[GRASS-SVN] r59094 - in grass/branches/develbranch_6/raster/r.li: . r.li.cwed r.li.daemon r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.shannon r.li.shape r.li.simpson
Tue Feb 18 16:24:09 PST 2014
Author: neteler
Date: 2014-02-18 16:24:09 -0800 (Tue, 18 Feb 2014)
New Revision: 59094
   grass/branches/develbranch_6/raster/r.li/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.cwed/cwed.c
   grass/branches/develbranch_6/raster/r.li/r.li.cwed/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.c
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.h
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/avl.c
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlDefs.h
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlID.c
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
   grass/branches/develbranch_6/raster/r.li/r.li.dominance/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c
   grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/edgedensity.c
   grass/branches/develbranch_6/raster/r.li/r.li.mpa/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.mpa/mpa.c
   grass/branches/develbranch_6/raster/r.li/r.li.mps/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.mps/mps.c
   grass/branches/develbranch_6/raster/r.li/r.li.padcv/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.padcv/padcv.c
   grass/branches/develbranch_6/raster/r.li/r.li.padrange/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.padrange/padrange.c
   grass/branches/develbranch_6/raster/r.li/r.li.padsd/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.padsd/padsd.c
   grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/main.c
   grass/branches/develbranch_6/raster/r.li/r.li.patchnum/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.patchnum/main.c
   grass/branches/develbranch_6/raster/r.li/r.li.pielou/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.pielou/pielou.c
   grass/branches/develbranch_6/raster/r.li/r.li.renyi/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.richness/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.richness/richness.c
   grass/branches/develbranch_6/raster/r.li/r.li.shannon/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.shannon/shannon.c
   grass/branches/develbranch_6/raster/r.li/r.li.shape/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.shape/main.c
   grass/branches/develbranch_6/raster/r.li/r.li.simpson/description.html
   grass/branches/develbranch_6/raster/r.li/r.li.simpson/simpson.c
r.li: trivial backports from trunk
Modified: grass/branches/develbranch_6/raster/r.li/description.html
--- grass/branches/develbranch_6/raster/r.li/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -59,6 +59,7 @@
     using on the areas selected on configuration file.
 </ol>
 <h2>NOTE</h2>
 The <em>r.li.daemon</em> module also has a "main" function front-end
Modified: grass/branches/develbranch_6/raster/r.li/r.li.cwed/cwed.c
--- grass/branches/develbranch_6/raster/r.li/r.li.cwed/cwed.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.cwed/cwed.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -48,20 +48,16 @@
     raster = G_define_standard_option(G_OPT_R_MAP);
-    conf = G_define_option();
+    conf = G_define_standard_option(G_OPT_F_INPUT);
     conf->key = "conf";
     conf->description = _("Configuration file");
-    conf->type = TYPE_STRING;
     conf->required = YES;
-    conf->gisprompt = "old_file,file,input";
-    path = G_define_option();
+    path = G_define_standard_option(G_OPT_F_INPUT);
     path->key = "path";
     path->description =
-	"Input file that contains the weight to calculate the index";
-    path->type = TYPE_STRING;
+        _("Name of file that contains the weight to calculate the index");
     path->required = YES;
-    path->gisprompt = "old_file,file,input";
     output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -84,28 +80,20 @@
 				double *result)
     double indice = 0;		/* the result */
     struct Cell_head hd;
     int i = 0;
     int file_fd = -1;
     int l;			/*number of read byte */
     int ris = 0;
     char *mapset;
     char *file;
     char *strFile;
     char row[NMAX];		/* to read the file */
     char **bufRighe;		/* contains every valid file row */
     char separatore;		/* separator to split a string */
     long totCoppie = 0;		/* number of cells pair */
     long totRow = 0;		/* of the file */
     long tabSize = 10;		/* array length */
     Coppie *cc = NULL;		/* here store the pair of cell with the weight. these information are in the file */
@@ -251,16 +239,13 @@
-	/*else
-	 *    num = 1  ---> in the line there is only 1 token
+	/* else num = 1  ---> in the line there is only 1 token
 	 * I ignore this line
     switch (ad->data_type) {
     case CELL_TYPE:
@@ -301,7 +286,6 @@
 int calculate(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
 	      double *result)
     double indice = 0;
     double somma = 0;
     double area = 0;
@@ -340,7 +324,6 @@
 	masked = TRUE;
     buf_sup = G_allocate_cell_buf();
     if (buf_sup == NULL) {
 	G_fatal_error("malloc buf_sup failed");
@@ -358,7 +341,8 @@
     G_set_c_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
     for (j = 0; j < ad->rl; j++) {	/* for each row */
-	buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad);	/* read row of raster */
+	/* read row of raster */
+	buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad);
 	if (j > 0) {		/* not first row */
 	    buf_sup = RLI_get_cell_raster_row(fd, j - 1 + ad->y, ad);
@@ -381,8 +365,8 @@
 	    if (!(G_is_null_value(&corrCell, CELL_TYPE))) {
 		supCell = buf_sup[i + ad->x];
-		/* calculate how many edge the cell has */
+		/* calculate how many edges the cell has */
 		if (((!G_is_null_value(&prevCell, CELL_TYPE))) &&
 		    (corrCell != prevCell)) {
 		    int r = 0;
@@ -414,7 +398,6 @@
 	    mask_sup = mask_corr;
     /* calcolo dell'indice */
     if (area == 0)
 	indice = -1;
@@ -431,6 +414,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_corr);
 	G_free(mask_sup);
@@ -443,7 +427,6 @@
 int calculateD(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
 	       double *result)
     double indice = 0;
     double somma = 0;
     double area = 0;
@@ -483,7 +466,6 @@
 	masked = TRUE;
     buf_sup = G_allocate_d_raster_buf();
@@ -498,7 +480,8 @@
     G_set_d_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
-	buf_corr = RLI_get_dcell_raster_row(fd, j + ad->y, ad);	/* read row of raster */
+	buf_corr = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
 	    buf_sup = RLI_get_dcell_raster_row(fd, j - 1 + ad->y, ad);
@@ -552,7 +535,6 @@
     if (area == 0)
 	indice = -1;
