[GRASS-SVN] r61144 - sandbox/wenzeslaus/gunittest
Thu Jul 3 16:10:12 PDT 2014
Author: wenzeslaus
Date: 2014-07-03 16:10:12 -0700 (Thu, 03 Jul 2014)
New Revision: 61144
   sandbox/wenzeslaus/gunittest/testing.rst
gunittest: handling of differnet locations (theory) and few updates to current state
Modified: sandbox/wenzeslaus/gunittest/testing.rst
--- sandbox/wenzeslaus/gunittest/testing.rst	2014-07-03 22:48:19 UTC (rev 61143)
+++ sandbox/wenzeslaus/gunittest/testing.rst	2014-07-03 23:10:12 UTC (rev 61144)
@@ -13,9 +13,108 @@
 the documentation of testing framework classes and scripts.
-Testing functions with doctest
+Testing with gunittest
+The tests should be in files in a ``testsuite`` directory which is a subdirectory
+of the directory with tested files (module, package, library). Each testing file
+(test file) can have can have several testing classes (test cases).
+All test files names should have pattern ``test*.py``.
+GRASS GIS `gunittest` package and testing framework is similar to the standard
+Python ``unittest`` package, so the ways to build tests are very similar.
+    import guinttest
+    class TestPython(gunittest.GrassTestCase):
+        def test_counting(self):
+            """Test that Python can count to two"""
+            self.assertEqual(1 + 1, 2)
+    if __name__ == '__main__':
+        gunittest.test()
+Each test file should be able to run by itself and accept certain set of command
+line parameters. This is ensured using `gunittest.test()`.
+To run (invoke) all tests in the source tree run::
+    python gunittest/main.py [gisdbase] location test_data_category
+All test files in all ``testsuite`` directories will be executed and
+a report will be created in a newly created ``testreport`` directory.
+You need to be in GRASS session to run the tests.
+The test_data_category parameter serves to filter tests accoring to data
+they can run successfully with. It is ignored for tests which does not have
+this specified.
+Each running test file gets its own mapset and current working directory
+but all run are in one location.
+.. warning:
+    The current location is ignored but you should run not invoke tests
+    in the location which is precious to you for the case that something fails.
+To run individual tests file you should be in GRASS session in GRASS NC sample
+location in a mapset of arbitrary name (except for the predefined mapsets).
+Your tests can rely on maps which are present in the GRASS NC sample location.
+But if you can provide tests which are independent on location it is better.
+Read the documentation of Python ``unittest`` package for a list of assert
+methods which you can use to test your results. For test of more complex
+GRASS-specific results refer to `GrassTestCase` class documentation.
+Tests of GRASS modules
+    class TestRInfo(gunittest.GrassTestCase):
+        def test_elevation(self):
+            rinfo = Module('r.info', map='elevation', flags='g',
+                           stdout_=subprocess.PIPE, run_=False)
+            self.assertModule(self.rinfo)
+.. todo:
+    Add example of assertions of key-value results.
+.. todo:
+    Add example with module producing a map.
+    class TestRInfoInputHandling(gunittest.GrassTestCase):
+        def test_rinfo_wrong_map(self):
+            map_name = 'does_not_exist'
+            rinfo = Module('r.info', map=, flags='g',
+            self.assertModuleFail(rinfo)
+            self.assertTrue(rinfo.outputs.stderr)
+            self.assertIn(map_name, stderr)
+.. todo:
+    Create ``SimpleModule`` or ``TestModule`` class which will have the right
+    parameters for ``assertModule()`` and ``assertModuleFail()`` functions.
+Tests of C and C++ code
+Tests of Python code
+Testing Python code with doctest
 In Python, the easiest thing to test are functions which performs some computations
 or string manipulations, i.e. they have sum numbers or strings on the input and
 some others on the output.
@@ -48,51 +147,94 @@
 the file is accessible through sys.path which is not true for case of GRASS modules.
 Do not use use doctest for tests of edge cases, for tests which require
-generate complex data first, etc. In these cases use unittest.
+generate complex data first, etc. In these cases use `gunittest`.
-Testing functions with gunittest
+Data
-GRASS GIS `gunittest` package and testing framework is similar to the standard
-Python ``unittest`` package, so the ways to build tests are very similar.
+Most of the tests requires some input data. However, it is good to write
+a test in the way that it is independent on the available data.
+In case of GRASS, we have we can have tests of functions where
+some numbers or strings are input and some numbers or string are output.
+These tests does not require any data to be provided since the numbers
+can be part of the test. Then we have another category of tests, typically
+tests of GRASS modules, which require some maps to be on the input
+and thus the output (and test) depends on the specific data.
+Again, it it best to have tests which does not require any special data
+or generally environment settings (e.g. geographic projection)
+but it is much easier to write good tests with a given set of data.
