[GRASS-SVN] r61178 - sandbox/krejcmat/src
svn_grass at osgeo.org
Mon Jul 7 15:33:28 PDT 2014
Author: krejcmat
Date: 2014-07-07 15:33:28 -0700 (Mon, 07 Jul 2014)
New Revision: 61178
sandbox/krejcmat/src/editor2.py
sandbox/krejcmat/src/jinjainfo.py
commented editor2.py
Modified: sandbox/krejcmat/src/editor2.py
--- sandbox/krejcmat/src/editor2.py 2014-07-07 22:17:36 UTC (rev 61177)
+++ sandbox/krejcmat/src/editor2.py 2014-07-07 22:33:28 UTC (rev 61178)
@@ -5,6 +5,7 @@
from owslib.iso import *
from jinjainfo import JinjaTemplateInfo as jt
+from jinjainfo import MdDescription
from lxml import etree as ET
@@ -46,25 +47,29 @@
self.wxIdTag={} #dict with id and tag from ows lib
mdo=MD()
- self.md=mdo.md
+ self.md=mdo.md #instance of
- self.comboItems=[]
+ self.comboItems=[] #list in combobox
self._layout()
self.templatePath='data/grassInspireTemplate01.xml'
#self.templatePath='data/jinjatest.xml'
jinj=jt(self.templatePath)
- self.mdDescription=jinj.mdDescription #list of object MdDescription
- self.mdOWSTagStr=jinj.mdOWSTagStr
+ self.mdDescription=jinj.mdDescription #list of object MdDescription
- self.MDinfoDictNum=jinj.cretemdDescriptionDict('num')
- self.MDinfoDictGroup=jinj.cretemdDescriptionDict('group')
- self.MDinfoDictBox=jinj.cretemdDescriptionDict('inbox')
- self.mdOWSTagStrList=jinj.mdOWSTagStrList
+ self.mdOWSTagStr=jinj.mdOWSTagStr #string of tags from jinja template (loops and OWSLib objects)
+ self.mdOWSTagStrList=jinj.mdOWSTagStrList #
+ self.valueStorageWxID={}
+ #self.mdDescriptionVAL=MdDescription()
+ self.mdDescriptionList=[]
+ #self.MDinfoDictNum=jinj.cretemdDescriptionDict('num')
+ #self.MDinfoDictGroup=jinj.cretemdDescriptionDict('group')
+ #self.MDinfoDictBox=jinj.cretemdDescriptionDict('inbox')
#self.initCreatorEmpty()
- self.FILLER=''
- self.idDict={}
self.initCreatorMD()
self.currWXid=None
@@ -141,14 +146,36 @@
self.valueCtrl = wx.TextCtrl(self.place, id=wx.ID_ANY,
style=wx.VSCROLL | wx.TE_DONTWRAP |
wx.TAB_TRAVERSAL|wx.RAISED_BORDER|wx.HSCROLL)
#register tag to created wx.id
- self.currWXid= self.valueCtrl.GetId()
- val=self.mdDescription[self.cTmp].value
- val=self.valueCtrl.SetValue(str(val))
- #self.MD.valueStorageByID[self.valueCtrl.GetId()]=MdInfo(tag,val)
+ self.currWXid= self.valueCtrl.GetId()
+ val=self.mdDescription[self.cTmp].value
+ mdVal=MdDescription()
+ self.valueCtrl.SetValue(str(val))
+ self.valueStorageWxID[self.currWXid]=val
+ try:
+ mdVal=self.mdDescription[self.c]
+ except:
+ # print mdVal
+ mdVal.value=str(val)
+ mdVal.id=str(self.currWXid)
+ self.mdDescriptionList.append(mdVal)
+ # print '='*50
+ # print self.currWXid
+ # print val
+ # print mdVal.value
+ # print '='*50
if multiple:
self.addItemButt=wx.Button(self.place,-1,size=(20,20),label='+')
#self.addInfoButt=wx.Button(self,-1,size=(20,20),label='I')
@@ -205,31 +232,54 @@
def _addComboBoxLay(self):
self.nbPanelSizer.Add(self.comboboxSizer,proportion=0,flag=wx.EXPAND)
#----------------------------------------------------------------------- CREATOR
- def initCreatorMD1(self):
- self.addNotebook()
- c=0
- markgroup=[] #notebok panel marker
- markbox=[] # box panel marker
- markitem=[] #item panel marker
- for lstruct, linfo in zip(self.struct.splitlines(),self.mdDescription):
- c+=1
- group=linfo.group
- if group not in markgroup: #if group is not created