@@ -568,6 +550,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_corr);
 	G_free(mask_sup);
@@ -579,7 +562,6 @@
 int calculateF(int fd, struct area_entry *ad, Coppie * cc, long totCoppie,
 	       double *result)
     double indice = 0;
     double somma = 0;
     double area = 0;
@@ -636,10 +618,11 @@
     c1.t = FCELL_TYPE;
     c2.t = FCELL_TYPE;
-	buf_corr = RLI_get_fcell_raster_row(fd, j + ad->y, ad);	/* read row of raster */
-	if (j > 0) {		/* not first row */
+	buf_corr = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
+	if (j > 0) {
+	    /* not first row */
 	    buf_sup = RLI_get_fcell_raster_row(fd, j - 1 + ad->y, ad);
 	/*read mask if needed */
@@ -672,7 +655,6 @@
 			return RLI_ERRORE;
 		if ((!(G_is_null_value(&supCell, FCELL_TYPE))) &&
 		    (corrCell != supCell)) {
 		    int r = 0;
@@ -692,7 +674,6 @@
     if (area == 0)
 	indice = -1;
@@ -708,6 +689,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_corr);
 	G_free(mask_sup);
Modified: grass/branches/develbranch_6/raster/r.li/r.li.cwed/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.cwed/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.cwed/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -28,7 +28,7 @@
 the <tt>$HOME/.r.li/output/</tt> folder.
 <p>
 <!-- TODO: verify next: -->
-If the input raster map contains only NULL values it is considered to
+If the sample area contains only NULL values it is considered to
 have 0 patch and CWED=0. If Area is 0 <em>r.li.cwed</em> returns -1.
 This is only possible if the map is masked.<br>
 If you want to change these -1 values to NULL, run subsequently on the resulting map:
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -6,6 +6,7 @@
  *   Read the COPYING file that comes with GRASS for details.
 #include "GenericCell.h"
 int equalsGenericCell(generic_cell c1, generic_cell c2)
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.h
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.h	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/GenericCell.h	2014-02-19 00:24:09 UTC (rev 59094)
@@ -7,12 +7,12 @@
+#ifndef GENERICCELL_H
+#define GENERICCELL_H
 #include <grass/gis.h>
 #include <grass/glocale.h>
-#ifndef GENERICCELL_H
-#define GENERICCELL_H
 #define GC_HIGHER 1
 #define GC_EQUAL 2
 #define GC_LOWER 3
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/avl.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/avl.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/avl.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -6,14 +6,15 @@
-#include <grass/gis.h>
-#include <grass/glocale.h>
 #include <string.h>
 #include <stdlib.h>
 #include <math.h>
 #include <stdio.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
 #include "defs.h"
 #include "avlDefs.h"
 #include "avl.h"
@@ -32,7 +33,7 @@
 void printAVL(avl_node * r);
-/* define function declsred in avl.h */
+/* define function declared in avl.h */
 avl_tree avl_make(const generic_cell k, const long n)
@@ -186,6 +187,8 @@
 static avl_node *avl_individua(const avl_tree root, const generic_cell k,
 			       avl_node ** father, int *direction)
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlDefs.h
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlDefs.h	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlDefs.h	2014-02-19 00:24:09 UTC (rev 59094)
@@ -6,6 +6,7 @@
 #define AVL_S 1
 #define AVL_D 2
 #define AVL_SS 11
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlID.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlID.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/avlID.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -7,13 +7,13 @@
 #include <stdlib.h>
 #include <fcntl.h>
 #include <math.h>
 #include "defs.h"
 #include "avlID.h"
@@ -30,7 +30,6 @@
 void avlID_rotation_rr(avlID_node * critical);
 avlID_tree avlID_make(const long k, const long n)
     avlID_node *root = NULL;	/* root pointer */
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -15,6 +15,7 @@
  * \include
+#include <grass/config.h>
 #include <stdlib.h>
 #include <stddef.h>
 #include <fcntl.h>
@@ -34,6 +35,10 @@
 #include "daemon.h"
+#ifdef __MINGW32__
+#define srandom srand
+#define random rand
+#endif
 int calculateIndex(char *file, int f(int, char **, struct area_entry *, double *),
 		   char **parameters, char *raster, char *output)
@@ -73,7 +78,6 @@
     if (mkfifo(reportChannelName, 0644) == -1)
 	G_fatal_error("Error in pipe creation");
        --------------create childs-------------------
@@ -132,7 +136,7 @@
     if (parsed == MVWIN) {
 	/* struct Cell_head cellhd_r, cellhd_new;
 	   char *mapset; */
-	/* create new raster file */
+	/*creating new raster file */
 	mv_fd = G_open_raster_new(output, DCELL_TYPE);
 	if (mv_fd < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), output);
@@ -169,8 +173,7 @@
 	i++;
-    /* body */
+    /*body */
     while (next_Area(parsed, l, g, &m) != 0) {
 	int j = 0, donePid;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/worker.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -275,6 +275,7 @@
 	if (write(mask_fd, buf, cl * sizeof(int)) < 0)
 	    return NULL;
     close(mask_fd);
     return G_store(tmp_file);
Modified: grass/branches/develbranch_6/raster/r.li/r.li.dominance/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.dominance/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.dominance/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -32,8 +32,11 @@
 <em>r.li.setup</em>) and saving results in <em>my_out</em>, run:
 <div class="code"><pre>
 r.li.dominance map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
-# forest map example:
+Forest map (Spearfish sample dataset) example:
+<div class="code"><pre>
 g.region rast=landcover.30m -p
 r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
 r.li.dominance map=forests conf=movwindow7 out=forests_dominance_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c
--- grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.dominance/dominance.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,13 +1,19 @@
- * \brief calculates dominance's diversity index
- *   \AUTHOR: Serena Pallecchi student of Computer Science University of Pisa (Italy)
- *                      Commission from Faunalia Pontedera (PI) www.faunalia.it
+ * MODULE:       r.li.dominance
+ * AUTHOR(S):    Serena Pallecchi (original contributor)
+ *                student of Computer Science University of Pisa (Italy)
+ *               Commission from Faunalia Pontedera (PI) www.faunalia.it
+ *               Rewrite: Markus Metz
- *   This program is free software under the GPL (>=v2)
- *   Read the COPYING file that comes with GRASS for details.
