[GRASS-SVN] r59051 - grass/trunk/raster/r.li/r.li.padsd
Fri Feb 14 07:07:22 PST 2014
Author: mmetz
Date: 2014-02-14 07:07:22 -0800 (Fri, 14 Feb 2014)
New Revision: 59051
   grass/trunk/raster/r.li/r.li.padsd/padsd.c
r.li.padsd: fix segfault
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c	2014-02-14 15:06:54 UTC (rev 59050)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c	2014-02-14 15:07:22 UTC (rev 59051)
@@ -22,9 +22,11 @@
 #include "../r.li.daemon/avlID.h"
 #include "../r.li.daemon/GenericCell.h"
 #include "../r.li.daemon/daemon.h"
 int calculate(int fd, struct area_entry *ad, double *result);
 int calculateD(int fd, struct area_entry *ad, double *result);
 int calculateF(int fd, struct area_entry *ad, double *result);
 int main(int argc, char *argv[])
     struct Option *raster, *conf, *output;
@@ -57,32 +59,25 @@
 int patchAreaDistributionSD(int fd, char **par, struct area_entry *ad, double *result)
     double indice = 0;
-    struct Cell_head hd;
     int ris = RLI_OK;
-    Rast_get_cellhd(ad->raster, "", &hd);
     switch (ad->data_type) {
     case CELL_TYPE:
 	    ris = calculate(fd, ad, &indice);
 	    break;
     case DCELL_TYPE:
 	    ris = calculateD(fd, ad, &indice);
 	    break;
     case FCELL_TYPE:
 	    ris = calculateF(fd, ad, &indice);
 	    break;
     default:
 	    G_fatal_error("data type unknown");
 	    return RLI_ERRORE;
@@ -92,19 +87,20 @@
 	*result = -1;
 	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
-    CELL *buf;
-    CELL *buf_sup;
+    CELL *buf, *buf_sup, *buf_null;
     CELL corrCell;
     CELL precCell;
     CELL supCell;
     int i, j;
-    int mask_fd = -1, *mask_buf;
+    int mask_fd = -1, *mask_buf = NULL;
     int ris = 0;
     int masked = FALSE;
     int areaPatch = 0;		/*if all cells are null areaPatch=0 */
@@ -118,6 +114,7 @@
     long doppi = 0;
     long *mask_patch_sup;
     long *mask_patch_corr;
+    long *ltmp;
     double indice = 0;
     double somma = 0;
     double area = 0;
@@ -150,25 +147,25 @@
 	G_fatal_error("malloc mask_patch_corr failed");
 	return RLI_ERRORE;
-    buf_sup = Rast_allocate_c_buf();
-    if (buf_sup == NULL) {
-	G_fatal_error("malloc buf_sup failed");
+    buf_null = Rast_allocate_c_buf();
+    if (buf_null == NULL) {
+	G_fatal_error("malloc buf_null failed");
 	return RLI_ERRORE;
-    buf = Rast_allocate_c_buf();
-    if (buf == NULL) {
-	G_fatal_error("malloc buf failed");
-	return RLI_ERRORE;
-    Rast_set_c_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    /*the first time buf_sup is all null */
+    Rast_set_c_null_value(buf_null, Rast_window_cols());
+    buf_sup = buf_null;
+    buf = buf_null;
     for (i = 0; i < ad->cl; i++) {
 	mask_patch_sup[i] = 0;
 	mask_patch_corr[i] = 0;
-    for (j = 0; j < ad->rl; j++)
-	/*for each raster row */
+    /*for each raster row */
+    for (j = 0; j < ad->rl; j++) {
 	if (j > 0) {
 	    buf_sup = RLI_get_cell_raster_row(fd, j - 1 + ad->y, ad);
@@ -180,9 +177,8 @@
 	Rast_set_c_null_value(&precCell, 1);
-	for (i = 0; i < ad->cl; i++)
-	    /* for each cell in the row */
+	/* for each cell in the row */
+	for (i = 0; i < ad->cl; i++) {
 	    area++;
 	    corrCell = buf[i + ad->x];
 	    if (masked && mask_buf[i + ad->x] == 0) {
@@ -191,38 +187,28 @@
 	    if (!(Rast_is_null_value(&corrCell, gc.t))) {
 		areaPatch++;
-		if (i > 0)
-		    precCell = buf[i - 1 + ad->x];
