[GRASS-SVN] r61192 - in grass/trunk/temporal: t.rast.extract t.rast.extract/testsuite t.remove
Tue Jul 8 07:39:32 PDT 2014
Author: huhabla
Date: 2014-07-08 07:39:31 -0700 (Tue, 08 Jul 2014)
New Revision: 61192
Added:
   grass/trunk/temporal/t.rast.extract/testsuite/
   grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
Removed:
   grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
   grass/trunk/temporal/t.remove/t.remove.py
Converted shell test into gunittest. Added testsuite directory.
Deleted: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh	2014-07-08 14:36:31 UTC (rev 61191)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh	2014-07-08 14:39:31 UTC (rev 61192)
@@ -1,37 +0,0 @@
-#!/bin/sh
-# Test the extraction of a subset of a space time raster input
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-# The @test
-t.rast.extract --o --v input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" \
-           expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=2
-t.info type=strds input=precip_abs2
-t.rast.extract --o --v -n input=precip_abs1 output=precip_abs3 where="start_time > '2001-06-01'" \
-           expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
-t.info type=strds input=precip_abs3
-# Let the test fail
-g.remove rast=prec_1
-t.rast.extract --o --v input=precip_abs1 output=precip_abs4 \
-          where="start_time > '2001-01-01'" expr="precip_abs1/1.0"\
-          base=new_test
-t.info type=strds input=precip_abs4
-t.remove -rf type=strds input=precip_abs1,precip_abs2,precip_abs3
Added: grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2014-07-08 14:39:31 UTC (rev 61192)
@@ -0,0 +1,155 @@
+"""Test t.rast.extract
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import grass.script as grass
+import grass.pygrass.modules as pymod
+import subprocess
+from gunittest.case import TestCase
+class TestRasterExtraction(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """!Initiate the temporal GIS and set the region
+        grass.use_temp_region()
+        cls.runModule("g.gisenv",  set="TGIS_USE_CURRENT_MAPSET=1")
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        grass.del_temp_region()
+    def setUp(self):
+        """Create input data for transient groundwater flow computation
+        # Use always the current mapset as temporal database
+        self.runModule("r.mapcalc", expression="prec_1 = 100")
+        self.runModule("r.mapcalc", expression="prec_2 = 200")
+        self.runModule("r.mapcalc", expression="prec_3 = 300")
+        self.runModule("r.mapcalc", expression="prec_4 = 400")
+        self.runModule("r.mapcalc", expression="prec_5 = 500")
+        self.runModule("r.mapcalc", expression="prec_6 = 600")
+        self.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                     output="precip_abs1",  title="A test",  description="A test")
+        self.runModule("t.register",  flags="i",  type="rast",  input="precip_abs1",
+                                     maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
+                                     start="2001-01-01", increment="3 months")
+    def tearDown(self):
+        """Remove generated data"""
+        self.runModule("t.remove",  flags="rf",  type="strds",
+                                   inputs="precip_abs1,precip_abs2")
+    def test_selection(self):
+        """Perform a simple selection by datetime"""
+        self.assertModule("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
+                                      where="start_time > '2001-06-01'")
+        #self.assertModule("t.info",  flags="g",  input="precip_abs2")
+        tinfo_string="""start_time=2001-07-01 00:00:00
+        end_time=2002-07-01 00:00:00
+        granularity=3 months
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        aggregation_type=None
+        number_of_maps=4
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=300.0
+        min_max=600.0
+        max_min=300.0
+        max_max=600.0"""
+        self.assertCommandKeyValue(module="t.info",
+                                                        parameters=dict(flags="g",  input="precip_abs2"),
+                                                        reference=tinfo_string,  precision=2,  sep="=")
+    def test_selection_and_expression(self):
+        """Perform a selection by datetime and a r.mapcalc expression"""
+                                      where="start_time > '2001-06-01'",
+                                      expression=" if(precip_abs1 > 400, precip_abs1, null())",
+                                      basename="new_prec",  nprocs=2)
+        tinfo_string="""start_time=2002-01-01 00:00:00
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        number_of_maps=2
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+    def test_expression_with_empty_maps(self):
+        """Perform r.mapcalc expression and register empty maps"""
+        self.assertModule("t.rast.extract",  flags="n",  input="precip_abs1",  output="precip_abs2",
+        tinfo_string="""start_time=2001-01-01 00:00:00
+        map_time=interval
+        north=80.0
+        south=0.0
+        east=120.0
+        west=0.0
+        top=0.0
+        bottom=0.0
+        number_of_maps=6
+        nsres_min=10.0
+        nsres_max=10.0
+        ewres_min=10.0
+        ewres_max=10.0
+        min_min=500.0
+        min_max=600.0
+        max_min=500.0
+        max_max=600.0"""
+if __name__ == '__main__':
+    from gunittest.main import test
+    test()
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2014-07-08 14:36:31 UTC (rev 61191)
+++ grass/trunk/temporal/t.remove/t.remove.py	2014-07-08 14:39:31 UTC (rev 61192)
@@ -125,7 +125,7 @@
                 # to avoid multiple deletation of the same map,
                 # but the database entries are still present and must be removed
                 if map.get_name() not in name_list:
-                    name_list.append(map.get_name())
+                    name_list.append(str(map.get_name()))
                 map_statement += map.delete(dbif=dbif, execute=False)
                 count += 1
@@ -140,11 +140,11 @@
                 dbif.execute_transaction(map_statement)
             if name_list:
                 if type == "strds":
-                    remove(rast=name_list, run_=True)
+                    remove(rast=",".join(name_list), run_=True)
                 if type == "stvds":
-                    remove(vect=name_list, run_=True)
+                    remove(vect=",".join(name_list), run_=True)
                 if type == "str3ds":
-                    remove(rast3d=name_list, run_=True)
+                    remove(rast3d=",".join(name_list), run_=True)
         statement += sp.delete(dbif=dbif, execute=False)