+ * PURPOSE:      calculates dominance diversity index
+ * COPYRIGHT:    (C) 2007-2014 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
@@ -21,6 +27,8 @@
 #include "../r.li.daemon/avl.h"
 #include "../r.li.daemon/daemon.h"
+/* template is shannon */
 int calculate(int fd, struct area_entry *ad, double *result);
 int calculateD(int fd, struct area_entry *ad, double *result);
 int calculateF(int fd, struct area_entry *ad, double *result);
@@ -41,11 +49,9 @@
     conf->key = "conf";
@@ -55,7 +61,6 @@
     return calculateIndex(conf->answer, dominance, NULL, raster->answer,
 			  output->answer);
@@ -91,22 +96,19 @@
 	    G_fatal_error("data type unknown");
 	    return RLI_ERRORE;
     if (ris != RLI_OK)
-	   return RLI_ERRORE;
+	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
     CELL *buf;
     CELL corrCell;
     CELL precCell;
@@ -266,14 +268,12 @@
 	    return RLI_ERRORE;
 	tot = avl_to_array(albero, zero, array);
 	if (tot != m) {
-	    G_warning
-		("avl_to_array unaspected value. the result could be wrong");
+	    G_warning("avl_to_array unexpected value. the result could be wrong");
 	    return RLI_ERRORE;
-	/* calculate summary */
+	/* calculate shannon */
 	for (i = 0; i < m; i++) {
 	    t = (double)array[i]->tot;
 	    percentuale = (double)(t / area);
@@ -325,9 +325,7 @@
     double logaritmo;
     avl_tree albero = NULL;
     AVL_table *array;
     generic_cell cc;
     cc.t = DCELL_TYPE;
@@ -464,7 +462,6 @@
 	    return RLI_ERRORE;
 	if (tot != m) {
 	    G_warning
@@ -478,7 +475,6 @@
 	    logaritmo = (double)log(percentuale);
 	    somma = somma + (percentuale * logaritmo);
 	G_free(array);
 	if (m != 0)
@@ -523,9 +519,7 @@
     double logaritmo;
     AVL_table *array;
     generic_cell cc;
     cc.t = FCELL_TYPE;
@@ -543,8 +537,6 @@
     G_set_f_null_value(&precCell, 1);
 	if (masked) {
 	    if (read(mask_fd, mask_buf, (ad->cl * sizeof(int))) < 0) {
@@ -661,14 +653,12 @@
 	    return RLI_ERRORE;
 	if (tot != m) {
-	    G_warning
 	    return RLI_ERRORE;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -3,10 +3,11 @@
 <em>r.li.edgedensity </em>calculates:<br>
 <br>
 <ul>
-   <li> the density of all the edge of patch i
+   <li> the density of all edges of patch type <em>k</em>
 	<img alt="rliEdgeDensity formula1" src="rliEdgeDensity_formula1.png">
 	, or
-   <li> the density of all the edge in the sampling area if i isn't specified,
+   <li> the density of all edges in the sampling area if <em>k</em> is
+        not specified,
 	<img alt="rliEdgeDensity formula2" src="rliEdgeDensity_formula2.png">
 </ul>
 <p>with:
@@ -14,7 +15,8 @@
 <li><b>k</b>: patch type</li>
 <li><b>m</b>: number of patch types</li>
 <li><b>n</b>: number of edge segments of patch type k</li>
-<li><b>e<small><small>ik </small></small></b>:total length of edge in landscape involving patch type k</li>
+<li><b>e<small><small>ik </small></small></b>:total edge length in
+the landscape involving patch type k</li>
 <li> <b>Area</b>: total landscape area</li>
 </ul>
@@ -49,8 +51,11 @@
 file run:<br>
 r.li.edgedensity map=my_map conf=my_conf output=my_out patch_type=34
+</pre></div>
+<p>
 r.li.edgedensity map=forests conf=movwindow7 out=forests_edgedens_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/edgedensity.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/edgedensity.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -40,12 +40,10 @@
     conf->key = "conf";
@@ -72,15 +70,11 @@
 int edgedensity(int fd, char **valore, struct area_entry *ad, double *result)
     int ris = -1;
     char *mapset;
     double indice = 0;
     mapset = G_find_cell(ad->raster, "");
@@ -88,7 +82,6 @@
     if (G_get_cellhd(ad->raster, mapset, &hd) == -1)
 	return RLI_ERRORE;
     case CELL_TYPE:
@@ -146,6 +139,7 @@
     /* open mask if needed */
     if (ad->mask == 1) {
 	if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0) {
 	    G_fatal_error("Cannot open mask file <%s>", ad->mask_name);
 	    return RLI_ERRORE;  /* FIXME: can not return from a fatal error */
@@ -184,7 +178,6 @@
 	if (j > 0)		/* not first row */
 	if ((j + 1) < ad->rl) {	/*not last row */
 	    buf_inf = RLI_get_cell_raster_row(fd, 1 + j + ad->y, ad);
@@ -204,10 +197,9 @@
 		return RLI_ERRORE;