-		if (j == 0)
-		    Rast_set_c_null_value(&supCell, 1);
-		else
-		    supCell = buf_sup[i + ad->x];
+		supCell = buf_sup[i + ad->x];
-		if (corrCell != precCell)
+		if (corrCell != precCell) {
 		     *      1 2
 		    if (corrCell != supCell) {
 			/*        3
 			 *      1 2
 			/*new patch */
-			if (idCorr == 0)
+			if (idCorr == 0) {
 			    /*first found patch */
 			    lastId = 1;
 			    idCorr = 1;
 			    totCorr = 1;
 			    mask_patch_corr[i] = idCorr;
-			else
+			else {
 			    /*not first patch */
 			    /* put in the tree the previous value */
 			    if (albero == NULL) {
 				albero = avlID_make(idCorr, totCorr);
@@ -231,31 +217,25 @@
 				npatch++;
-			    else
+			    else {
 				/*tree not empty */
 				ris = avlID_add(&albero, idCorr, totCorr);
 				switch (ris) {
 				case AVL_ERR:
 					G_fatal_error("avlID_add error");
 					return RLI_ERRORE;
 				case AVL_ADD:
 					npatch++;
 					break;
 				case AVL_PRES:
 					break;
 				default:
 					G_fatal_error
 					    ("avlID_add unknown error");
@@ -269,12 +249,10 @@
-		    else
+		    else {
 			/*        2
 			 *      1 2
@@ -284,7 +262,6 @@
 			    npatch++;
 			else {	/*tree not null */
 			    switch (ris) {
 			    case AVL_ERR:
@@ -318,7 +295,6 @@
 		     *      1 1
 		    if (corrCell == supCell) {	/*current cell and upper cell are equal */
 			/*        1
 			 *      1 1
@@ -327,7 +303,6 @@
 			    long r = 0;
 			    long del = mask_patch_sup[i];
 			    r = avlID_sub(&albero, del);	/*r=number of cell of patch removed */
 			    if (r == 0) {
@@ -387,25 +362,14 @@
 	    else {		/*cell is null or is not to consider */
+	    precCell = corrCell;
-	    int ii;
-	    long c;
-	    for (ii = 0; ii < ad->cl; ii++) {
-		c = mask_patch_corr[ii];
-		mask_patch_sup[ii] = c;
-		mask_patch_corr[ii] = 0;
+	ltmp = mask_patch_sup;
+	mask_patch_sup = mask_patch_corr;
+	mask_patch_corr = ltmp;
     if (areaPatch != 0) {
@@ -415,29 +379,24 @@
 	    npatch++;
 	else {
 	    switch (ris) {
 	    case AVL_ERR:
 		    return RLI_ERRORE;
 	    case AVL_ADD:
 		    npatch++;
 		    break;
 	    case AVL_PRES:
 		    break;
 	    default:
 		    G_fatal_error("avlID_add unknown error");
 		    return RLI_ERRORE;
@@ -480,30 +439,32 @@
 	indice = sd;
 	G_free(array);
     else
 	indice = (double)(-1);
-    if (masked)
+    if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     G_free(mask_patch_sup);
+    G_free(mask_patch_corr);
+    G_free(buf_null);
+    avlID_destroy(albero);
     *result = indice;
-    G_free(buf_sup);
-    G_free(buf);
     return RLI_OK;
-    DCELL *buf;
-    DCELL *buf_sup;
+    DCELL *buf, *buf_sup, *buf_null;
     DCELL corrCell;
     DCELL precCell;
     DCELL supCell;
     int i, j;
     int ris = 0;
     int masked = FALSE;
@@ -517,6 +478,7 @@
     long doppi = 0;
+    long *ltmp;
     double indice = 0;
     double somma = 0;
     double area = 0;
@@ -549,25 +511,25 @@
 	return RLI_ERRORE;
-    buf_sup = Rast_allocate_d_buf();
+    buf_null = Rast_allocate_d_buf();
 	return RLI_ERRORE;
-    buf = Rast_allocate_d_buf();
-    Rast_set_d_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    Rast_set_d_null_value(buf_null, Rast_window_cols());
+    buf = buf_null;
 	if (j > 0) {
 	    buf_sup = RLI_get_dcell_raster_row(fd, j - 1 + ad->y, ad);
@@ -579,9 +541,8 @@
 	Rast_set_d_null_value(&precCell, 1);
