result = indice;
     return RLI_OK;