-	    if ((j + 1) < ad->rl) {	/*not last row */
+	    if ((j + 1) < ad->rl) {	/* not last row */
 		if (read(mask_fd, mask_inf, (ad->cl * sizeof(int))) < 0) {
-		    G_fatal_error("reading mask_inf");
+		    G_fatal_error("reading mask_inf at row j");
 		    return RLI_ERRORE;
@@ -243,20 +235,17 @@
 		if (masked && mask_inf[i + ad->x] == 0)
 		    G_set_c_null_value(&infCell, 1);
 		else
 		    infCell = buf_inf[i + ad->x];
 		if ((G_is_null_value(&prevCell, CELL_TYPE)) ||
 		    bordoCorr++;
 		if ((G_is_null_value(&supCell, CELL_TYPE)) ||
 		    bordoCorr++;
@@ -267,13 +256,12 @@
 		    bordoCorr++;
 		if ((G_is_null_value(&nextCell, CELL_TYPE)) ||
 		    (corrCell != nextCell)) {
 		    bordoCorr++;
-		/*store the result in the tree */
+		/* store the result in the tree */
 		if (albero == NULL) {
 		    c1.val.c = corrCell;
 		    albero = avl_make(c1, bordoCorr);
@@ -309,13 +297,10 @@
 		bordoCorr = 0;
 	    prevCell = buf_corr[i + ad->x];
 	if (masked)
@@ -337,10 +322,8 @@
 	    c1.val.c = cella;
 	    e = (double)howManyCell(albero, c1);
 	    somma = e;
 	else {			/* all classes */
 	    array = G_malloc(m * sizeof(AVL_tableRow));
 	    if (array == NULL) {
 		G_fatal_error("malloc array failed");
@@ -349,7 +332,7 @@
 	    if (tot != m) {
 		G_warning
+		    ("avl_to_array unexpected value. the result could be wrong");
 		e = (double)array[i]->tot;
@@ -371,7 +354,6 @@
     return RLI_OK;
 int calculateD(int fd, struct area_entry *ad, char **valore, double *result)
     double indice = 0;
@@ -461,7 +443,6 @@
 		return RLI_ERRORE;
@@ -481,18 +462,15 @@
 	G_set_d_null_value(&corrCell, 1);
 	for (i = 0; i < ad->cl; i++) {	/* for each cell in the row */
 	    area++;
 	    corrCell = buf_corr[i + ad->x];
 	    if (masked && mask_corr[i + ad->x] == 0) {
 		area--;
 	    if (!(G_is_null_value(&corrCell, DCELL_TYPE))) {
 		if ((i + 1) == ad->cl)	/*last cell of the row */
 		    G_set_d_null_value(&nextCell, 1);
 		else if (masked && mask_corr[i + 1 + ad->x] == 0)
@@ -502,7 +480,6 @@
 		    G_set_d_null_value(&infCell, 1);
 		else
@@ -530,7 +507,7 @@
 		    bordoCorr++;
 		    c1.val.dc = corrCell;
@@ -566,17 +543,12 @@
 		bordoCorr = 0;
 	if (masked)
     /* calculate index */
@@ -605,7 +577,7 @@
 	    if (tot != m) {
 		G_warning
@@ -684,7 +656,6 @@
     /* for each raster row */
@@ -692,7 +663,6 @@
 	    buf_inf = RLI_get_fcell_raster_row(fd, 1 + j + ad->y, ad);
 	else {
@@ -701,11 +671,10 @@
 		G_fatal_error("malloc mask_inf failed");
 		return RLI_ERRORE;
 	    G_set_f_null_value(buf_inf + ad->x, ad->cl);
-	/*read mask if needed */
+	/* read mask if needed */
 	if (masked) {
 	    if (read(mask_fd, mask_corr, (ad->cl * sizeof(int))) < 0) {
@@ -752,14 +721,12 @@
 		    G_set_f_null_value(&infCell, 1);
 		else
 		if ((G_is_null_value(&prevCell, FCELL_TYPE)) ||
 		    bordoCorr++;
@@ -780,7 +747,7 @@
 		    bordoCorr++;
@@ -816,17 +783,12 @@
 		bordoCorr = 0;
 	if (masked)
@@ -869,6 +831,7 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_inf);
 	G_free(mask_corr);
Modified: grass/branches/develbranch_6/raster/r.li/r.li.mpa/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.mpa/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.mpa/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -35,8 +35,11 @@
 r.li.mpa map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.mpa map=forests conf=movwindow7 out=forests_mpa_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.mpa/mpa.c
--- grass/branches/develbranch_6/raster/r.li/r.li.mpa/mpa.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.mpa/mpa.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -40,12 +40,10 @@
     conf->key = "conf";
@@ -55,26 +53,20 @@
     return calculateIndex(conf->answer, meanPixelAttribute, NULL,
 			  raster->answer, output->answer);
 int meanPixelAttribute(int fd, char **par, struct area_entry *ad, double *result)
     char *mapset;
     int ris = 0;
     double indice = 0;
 	return RLI_ERRORE;
     case CELL_TYPE:
@@ -102,14 +94,12 @@
 	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
     CELL *buf;
@@ -122,7 +112,6 @@
     double indice = 0;
     double somma = 0;
@@ -142,7 +131,6 @@
 	buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);	/*read raster row */
 	if (masked) {		/*read mask row if needed */