- markgroup.append(group)
- self.addNotebookPage(linfo.group)
- for item in self.MDinfoDictGroup[group]:
- box=item.inbox
- if box not in markbox and box!=None: #if box is not created or item is not in box
- markbox.append(box)
- self.addBox(item.inbox) #mark box
- for boxite in self.MDinfoDictBox[box]:
- markitem.append(boxite.num)
- self.addItem(boxite, True)
- else:
- if item.num not in markitem: #if item is not created
- self.addItem(item)
- #----------------------------------------------------------------------- CREATOR
+ # def initCreatorMD1(self):
+ # self.addNotebook()
+ # c=0
+ # markgroup=[] #notebok panel marker
+ # markbox=[] # box panel marker
+ # markitem=[] #item panel marker
+ # for lstruct, linfo in zip(self.struct.splitlines(),self.mdDescription):
+ # c+=1
+ # group=linfo.group
+ # if group not in markgroup: #if group is not created
+ # markgroup.append(group)
+ # self.addNotebookPage(linfo.group)
+ # for item in self.MDinfoDictGroup[group]:
+ # box=item.inbox
+ # if box not in markbox and box!=None: #if box is not created or item is not in box
+ # markbox.append(box)
+ # self.addBox(item.inbox) #mark box
+ # for boxite in self.MDinfoDictBox[box]:
+ # markitem.append(boxite.num)
+ # self.addItem(boxite, True)
+ # else:
+ # if item.num not in markitem: #if item is not created
+ # self.addItem(item)
+#------------------------------------------------------------- MAIN PANEL LAYOUT
+ def _layout(self):
+ #main sizer in frame
+ self.mainSizer=wx.BoxSizer(wx.VERTICAL)
+ self.SetSizer(self.mainSizer)
+#-------------------------------------------------------------------------- INFO
+ def createInfo(self,item):
+ string=''
+ if item.name !=None:
+ string+='name: '+ item.name + '\n'
+ if item.desc !=None:
+ string+='description: ' + item.desc + '\n'
+ if item.example !=None:
+ string+='example: ' + item.example + '\n'
+ return string
+#----------------------------------------------------------------------- CREATOR
def executeStr(self,stri,linfo):
print stri
exec stri
@@ -240,95 +290,126 @@
self.c-=1
self.stop=True
- def initCreatorMD(self):
+ def initCreatorMD(self):
+ @var var: self.c index of lstruct and self.mdDescription
+ lstruct lstruct is self.mdOWSTagStr in list. Item=line from jinja template(only lines with owslib objects and loops)
+ linfo list of MdDescription() objects inicialized by information from jinja t.
+ markgroup markers of created list in GUI notebook
+ self.max length of lstruct and linfo
+ self.stop index self.c is increasing by function plusC(), that care about not exceeding the index
self.addNotebook()
- c=0
- lstruct=self.mdOWSTagStrList
- linfo=self.mdDescription
- self.c=0
+ lstruct=self.mdOWSTagStrList
+ linfo=self.mdDescription #from jinja
+ self.c=0 #this valus is the index of self.mdOWSTagStrList and also in self.mdDescription
self.stop=False
- self.max=len(linfo) ##TODO why -1? :-(
+ self.max=len(linfo)
- def inBox2():
+ def chckLen():
+ @note: -length of list in jinja template is provided by |length.
+ -need to convert to python len()
+ try:
+ if '|length' in str(lstruct[self.c-1])and self.stop is False:
+ a=lstruct[self.c-1]
+ a=a.replace('|length',')').replace('if ','if len(self.')
+ lstruct[self.c-1]=a
+ except:
+ self.stop=True
+ #print '='*60
+ def inBox2(): #function in def initCreatorMD(self): !!!
