[GRASS-SVN] r58740 - grass/trunk/lib/gis
Fri Jan 17 11:45:40 PST 2014
Author: glynn
Date: 2014-01-17 11:45:38 -0800 (Fri, 17 Jan 2014)
New Revision: 58740
Added:
   grass/trunk/lib/gis/mkstemp.c
Replacement for mkstemp() etc (issue #2153)
Added: grass/trunk/lib/gis/mkstemp.c
--- grass/trunk/lib/gis/mkstemp.c	                        (rev 0)
+++ grass/trunk/lib/gis/mkstemp.c	2014-01-17 19:45:38 UTC (rev 58740)
@@ -0,0 +1,103 @@
+#include <stdio.h>
+#include <string.h>
+#include <errno.h>
+#include <unistd.h>
+#include <fcntl.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#define MAX_REPLACE 5
+static int next(char **replace, int num_replace)
+    int i;
+    for (i = 0; i < num_replace; i++) {
+	char *p = replace[i];
+	if (*p < 'z') {
+	    (*p)++;
+	    return 1;
+	else
+	    *p = 'a';
+    return 0;
+static int G__mkstemp(char *template, int flags, int mode)
+    char *replace[MAX_REPLACE];
+    int num_replace = 0;
+    char *ptr = template;
+    int fd;
+    while (num_replace < MAX_REPLACE) {
+	char *p = strchr(ptr, 'X');
+	if (!p)
+	    break;
+	replace[num_replace++] = p;
+	*p = 'a';
+	ptr = p + 1;
+    if (!num_replace)
+	return -1;
+    for (;;) {
+	if (!next(replace, num_replace))
+	    return -1;
+	if (access(template, F_OK) == 0)
+	    continue;
+	if (!flags)
+	    return 0;
+	fd = open(template, flags, mode);
+	if (fd < 0) {
+	    if (errno == EEXIST)
+		continue;
+	    return -1;
+	return fd;
+    return -1;
+char *G_mktemp(char *template)
+    return G__mkstemp(template, 0, 0) < 0 ? NULL : template;
+int G_mkstemp(char *template, int flags, int mode)
+    switch (flags & O_ACCMODE) {
+    case O_RDONLY:
+	G_fatal_error(_("Attempt to create read-only temporary file"));
+	return -1;
+    case O_WRONLY:
+    case O_RDWR:
+	break;
+    default:
+	G_fatal_error(_("Unrecognised access mode: %o"), flags & O_ACCMODE);
+	return -1;
+    return G__mkstemp(template, flags | O_CREAT | O_EXCL, mode);
+FILE *G_mkstemp_fp(char *template, int flags, int mode)
+    const char *fmode = (flags & O_ACCMODE == O_RDWR)
+	? ((flags & O_APPEND) ? "a+" : "w+")
+	: ((flags & O_APPEND) ? "a" : "w");
+    int fd = G_mkstemp(template, flags, mode);
+    if (fd < 0)
+	return NULL;
+    return fdopen(fd, fmode);
Property changes on: grass/trunk/lib/gis/mkstemp.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