 		G_fatal_error("mask read failed");
 		return RLI_ERRORE;
@@ -161,7 +149,6 @@
     if (area == 0)
 	indice = (double)-1;
     else
@@ -169,11 +156,14 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
     DCELL *buf;
@@ -186,7 +176,6 @@
     double indice = 0;
     double somma = 0;
@@ -207,7 +196,6 @@
 	buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);	/*read raster row */
 		return RLI_ERRORE;
@@ -226,7 +214,6 @@
     if (area == 0)
     else
@@ -234,8 +221,10 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
@@ -251,7 +240,6 @@
     double indice = 0;
     double somma = 0;
@@ -267,12 +255,10 @@
     for (j = 0; j < ad->rl; j++) {	/*for each raster row */
 	buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);	/*read raster row */
 		return RLI_ERRORE;
@@ -292,7 +278,6 @@
     if (area == 0)
     else
@@ -300,7 +285,9 @@
     *result = indice;
     if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     return RLI_OK;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.mps/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.mps/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.mps/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,8 +1,13 @@
 <h2>DESCRIPTION</h2>
-<em>r.li.mps</em> (mean patch size) calculates the mean size of the patches
-in the sampling area as:<br>
+<em>r.li.mps</em> (mean patch size) calculates the mean size of the
+patches in the sampling area as:<br>
 <img src="rlimps_formula.png" alt="rliMps formula"><br>
+MPS = A / Npatch
+</pre></div>
 with:
 <ul>
@@ -10,6 +15,12 @@
   <li><b>Npatch</b>: number of patches</li>
 </ul>
+The unit of the mean size is hectare.
+<p>
+This index is calculated using a 4 neighbour algorithm, diagonal cells
+are ignored when tracing a patch.
 <h2>NOTES</h2>
 Do not use absolute path names for the <b>output</b> map/file.
@@ -32,8 +43,11 @@
 r.li.mps map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.mps map=forests conf=movwindow7 out=forests_mps_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.mps/mps.c
--- grass/branches/develbranch_6/raster/r.li/r.li.mps/mps.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.mps/mps.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,13 +1,18 @@
- * \brief calculates mean patch size index
+ * MODULE:       r.li.patchnum
+ * PURPOSE:      calculates mean patch size index
+ *               for details.
 #include <stdlib.h>
 #include <fcntl.h>
@@ -40,12 +45,10 @@
     conf->key = "conf";
@@ -54,7 +57,6 @@
     return calculateIndex(conf->answer, meanPatchSize, NULL, raster->answer,
 			  output->answer);
@@ -93,7 +95,7 @@
     if (ris != RLI_OK)
     *result = indice;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padcv/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.padcv/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padcv/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,15 +1,15 @@
-<em>r.li.padcv</em> (patch area distribution coefficient of variation) calculates
-as:<br>
-<img src="rlipadcv_formula1.png" alt="rlipadcv formula"> <br>
+<em>r.li.padcv</em> calculates the coefficient of variation of patch
+area sizes in hectares as:<br>
+<img src="rlipadcv_formula1.png" alt="r.li.padcv formula"> <br>
 with:<br>
 <ul>
  <li><b>SD</b>: standard deviation of patch area size
   <img src="rlipadcv_formula2.png">  </li>
   <li><b>MPS</b>: mean patch area size </li>
   <li><b>a<small><small>i</small></small></b>: area of patch i</li>
-  <li><b>N<small>patch</small></b>: number of patch</li>
+  <li><b>N<small>patch</small></b>: number of patches</li>
 </ul>
 <h2>NOTES</h2>
@@ -33,8 +33,11 @@
 r.li.padcv map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padcv map=forests conf=movwindow7 out=forests_padcv_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padcv/padcv.c
--- grass/branches/develbranch_6/raster/r.li/r.li.padcv/padcv.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padcv/padcv.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,13 +1,19 @@
- * \brief calculates coefficient of variation of patch area
+ * MODULE:       r.li.padcv
+ *               Fixes: Markus Neteler <neteler itc.it>
+ * PURPOSE:      calculates coefficient of variation of patch areas
+ *               for details.
