[GRASS-SVN] r58594 - in grass/trunk: display/d.vect.chart raster/r.li/r.li.patchdensity raster/r.watershed/front
Fri Jan 3 10:28:50 PST 2014
Author: neteler
Date: 2014-01-03 10:28:50 -0800 (Fri, 03 Jan 2014)
New Revision: 58594
   grass/trunk/display/d.vect.chart/d.vect.chart.html
   grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
   grass/trunk/raster/r.watershed/front/r.watershed.html
manual pages: fix r.to.vect parameter in examples
Modified: grass/trunk/display/d.vect.chart/d.vect.chart.html
--- grass/trunk/display/d.vect.chart/d.vect.chart.html	2014-01-03 18:28:04 UTC (rev 58593)
+++ grass/trunk/display/d.vect.chart/d.vect.chart.html	2014-01-03 18:28:50 UTC (rev 58594)
@@ -35,8 +35,8 @@
 Create framed bar graphs of an erodibiliy index from the SPEARFISH dataset.
 <div class="code"><pre>
-g.region rast=erode.index
-r.to.vect -s -v input=erode.index output=erode_index feature=area
+g.region rast=erode.index -p
+r.to.vect -s -v input=erode.index output=erode_index type=area
 v.extract input=erode_index output=erode_index_ctrds type=centroid
 d.rast aspect
 d.vect.chart map=erode_index_ctrds ctype=bar columns=cat \
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-01-03 18:28:04 UTC (rev 58593)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-01-03 18:28:50 UTC (rev 58594)
@@ -33,7 +33,7 @@
 r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
 d.rast.leg forests_p_dens7
-r.to.vect forests out=forests feature=area
+r.to.vect forests out=forests type=area
 d.vect forests type=boundary
 </pre></div>
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2014-01-03 18:28:04 UTC (rev 58593)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2014-01-03 18:28:50 UTC (rev 58594)
@@ -411,7 +411,7 @@
   # <i>Thinning is required before converting raster lines to vector</i>
   r.thin in=rwater.course out=rwater.course.Thin
   r.colors -gn rwater.course.Thin color=grey
-  r.to.vect in=rwater.course.Thin out=rwater_course feature=line
+  r.to.vect in=rwater.course.Thin out=rwater_course type=line
   v.db.dropcolumn map=rwater_course column=label
 </pre></div>
 <!-- can't set line attribute to catchment it is in as v.what.rast and
@@ -425,7 +425,7 @@
 Create watershed basins map and convert to a vector polygon map
   r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
-  r.to.vect -s in=rwater.basin out=rwater_basins feature=area
+  r.to.vect -s in=rwater.basin out=rwater_basins type=area
   v.db.dropcolumn map=rwater_basins column=label
   v.db.renamecolumn map=rwater_basins column=value,catchment
 </pre></div>
