[GRASS-SVN] r61203 - sandbox/wenzeslaus/gunittest
Tue Jul 8 19:54:41 PDT 2014
Author: wenzeslaus
Date: 2014-07-08 19:54:41 -0700 (Tue, 08 Jul 2014)
New Revision: 61203
   sandbox/wenzeslaus/gunittest/case.py
   sandbox/wenzeslaus/gunittest/gutils.py
   sandbox/wenzeslaus/gunittest/invoker.py
gunittest: add method to compare two raster using difference and r.univar (or just max difference/precision)
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py	2014-07-08 21:37:37 UTC (rev 61202)
+++ sandbox/wenzeslaus/gunittest/case.py	2014-07-09 02:54:41 UTC (rev 61203)
@@ -347,6 +347,40 @@
        reference)
             self.fail(self._formatMessage(msg, stdmsg))
+    # TODO: add tests for this method
+    def assertRastersNoDifference(self, actual, reference,
+                                   precision, statistics=None, msg=None):
+        """Test that `actual` raster is not different from `reference` raster
+        Method behaves in the same way as `assertRasterFitsUnivar()`
+        but works on difference ``referece - actual``.
+        If statistics is not given ``dict(min=-precision, max=precision)``
+        is used.
+        if statistics is None:
+            statistics = dict(min=-precision, max=precision)
+        self.assertRastersDifference(actual=actual, reference=reference,
+                                     statistics=statistics, precision=precision,
+                                     msg=msg)
+    def assertRastersDifference(self, actual, reference,
+                                statistics, precision, msg=None):
+        """Test statistical values of differece of reference and actual rasters
+        For cases when you are interested in no or minimal difference,
+        use `assertRastersNoDifference()` instead.
+        diff = ('tmp__' + self.id() + '__assertRastersDifference_diff'
+                + actual + '__diff__' + reference)
+        call_module('r.mapcalc', stdin='"{d}" = "{r}" - "{a}"'.format(d=diff,
+        a=actual,
+        r=reference))
+        try:
+            self.assertRasterFitsUnivar(raster=diff, reference=statistics,
+                                        precision=precision, msg=msg)
+        finally:
+            call_module('g.remove', rast=diff)
     @classmethod
     def runModule(cls, module, **kwargs):
         """Run PyGRASS module.
@@ -382,10 +416,20 @@
             # because we want to capture it
         module.run()
         if module.popen.returncode:
+            errors = module.outputs['stderr'].value
+            # provide diagnostic at least in English locale
+            # TODO: standardized error code would be handy here
+            import re
+            if re.search('Raster map.*not found', errors, flags=re.DOTALL):
+                errors += "\nSee available raster maps:\n"
+                errors += call_module('g.list', type='rast')
+            if re.search('Vector map.*not found', errors, flags=re.DOTALL):
+                errors += "\nSee available vector maps:\n"
+                errors += call_module('g.list', type='vect')
             # TODO: message format, parameters
             raise CalledModuleError(module.popen.returncode, module.name,
                                     module.get_python(),
-                                    errors=module.outputs['stderr'].value)
+                                    errors=errors)
     # TODO: we can also comapre time to some expected but that's tricky
     # maybe we should measure time but the real benchmarks with stdin/stdout
Modified: sandbox/wenzeslaus/gunittest/gutils.py
--- sandbox/wenzeslaus/gunittest/gutils.py	2014-07-08 21:37:37 UTC (rev 61202)
+++ sandbox/wenzeslaus/gunittest/gutils.py	2014-07-09 02:54:41 UTC (rev 61203)
@@ -6,6 +6,6 @@
 from .gmodules import call_module
-def get_curret_mapset():
+def get_current_mapset():
     """Get curret mapset name as a string"""
     return call_module('g.mapset', flags='p').strip()
Modified: sandbox/wenzeslaus/gunittest/invoker.py
--- sandbox/wenzeslaus/gunittest/invoker.py	2014-07-08 21:37:37 UTC (rev 61202)
+++ sandbox/wenzeslaus/gunittest/invoker.py	2014-07-09 02:54:41 UTC (rev 61203)
@@ -68,6 +68,10 @@
     def _run_test_module(self, module, results_dir, gisdbase, location):
         cwd = os.path.join(results_dir, module.tested_dir, module.name)
+        data_dir = os.path.join(module.file_dir, 'data')
+        if os.path.exists(data_dir):
+            shutil.copytree(data_dir, os.path.join(cwd, 'data'),
+                            ignore=shutil.ignore_patterns('*.svn*'))
         ensure_dir(os.path.abspath(cwd))
         # TODO: put this to constructor and copy here again
         env = os.environ.copy()