 #include <stdlib.h>
 #include <fcntl.h>
@@ -40,18 +46,15 @@
     /* define options */
     conf->key = "conf";
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionCV, NULL,
@@ -87,8 +90,8 @@
 	    return RLI_ERRORE;
     if (ris != RLI_OK) {
 	*result = -1;
 	return RLI_ERRORE;
@@ -99,6 +102,7 @@
     return RLI_OK;
     CELL *buf;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padrange/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.padrange/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padrange/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,14 +1,18 @@
-<em>r.li.padrange</em> (patch area distribution range) calculates
-as:<br>
-<img src="rlipadrange_formula.png" alt="rlipadrange formula"> <br>
+<em>r.li.padrange</em> calculates the range of patch area sizes in
+hectares as:<br>
+<img src="rlipadrange_formula.png" alt="r.li.padrange formula"> <br>
 with:<br>
 <ul>
   <li><b>a<small><small>max</small></small></b>: max patch area size</li>
   <li><b>a<small><small>min</small></small></b>: min patch area size</li>
 </ul>
+<p>
 <h2>NOTES</h2>
@@ -31,8 +35,11 @@
 r.li.padrange map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padrange map=forests conf=movwindow7 out=forests_padrange_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padrange/padrange.c
--- grass/branches/develbranch_6/raster/r.li/r.li.padrange/padrange.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padrange/padrange.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,21 +1,27 @@
- * \brief calculates range of patch area size
+ * MODULE:       r.li.padrange
+ * PURPOSE:      calculates calculates standard deviation of patch areas
+ *               for details.
 #include <stdlib.h>
 #include <fcntl.h>
 #include <math.h>
 #include "../r.li.daemon/defs.h"
 #include "../r.li.daemon/avlDefs.h"
 #include "../r.li.daemon/avlID.h"
@@ -39,13 +45,14 @@
     conf->key = "conf";
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionRANGE, NULL,
@@ -65,13 +72,11 @@
 	return RLI_ERRORE;
     case CELL_TYPE:
 	    ris = calculate(fd, ad, &indice);
 	    break;
     case DCELL_TYPE:
 	    ris = calculateD(fd, ad, &indice);
 	    break;
@@ -82,7 +87,6 @@
 	    break;
     default:
 	    return RLI_ERRORE;
@@ -92,7 +96,9 @@
 	*result = -1;
 	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
@@ -123,16 +129,11 @@
     long *mask_patch_sup;
     long *mask_patch_corr;
     double indice = 0;
     double rk = 0;
     avlID_tree albero = NULL;
     avlID_table *array = NULL;
     generic_cell gc;
     gc.t = CELL_TYPE;
@@ -482,8 +483,6 @@
 	rk = area_max - area_min;
 	indice = rk;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padsd/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.padsd/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padsd/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,14 +1,19 @@
-<em>r.li.padsd</em> (patch area distribution standard deviation) calculates as:<br>
-<img src="rlipadsd_formula.png" alt="rlipadsd formula"> <br>
+<em>r.li.padsd</em> calculates the standard deviation of patch
+<img src="rlipadsd_formula.png" alt="r.li.padsd formula"> <br>
 with:<br>
 <ul>
   <li><b>MPS</b>: mean patch area size</li>
 </ul>
+<p>
 <h2>NOTES</h2>
@@ -31,8 +36,11 @@
 r.li.padsd map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padsd map=forests conf=movwindow7 out=forests_padsd_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.padsd/padsd.c
--- grass/branches/develbranch_6/raster/r.li/r.li.padsd/padsd.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.padsd/padsd.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,21 +1,27 @@
- * \brief calculates standard deviation of patch area
+ * MODULE:       r.li.padsd
+ *               for details.
 #include <stdlib.h>
 #include <fcntl.h>
 #include <math.h>
@@ -24,6 +30,7 @@
 int main(int argc, char *argv[])
     struct Option *raster, *conf, *output;
@@ -37,13 +44,14 @@
     conf->key = "conf";
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionSD, NULL,
@@ -62,25 +70,21 @@
 	return RLI_ERRORE;
     case CELL_TYPE:
 	    break;
     case DCELL_TYPE:
 	    break;
     case FCELL_TYPE:
 	    ris = calculateF(fd, ad, &indice);
 	    break;
     default:
 	    return RLI_ERRORE;
@@ -90,10 +94,13 @@
 	*result = -1;
 	return RLI_ERRORE;
     *result = indice;
     return RLI_OK;
     CELL *buf;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,13 +1,21 @@
-<em>r.li.patchdensity</em> calculates the "patch density index" as:
+<em>r.li.patchdensity</em> calculates the "patch density index",
+the number of patches per square kilometer, as:
-f(sample_area) = (Patch_Number/Area) * 1000000
+PD = Npatch / A
 </pre></div>
-that is 1000000 by number of patch for area unit.
-This index is calculated using a 4 neighbour algorithm.
