[GRASS-SVN] r61121 - sandbox/wenzeslaus/gunittest
Wed Jul 2 10:16:24 PDT 2014
Author: wenzeslaus
Date: 2014-07-02 10:16:24 -0700 (Wed, 02 Jul 2014)
New Revision: 61121
   sandbox/wenzeslaus/gunittest/main.py
gunittest: first version of switching location and mapset (using existing GISDBASE and hardcoded mapset)
Modified: sandbox/wenzeslaus/gunittest/main.py
--- sandbox/wenzeslaus/gunittest/main.py	2014-07-02 15:35:59 UTC (rev 61120)
+++ sandbox/wenzeslaus/gunittest/main.py	2014-07-02 17:16:24 UTC (rev 61121)
@@ -2,6 +2,7 @@
 import os
 import sys
+import shutil
 from unittest.main import TestProgram, USAGE_AS_MAIN
 TestProgram.USAGE = USAGE_AS_MAIN
@@ -9,7 +10,10 @@
 from loader import GrassTestLoader, discover_modules
 from runner import GrassTestRunner
+import grass.script.setup as gsetup
+import grass.script.core as gcore
 class GrassTestProgram(TestProgram):
     def __init__(self, exit_at_end, grass_location, clean_outputs=True,
@@ -98,13 +102,36 @@
                                all_locations_value=GrassTestLoader.all_tests_value,
                                universal_location_value=GrassTestLoader.universal_tests_value,
                                import_modules=False)
-    env = os.environ.copy()
+    ensure_dir(os.path.abspath(results_root))
     main_index = open(os.path.join(results_root, 'index.html'), 'w')
     main_index.write('<html><body>'
                      '<ul>')
     for module in modules:
         cwd = os.path.join(results_root, module.tested_dir, module.name)
         ensure_dir(os.path.abspath(cwd))
+        env = os.environ.copy()
+        # using path.sep but also / and \ for cases when it is confused
+        # (namely the case of Unix path on MS Windows)
+        # replace . to get rid of unclean path
+        # TODO: clean paths
+        dir_as_name = module.tested_dir.replace('.', '_').replace('/', '_').replace('\\', '_').replace(os.path.sep, '_')
+        mapset = dir_as_name + '_' + module.name
+        location = 'nc_spm_08_grass7_tests'
+        gisdbase = gcore.gisenv()['GISDBASE']
+        assert gisdbase
+        gisrc = gsetup.write_gisrc(gisdbase, location, mapset)
+        env['GISRC'] = gisrc
+        # TODO: use grass module to do this?
+        mapset_dir = os.path.join(gisdbase, location, mapset)
+        # TODO: perhaps remove dir if exists
+        os.mkdir(mapset_dir)
+        # copy WIND file from PERMANENT
+        # TODO: this should be a function in grass.script (used also in gis_set.py, PyGRASS alos has its way with Mapset)
+        # TODO: are premisions an issue here?
+        shutil.copy(os.path.join(gisdbase, location, 'PERMANENT', 'WIND'),
+                    os.path.join(mapset_dir))
         # TODO: we don't do any HTML escaping, use txt file
         stdout = open(os.path.join(cwd, 'stdout.html'), 'w')
         stderr = open(os.path.join(cwd, 'stderr.html'), 'w')
@@ -112,6 +139,7 @@
         stderr.write('<html><body><pre>')
         stdout.flush()  # we need to flush to write our changes before stdout
         stderr.flush()
         # TODO: we might clean the directory here before test if non-empty
         p = subprocess.Popen([sys.executable, module.abs_file_path],
                              cwd=cwd, env=env,
@@ -138,6 +166,9 @@
         stdout.close()
         stderr.close()
         file_index.close()
+        os.remove(gisrc)
+        # TODO: only if clean up
+        shutil.rmtree(mapset_dir)
     main_index.write('</ul>'
                      '</body></html>')