+ @note:
self.k=0
loop = lstruct[self.c-1]
str2=loop.replace(' md.',' self.md.')+':\n'
str2+='\t' +'self.addBox(linfo[' + str(self.c) + '].inbox)\n'
str1=str2
while '\t' in lstruct[self.c] and self.stop is False:
if not 'for' in str(lstruct[self.c]).split() or 'if' in str(lstruct[self.c]).split():
value= str(self.mdOWSTagStrList[self.c])
+ #print value
str1+= '\t' +'self.mdDescription['+str(self.c)+'].value='+str(value)+'\n'
- str1+= '\t' +'self.idDict[self.currWXid]=' + 'linfo[' + str(self.c) + ']\n'
str1+= '\t' +'self.cTmp='+str(self.c)+'\n' #save wx id
str1+= '\t' +'self.addItem(linfo[' + str(self.c) + '], True)\n'
- else:
+ tab='\t'
+ else:#if loop in loop
loop = lstruct[self.c]
self.plusC()
str1+=str2
while '\t\t' in lstruct[self.c] and self.stop is False:
str1+= '\t\t' +'self.mdDescription['+str(self.c)+'].value='+str(value)+'\n'
- str1+= '\t\t' +'self.idDict[self.currWXid]=' + 'linfo[' + str(self.c) + ']\n'
str1+= '\t\t' +'self.cTmp='+str(self.c)+'\n' #save wx id
str1+= '\t\t' +'self.addItem(linfo[' + str(self.c) + '], True)\n'
- print str1
+ tab='\t\t'
self.plusC()
self.plusC()
- print '--'*80
- str1+= '\tself.k+=1\n'
+ ##print '--'*80
+ self.c-=1
+ str1+= tab+'self.c+=1\n'
self.executeStr(str1,linfo)
- self.c+=self.k - 1
- while self.stop is False:
+ #START of the looop of genereator
+ while self.stop is False: #self.stop is managed by def plusC(self):
group=linfo[self.c].group
- self.addNotebookPage(linfo[self.c].group)
+ markgroup.append(group) #mark group
+ self.addNotebookPage(linfo[self.c].group) #crate notebog page in gui
- if '\t' in lstruct[self.c]and self.stop is False:
+ if '\t' in lstruct[self.c]and self.stop is False: #if starting the loop
inBox2()
- elif not 'for' in str(lstruct[self.c]).split() or 'if' in str(lstruct[self.c]).split():
+ chckLen()
+ elif not 'for' in str(lstruct[self.c]).split() or 'if' in str(lstruct[self.c]).split(): # if just singe item without loop
value= 'self.'+str(self.mdOWSTagStrList[self.c]).replace('\n','')
addStr='self.mdDescription['+str(self.c)+'].value='+str(value)
- print '--'*80
- print addStr
+ ##print '--'*80
+ ##print addStr
self.executeStr(addStr,False)
- self.cTmp=self.c
+ self.cTmp=self.c
self.addItem(linfo[self.c], False)
self.plusC()
else:
+ #if lstruct[self.c] is "FOR", "IF" "WHILE"
+ #print str(lstruct[self.c])
self.plusC()
- #print self.FILLER
-#------------------------------------------------------------- MAIN PANEL LAYOUT
- def _layout(self):
- #main sizer in frame
- self.mainSizer=wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.mainSizer)
+# print '========================================'
+# for keys,values in self.valueStorageWxID.items():
+# print(keys)
+# #print values
+# print values
+# print '------------'
-#-------------------------------------------------------------------------- INFO
- def createInfo(self,item):
- string=''
- if item.name !=None:
- string+='name: '+ item.name + '\n'
- if item.desc !=None:
- string+='description: ' + item.desc + '\n'
- if item.example !=None:
- string+='example: ' + item.example + '\n'
- return string
+ # for values in self.mdDescriptionList:
+ # print values.id
+ # print values.name
+ # print values.value
+ # print '------------'
+ # #print self.mdDescriptionList[9].id
# MAIN FRAME
Modified: sandbox/krejcmat/src/jinjainfo.py
--- sandbox/krejcmat/src/jinjainfo.py 2014-07-07 22:17:36 UTC (rev 61177)
+++ sandbox/krejcmat/src/jinjainfo.py 2014-07-07 22:33:28 UTC (rev 61178)
@@ -20,7 +20,7 @@
from jinja2 import Environment, FileSystemLoader
class MdDescription():
- def __init__(self,tag, name = None, desc = None, example = None, type = None, multi = 0, inboxmulti=None, group = None, inbox = None, multiline = None, value=None,id=None,num=None ):
+ def __init__(self,tag= None, name = None, desc = None, example = None, type = None, multi = 0, inboxmulti=None, group = None, inbox = None, multiline = None, value=None,id=None,num=None ):
self.tag=tag
self.name = name
@@ -34,6 +34,7 @@
self.multiline=multiline #type of ctrl text
self.num=num
self.value=value
+ self.id=id
class JinjaTemplateInfo():
def __init__(self,template):
@@ -137,7 +138,7 @@
continue
tabstr='\t'*tab
- str1=tabstr + item[1:] + '\n'
+ str1=tabstr + item[1:] + '\n'
self.mdOWSTagStr+=str1
self.mdOWSTagStrList.append(tabstr + item[1:])