+with:
+<ul>
+  <li><b>A</b>:sampling area size</li>
+  <li><b>Npatch</b>: number of patches</li>
+</ul>
+<p>
 <h2>NOTES</h2>
@@ -43,6 +51,7 @@
 # patch density (7x7 moving window defined in r.li.setup):
 r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
+r.univar forests_p_dens7
 d.rast.leg forests_p_dens7
 r.to.vect forests out=forests feature=area
Modified: grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/main.c
--- grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/main.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.patchdensity/main.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -7,7 +7,7 @@
  *               Fixes: Serena Pallecchi, Markus Neteler <neteler itc.it>
  * PURPOSE:      calculates patch density index
- * COPYRIGHT:    (C) 2006-2007 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006-2014 by the GRASS Development Team
@@ -36,23 +36,18 @@
     conf->key = "conf";
-	/** add other options for index parameters here */
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patch_density, NULL, raster->answer,
 			  output->answer);
Modified: grass/branches/develbranch_6/raster/r.li/r.li.patchnum/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.patchnum/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.patchnum/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -2,8 +2,11 @@
 <em>r.li.patchnum</em> calculates the "patch number index" as:<br>
 <I> f(sample_area)= Patch_Number </I><br>
-This index is calculated using a 4 neighbour algorithm<br>
+<p>
 <h2>NOTES</h2>
@@ -25,8 +28,11 @@
 r.li.patchnum map=my_map conf=my_conf out=my_out
+</pre></div>
+<p>
 r.li.patchnum map=forests conf=movwindow7 out=forests_patchnum_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.patchnum/main.c
--- grass/branches/develbranch_6/raster/r.li/r.li.patchnum/main.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.patchnum/main.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -8,7 +8,7 @@
  * PURPOSE:      calculates patch number index
- * COPYRIGHT:    (C) 2007-2007 by the GRASS Development Team
@@ -38,22 +38,18 @@
     conf->key = "conf";
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patch_number, NULL, raster->answer,
 			  output->answer);
 int patch_number(int fd, char **par, struct area_entry *ad, double *result)
Modified: grass/branches/develbranch_6/raster/r.li/r.li.pielou/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.pielou/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.pielou/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,7 +1,7 @@
 <em>r.li.pielou</em>  calculates the "Pielou's diversity index" as: <br>
-<img src="r_li_pielou.png"><br>
+<img src="r_li_pielou.png" alt="r.li.pielou formula"> <br>
 with:
 <ul>
   <li><b>J</b>: Pielou eveness index</li>
@@ -16,6 +16,7 @@
 output will be a raster map, otherwise an ASCII file will be generated in
 <p>
+<!-- TODO: verify next: -->
 If the input raster contains NULL value cells, <em>r.li.pielou</em>
 returns -1 for these cells. <br>
@@ -30,8 +31,11 @@
 r.li.pielou map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.pielou map=forests conf=movwindow7 out=forests_pielou_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.pielou/pielou.c
--- grass/branches/develbranch_6/raster/r.li/r.li.pielou/pielou.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.pielou/pielou.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -26,6 +26,8 @@
@@ -62,11 +64,9 @@
     conf->key = "conf";
@@ -76,18 +76,15 @@
     return calculateIndex(conf->answer, pielou, NULL, raster->answer,
 			  output->answer);
 int pielou(int fd, char **par, struct area_entry *ad, double *result)
     char *mapset;
     int ris = RLI_OK;
     double indice = 0;
 	return RLI_ERRORE;
@@ -123,16 +120,15 @@
     *result = indice;
     return RLI_OK;
     CELL *buf;
     CELL corrCell;
     CELL precCell;
     int i, j;
     int mask_fd = -1, *mask_buf;
     int ris = 0;
@@ -159,7 +155,6 @@
     generic_cell cc_passage;	/*add to compute the number of class */
     AVL_table *array;
     cc.t = CELL_TYPE;
@@ -176,15 +171,12 @@
 	masked = TRUE;
     G_set_c_null_value(&precCell, 1);
     /*for each row */
 	if (masked) {
Modified: grass/branches/develbranch_6/raster/r.li/r.li.renyi/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.renyi/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.renyi/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,7 +1,7 @@
 <em>r.li.renyi</em> calculates the "Renyi's diversity index" as:<br>
-<img src="r_li_renyi.png"> <br>
+<img src="r_li_renyi.png" alt="r.li.renyi formula"> <br>
 with:
 <ul>
   <li><b>H</b>: Renyi entropy</li>
@@ -33,8 +33,11 @@
 r.li.renyi map=my_map conf=my_conf output=my_out alpha=0.6
+</pre></div>
+<p>
 r.li.renyi map=forests conf=movwindow7 out=forests_renyi_mov7_a06 alpha=0.6
Modified: grass/branches/develbranch_6/raster/r.li/r.li.richness/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.richness/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.richness/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,12 +1,15 @@
-<em>r.li.richness</em> calculates the "richness diversity index" as:<br>
-<img src="rliRichness_formula.png alt="rliRichness formula"> <br>
+<em>r.li.richness</em> calculates the "richness diversity index" as:
+<br>
+<img src="rliRichness_formula.png" alt="r.li.richness formula">
+<br>
 with:
 <ul>
   <li><b>m</b>: number of different patch types</li>
 </ul>
 <h2>NOTES</h2>
@@ -24,31 +27,39 @@
 after index calculation.
 <h2>EXAMPLES</h2>
 To calculate the richness diversity index on map <em>my_map</em>, using
 <em>my_conf</em> configuration file (previously defined with
 r.li.richness map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.richness map=forests conf=movwindow7 out=forests_richness_mov7
 r.univar forests_richness_mov7
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="r.li.html">r.li</a> - package overview<br>
 <a href="r.li.setup.html">r.li.setup</a>
 </em>
 <h2>REFERENCES</h2>
 McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
 analysis program for quantifying landscape structure. USDA For. Serv.