+So, an compromises must be made and tests of different types should be written.
+In the GRASS testing framework, each test file should be marked according to
+category it belongs to. Each category corresponds to GRASS location or locations
+where the test file can run successfully.
-    from guinttest.case import GrassTestCase
+Universal tests
+    First category is *universal*. The tests in this category use some some
+    hard coded constants, generated data, random data, or their own imported
+    data as in input to function and GRASS modules. All the tests, input data
+    and reference results should be projection independent. These tests will
+    runs always regardless of available locations.
-    class TestRUnivar(GrassTestCase):
+Standard names tests
+    Second category are tests using *standard names*. Tests rely on a
+    certain set of maps with particular names to be present in the location.
+    Moreover, the tests can rely also on the (semantic) meaning of the
+    names, i.e. raster map named elevation will always contain some kind of
+    digital elevation model of some area, so raster map elevation can be
+    used to compute aspect. In other words, these tests should be able to
+    (successfully) run in any location with a maps named in the same way as
+    in the standard testing location(s).
-        def test_conting(self):
-            """Test that Python can count"""
-            self.assertEqual(1 + 1, 2)
+Standard data tests
+    Third category of tests rely on *standard data*. These tests expect that the
+    GRASS location they run in not only contains the maps with particular names
+    as in the *standard names* but the tests rely also on the data being the
+    same as in the standard testing location(s). However, the (geographic)
+    projection or data storage can be different. This is expected to be the
+    most common case but it is much better if the tests is one of the previous
+    categories (*universal* or *standard names*). If it is possible the
+    functions or modules with tests in this category should have also tests
+    which will fit into one of the previous categories, even though these
+    additional tests will not be as precise as the other tests.
-Note that GRASS-specific invoking of tests is not yet implemented
-but you should try different combinations of adding the following Python
-code to your test and running it from command line::
+Location specific tests
+    Finally, there are tests which requires certain concrete location. There
+    is (or will be) a set of standard testing locations each will have the same
+    data (maps) but the projections and data storage types will be different.
+    The suggested locations are: NC sample location in SPM projection,
+    NC in SPF, NC in LL, NC in XY, and perhaps NC in UTM, and NC in some
+    custom projection (in case of strange not-fitting projection, there is
+    a danger that the results of analyses can differer significantly).
+    Moreover, the set can be extened by GRASS locations which are using
+    different storage backends, e.g. PostGIS for vectors and PostgreSQL for
+    temporal database. Tests can specify one or preferably more of these
+    standard locations.
-    if __name__ == '__main__':
-        unittest.main()
+Specialized location tests
+    Additionally, an specialized location with a collection of strange,
+    incorrect, or generally extreme data will be provided. In theory, more
+    than one location like this can be created if the data cannot be
+    together in one location or if the location itself is somehow special,
+    e.g. because of projection.
-adding the directory or parent directory of your tests to ``PYTHONPATH``
-and using::
+Each category, or perhaps each location (will) have a set of external data
+available for import or other purposes. The standardization of this data
+is in question and thus this may be specific to each location or this
+can be a separate resource common to all tests using one of the standardized
+locations, or alternatively this data can be associated with the location
+with special data.
-    python -m unittest test_runivar
+.. note::
+    The more general category you choose for your tests the more testing data
+    can applied to your tests and the more different circumstances can be tried
+    with your tests.
-or using automatic test discovery which might be sometimes tricky::
-    python -m unittest discover some/path
-You should be in running GRASS session in GRASS NC sample location in a mapset
-of arbitrary name (except for the predefined mapsets).
-Your tests can rely on maps which are present in the GRASS NC sample location.
-But if you can provide tests which are independent on location it is better.
-Read the documentation of Python ``unittest`` package for a list of assert
-methods which you can use to test your results. For test of more complex
-GRASS-specific results refer to `GrassTestCase` class documentation.
 .. note::
     gunittest is under development but, so some things can change, however
     this should not stop you from writing tests since the actual differences
@@ -112,7 +254,8 @@
 Analyzing quality of source code
-Besides testing, you can also use some tools to check the quality of your code.
+Besides testing, you can also use some tools to check the quality of your code
+according to various standards and occurrence of certain code patterns.
 For C/C++ code use third party solution `Coverity Scan`_ where GRASS GIS
 is registered as project number `1038`_. Also you can use `Cppcheck`_
@@ -150,4 +293,4 @@
 .. _doctest: https://docs.python.org/2/library/doctest.html
 .. _Coverity Scan: https://scan.coverity.com/
 .. _1038: https://scan.coverity.com/projects/1038
-.. _Cppcheck:http://cppcheck.sourceforge.net/
+.. _Cppcheck: http://cppcheck.sourceforge.net/
