[GRASS-SVN] r61107 - sandbox/wenzeslaus/gunittest
Tue Jul 1 14:56:06 PDT 2014
Author: wenzeslaus
Date: 2014-07-01 14:56:06 -0700 (Tue, 01 Jul 2014)
New Revision: 61107
   sandbox/wenzeslaus/gunittest/main.py
gunittest: remove overridden method, original is enough when passing loader instance
Modified: sandbox/wenzeslaus/gunittest/main.py
--- sandbox/wenzeslaus/gunittest/main.py	2014-07-01 21:52:11 UTC (rev 61106)
+++ sandbox/wenzeslaus/gunittest/main.py	2014-07-01 21:56:06 UTC (rev 61107)
@@ -10,73 +10,33 @@
 class GrassTestProgram(TestProgram):
-    def _do_discovery(self, argv, Loader=None):
+    def __init__(self, grass_location=None, clean_outputs=True,
+                 unittest_argv=None,
+                 exit_at_end=True, verbosity=1,
+                 failfast=None, catchbreak=None):
+        """Prepares the tests in GRASS way and then runs the tests.
-        Taken from Python's ``unittest.main.TestProgram._do_discovery()``.
-        Line::
-            Loader = lambda: self.testLoader
-        changed to::
-            Loader = self.testLoader
+        :param bool clean_outputs: if outputs in mapset and in ?
-        if Loader is None:
+        self.test = None
+        self.grass_location = grass_location
+        # it is unclear what the exact behavior is unittest
+        # buffer stdout and stderr during tests
+        buffer_stdout_stderr = False
-        # handle command line args for test discovery
-        self.progName = '%s discover' % self.progName
-        import optparse
-        parser = optparse.OptionParser()
-        parser.prog = self.progName
-        parser.add_option('-v', '--verbose', dest='verbose', default=False,
-                          help='Verbose output', action='store_true')
-        if self.failfast != False:
-            parser.add_option('-f', '--failfast', dest='failfast', default=False,
-                              help='Stop on first fail or error',
-                              action='store_true')
-        if self.catchbreak != False:
-            parser.add_option('-c', '--catch', dest='catchbreak', default=False,
-                              help='Catch ctrl-C and display results so far',
-        if self.buffer != False:
-            parser.add_option('-b', '--buffer', dest='buffer', default=False,
-                              help='Buffer stdout and stderr during tests',
-        parser.add_option('-s', '--start-directory', dest='start', default='.',
-                          help="Directory to start discovery ('.' default)")
-        parser.add_option('-p', '--pattern', dest='pattern', default='test*.py',
-                          help="Pattern to match tests ('test*.py' default)")
-        parser.add_option('-t', '--top-level-directory', dest='top', default=None,
-                          help='Top level directory of project (defaults to start directory)')
+        grass_loader = GrassTestLoader(grass_location=self.grass_location)
+        grass_runner = GrassTestRunner(verbosity=verbosity,
+                                       failfast=failfast,
+                                       buffer=buffer_stdout_stderr)
-        options, args = parser.parse_args(argv)
-        if len(args) > 3:
-            self.usageExit()
+        super(GrassTestProgram, self).__init__(module=None, argv=unittest_argv,
+                                               testLoader=grass_loader,
+                                               testRunner=grass_runner,
+                                               exit=exit_at_end,
+                                               verbosity=verbosity,
+                                               catchbreak=catchbreak,
-        for name, value in zip(('start', 'pattern', 'top'), args):
-            setattr(options, name, value)
-        # only set options from the parsing here
-        # if they weren't set explicitly in the constructor
-        if self.failfast is None:
-            self.failfast = options.failfast
-        if self.catchbreak is None:
-            self.catchbreak = options.catchbreak
-        if self.buffer is None:
-            self.buffer = options.buffer
-        if options.verbose:
-            self.verbosity = 2
-        start_dir = options.start
-        pattern = options.pattern
-        top_level_dir = options.top
-        loader = Loader()
-        self.test = loader.discover(start_dir, pattern, top_level_dir)
 if __name__ == '__main__':
-    GrassTestProgram(module=None, testLoader=GrassTestLoader, testRunner=GrassTestRunner)
+    GrassTestProgram(grass_location='nc')