-	    /* for each dcell in the row */
+	/* for each dcell in the row */
 	    area++;
@@ -590,18 +551,13 @@
 		areaPatch++;
-		if (i > 0)
-		if (j == 0)
-		    Rast_set_d_null_value(&supCell, 1);
-		else
 		     *      1 2
 			/*        3
 			 *      1 2
@@ -613,11 +569,9 @@
 			    totCorr = 1;
-			else
+			else {
@@ -626,31 +580,25 @@
 				npatch++;
-			    else
+			    else {
 				/*tree not empty */
 				switch (ris) {
 				case AVL_ERR:
 					return RLI_ERRORE;
 				case AVL_ADD:
 					npatch++;
 					break;
 				case AVL_PRES:
 					break;
 				default:
 					G_fatal_error
@@ -664,13 +612,11 @@
-		    else
+		    else {
 			/*        2
 			 *      1 2
@@ -714,7 +660,6 @@
 		     *      1 1
 			/*        1
 			 *      1 1
@@ -723,7 +668,6 @@
 			    long r = 0;
 			    if (r == 0) {
@@ -783,26 +727,14 @@
-	    int ii;
-	    long c;
@@ -812,29 +744,24 @@
 	    npatch++;
 	else {
 	    switch (ris) {
 	    case AVL_ERR:
 		    return RLI_ERRORE;
 	    case AVL_ADD:
 		    npatch++;
 		    break;
 	    case AVL_PRES:
 		    break;
 	    default:
 		    return RLI_ERRORE;
@@ -877,25 +804,31 @@
 	indice = sd;
 	G_free(array);
     else
-    if (masked)
+    if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
+    G_free(buf_null);
     *result = indice;
     return RLI_OK;
-    FCELL *buf;
-    FCELL *buf_sup;
+    FCELL *buf, *buf_sup, *buf_null;
     FCELL corrCell;
     FCELL precCell;
     FCELL supCell;
     int i, j;
     int ris = 0;
     int masked = FALSE;
@@ -908,6 +841,7 @@
     long doppi = 0;
+    long *ltmp;
     long np = 0;
     double indice = 0;
     double somma = 0;
@@ -941,25 +875,25 @@
 	return RLI_ERRORE;
-    buf_sup = Rast_allocate_f_buf();
+    buf_null = Rast_allocate_f_buf();
 	return RLI_ERRORE;
-    buf = Rast_allocate_f_buf();
-    Rast_set_f_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    Rast_set_f_null_value(buf_null, Rast_window_cols());
+    buf = buf_null;
 	if (j > 0) {
 	    buf_sup = RLI_get_fcell_raster_row(fd, j - 1 + ad->y, ad);
@@ -971,8 +905,8 @@
 	Rast_set_f_null_value(&precCell, 1);
+	/* for each fcell in the row */
-	    /* for each fcell in the row */
 	    area++;
@@ -981,18 +915,13 @@
 		areaPatch++;
-		if (i > 0)
-		if (j == 0)
-		    Rast_set_f_null_value(&supCell, 1);
-		else
 		     *      1 2
 			/*        3
 			 *      1 2
@@ -1004,11 +933,9 @@
 			    totCorr = 1;
-			else
+			else {
@@ -1017,31 +944,25 @@
 				npatch++;
-			    else
+			    else {
 				/*tree not empty */
 				switch (ris) {
 				case AVL_ERR:
 					return RLI_ERRORE;
 				case AVL_ADD:
 					npatch++;
 					break;
 				case AVL_PRES:
 					break;
 				default:
 					G_fatal_error
@@ -1055,13 +976,11 @@
-		    else
+		    else {
 			/*        2
 			 *      1 2
@@ -1105,7 +1024,6 @@
 		     *      1 1
 			/*        1
 			 *      1 1
@@ -1114,7 +1032,6 @@
 			    long r = 0;
 			    if (r == 0) {
@@ -1174,26 +1091,14 @@
-	    int ii;
-	    long c;
@@ -1203,29 +1108,24 @@
 	    npatch++;
 	else {
 	    switch (ris) {
 	    case AVL_ERR:
 		    return RLI_ERRORE;
 	    case AVL_ADD:
 		    npatch++;
 		    break;
 	    case AVL_PRES:
 		    break;
 	    default:
 		    return RLI_ERRORE;
@@ -1268,12 +1168,19 @@
 	indice = sd;
 	G_free(array);
     else
-    if (masked)
+    if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
+    G_free(buf_null);
     *result = indice;
     return RLI_OK;