 Gen. Tech. Rep. PNW-351. (<a href="http://treesearch.fs.fed.us/pubs/3064">PDF</a>)
 <h2>AUTHORS</h2>
 Serena Pallecchi student of Computer Science University of Pisa (Italy).<br>
 Commission from Faunalia Pontedera (PI), Italy (www.faunalia.it)
Modified: grass/branches/develbranch_6/raster/r.li/r.li.richness/richness.c
--- grass/branches/develbranch_6/raster/r.li/r.li.richness/richness.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.richness/richness.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,6 +1,6 @@
+ * \brief calculates richness diversity index
@@ -42,11 +42,9 @@
     conf->key = "conf";
@@ -62,15 +60,10 @@
 int dominance(int fd, char **par, struct area_entry *ad, double *result)
     char *mapset;
     int ris = RLI_OK;
     double indice = 0;
 	return RLI_ERRORE;
@@ -121,16 +114,11 @@
     int ris = 0;
     int masked = FALSE;
     int a = 0;			/* a=0 if all cells are null */
     long m = 0;
     double indice = 0;
     generic_cell uc;
     uc.t = CELL_TYPE;
@@ -280,11 +268,8 @@
     int ris = 0;
     int masked = FALSE;
     long m = 0;
     double indice = 0;
     generic_cell uc;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.shannon/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.shannon/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.shannon/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,7 +1,7 @@
 <em>r.li.shannon</em> calculates the "Shannon's diversity index" as:<br>
-<img src="rliShannon_formula.png" alt="rliShannon formula"> <br>
+<img src="rliShannon_formula.png" alt="r.li.shannon formula"> <br>
 with:
 <ul>
 <li><b>i</b>: patch type</li>
@@ -33,8 +33,11 @@
 r.li.shannon map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.shannon map=forests conf=movwindow7 out=forests_shannon_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.shannon/shannon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.shannon/shannon.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.shannon/shannon.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,13 +1,18 @@
- * \brief calculates shannon's diversity index
+ * MODULE:       r.li.shannon
+ * PURPOSE:      calculates Shannon's diversity index
+ *               for details.
@@ -21,6 +26,8 @@
+/* template for dominance, renyi, pielou, simpson */
@@ -41,11 +48,9 @@
     conf->key = "conf";
@@ -55,22 +60,16 @@
     return calculateIndex(conf->answer, shannon, NULL, raster->answer,
 			  output->answer);
 int shannon(int fd, char **par, struct area_entry * ad, double *result)
     char *mapset;
     int ris = RLI_OK;
     double indice = 0;
 	return RLI_ERRORE;
@@ -106,13 +105,11 @@
     *result = indice;
     return RLI_OK;
     CELL *buf;
     CELL corrCell;
     CELL precCell;
@@ -138,10 +135,8 @@
     generic_cell cc;
     AVL_table *array;
     cc.t = CELL_TYPE;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.shape/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.shape/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.shape/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -26,8 +26,11 @@
 r.li.shape map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.shape map=forests conf=movwindow7 out=forests_shape_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.shape/main.c
--- grass/branches/develbranch_6/raster/r.li/r.li.shape/main.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.shape/main.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -36,11 +36,9 @@
     conf->key = "conf";
@@ -52,13 +50,10 @@
     return calculateIndex(conf->answer, shape_index, NULL, raster->answer,
 			  output->answer);
 int shape_index(int fd, char **par, struct area_entry *ad, double *result)
     double area;
     char *mapset;
@@ -108,5 +103,6 @@
 	(ad->rl * ad->cl - null_count);
     *result = area;
     return 1;
Modified: grass/branches/develbranch_6/raster/r.li/r.li.simpson/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.simpson/description.html	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.simpson/description.html	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,7 +1,7 @@
 <em>r.li.simpson</em> calculates the "Simpson's diversity index" as:<br>
-<img src="rliSimpson_formula.png" alt="rliSimpson formula"> <br>
+<img src="rliSimpson_formula.png" alt="r.li.simpson formula"> <br>
 with:
 <ul>
@@ -32,8 +32,11 @@
 r.li.simpson map=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.simpson map=forests conf=movwindow7 out=forests_simpson_mov7
Modified: grass/branches/develbranch_6/raster/r.li/r.li.simpson/simpson.c
--- grass/branches/develbranch_6/raster/r.li/r.li.simpson/simpson.c	2014-02-18 22:12:25 UTC (rev 59093)
+++ grass/branches/develbranch_6/raster/r.li/r.li.simpson/simpson.c	2014-02-19 00:24:09 UTC (rev 59094)
@@ -1,27 +1,34 @@
- * \brief calculates Simpson's diversity index
+ * MODULE:       r.li.simpson
+ * PURPOSE:      calculates Simpson's diversity index
+ *               for details.
 #include <stdlib.h>
 #include <fcntl.h>
 #include <math.h>
 double calculate(struct area_entry *ad, int fd, double *result);
 double calculateD(struct area_entry *ad, int fd, double *result);
 double calculateF(struct area_entry *ad, int fd, double *result);
@@ -45,8 +52,6 @@
     conf->key = "conf";
@@ -56,7 +61,6 @@
     return calculateIndex(conf->answer, simpson, NULL, raster->answer,
 			  output->answer);
 int simpson(int fd, char **par, struct area_entry *ad, double *result)
@@ -91,7 +95,6 @@
 	    return RLI_ERRORE;
     if (ris != RLI_OK)
@@ -100,11 +103,9 @@
     *result = indice;
     return RLI_OK;
     CELL *buf;
@@ -130,7 +131,6 @@
     AVL_table *array;
     generic_cell uc;
     uc.t = CELL_TYPE;
@@ -317,9 +317,7 @@
     double t;
     AVL_table *array;
     generic_cell uc;
     uc.t = DCELL_TYPE;
@@ -526,7 +524,6 @@
 	if (masked) {
@@ -538,7 +535,6 @@
 	for (i = 0; i < ad->cl; i++) {	/* for each fcell in the row */
 	    area++;
 	    corrCell = buf[i + ad->x];
@@ -663,10 +659,11 @@
     G_free(array);
-    if (masked)
+    if (masked) {
+	close(mask_fd);
 	G_free(mask_buf);
     *result = indice;
     return RLI_OK;
